Denis,
  There were two layers of plastic for me to drill through, so I just drilled at an angle.  The top of the dowel rod is sitting against the top of the fuselage.
The first step in painting the Hustler is to prime it black:
Regardless of whether I use faux metallics or just use metallics, I need the black base to give the model depth.
I am pleased with how the seams came out. They pretty much disappeared.
Building:
Now thats looking the business   very  menacing.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Thank you, OC.
The first attempt at using faux metallics failed.  The model is too large, and too bright, to use the same technique that I would on say, a knight.
However, I never did know when to give up:4566AF49-BF6F-4FB8-B7EB-8FDAFE7AE3EB.thumb.jpeg.57e49e5f73b73686e117b14d332a8f6e.jpeg
The model is currently a medium gray.  I am going to attempt to use dry brushing to create a brushed metal finish on the model.
Building:
If you apply the same attitude you do on this as your Vic  - then you will deffo succeed.
OC.
Current builds
Completed works.
non deficere  (never give up)
OC.
Current builds
Completed works.
That is looking mighty fine Phil - really looks the business.
OC.
Current builds
Completed works.
OC.
I'm pleased that the "Business" never happened....
Phew!! 🙂
(Model looks awesome!!)
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
Sergal/Mantua Cutty Sark
A/L Pen Duick
A/L Fulgaro
Amati/Partworks 1/200 Bismarck
A/L Sanson
Thank you all for the comments, the likes and just for stopping by!
Yves,
  The model looks much shinier in person.  It actually looks like metal.
The Pulaski Hustler is almost done.  I apologize for the condition of my work area, it is a disaster, but I’ve been busy.
38222384-9FBD-4C68-A2D0-79C2EB823848.thumb.jpeg.95142eef5a4055737cb4e7b0a278ec44.jpeg38222384-9FBD-4C68-A2D0-79C2EB823848.thumb.jpeg.95142eef5a4055737cb4e7b0a278ec44.jpeg7069EF72-B89D-4D5C-B128-1031FD8D11BA.thumb.jpeg.03ec0fefa7c54ed3f588278241925e96.jpegB2D56459-A0FD-4BF8-9F2F-E4D7C034CBA6.thumb.jpeg.c224ec1c1318ed4850b857075eb6114d.jpegE72283DE-E722-47DD-B611-864E8A827F12.thumb.jpeg.8ae37742fdea7e61afd6e7eae98bfddb.jpeg
The decals are on, but a small bit of detail painting remains on the aircraft itself, as well as some touch ups.
The underwing nukes still need painted.
The base needs gloss coated.
The entire plane needs sealed so the decals don’t peel off later and the paint is protected.
Building:
Thank you very much!
The external stores are painted and attached.  The rest of the model is done.
Once they dry, I will seal them.
The first coat of gloss coat on the base is drying.  I will probably put four or five coats on it to give it a good shine.
Building:
Shades of the B&W film Fail Safe with  Henry Fonda and Larry Hagman (of J.R. on Dallas fame).
Dave
“You’ve just got to know your limitations”  Dirty Harry
Current Builds:  Modified MS 1/8” scale Phantom, and modified plastic/wood hybrid of Aurora 1:87 scale whaling bark Wanderer.
Past Builds: (Done & sold) 1/8” scale A.J. Fisher 2 mast schooner Challenge, 1/6” scale scratch built whaler Wanderer w/ plans & fittings from A.J. Fisher, and numerous plastic kits including 1/8” scale Revell U.S.S. Constitution (twice), Cutty Sark, and Mayflower.
                  (Done & in dry dock) Modified 1/8” scale Revell U.S.S. Constitution w/ wooden deck and masting [too close encounter w/conc. floor in move]
Hope to get to builds: MS 3/16” scale Pride of Baltimore II,  MS 1/2” scale pinky schooner Glad Tidings,  a scratch build 3/16” scale  Phantom, and a scratch build 3/16" scale Denis Sullivan.
Excellent work Phil  - the decals bring an already eaxcellent build to life.
OC.
Current builds
Completed works.
Looks perfect from here.   Can still hear those engines roar as it flies over the house as a kid.
Very nice job.
OC.
Current builds
Completed works.
It's sure does look the part... nice job....
Quote:
WOW!   ...came out great! :)    the finish looks really good.......the decaling sets it off nice!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Looks great, Phil !
Jack
Current buildUS Constellation
Nice work Phil, good looking plane!!
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
As usual I'm a little late but this build really turned out nice Phil. I will never get tired of the lines of the Hustler. I like your slightly climbing pose as well instead of  a flat stance. It shows the plane in a much more dynamic light than just sitting on a runway. Gives it a sense of movement and speed that the Hustler needs to show off.
Another part of your build I found interesting was when you were applying the black undercoat. It showed what the B-58 could have looked like in a different life as a Blackbird style reconnaissance aircraft. VERY sinister looking.:ph34r:
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
  • 1 year later...
