F-104C Starfighter "Blue Jay Four" 1/32nd Scale, Italeri #2515, by Egilman
Ok, here we go, ROUND 2!!!
Bluejay 4, the Iconic Starfighter as seen in The Star Trek Episode "Tomorrow is Yesterday"  I call it round two cause most are familiar with the last time I tried this and failed to finish cause I basically didn't know what I was doing when trying to get an accurate Bare Metal Finish... By the time I finally burned out on it and had to quit I had learned how other great modelers did it and am now going to try again... Old Thread here...
This time with a more modern version of the F-104C (latest Italeri kit) and I acquired the Eduard "Big Ed" photoetch set for this one...
I still haven't decided what view I'm going to do with this model, I know it's going to represent the real aircraft though, but I think I'm going to put more details into this much improved kit that the previous Hasegawa kit would allow... Instead of the roll-out scramble view I was doing I'm going to do the full detail version like she is being maintained ready for the call to get the Enterprise... At least, that's the plan....
Anyways, I'm preparing for this one... It's going to be a long journey and of course since this is a real airplane with a real history I will go into parts of it's service history and it and it's pilots tragic ending...
F-104C #57-0914  A great airplane with a great pilot...
tomorrowisyesterdayhd001.jpg.9f75cb6701867d6cf37df4d716d9fbec.jpgtomorrowisyesterdayhd002.jpg.b3575b802103ca28c4affa36051cf507.jpgtomorrowisyesterdayhd003.jpg.090f6114245626d394263be049e6421e.jpgtomorrowisyesterdayhd004.jpg.89b1aa12010a9b8126fa272442124845.jpg
More when I get organized...
Onwards
Edited by Egilman
Added link to old topic
Quote:
Me thinks you are gonna  get Alot of attention with this build brother   - bring it  to us    "we are stocked up  @mtaylor  has a brand new shinny  Pop Corn machine   - and the rest are sharing around the  liquid  stuffs"☺️
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
On 2/10/2022 at 5:10 PM, king derelict said:
Looking forward to this Egilman. I have a Vampire in the pile that needs a bare metal finish and I haven't a clue so I will be all attention here
Alan
Now the pressure is on, {chuckle} I'll do my best, if I do it right it should look something like this....
Hasegawa...
102_097_fs.jpg.83756b023680edf21d1324cb99132b85.jpg102_134_fs.jpg.affc54de4d7e197068af4c62bba04443.jpg
Or this, Original Italeri...
F104G_allemand_001_fs.jpg.bb7ca891e97dc681bdf9f83ebaaf2eec.jpgF104G25_fs.jpg.da5a8c9616283868ec884b8efc25482d.jpgF104G23_fs.jpg.4ae0bf9ed10c166518c150813a7141cd.jpgF104G_allemand_120_fs.jpg.477ac78e799d220a149416b162d5ecd6.jpg
Two different models, two different modelers... Both used the same product to produce that finish... There is a third as well (did a CF-104) This finish cannot be replicated with paint...
Actually I'm going to go straight into the build with this one... I'll add a link to the old build to make the connection with the history...
Your vampire will really look the business with this type of finish on her... I sincerely hope Alan, I can show it correctly, to a certain point this is still an experiment, my second attempt...
But, if they could do it, I can do it...
Edited by Egilman
Quote:
On 2/10/2022 at 6:00 PM, Canute said:
Oh boy, a shiny Zipper. Looking forward to this build, EG.
Thanks Ken, hopefully it turns out better than the last one....
OC.
I don't know about that one brother, everyone is welcome of course... just take it easy on the liquids ok? and don't forget to share the popcorn...  I added rafters to the building so those that like to hang out up there can be more comfy...
Quote:
Now, just like most modern model airplanes, the Italeri kit starts with the seat....
As you can see, from the last build I did an aftermarket Lockheed C-2 ejection seat for that build and fortunately I saved it for this build....
IMG_9947.thumb.JPG.e8a4fa7d52f36f7124b3ffefe1dafa19.JPGIMG_9948.thumb.JPG.26ec534e925b684a724fbaa327291726.JPGIMG_9949.thumb.JPG.a442376d8d13cefaadd3232f122475ed.JPGIMG_9950.thumb.JPG.95d26db5b9930150f5fedb318dfc01d6.JPG
Unfortunately I could not save the cockpit itself, if we remember I had to completely rebuild it to fit the aftermarket into the fuselage... Trying to save it would have destroyed it...
