Post Twenty-eight
A small diversion – an inspection visit by Royal decree.
I mentioned a while ago about crewing the barge and today my ‘Queen Anne’ arrived to audition for the part.
She is an Edwardian figure at 1:24 scale produced by Modelu in the UK.
1508
She represents one of several sitting figures designed for a model rail setting and produced in various scales.
1808
As can be seen she is good fit for the Royal Barge.
1806
The lines and folds of of her long dress are also a good fit, altho’ the head will require some surgery to replace her hat with the more voluminous hair style of the early eighteenth century.
203.-GettyImages-544167660-483de67-e1568186900532.jpg.6c3da92a9c7189d089baadbe50b1b6b4.jpg
Queen Anne
1812
A little surgery was required to her clothing to allow her to sit square in the Stern sheets.
1813
1814
1811
1815
I will continue to modify her appearance, but I need to get back to the main event.
B.E.
13/05/21
Thanks Chuck,
As a first move to transforming my Edwardian lady into an 18th Century Queen I had to remove all the hat and hair detail and give her the Virgin Queen look without her wig.
1816
1818
I have left the remnants of a ribbon which will hopefully turn into a ringlet.
I used a combination of scalpel, chisel, and files to perform the task.
The tricky part was removing the rim of the hat which came down over her forehead.
The next stage is to recreate the ringlets and curls piled high on her head and tumbling down over her shoulders. Easier said than done I suspect.
For the purpose I will be using Windsor and Newton heavy carving modelling paste to build up the hair by layers and hopefully give her a hair style fit for a Queen.
B.E.
Awesome - her expression of detachment, bordering on dis-interest, is pitch-perfect!  Your hair modifications give me a good idea what I might look like in that particular get-up; #TWINING.  I'd be pretty psyched to be in the boat, though.
Edited by Hubac's Historian
Sounds like my barber, and with similar results😁
Seriously though, I've always admired your figures and will watch this transformation with interest.
Cheers, Derek
Current build:   Duchess of Kingston
On hold:              HMS Winchelsea
Previous builds:  HMS SpeedyEnglish Pinnace, Royal Yacht Caroline (gallery),
                            Victory Cross-section (gallery), US Clipper Albatros, Red Dragon (years ago!)
On the stocks:    18th Century Longboat
Post Twenty-nine
Still in attendance to the Queen
Before I put paste to Royal head, I had a trial on a spare figure to get a feel of the how the paste worked, and its working and drying times.
The Queen will be wearing a small crown or coronet and I need to establish how this will fit on her hair.
1838(2)
Having made a brass ring to form the base of the crown, I could start to form the hair and when the paste had started to set, the ring was placed on the head leaving an impression for the final fit.
I then had the task of making up the crown, a tiny thing of 5mm diameter by 5mm high.
1823
The fit looks ok.
1833(2)
The parts were silver soldered together and gemstones added in the form of seed beads.
1846
1847
1850
1854
1857
1853
1856(2)
Still some tweaking to do, I think the hairline across the forehead needs softening, but I feel that she will now make a credible 18thc figure.
I will leave it there now and return to fitting out the barge.
B.E.
14/05/21
You have probably seen this Contemp model.  But anyway...the Queen is prob a replacement because the original was lost.
Thanks Chuck, I understand the figure was left unpainted to distinguish that it was a modern (1975) replacement.
There’s no mistaking that she is the Queen, dressed in what looks like her Coronation robes, wearing the Imperial Crown, orb and septre in her hands.
Interesting that the contemporary model of the Barge has no Flying Transom and is fitted with with tiller lines rather than a tiller.
B.E.
Post Thirty
Thwarts n’all
I decided to return to fitting the thwarts but before I did I released the one whittled Acanthus decoration from its backing.
Hardly a success, it did release naturally but a couple of bits fell off, even more problematic the decoration would not fit between the rails.
1874(2)
This is quite puzzling as I measured it accurately, and the resin versions as shown above fits perfectly.
The inference is that I haven’t reduced the width of the scrolls and swirls sufficiently, and I thought that they were already pretty thin.
I will park this issue until the thwarts are fitted.
Fitting the thwarts.
My main concern is to ensure that all the cut outs that take the centre pieces are in line once the thwarts are fitted onto the risers.
Thwarts 1, 7, and 9 are not much of a problem because they are clear of the frames, but the remainder are blocked from fitting at their full length because the frames at some point inhibit their passage.
It looks like Chuck has cut the thwarts on his build shorter to just sit on the risers and up against the frames where necessary.
The riser edges are a very narrow surface to support the thwarts, and I envisage problems if there are centring errors with the centre boards.
1871
I opted to notch the thwarts where required which will give me more leeway when it comes to adding the centre boards.
