7 hours ago, Dr PR said:
John,
Nice work on the sails, and nice attention to details.
Isn't it interesting how a simple triangular sail with just a halliard, two sheets and a tack can turn into a plethora of blocks, hooks, lines fairleads, pins and cleats - not to mention the hanks. Oh yes - the downhauls with even more of the same!
Thanks for noticing the detail Phil. I appreciate your comments. There certainly is a lot of detail. 🧐 I know I’m not getting it all perfect, but she is looking good. 😊
More interesting still is the crew coordination it takes to work the rigging to hoist the sails then sail the vessel. It was certainly fascinating to watch the Bluenose II crew on our short cruise on her last summer. It helps to understand how this stuff works.
Cheers 🍻
IMG_2113.thumb.jpeg.1a494c0a5e2d4181655602cb770b7cd6.jpegIMG_2114.thumb.jpeg.8495c6edf37a4c2bf51a82196685e0fe.jpegIMG_2119.thumb.jpeg.f8d05f0223807518963224cd3514519e.jpegIMG_2131.thumb.jpeg.567b0d64f6ce6776f84d4178653b8db9.jpeg
IMG_2148.thumb.jpeg.d1956d8771fe849134067b8e68c74c40.jpegIMG_2141.thumb.jpeg.e9e621f0ca10fe17f964e7b82cdf1f35.jpeg
Stay Sail…
Rigging Sheet Pendant Block…
Halyard, Throat, Tack and Sheet rigged.
Staysail Throat Halyard block…
Staysail Tack Pendant with Fairlead…
Staysail Halyard…
Halyard belayed at Sheer Pole Starboard side.
Putting some wind in her sails…
Staysail Sheet Tackle…
IMG_4006.thumb.jpeg.06a8816b9d6069af0916a79c940f8e63.jpegIMG_4008.thumb.jpeg.f99e9125342bdb980ab51f0eba651a84.jpeg
Staysail Sheet belayed pin #38 (starboard)
Staysail Throat Halyard and Tack belayed to Fore Pin Rail.
Staysail set…
Cheers 🍻
Edited by John Ruy
Jib Downhauls…
Just in, Amati Rope for the downhaul rigging.
Threading down haul through hanks.
Tying down haul off to Jumbo Jib.
IMG_4019.thumb.jpeg.8b70ee22abe7006028124da9b5b26227.jpegIMG_4020.thumb.jpeg.7f08a00cebe5aacb83ff0a3943daf8c0.jpegIMG_4027.thumb.jpeg.f5f6af190e010a220e739f9f4f04a7f6.jpeg
Jumbo Jib down haul belayed to starboard bitt.
Jib Downhaul belayed to pin #2
IMG_4024.thumb.jpeg.4aed29c284d99aa18b60260bcf4b2e17.jpegIMG_4025.thumb.jpeg.813e0d401a69c0acb8269fc1c46460be.jpeg
Balloon Jib belayed to pin #1.
IMG_4026.thumb.jpeg.ae1d5bdbd31819f5df7d08c149b0388e.jpegIMG_4028.thumb.jpeg.0e255af4d6f5f68c01a100abf07f3197.jpeg
Jib Downhauls complete with rope coils.
Cheers 🍻
Fore Sail…
Added Bolt Rope and Reef Points to previously sewn Fore Sail.
Installed block and line for Top Sail Sheet.
IMG_4073.thumb.jpeg.b4a158ee7f461d2728f8f6407f39b403.jpegIMG_4074.thumb.jpeg.1e8f676fd0160543b92497201b40d343.jpeg
Laced Gaff to Fore Sail.
Laced Fore Sail to Boom.
Added Parrel w/Wood Trucks to Gaff.
Blocks for the Fore Sail Rigging.
Throat Halyard attached to Gaff.
Connecting Gaff to Fore Mast.
Throat Halyard in place.
Peak Halyards in place.
Sewing Mast Hoops to the Sail.
IMG_4094.thumb.jpeg.39822f355d12407c2287a876ae6a8d0a.jpegIMG_4095.thumb.jpeg.c34adaf51ea0bfa375586d1292c49d6b.jpegIMG_4096.thumb.jpeg.e2ee7e44f42ed28482ba9a6532ced27a.jpegIMG_4097.thumb.jpeg.e4c85ff9ead84cd0e626032827559480.jpegIMG_4098.thumb.jpeg.ec34f4fec5d0ad9fcced9263bb98234f.jpeg
Fore Mast Hoops attached to Fore Sail.
Boom Tackle placed.
Placing Fore Sail Sheet.
Sheet belayed to Fife Rail.
Topping Lift installed.
IMG_4104.thumb.jpeg.102a9f5743a1e62fe090acc953fa359e.jpegIMG_4135.thumb.jpeg.43290746b26e1669945b3ec8a0e61d40.jpeg
Topping Lift belayed to Fife Rail.
Peak Halyard belayed to pin #8.