So here, we start with the Cockpit...
And the actual cockpit tub...
Beautifully modeled details and a lot more accurate than the old Hasegawa cockpit was, but to add the photoetch, all that detail has to be sanded off so the panels will glue into correct positions...
Here we go brothers, first steps down the path....
Wish me luck....
EG
Edited by Egilman
Quote:
I'm in, a bit late, but a couple of hammocks in the rafters and some nut brittle!
I'm  glad you're revisiting this plane EG, looking forward to the new edition, with the enhanced bare metal finish.
Onwards indeed😉
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Actually, Right on Time Brother.... Just putting first glue to brass & plastic...
Welcome, lay back, relax and enjoy the journey....
Quote:
First update, Installing the base brass for the cockpit sidewalls....
Structural brass, not all of those parts will be used, the kit and brass is designed to allow the building of an "A" model if you so choose... To do that you have to modify the cockpit tub by cutting out the floor...
That red square, designated for removal, we are building the "C" variant so no need to cut, but the pink areas needed to be sanded away to accommodate the photoetch (PE) details to be installed...
For example the left cockpit wall... (with it's magazine holder)
Installed...
I'm using Extreme power thin CA to attach these, had the dickens of a time getting it placed correctly before it set, it's been a while since I did any serious PE work...
The passenger side... (with it's magazine holder as well, chuckle)
Now all we need is a coat of Aircraft Grey paint and we will be ready for the side control panels....
Onwards Brothers...
EG
Quote:
One of the most aesthetically beautiful aircraft in a senior scale, I will be also following, if you don't mind.
Great start with the cockpit. Side walls with magazines look spot on.
Kind regards,
Dan
Maybe so, but one with an appalling accident rate. From the Wikipedia entry:
"The cumulative destroyed rate of the F-104 Starfighter in USAF service as of 31 December 1983 was 25.2 aircraft destroyed per 100,000 flight hours. This is the highest accident rate of any of the USAF Century Series fighters. By comparison, the cumulative destroyed rates for the other Century Series aircraft in USAF service over the same time period were 16.2 for the North American F-100 Super Sabre, 9.7 for the McDonnell F-101 Voodoo, 15.6 for the Republic F-105 Thunderchief, and 7.3 for the Convair F-106 Delta Dart.[166] By comparison, the Royal Australian Air Force (RAAF) experienced an overall loss rate of 11.96 per 100,000 flying hours with the Dassault Mirage III, losing 40 of 116 aircraft to accidents over its 25-year career from 1965 to 1989."
Kind regards,
Dan
Thanks Dan, Your welcome anytime....
I agree she is one of the most beautiful aircraft ever built and flown...
Yeah she did have some not so nice nicknames, "Widowmaker" "Lawn Dart" and several others... The wing loading was particularly high on this bird, heck it was made for speed in the interceptor role not as a fighter bomber... It's had a couple of bad habits and one of which the only recovery was to bail out...
But it was the ride everyone wanted to fly...
Quote:
I was an exchange student in West Germany in '79-'80. Franz Josef Strauss, the West German Minister of Defense at the time the Bundesrepublik made their F-104 purchase, was still politically active at the time and still haunted by the rumors that Lockheed had greased the skids of the sale with some bribe money. I don't think that anything was conclusively proven, but then rumors don't need corroboration to be damaging. The fact that so many Luftwaffe Starfighters were lost in accidents certainly didn't help Strauss's public image.
We said the same thing about the F-16 early on. Had some air start problems; the high AOAs (angles of AttacK0 they could generate, cut off the air entering the engine inlet. If the one burning ain't turning, it's a blivet and crashes.
Reusing the kit cockpit bucket should ensure the nose area will have minimal fit issues. Watching with great interest, EG.
Ken
Started: MS Bounty Longboat,
I’ve pulled up a seat to follow along.  Looks like a really nice kit and I’m sure you’ll make a terrific job of it.  I am especially interested in seeing the bare metal rendering as I’ve never done anything like it myself.  Best of luck on this new project Egilman.
Gary
Completed Scratch Builds
The  history of the  Starfighter is Amazing   - I love that it was chosen to be the SR71  Blackbird  chase plane.
OC.
Current builds
Completed works.
Favorite location, favorite lounge furniture, one of my favorite aircraft, FAVORITE FOOD! You have company Edward........... Hope you are willing to share the brittle! I have to wait until early March for my stock!:unsure:
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
OC.