The thwarts fitted spot on in the riser notches but as indicated by Chuck, the notches required deepening a tad to allow the thwarts to sit down to allow a close-fit run of the inboard panelling atop the thwarts.
1868(2)
Note to self, remember to fit the step for the Royal Standard Flagstaff below thwart six before it is glued into place.
1866(2)
The thwarts will now be removed and the risers painted.
1865(2)
The next stage is the testy business of cutting and fitting the central boards.
B.E
15/05/21
For the carving.  Just remove and refit the lower molding.  It was designed to actually sit on the planking line so you will have plenty of room for those carvings. Just where the acanthus leaf carvings are as I can see a bit of an upward run which when evened out will allow your carvings to fit perfectly.  Use the planking seam as your guide.
I did them individually.  That doesnt mean it cant be do e the other way.  I just like to custom fit each piece for the best fit possible.
Post thirty-one
Progressing the seating
This involves placing sections that fit between the thwarts centrally down the boat.
The main objective is to get a tight clean fit up against and either side of the thwarts.
I start by gluing a section into thwart one, the forward end fitting into the Fore deck edge.
The sections will require cutting of one edge to fit the space, the length is marked and cut sufficient to leave a final sanding trim.
1880
To this end I made a simple jig to hold the thwart and centre section for sanding. I took this process very slowly with constant test fits.
1877
I moved progressively down the boat until each thwart had a centre section that fitted into the thwart forward of it.
My decision to notch the thwarts around the frames proved the right one.
On three of the thwarts, I did need to tweak the fit to get the centres in line; had I initially trimmed them to sit only on the risers, one side may have been left without support.
Once I had completed the whole thing I reviewed and replaced three centre sections where I thought the joint insufficiently tight.
Fortunately, Chuck includes a few spares no doubt for this purpose.
1882(2)
 One of my concerns is that viewed from the side the centre line planks run in a subtle sheer line from bow to stern without any hint of an angle.
1885(2)
Being unglued at this stage the centre planks can move about a bit but once I have confirmed I can achieve a look good to my eye, I trust I can replicate it as I glue the sections into place.
1895(2)
Worth getting my oarsman in to check the seating arrangement.
1898
1896
1888
1891(2)
1890(2)
At this point I am torn between painting the thwarts red or leaving them natural, sealed with wipe-on-poly.
B.E.
18/05/21
Hmmmmmm. If the tiller is in place, where does the Queen sit? The many layers of protocol surrounding HM probably dictated that no tillerman's bum shall point at the Queen, so a couple of lines past her elbows may have been the deal.
STAY SAFE
current builds:
B.E.
18/05/21
My two cents - paint the foredeck red and leave the thwarts natural. She will be stunning, whatever you decide, B.E.
Post thirty-two
Completing the seating.
Decision made, I am leaving the thwarts unpainted which I think will make a nice contrast to the Red paintwork.
There is also an element in me that dislikes painting nice wood.
1906
I firstly fixed the position of the step for the Royal Standard Flagstaff. This is far easier to fit before the thwarts are glued into place.
1901
The kit provides 2.25mm ø dowel for the Flagstaffs which is a tad narrow for the step socket meaning it readily flops about even when fitted thro’ the hole in the thwart.
1902
This is not helpful when trying to position the step on the floorboards to give a staff that will be vertical in both planes.
A  small ring was added atop the step to securely hold the Staff.
1909
The Foredeck is painted, and the first thwart fitted into place.
1907
The remaining thwarts are then fitted sequentially, each with its centre section to be glued into the thwart before it.
The thinnest smear of pva is used to glue the thwarts in place, and the run is checked to ensure a smooth transit.
1910
Small Weights are used to secure each thwart as fitted.
1914(2)
A final check of the line run.
1919(2)
1920(2)
A coat of wipe-on-poly has been applied at this point.
1922(2)
1921(2)
The Flagstaff seems to be ok, so the next stage is fitting the interior bulwark planking.
B.E.
20/05/21
Post Thirty-three
Inboard Planking.
Spiled Laser cut strips are provided for the purpose, but these still need tweaking to fit properly.
The bottom edge sits tight against the riser top and across the thwarts, the top edge is required to run up to the lower edge of the capping rail.
In the case of my build the strip simply requires sanding of the top edge to reduce its width a tad.
I marked the position of the thwarts on the strip and measured the distance between riser and capping rail using a tick strip method.
The marks were transferred to the strip and the sanding line marked. It was then simply down to sanding and test checking.
1966
Once satisfied, the strip was clamped into place and given the hairdryer heat treatment to take the tension out of it before final gluing into place.
1972(2)
Note the rabbet formed with the Capping rail.
1971
Both strips fixed into place.
The trickier element of the inboard planking is a shorter section that runs forward around the curve of the bow.
These are also pre- spiled but will need some fettlin’ to fit.
