 Phil, any updates on Hannah? Hoping all is well with you and yours.
 Moving stinks, I hope your life gets back to normal in short order.
 Phil, good to see you back up and running. Sorry to see Hannah take a hit but certainly glad it wasn't worse. Moving takes a toll on everything and everybody.
I think that Hannah is ready for sails and the running rigging.
C5A1C301-7EC3-4DC2-A88B-287E7A47EF0A.thumb.jpeg.e841e0c66226be52aebd668407190379.jpeg1511916A-8FD1-4487-BF8D-57D3EB8E9910.thumb.jpeg.05bc505bba77710c4e6e759731bd9121.jpeg620DFB75-C30A-4C80-892C-1AF7DF4A58EA.thumb.jpeg.27cad35af1da672b119dc7ab2a1c1143.jpeg
I do not think that I have missed anything.
I do know that next time I need to plan out the running rigging better.  If I am going to use one of the plans from the Hahn books or an AOTS, then I need to study a better belaying plan, or generate my own, and plan accordingly.
Thankfully, this was a schooner and not a larger warship.  I need to install deck blocks BEFORE I put in masts and standing rigging. Oops.  Oh well, lol.  We will call this one a lesson learned.
I share it to help others avoid making the same mistake.
On to sails!
Building:
Fore and aft sails templates test fitting:
I adjusted the jib sails a bit to allow a bit for variation due to rescaling errors.
I still need to make a template for the fore top sail.
The rigging is one of my favorite parts of the model.  Detailing/fitting out the hull is my other favorite part.
Edited by GrandpaPhil
Building:
Excellent work on the sails mate.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Yes you are!   I think all of us get better if we keep trying new methods.    I suggest you purchase David Antscherl's booklet ($8) on making sails from Sea Watch Books before Bob closes it down which will  be sooner than later.    For Victory, assuming smaller than 1:48, there is no way cloth sails and sewing them will look realistic as there is no cloth with a high enough TC or sewing methods that will be to scale.     There is at least one well done You Tube video on making sails with silkspan, artist's tubed acrylics and matte medium with slight variations on the methods in the booklet mentioned above.
Allan
4 hours ago, GrandpaPhil said:
Where do you get silkspan from?
If you have a hobby shop that sells flying model aircraft, check with them.  Otherwise it's probably and online search.
I bought mine on line.    https://sigmfg.com/products/sig-silkspan-tissue     The hobby shops near me had plastic type materials and no silk span, so maybe call ahead to your local hobby shop to avoid wasting a trip.  It is pretty cheap stuff, but you will also need good quality artists tubed acrylic paints (not the cheap poor quality stuff in bottles found a few aisles over from the better quality paints), matte medium and some scrap wood to make a frame and plug that goes inside the frame.   It is not at all complex,  Follow the steps on the tutorials for the first try, then it is an easy go from there.   There is some information here at MSW including in the scratch build of the Boothbay 65 as well as tutorials in David Antscherl's booklet and You Tube clips.
Allan
Installing Hannah’s jib sails (1 stay sail and 1 actual jib sail).
555C0848-73E3-49A6-BA7E-A32B4879499D.thumb.jpeg.9ad40e0645919bcd70b91463611cf028.jpegAF671113-AC5D-4761-AC5E-E0B2277F9BC5.thumb.jpeg.fc00736f253f70d52bbc46b09e84e43f.jpeg27EE3B17-547C-4EE0-8AC4-7A4B58A146A1.thumb.jpeg.ee8dcec2dcb12f646bede829b59414c6.jpeg
Using metal loops fed through the bolt rope to attach to the jib stays:7C08CADE-DBFF-44EE-9E0F-5C6070BAC8FD.thumb.jpeg.2a679fdca259a2b50cdaedcb0abd51ce.jpeg
I’ve been making the loops by wrapping annealed steel wire around a shish kabob skewer and cutting them in a line.
I’m currently waiting on a cleat that I broke to dry.  I should have pinned them in place for strength, instead of just glueing them.  Oh well, things to remember for next time.
Building:
I'm coming late to this party, but I get my silkspan from: www.bluejacketinc.com. Before I got a set of sails for Scud that I was happy with, I went through
5 sheets of the stuff (each sail is 3 ply). Also, Tom Ruggiero (tomshipmodel) has a tutorial on sail making. Otherwise, a nice looking craft!
Tom
