Do you know the reason behind diagonal planking? Was it stronger somehow? Horizontal planks give the ship strength and rigidity, I’ll assume diagonal planks do the same, but what was the specific reasoning behind diagonal planks?
Current Builds:
Flying Fish - Model Shipways - 1:96
Future Builds:
Young America 1853 - Scratch Build - 1:72
Completed Builds:
HMS Racehorse - Mantua - 1:47 (No pictures unfortunately)
Providence Whale Boat - Artesania Latina - 1:25 (Also no pictures)
Lowell Grand Banks Dory - Model Shipways - 1:24
Shelved Builds:
Pride of Baltimore 2 - Model Shipways - 1:64 (Also no pictures)
It is designed for covering the hulls of boats, which should have the greatest transverse and longitudinal strength.
Edited by vladislemm
  • 5 weeks later...
Fantastic plank job so far! Very interesting build so far.
Bradley
Current Builds:
Future Builds:
Completed Builds:
Shelved Builds:
A very clean looking model, nice planking work.
Michael
BEAUTIFUL work!...Moab
Completed Builds:
Virginia Armed Sloop...Model Shipways
Ranger...Corel
Louise Steam Launch...Constructo
Hansa Kogge...Dusek
Yankee Hero...BlueJacket
Spray...BlueJacket
26’ Long Boat...Model Shipways
Under Construction:
Emma C. Berry...Model Shipways
Actually, the diagonally layered planking such as in this boat had a layer of muslin or calico set in thick shellac or white lead between the planking layers. This created a sort of early cold-molded hull which resisted opening up when stored above a ship better than standard carvel planking did. This reduced, if not eliminated the need to launch and tow ("stream") the ship's boats regularly to keep them from leaking when dried out. It was very common on ship's launches and lifeboats and lifesaving boats stored ashore in this period.
According to my German 1878 textbook on (naval) boatbuilding, the diagonal planking was up to 30% lighter, than a carvel-planked boat and even more so for a lap-strake built one. However, building costs were higher and they are also more difficult to repair. The diagonal-carvel system (as in this example) was used particularly, when the hull was to be (partially) varnished on the outside, rather than painted all over. A tropical hardwood was preferred for the inner planking to better resist rotting - it would have been very difficult to replace inner planking without essentially dismantling half of the boat.
The model is coming on nicely. It's a pity that not much of the inner diagonal strakes will be visible at the end.
