Hello Everyone,
This is my attempt to build the Flower Class corvette HMCS Snowberry (1/72)  in the May 1943 configuration (after Charleston, SC refit)
And yes, again a Snowberry.
I am working on the old Revell / Matchbox kit, unfortunately not the newer Platinum version.
The following aftermarket photoetch & 3d printed parts will be used:
David J. Parkins, Great Little Ships
https://www.djparkins.com/home.php?cat=303&sort=orderby&sort_direction=0&page=3
- Flower Class deck & fitting set
- Flower Class Corvette type “C” Bridge
- Funnel and Mast Set
- 9” Scuttle set
- robe rails (stations)
- 4” gun Mark IX
- 2pdr. Pom-Pom Gun
- 20 mm Oerlikon guns
- Hedgehog
Micro Masters
https://micromaster.co.nz/
- 14’ Drifter Dinghys
- Depth Charge Rails
- Depth Charge Thrower
- 10” signaling projector
- 4” gun (maybe)
XY Models
distributed by Hobby Easy https://www.hobbyeasy.com/en/category/SHP/20/1/maker/YXN.html"
- 3D printed Anchor chain
Archer Resin Surface Details
https://archertransfers.com/SurfaceDetailsMain.html
- Resin Rivets
HGW Models
https://hgwmodels.cz/en/
- Resin Rivets
H&B Hobbies
https://www.hbhobbies.com/
- RN Colorcoats paints
Hecker & Goros Zinnfiguren
http://www.hecker-goros.de/products - 1-72.htm
- Royal Navy 1939-1945
Gunthwaite Miniatures
distributed by Halifax Modellversuch World https://www.halifaxmodellersworld.co.uk/gunthwaite-miniatures-238-c.asp
- British and Commonwealth Seamen
Accurate Model Part (AMP)
https://amp.rokket.biz/
- Ensign Flag
 Looking forward to comments and feedback and here we go …
Next is to cover the styrofoam with paper towels (I am using the blue shop towels because the kitchen towels have a often a structure with flowers and so on). I “glue” the paper towels with Liquitex Gloss Gel to the foam.
Next step is to create some foam on the waves. I did mix the gel with very tiny glass bubbles (it is like powder) and cotton flakes for bigger stuff. They are both used in the Epoxy world to thicken it.
Edited by Hsae
Typo correction
Fantastic work on the sea - looks fantastic!
Hope you don't mind me following your log.  I have this kit (I think I might have the Platinum edition which includes a wooden deck and some PE upgrades) along with the Parkins upgrades.  I also have the Revell 1:144 version with the Pontos upgrade.  Was thinking of doing the 1:144 as the Snowberry and the 1:72 as the USS Saucy just to mix it up a bit.  Interestingly, I found an electronic copy of the old Matchbox kit instructions which covered the Saucy along with the Snowberry and Bluebell.  Seems that the Revell kit -- which my version only includes the Snowberry and Campanula -- might include the Saucy pieces, which I think were only a few minor differences in the bridge and then a different rear gun platform (putting aside numbering and other decal-type differences).
Otherwise, I might try to build both as USS ships.  There are some cool ships like the USS Fury, USS Restless, and USS Tenacity.  Just a matter of doing the research and trying to figure out what the differences are, which is probably easier said than done.
Edited by Landlubber Mike
1 minute ago, Hsae said:
Thank you guys for the “likes” and the input.
I am still not entirely happy with the looks.
Do you think the hull is riding to high?
From the pictures, it looks pretty good to me.  Hard to tell how low the stern is in the water but overall I would say it's looking great or at least very close.  I know there are some people that are sticklers on this who hopefully will give their thoughts.
Can I ask - in cutting the bottom as you did, I see there is an open hole in the bottom.  My guess is that the hole would be perfectly fine using your sea approach of a styrofoam base.  I'd probably be a little nervous with a hole if using liquid resin to create the sea.  I have been thinking about sea approaches for some of my models, and have always wondered about cutting the bottom of the hull as you did.
Mike,
If you use Epoxy, you can seal the bottom of the hull to the board with hot glue for instance. You should be Ok with pouring Epoxy afterwards. You have to experiment a little bit what works best.
