Stage Coach 1848 by Kevin - Artesania Latina - 1/10 - July 2021 - finished March 2022
5 hours ago, Canute said:
Stagecoach looking good, Kevin
And the dollhouses look good, too, What scale are they? I have a buddy here who used to build upscale furniture for these houses in I think 1/12 scale. He used the furniture catalogs from a home named Winterthur, outside Philadelphia, PA. Built clocks, dining room sets; he's was prolific with the furniture.
good morning, its all 1/12, i personally dont get involved in the internal side of things, i will build the kits up if asked and sort the electrics out,
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
good evening everyone
4 wheels on my wagon (well not quite on but complete), tonight i made the outer wheel bandings
the chassis which was stripped down yesterday, was primed and now has a new coat on, pin strips well complete it
at present i am rebuilding it, looks better than before, but even further removed from what it should look like
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
the chassis continues, a lot more banding has gone in, and whilst brass at present i may take it to black before completion
the suspension was put back on and then had a bit of fun with the through braces, which were made from leather straps, the kits asks you yo make them from wooden strips, i went my own way and used face mask elastic strapping, and clamped them in place with brass strips, the height above the chassis may be to high but no weight on there yet
the elastic was coloured using a Flory black wash
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
That is looking so nice Kevin.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Just a question Kevin, I think your idea of using elastic for the leather suspension gives a very real action to the suspension... have you figured a way to deal with the rubber in those elastics when it dries out and breaks? My suggestion, while you are at this point, is to thread a thin brass wire or two through each elastic, so when the rubber dries out and breaks, the nylon covering and wire will hold them together and the dead rubber will serve as a filler to let them keep their shape?
I would hate to see all that beautiful work fail in a few years...
Quote:
good to see your back working on the coach!  :)   the chassis and wheels look very good........a very cheerful color.  so when the occupants are ticked off by the erratic ride.....just stop and tell 'em to look at the chassis  ;)    {look at the flowers Lizzie}!
it might not be that dramatic.......what he's using is woven with fabric.  it will tend to sag over time,  but it will take longer to completely fail.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
i had considered putting something under the coach to take the weight, but i like the wire idea
thanks popeye
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
thank you for comments and likes
the coach looked awful (in my eyes, so i decided to do something about it
removed all door and widow frames and the top panelling between the windows, as that never looked right from day one,
fine grade sandpaper and took the upper coats of varnish off, washed down and then a varnish 50/50 white spirit wash applied
the door frames and windows are now fitted on one side
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
most of the main coach body work is done now, a few pretty strips still to be added
i may have to rethink the suspension straps, they are very springy and quite saggy
the door hinges are on well the rebates are done  (they will not be opening)
i used a bit of tape to hold the drivers cab in position, the glue in the coach is to offset the front weight
nothing is fixed yet
IMG_2766.thumb.JPG.0a1e3e548c82e1c2ccb58d299c61893e.JPGIMG_2767.thumb.JPG.367bbee7092dd22e14f2ba5d8a181c31.JPGIMG_2768.thumb.JPG.39567031de7058e98ab84c5937382cb9.JPGIMG_2769.thumb.JPG.464cf35d7e84c8db280672b09f7f6033.JPGIMG_2770.thumb.JPG.630b5acbdceafb6090f831aea9d3da50.JPGIMG_2771.thumb.JPG.fe4b1b3e8ccea808b5b598462ad0eadd.JPGIMG_2772.thumb.JPG.f625047f4da6ed9b816177ecf3363ff2.JPG
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Hi Kevin, if you do decide to replace them, the 1946 Popular Mechanics Overland Stage model, (1/12th scale scratchbuilt) recommended using leather shoelaces, you can get them wide enough (at least you could back in '48) and one pair is more than long enough... They would have to be shaved for thickness down to the tanned side and overlapped.. the shackles would fit in their appropriate places so it would look the same and the ends in the middle where they meet put on the top side so they are hidden next to the coach body...
It looks natural and real when done... (you can also bury the wire support inside them as well just in case) The leather will accept hide glue or white glue and be very secure...
The coach work is brilliant the carriage work is excellent, it's going to be a real masterpiece when done...
Edited by Egilman
Quote:
I have just been looking at a faux-leather jacket. It is made of a black vinyl about 1mm thick and it probably would do for the suspension without any issues of fading or weakening with age.  (The Admiral would not be sympathetic to any request to slice a bit off so I can only suggest, not supply!)  Haven't checked but I'm pretty sure some sunglass cases are made of similar stuff, hope this helps.
It is looking good.