Probably at the time, it was one of the few planes that could keep up with a Blackbird during the testing.
It had a J79 GE engine, same as the F4 and A5 Vigilante. Heck of a lot less iron around it. Great acceleration.
Ken
On 2/12/2022 at 5:38 PM, Canute said:
We said the same thing about the F-16 early on. Had some air start problems; the high AOAs (angles of AttacK they could generate, cut off the air entering the engine inlet. If the one burning ain't turning, it's a blivet and crashes.
Yep, the F-104 had HAoA issues as well but they were more from the configuration of the wings, they eventually put a warning stick shaker on it and then a force return to keep the aircraft within it's flight envelope to prevent stalls, but pilots routinely disabled it... When the F-104 went into a stall, it usually did one of two things, started tumbling, or flat spinned... Both unrecoverable conditions... The first pilot to experience it was Chuck Yeager in the XF-104 he crashed from flight level 22.... He reported that the aircraft dropped like a anvil and there was no aerodynamic control from the control surfaces... He spent six months in the hospital recovering from the ejection experience.... The Air Force eventually made 1500 flight hours in supersonic aircraft a requirement to become a zipper pilot....
Thanks Brother, not having to rebuild the cockpit tub is a bonus with this one...
Quote:
Gary
Welcome Gary, It's a gorgeous kit and the PE looks great as well... the finish I'm hoping comes out like the others show there are... Praying I don't muck this one up as well..
Thank you...
Quote:
OC.
It was a revolutionary aircraft when first built, pushing the edge of the envelope of aircraft engineering... Nasa flew several of them for decades as a research aircraft.... It really was a manned missile... It was chosen as the chase plane for a number of experimental aircraft including the XB-70... And when they did the highspeed runs with the experimental's, the starfighter was usually the last chase plane left behind...
Welcome aboard Brother...
Edited by Egilman
Quote:
Welcome aboard brother, I made sure there was room up there for you... I'm sure the goodies will be passed around with abundance in a bit....  And the brittle? At least I won't be shelled again.... {chuckle}
Enjoy my friend...
Quote:
Yep, until the Phantom II came along.... To be completely candid there were only two other aircraft ever built that could keep up with an A-12/SR-71 at speed... The MiG 31, and the XB-70... and as far as the MiG 31 went, SR-71 pilots said all they would have to do is push the throttle a little closer to the firewall....
Edited by Egilman
Quote:
It was the first axial flow turbojet that wouldn't compressor stall in transition from sub-sonic to supersonic speeds... it was a revolution in engine tech... Also, depending on aerodynamic condition and throttle commands, the stators in the compressor would change their pitch automatically maintaining smooth airflows while increasing the volume of air almost instaneously... The built this capability to stop compressor stall which it did in all except the most extreme conditions, solved the aerial restart problem as well... What they didn't expect and surprised the heck out of them was the instant thrust response it gave them... Most jet engines have a delay between throttle up and thrust increase, it takes a bit of time for the compressor to spin up faster and deliver the increased airflow.... Variable stators in the compressor altered that to next to nothing.... instead of waiting five seconds for the increased thrust on throttle up, the increase in thrust was right there, now, almost immediately.....
And yeah it wasn't carrying a B-17's worth of bombs slung under it's belly either...
Quote:
Ok, short update...
Decided to take a break on the tub PE and see what I was going to do with the Instrument panel... the Tub was easy to clean the detail molding from and although nice was a bit soft on the details... the Instrument panel on the other hand is extremely detailed, clean and crisp with deep details not easily removed... The debate I had was do I actually want to try to remove it or build a new instrument panel to accommodate the PE, (which looked flat in comparison to the moulded in detail) or detail paint the existing....
I figured it would probably be best to first see what the status of my ancient 5/0 brush skills were...
This is what the real instrument panel looks like....
And this is my attempt to replicate that in paint....
My attempt to detail paint...
Please, I would like to know what you guys think, remembering that it's going to be inside a cockpit and under the Hud shroud...
Edited by Egilman
Quote:
EG, it's good to go, bud. Side panel decals(?) look very good. Instrument panel is very good. Too bad it will be almost hidden in your cockpit. Bet you're crossed-eyed from that detailing job. What's on the radar screen? It has that appropriate green glow of 50's CRTs. Nicely done. 👍👍
Ken
