Hi Everyone,
I’m thinking that model ship building is much like the industry I retired from, i.e. tons of research and development and lots of man hours to design, plan, buy etc., and then a couple of non skilled laborers put it together in 4 hours.
I’m looking at the officers quarters bulkhead. Not one mention in the plans at all concerning the bulkhead, no supplied material for said bulkhead, only a view o the drawing. Did you Snake builders supply your own material and do your best scratch building the entire bulkhead?
Edited by Dave_E
Dave
Current builds: Rattlesnake, Curtis P-40 Warhawk - 1/33 Card
Completed builds: Lady Nelson
On the shelf: NRG Half Hull Project, Various metal, plastic and paper models
It has to be scratch built, and you'll find yourself taking many measurements to ensure it looks correct. It is a challenge to get it looking like the plans. Take your time with it and you'll do just fine.
Jim
Current Build: Fair American - Model Shipways
Awaiting Parts - Rattlesnake
On the Shelf - English Pinnace
                        18Th Century Longboat
I stand firmly against piracy!
Keep in mind, that bulkhead is Campbell's creation.  Look at Winnie and other builds to get some ideas. I'm thinking the windows would make more sense in the doors.
― Jimmy Buffett
Slow crawl:    Rattlesnake
I'm finding some inspiration for the quarterdeck bulkhead in Beckmann's Winchelsea build.
Link to the relevant content..
Here is a small sample.
Click on down through the link above for a lot more detail regarding method.
@Dave_E  If I'm cluttering up your log too much just let me know and I will delete posts.
― Jimmy Buffett
That level of detail is just insane! Ah, I don't think my Rattlesnake is going to get this level of craftsmanship. I'm just not that good and dont have the tooling. I admire those that have the talent, tools and patience. 👍 You are not cluttering up my log. 😀 I'm not sure what I'll do. Save it for another day and press on.
Dave
I wasn't thinking so much as duplicating the craftsmanship and/or detail but more in the way of a design concept, which is not that  much different from the MS/Campbell drawings.
The red drawing is from the Winnie plans reshaped a bit for size.
The upper curved panels on the MS drawings do not look homogeneous to me.  They don't follow the shape of the bulwarks.
And once again there are the windows.  It would seem more logical for them to be in the doors.
― Jimmy Buffett
Beckman is exceptional, he made those out of ivory from old piano keys. Before you get overwhelmed ther are simpler ways to do bulkheads. I scratch built the one for my Pegasus, it doesn’t have to be that hard.
Regards,
Glenn
Current Build: HM Flirt
Dave, you can use the knock out piece from the frame at that location for the template of the bulkhead/removeable panels. The tough part is deciding and making the windows, and the raised trim.
Jim
Good Friday to All,
It has begun! 😄 Wasn’t as hard as I thought it would be. Actually the hardest part was overthinking, looking at the drawings until my eyes hurt and looking at all the build logs to decide where to start. I almost went with the hull planking first, but I remembered how I manhandled the Lady Nelson and thought I’d surly snap the gun port framing over and over. I know it looks a little crude, but when I’m down to the wales, then I’ll break out the sandpaper and clean up the ports.
Edited by Dave_E
Dave
I've decided I'm going to do a lot of topside work before proceeding with the lower hull..
Does anyone know a good reason for doing all the hull planking first, other than "that's the way it's always been done.".?
― Jimmy Buffett
The hull is handled a lot and also easiest to plank with the hull upside down. It’s done to preclude damage to anything on the deck. You can plank with an easier mind when there is nothing on top to worry about.
Besides planking is fun. 😊
Regards,
Glenn
So says the master “planker”. 😆I have seen builds that save planking for later, I too wondered why they would do that.
Dave
I wondered as well; had I followed the order of the instructions, I'd have lots of little shards of wood scattered across my workbench that used to be railings!
John
Current Build: Rattlesnake (Model Shipways 1:64)
Dave, Damage is the reason! I just finished planking. Now I have to rebuild several deck supports plus the focsl railing. Not to mention breaking the stem off!! Lots of pushing and pressing against the hull in an upside down position. You'll be glad you did it first by the time you're done!
Thanks & Best regards,
Ed Kutay
Current build: Model Shipways "Rattlesnake"
Completed build: Model Shipways "Bluenose I"
I just discovered your build log today and admired your workmanship. I built the Mamoli Rattlesnake in 2017 as my first square rigged wooden ship using Robert Hunt's practicum as my bible. I could not have built my model without it. The build was a kit bash adding all kinds of details the kit did not have. and was a challenge for me as a first time builder, but I think it was worth it. The Rattlesnake is a beautiful ship. I look forward to your future posts.
Jonathan
  • 1 year later...
Hi Andrew, and everyone else,
Yes the Snake build is on hold. This past winter, when I was planning on getting the shipyard resurrected, I decided to build another guitar. Last year I also ventured into card modeling (which I picked up on this forum). Spring is here now, I’m back out in the garden, tending the fruit trees and the vineyard. However, I do keep active on the forum as I love watching everyone’s work. Total transparency here, I was a plastic airplane modeler as a kid and that one never went away and this forum has a room for non-ship endeavors. I spend a lot of time there. 😀
The Snake is on one of my bench tops in the man cave and I see it every time I go in there and one day, I’ll just start working on it. 😀
Dave
Dave
