4 hours ago, hollowneck said:
It’s looking really good, Tom. Have you assembled some of the unique rigging components like turnbuckles and wire rope?
Hi Ron
no not yet. Should be a real challenge at 1:96
Tom
Finally got back to modeling. This working for a living is getting old. 😂. I spent some time figuring out how to make some of the hardware and chain and get it to look like it is to scale at 1:96.
I am very happy with the chain. I took copper wire, in this case I used .012”diameter (28 gauge) to experiment with.
it came out about .027” in diameter and about 28 links per inch. I can buy chain about the same diameter and 40 LPI so I will experiment with 30 and 34 gage wire. The advantage to using my wire is it is stiff and can easily be formed to any curve or kept very straight to look taut.
I just took a length of wire, folded it in half and placed my homemade hook in the  looped end and twisted the wire. Then I took a common pin and poked it through the twists to slightly separate the wire twists to make something that looks just like a link. The whole process took less than 10 minutes. Here are a couple of blackened test pieces below.
I also took a stab at making miniature turnbuckles and thimbles. The turnbuckle shown below was made by filing about a third of the way through the side wall of a 1 millimeter diameter brass tube, turning it around and doing the same on the opposite side. This left a tube with slots on opposite sides that sort of simulates the body of a turnbuckle. I then micro-brazed an eye hook on each end to tie a rope or attach a hook to.
The thimbles above were made by collapsing a 1 millimeter brass tube on a forming tool that flares the ends of the straight blank to what you see in the picture above. The inside diameter is .024” and the length is about .035”. They can definitely pass for proper scaled pieces. I also have a set of forming tools to make them with a .039 ID which seemed to big for 1:96 scale.
I did manage to braze up some chain plates and mount some fore channels. Zooming in on the pics I see I need to touch up the white edges in a couple of places.  I will continue onto the main and mizzen channels and plates next as long as the “work thing” does not go back into crazy mode.
Tom
Hi Bob,
Thanks for the comment. I neglected to mention in the post above that it only works if you don’t twist the wire too tightly. The wire need to be able to open up around the pin when you insert it into the twist.  I just received some 30 and 34 gauge wire to see how it will look. Might be too small to even notice the links versus just twisted wire.
Tom
Wow, I didn’t think I would ever get back to working on this model. What started out as a simple fix a shower arm leak and paint blossomed into a 3 week project. Ah the joys of home ownership. 🤪
Anyway, I did manage to finish making and installing all the channels and chain plates.
I did get in some finer brass wire to experiment further with making tiny “cheater chain”. Below are samples of 30 gauge (.010”) and 34 gauge (.006) copper wire. The 30 gauge seemed to work okay. Not surprisingly, the finished size is very similar to my earlier test with 28 gauge wire since the wire diameter is only .002” different.  The 34 wire in my opinion is a bit too small to actually notice or perceive there to be links unless viewed under magnification. To the naked eye the twisted wire prior to separating the twists with a pin looks pretty much the same after creating the links with the pin. Since 99.9% of people looking at the model won’t be using an optivisor to look at the model, it probably would be fine to just twist the wire and leave it be.
The upper wire is the 30 gauge, lower is 34.
Hopefully, I can now put some time into modeling my Morgan instead of master bathrooms and such. 😁
Tom
Hi Tom
i am going to wait until it is finished before I put it on display. Last summer I was hopeful it would make it for this year’s show but life keeps getting in the way so modeling ends up taking a back seat.  It will be there next year, at least that is the plan. 😜
Tom
Managed to get the bowsprit netting done. Took a couple of tries but I think persistence paid off.
Here is a picture of the actual netting on the Morgan I took this past summer that I used for a guide.
I made a miniature loom and wove the netting around pins that were placed at each intersection along the outside edges. The ropes on the edges were held in place using the slits in each end of the loom. After everything was woven, I took some Tex 10 thread and tied knots at each intersection to keep everything in place. Those knots are barely noticeable. 👍 Below is a picture of the loom. Nothing fancy but quit effective. 😜
Tom
Edited by toms10
Had a nice spring day here in Connecticut today. 😊. I managed to get some yard work in 😂
Hey I thought this is what my wife meant this morning when she mentioned yard work.  Evidently I may have misunderstood. 😜
Tom
Edited by toms10
Okay. After completing my wife’s definition of yard work 😂😜, I managed to get the fore mast set of shrouds made and installed. Not my favorite task but the are in nonetheless.
Need to double check again to make sure I don’t need anymore eyes, blocks or other items attached to the fore mast.     There is still plenty of room to work in now but later when I running lines for the running rigging I don’t want to try to add anything.
I do need to make a decision about main top mast and top gallant staysails. The Mystic plans don’t include them. There is a note on the plans saying they are shown on an earlier sail plan but no evidence they were used during the restoration period so Mystic does not display them. Even though I am following these plans I kind of think that they would make the ship a bit more complete looking. Right now the plans only show the main staysail.
Usually all the lower sails are shown furled or reefed so the deck details are more exposed. I am thinking that if the main top and t’gal staysails are omitted and the main and main staysail are furled there might be a big hole in the middle.
Anybody have any thoughts to persuade me to not include or include the top and t’gal staysails?  I kind of need to know soon because there are blocks and eyes that would be needed to be installed prior to installing the appropriate masts.
Tom
Edited by toms10
Tom, the sails, I believe are your choice and what your vision is of the completed model.  Either way... go for it.
Finished the main mast shrouds and the mainstay. Also put all the ropes through the blocks under the tops. At least I hope it is all of them. 😁. It now becomes a lot more difficult to add a block or eye that was overlooked.
The Northeast Joint Conference took place yesterday. A good time seemed to be had by all. The level of creativity and craftsmanship was inspiring. Thank you to the New York club for the work they did in hosting this year’s event.