Eyelet for Throat Halyard Block inaccessible.
Had to remove Engine Box. Fortunately, spot glued with CA and I was able to pop it out.
IMG_4111.thumb.jpeg.78fcca66e59fdf717514fc512121b1c7.jpegIMG_4114.thumb.jpeg.b50f61336bc72930f634610db652fff6.jpegIMG_4115.thumb.jpeg.1ea487013a43a7def34b2a88456a83c1.jpegIMG_4116.thumb.jpeg.48a38e1e0ee35fce2d9e47286a6e6b7b.jpeg
Throat Halyard belayed to pin #7.
IMG_4117.thumb.jpeg.cfca0c833d86020a0b65b045328460cf.jpegIMG_4118.thumb.jpeg.2fbf9dc5f4b6a87cfd95deceb23ac3d4.jpegIMG_4119.thumb.jpeg.b2705b48403bbe5ae6312be50f17c774.jpegIMG_4120.thumb.jpeg.a9a21e390de1a1a54cd40118720ec313.jpegIMG_4121.thumb.jpeg.7fbe57e4a2018d07166211c67dfbee78.jpegIMG_4122.thumb.jpeg.f86ddd884f6cc099c8b9f41927e7b9a3.jpegIMG_4125.thumb.jpeg.51913b956ba8bde557f73716f84e4619.jpegIMG_4126.thumb.jpeg.abc35371ed3f041662cc46d15cb846a4.jpeg
Peak Halyard Tackle belayed to pin #17.
IMG_4131.thumb.jpeg.05da0ccf5da78d77f5d69c136c8d6482.jpegIMG_4133.thumb.jpeg.821eb6bea9258a4f3b60f0d6c4296940.jpeg
Throat Halyard belayed to pin # 18.
Fore Sail Downhaul belayed to Fore Boom.
IMG_4137.thumb.jpeg.7ab432757bbb9f86eed28ed1f6fc790b.jpegIMG_4138.thumb.jpeg.3b882083ec4c5d2c73d05172111c48f6.jpeg
Fore Sail Rigging complete.
Cheers. 🍻
Nice work, John!  Hard to get into those small spaces!  Lots of pics with tweezers in the camera shot!  Excellent!
I'm getting my lower shrouds in now.  Wish I was as far as you, but then I keep telling myself I am in no particular hurry... take it slow!
Gregg
Current Projects:                                                             Completed Projects:        Waiting for Shipyard Clearance:
Looks great.  You're not afraid to get in close with the camera, and your work holds up to the tight views.  Very nice!
John,
Good progress! The model looks good with the sails. I will say again that you are fortunate to be able to visit the vessel and see the way the real thing is rigged.
I have been waiting to see how you rigged the gaff sails. Since these sails  are on the centerline and at the bottom of the masts - basically inside all the other rigging - I think I will rig them first, even before I put the ratlines on the shrouds. The fewer lines in the way while I am fiddling with the hoops and sails the better!
In particular, I noticed that you pre-rigged the ties to the mast hoops. I am thinking about how I will tie the sails to the hoops. While I have tried to follow the rigging techniques shown in the books for most of the rigging, for the hoops I think I will just use a simple single loop and knot.
Phil
Current build: USS Cape MSI-2
Greg,  No deadlines… That’s what makes it an awesome experience. Looks like I’ll hit two years on this one. But then I work on more than one at a time, so it’s really hard to say how long it really takes. But then it doesn’t really matter, does it. 😜
John
Edited by John Ruy
Phil, Those hoop ties were very tedious and took a couple of hours, just for the Fore Sail. In hind site I think it may have been better to rig the sails on the hoops prior to setting the masts. However it is what it is now. 😆
John
One method that works for me:
I rig the throat and peak gaff halyard and topping lift with the mast and boom and gaff laying flat on a table off the boat. Then I place the sail and tie the mast hoops and rig the sails to the boom and gaff.  Makes it so much easier. Everything stays in place while tieing and running lines. Then I'll set the masts with temporary shrouds until I get all running rigging close to the masts done. Only then do I do the stays and shrouds.  That way I have much less work inward of the shrouds.
That sounds like a great idea. 👍
I’ll have to give that a try on the next one.
Fore Topsail…
IMG_4182.thumb.jpeg.1e40236a548b8bc090c34eee87ad4910.jpegIMG_4184.thumb.jpeg.a4c69135ef41d888dd4dbab037362194.jpeg
Fore Topsail Halyard Blocks…
IMG_4185.thumb.jpeg.b665210cdad50f67f592eb0435c12038.jpegIMG_4187.thumb.jpeg.eea3ff801130b6cdc993f57313c9706f.jpeg
Blocks and Fairleads for Clew…
Tack…
Sheet…
Installing Sheet Blocks…
Topsail Hoisted
Halyard belayed to pin #15 port…
Setting Rope Coil for Topsail Halyard…
Topsail Halyard Rigged…
Topsail Tack belayed to pin #10 starboard Fore Pinrail.