Hermann
Funny thing. The kit I have has the “Saucy” in it. I bought the kit many, many years ago. Lol
The shaded parts are not needed for the “Snowberry “ maybe for another ship?
Edited by Hsae
Preparation of the hull / deck:
- sanding the entire hull
- sanding down the bow / stem bar to a sharp point
- sanding down the keel
don’t need to replace the bilge keels and the propeller because you can’t see them (less work for me)
sanding down all the decks for accepting the brass deck from Great Little Ships (GLS)
Nice work with the sanding down of the hull and deck.  I have to say, when I saw that GLS suggests you do that, I almost didn't get the kit!  It will be all downhill (in a good way) from there!
Thanks for posting those pictures from the instructions.  Very helpful!  Here are some of the color profiles from the old Matchbox instructions.  I'm happy to delete them if you don't want them cluttering up your log (if so, my apologies in advance!).  The instructions also show the minor differences in the parts construction here and there - happy to send or post them here if you'd like to see.
Mike,
Thank you for posting. It’s quite interesting that they had 3D view way back then.
But I think the colors are not quite accurate. For instance the deck of the Snowberry was Dark Deck Gray NARN54.
But maybe it was not even intended to have an absolute accurate model. 😎
Yep. Bottom line is do your research. Find as much info about your ship at a certain time you can get. During wartime ships upgraded in weapons and were repainted quite often.
In my case I am building the HMCS Snowberry, because there are some good photos on the web.
But I am still missing a layout drawing. I think a good source would have been the booklet  Warship Perspectives: Flower Class Corvettes in World War Two. But unfortunately it is out of print for a long time. I do know that there are some photos / drawings in it.
This is the only RC model warship I ever built. Mine was one of the Matchbox kits from the first release. A 1/72nd kit of this type of ship was unheard of at that time. She had many years of running true North Atlantic conditions on a number of my local lakes and a few not so local. The model has been retired for some time now but still sits a little the worst for wear on a shelf in the basement.:( My build outside of the RC conversion was of course out of the box as there was no after market at the time.
I think that if you look a little closer at the pictures of the Saucy, you will see pretty much two periods. The " Snapdragon" picture is of the saucy as she looked when handed over to the US with the 4"/50 and shield forward and the two pounder AA gun mounted in the amidships tub with searchlight platform. It also has the British style radar lantern aft of the bridge.
In the picture supplied by Mike it looks like the forward 4" gun mount has been completely removed and replaced with a 3", (?) American open mount. The  AA tub and searchlight had been completely removed from the boiler casing and a quad .50 mount put in it's place but without the tub. A new American style tub is installed at the very end and another open 3", (?) installed. Also in this picture the lantern style radar has been removed and replaced with what looks to be a searchlight platform and the crows nest on the mast is also gone. The mast looks like it has been reinforced to hold a more modern US radar. As this is a wartime photo it is possible that the radar and some of the other mast or gun details have been cropped out of the picture for security reasons.
With more time, better pictures, and eyesight there are possibly other things to be picked out but in my humble opinion the "Snapdragon" picture is in reality the Arabis just after being handed over to the US. There would have been no real reason to return the Saucy back to British configuration in 1945.
I think that if I was to build this kit again I would be sorely tempted to build her as the Sackville. Plenty of documented material there! :D
As for the stern not being low enough in the "water", I think I would have to agree with you. The stance you put her into is very similar to the original Matchbox box art:
   Boxart Flower Class Corvette PK-901 Matchbox
And if you look there is no boot top showing aft.  But then that is a painting and if you are off at all it is only very slightly. Instead of lowering the hull you could build up the wave at the stern instead and get pretty much the same effect.
Also you could look here in case you feel you have not spent enough money so far: https://distefano3dprint.com/collections/uss-saucy-pg-65-flower-class-corvette :ph34r:
Looking forward to following your build. It is very impressive so far and it is just started.
Edited by lmagna
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Thank you all for the likes!
Working on improving the kit with mixed results. I was trying to add the additional opening in the connection between wheelhouse and the galley. And I messed it up. I did choose the wrong bit. After changing to a different bit it was easy. Live & learn!
Edited by Hsae
Ensign 3 - Flower class Corvettes by Anthony Preston and Alan Raven has drawings for Buttercup and Begonia.