1976
The first task is to water/heat bend to fit the curve.
1977
 The forward end is firstly trimmed to fit beneath the rail.
1987
By degrees the top edge is sanded and the length cut to meet the long strip.
1988
To support the panel I added an additional ‘false’ frame each side beneath the rail.
This something Chuck mentions in his pdf Instructions and is worth doing to properly secure the panels.
1993
Sections glued into place.
1995
 The final assembly of this part is to add small sections to provide a wider surface for the thole pins to sit.
These sections are laser cut, and simply require sanding flush with the capping rail.
2002(2)
1998
A little filling and smoothing and she’s ready to lay some paint down.
I suspect there will be several sessions of paint, fill and sand, before she is ready for a final coat.
B.E.
23/05/21
Post Thirty-four
Paint, sand, fill, and repeat.
Any obvious areas needing filling are attended to and a first paint layer applied.
This has the effect of revealing multiple deficiencies, not entirely unexpected, so it’s a case of sand, fill, and repeat.
The result, better, but not there yet. The following control photos are the result after two further sand and fill sessions.
2055(2)
2054(2)
2053
2051
2049(2)
One thing I should have realised is that the paint dust on my fingers has a tendency to mar the bare Cherry wood hull so it was necessary to tape over the woodwork. I should have done this at the outset.
2050
Painting the inboard panels and capping rails has given me a chance to get a better appreciation of how leaving the thwarts as varnished wood will look in the overall scheme.
2048
Time to repeat the sanding process, but this time I am using a light touch and fine grade paper.
B.E.
24/05/21
Post Thirty-five
Adding the Decorative panels.
Chuck emphasises the fragility of these fancy little frames, but at least had them laser cut saving a lot of time and effort.
I well remember forming the mitres for the panels on the 1:48 scale Pinnace and have even less fond memories of doing the same for the 1:64 scale Pinnace I made for Pegasus.
The first issue that comes to mind is how do I glue these frames to the inboard planking without marring the paintwork that I have just spent hours fiddling with.
The majority of pieces fit simply enough guided by the thwart edges, but I can’t afford to have excess glue squeezing beneath the outer edges or be faced with any form of hard-edged clean-up.
2056
 To fix the frames I decided on minute spots of ca applied to the back face. With the bottom edges sitting on the thwart the question of moving around to fix position does not arise.
As advised by Chuck I did minimal cleaning up of the frame edges, using the centres to support the piece whilst light pressure was applied.
2058
I wet the curved bow pieces for a few minutes, clamped them into place, and applied heat for a few moments. This was sufficient to de-stress them before gluing into place.
The panels that gave me the most trouble were those for the Sternsheets. There are no fixed points of reference for height and distance, and the shape and dimensions of the Boxwood patterns differed slightly from those shown on the plan.
2061
I used Tamiya tape to define the inboard position of the larger frame, (7mm) and the distance between the two frames, (6mm).
2059
A 1.5mm thick piece of scrap wood was used to get a uniform height above the benches.
2064
 The final item is the Frame to fit on the Transom, to get this centred I used a cut-out from the plan.
2073
Careful as I was, the paintwork was marred a little as can be seen on the benches here, but I managed to get thro’ this exercise without any breakages.
2074
Further evidence of paint scuffing on the Fore deck.
2072(2)
2068(2)
2070(2)
A small repair to the paintwork and then the panel friezes to fit.
B.E.
25/05/21
BE,
Going back a few days/weeks, how did you silver solder the beads on the crown without any falling off as you soldered the next ones?  I have used several different solders with three different melt points, but that would not work with so many beads.   I sometimes use clips as heat sinks on the first items soldered, but on this small and delicate piece, I would love to hear your secret.   The entire project looks great !
Allan
Post Thirty-six
Applying friezes.
Before I started I re-sprayed the friezes using Windsor & Newton fixative.
2079(2)
An improvised spray booth.
2077(2)
A  kit was put together to aid this rather tedious task.
2080
Diluted pva applied with fine brush was used to glue the friezes in place. A centre blank attached to a toothpick is used to press the friezes into place.
2091(2)
The addition of the friezes  transforms the look of the barge.
At this point I add the support bracket for the bow Flagstaff.
This probably also doubles up as a hull brace.
2085(2)
Quite a tricky little beggar to fit, ensuring it is central and sits as best it can down on the bow frieze panels. Even so a touch of filler is required to smooth out the edge joins.
2083(2)
I ran a bead of diluted pva along the joins. Once that has cured, I will complete the filling and paint the bracket.
2084
2089(2)
Best part of a day to see this task completed, time to crack open the Merlot I think. 🍷
B.E.
26/05/21
That looks lovely.   I am close to getting a shipment of milled cherry so I will soon have more of these kits available.   You are doing an excellent job on it.   Very elegant indeed.