Bruce
STAY SAFE
current builds:
Hmm.... need to stiffen it up a bit then.   Just musing here, would thin CA brushed on one side and the coated with flat clear or flat shellac work?  The catch is that it would prevent all movement and possibly be somewhat fragile.
thank you for the comments, i will look at the shoelace and leather ideas
mark i feel i would run into all sorts of problems and get very messy doing that, i had to cut a piece of wood of the dog yesterday and that was just with wood glue lol
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
good afternoon everyone
put some go faster stripes on, as i bring this side to completion
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
That is looking so nice  Kevin, the wood detailing is really sharp  - and the varnish makes it  Pop.
OC.
Current builds
Completed works.
OC.
Thank you OC, i was wondering where you were, you both ok?
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
We are Ok  mate,   im still  plodding on with my  M1  kit.
OC.
Current builds
Completed works.
look'in really sweet Kevin.  you can also do a browse in your local craft stores.   you might find leather strip in rolls,  or you may be able to find bags of leather odds and ends pieces
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
thank you for comments and likes, i will get back to you
@popeye the sailor @Canute @Old Collingwood
the great fence repair has taken me away from the build for the last few days, sorted for now, the rest can wait for warmer days
the pretty strips are done both sides now and has all had another coat of varnish
last night was spent making up one of the two mail pouches
the previous night doing the trunk
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
made up the supports to take the weight of the seats
IMG_2821.thumb.JPG.fcff224b4739168a8f1b769bed3749d3.JPGIMG_2823.thumb.JPG.3c2d959a7bcd906272f9fd50641e622b.JPG
started the boot area (dont actually know whats its called) which wil all be covered overIMG_2814.thumb.JPG.a1af34c4422f52f36b1373676bf121d3.JPGIMG_2815.thumb.JPG.da091294df5d49ae7ca37f4ed59938d0.JPGIMG_2816.thumb.JPG.a3f35aaa020d92bbd67246781400656a.JPGIMG_2817.thumb.JPG.dfa4d63b03240868a09e553d4f6a1fff.JPGIMG_2819.thumb.JPG.e56e81ec12b9a3da4b339c83b6157c78.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
good day today, sun was out, so the wife was happy, dog was happy, had a visitor, first one to see me in years, other than family, even brought my new build
stagecoach boot finished, it could have been better, but looks like a covered area as intended
IMG_2826.thumb.JPG.b7e26216b0492ca91534c3c230f61141.JPGIMG_2827.thumb.JPG.ae7cf4428b3b4d468ec7446216e21fa6.JPGIMG_2828.thumb.JPG.9a5b9de73ae38f7ee966cc7ee0095cef.JPGIMG_2829.thumb.JPG.5a7528b3bc1c92b46938add6e59cf2ca.JPGIMG_2830.thumb.JPG.6011cc9105e41b0b6c67a19c4f5faf25.JPGIMG_2831.thumb.JPG.83933a7c27e3b3565cbce92c41f16c2d.JPGIMG_2832.thumb.JPG.66c7125ddaf76f4f0178f3c796375beb.JPG
and the drivers area is also in position
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Looking very nice
OC
Current builds
Completed works.
16 hours ago, Old Collingwood said:
Looking very nice
OC
Thank you OC
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Good evening everyone
im still adding bits to this
the window blinds, rolled around a bit of 1mm brass, with some tie backs added to the large windows and doors
the wheel rims went on next, 5mm black card was used
still to do
replace or update the through braces
fix the brake system
put carriage onto through braces
insert lighting
put in seats and benches
driver position  rails
roof rails
hinges to doors
foot rests
PE lettering
and a general tidy up
IMG_2835.thumb.JPG.79487a93180ccdc436bfa0f4e2028dfe.JPGIMG_2836.thumb.JPG.64431faa56dd4cf3f9172f197e02e1b9.JPGIMG_2837.thumb.JPG.7fced307550a13eba22b79ca9cf3b3a0.JPGIMG_2838.thumb.JPG.bf00ca901d637d02362816fb70f4fc3e.JPGIMG_2839.thumb.JPG.5297dfedc1cdd7a5e56b63c853433554.JPG
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
still to do
insert lighting
roof rails
hinges to doors
foot rests
PE lettering
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
still to do
insert lighting
roof rails
hinges to doors
foot rests
PE lettering
good evening more done off the still to do list
the through braces were tightened up a lot more and now carries the weight a lot better, still more to add so it will sink a little lower
completion may be delayed as the stanchions have gone missing, i will either order some or make them
now away tomorrow so she wont be finished by the weekend
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