Tom
Well now I have all 3 masts set and shrouded with lots of little coils of rope (with little tags) hanging all over the place. Things are moving along somewhat smoothly, provided the little tags stay on. 😜😂. It looks like a nightmare with all the ropes coiled and hanging but I find it is much easier to Reece all the blocks before the masts are in place and then just uncoil each one as it gets tied to belaying pins and whatever is at the other end.  As I am sure you all know and heard, “Do as much as you can off the model”.  At least within reason.
I think I will make a couple of whale boats to put on top of the boat bearer/shelter now as a change of pace.
I want to make sure I have everything done along the centerline of the deck and then work outward. That makes it a bit easier without having to reach around things to get at something in the middle.
Tom
So I started on the whale boats. The plans suggested using what I call a “pancake” method. There are 7 layers that are to be glued together one on top of the other. Each layer’s outside contour is basically the waterlines of a half breadth view on a body plan.
After making 7 copies I cut them out and rubber cemented them to a piece of 1/16” thick basswood. Note I only cut the outside contour at this point.
Next I used a #4 scalpel to cut out the inside contour. Unfortunately I forgot to take a picture at this point. This was a big tedious but I only had to cut out the interior on 5 of the 7 boats.  Two of them will be stowed upside down on the boat bearer shelter.
After all the interior contours were cut out I proceeded to use a band saw and cut all the outside contours as shown below.   The one on the right is the bottom layer which closes up the bottom.
Next,  all of the layers except the bottom were glued together. The reason I left the bottom off was to allow easier access to the inside contour for shaping and sanding.
 All the high edges need to be knocked down and sanded so each layer is flush with the next. That is easier said than done 😜. I used a pencil like hand engraving tool to do all the rough work and then rolled up sand paper. I needed to use a bit of filler in a few spots but it all worked in the end. It was a bit like taking an Aztec pyramid and turning it it into an Egyptian style one 😁. Here is a pic of the inside contour smoothened. These surfaces will all be painted so any filler will not be seen.
The bottom was the glued on and the outside contour was then shaped and sanded.
Finally the ends were shaped and curved to the final hull configuration.
Next I will put on the keel, top rail and the side rubs. Then eventually all the interior structures.  When I get to that point I will post more pics.  Right now I have 6 more boat hills to make.
Tom
Edited by toms10
Added pic
Tom,
what kind of “pencil like hand engraving tool” are you using? BTW, the pictures didn't seem to come out on my computer. Am I alone?
Edited by TBlack
3 hours ago, TBlack said:
Tom,
Nope, you're not alone.  Tom, try doing an edit of your post re-upload them.
7 hours ago, TBlack said:
Tom,
Tom B.,
It was just some cheap engraving tool that I picked up at Harbor Freight but it does the job.  It runs on 2 AAA batteries.  It has a spherical abrasive metal tip that is about 1/16” diameter.
Tom
Edited by toms10
Well the 7 hulls are finally all shaped. There is still a bit of light sanding to do to smooth out the insides.  I noticed there is nothing in the picture for a scale reference. The overall length of each is 3.450”.  Now I can start making the pieces for all the detail work. 😁. I am sure that will be much more fun than all the sanding I just did for the past week  😜IMG_2698.thumb.jpeg.392265075f1a65df4cb089c57f59476c.jpeg
Tom
T.B.
I need to be honest. I cannot claim this as my technique. I copied it from a set of plans. From what I understand it is a common tech for building half hull models.
Tom
The hulls now have keels. I am almost done putting all the “pseudo frames” on 5 of the hulls. Next I need to put inner planking up about 3/4 the way up from the bottom. That will be a nice change from putting in all those “frames”
I am using photos of the actual boats at Mystic as a guide.
Tom
Made a little more progress on the whale boats. All 5 have the components made for the hull. I still feel like I am an eternity from finishing these. I still have to make all the gear that goes with each boat!
I went ahead and assembled one and gave it some color just to see how one would look. As I said, still have miles to go. 🤪
Tom
And then there were 5. 😁  Now for the fittings, mast and all the equipment. These are turning into just as much work as the Morgan herself! 😂
Oh yeah. Can’t forget about the 2 spare boats. Just have to do the outsides of the hulls on those so those should be much easier.
Tom
That set of boats are beauties.
Steve
"If they suspect me of intelligence, I am sure it will soon blow over, ha, ha, ha!"
-- Jack Aubrey
Builds:
Yankee Hero, Fannie Gorham, We’re Here, Dapper Tom (x3), New Bedford Whaler, US Brig Lawrence (Niagara), Wyoming (half hull), Fra Berlanga (half hull), Gokstad Viking Ship, Kate Cory, Charles Morgan, Gjoa
Still cranking away on the whale boats. Started to install the miscellaneous fittings like cleats, loggerhead, rudder in the stowed position, etc.
Also got started on making all the oars. At 1:96 scale it is a bit of a challenge to make “little sticks” look like oars but I came up with the following method for making 30 oars and 5 paddles.
The picture below shows the 4 steps I used starting from a basic round toothpick.
The piece on the far left is step one, take the toothpick out of the box. 😜
The 2nd piece from the left shows step 2, turning (actually filing) down the loom to about .035” diameter.  This took some patience because if you press too hard with the file you end up breaking the stem off. 😤😡
The next two pieces actually show the same step, one the front view and one the side view.  The original diameter of .078” was sanded down flat to the loom on both sides to form the blade.
The last piece is the final oar after cutting to length, shaping and beveling the sides of the blade.
Below are closeups of each working step.
Step 2: Turning loom diameter
Step 3: Flattening blade
Final oar:
Now I just have to do it 29 more times!!!  These boats are going to end up taking just as long as the Morgan itself!😂
Tom