Fore Topsail Sheet belayed to pin #20 starboard.
Port Sheet and Tack must hang slack over Standing Rigging. IMG_4222.thumb.jpeg.a3077e282cf7aaa3916c9e7bdaaef64e.jpeg
Belayed to Port Pin # 9 and 19
Time to lay her on her side and put some wind in her sails. 😎 Fabric Stiffener does the trick.
IMG_4226.thumb.jpeg.ea177977dca5e4a6dfc225c10b859fa1.jpegIMG_4227.thumb.jpeg.531b813334b3bbe832f250f450533239.jpeg
Ready for the Main Sail and its Topsail.
Cheers 🍻
Edited by John Ruy
Great work, John!  you are SOOO close to being done. Looking great!
Gregg
That is a superb job of attaching the sails and making them look lifelike!  You are really raising the bar with your fine work.
Bob
Current build -- MS Bluenose
Future build - MS Flying Fish
"A ship is safe in harbor, but that's not what ships are for." - William G. T. Shedd
Main Sail…
Main Sheet Bolt Rope and Reef Lines completed. IMG_4313.thumb.jpeg.247ba12249c5fa670e61c8aab7ae1327.jpeg
Lacing of the Main Sheet to the Boom and Gaff completed.
IMG_4319.thumb.jpeg.011f03198f60e2a12a6823dcdd17fa1c.jpegIMG_4320.thumb.jpeg.58493be2e48f8ce8193a67959b273fbc.jpeg
Boom Tackle completed and belayed to Pin #27 Port.
IMG_4323.thumb.jpeg.73fa2b21204407bd50c38ced6db7329b.jpegIMG_4326.thumb.jpeg.fff3027a1af6cbc27dd4c30b89056b4f.jpegIMG_4327.thumb.jpeg.9979d71283e8a8410b85dbf3c2e6fe78.jpegIMG_4328.thumb.jpeg.8830dc482ef341977dc801b934f8c9fc.jpegIMG_4324.thumb.jpeg.a93a192eb690cb20d4fcc3b66bc05ac5.jpegIMG_4329.thumb.jpeg.ded151003f95289d7c2022b8753d890e.jpegIMG_4325.thumb.jpeg.9569b91cfdc32920e64be85a5a678c84.jpeg
Topping Lift Tackle completed and belayed to pin# 26 starboard.
IMG_4330.thumb.jpeg.db37405c35d55b602f8103ff3b78202e.jpegIMG_4331.thumb.jpeg.01f54f2b1661fc33de1b80fb93002d7d.jpegIMG_4332.thumb.jpeg.95467fe71897ab1967223043c15fa960.jpegIMG_4333.thumb.jpeg.e53719002eda832ea557d13e3ddec176.jpeg
Quarter Lifts Pendants completed Port and Starboard.
 Completed Foot Ropes Port and Starboard.
IMG_4339.thumb.jpeg.9a47d60f4981b41e088fec78d35b36a7.jpegIMG_4340.thumb.jpeg.ebb925c207e686f2fae3126a77b83d81.jpeg
Peak Halyard Bridles completed with Blocks.
IMG_4342.thumb.jpeg.80a20b304e6b8c07d6a9ec8288c30816.jpegIMG_4343.thumb.jpeg.da26792e352c8a8835f63c3e806aad99.jpeg
IMG_4344.thumb.jpeg.3fdcc7e9f716f4c6c2078e3d3ec1bc31.jpegIMG_4345.thumb.jpeg.6745162e049b52f5a87d5d1c10b554ae.jpegIMG_4346.thumb.jpeg.6e4106e004d1314ebf8044400827da71.jpeg
Boom and Gaff attached to the Main Mast and Main Sail Hoops Attached to Main Sail.
Peak Halyard Rigged.
IMG_4348.thumb.jpeg.081c5703f56dcef12a0938f1705cd708.jpegIMG_4350.thumb.jpeg.85b186af6c27c5bb62f82fd6fdf3bb04.jpeg
She has wind in her Main Sail.
Main Sheet Tackle belayed to Bitt on Starboard side.
IMG_4354.thumb.jpeg.8e48f284bf2a17b1d45be42e9c8cc72f.jpegIMG_4357.thumb.jpeg.394557e63c72f5130623144d6b5b5a47.jpegIMG_4356.thumb.jpeg.3363497c143adf3407a8854113a036dd.jpegIMG_4358.thumb.jpeg.88a2fb99eb678094433c2ee86b5b9bce.jpeg
Quarter Lift and Lazy Jack Line installed.
IMG_4373.thumb.jpeg.e7f10244eb83066b17a3e7ecf66439d6.jpegIMG_4374.thumb.jpeg.d049d856682a4bb16e82b4cef2e0462a.jpegIMG_4375.thumb.jpeg.3051e0f57e5bfe62b99853a936b777ae.jpegIMG_4376.thumb.jpeg.0e86f615a932bf058c9cebec7dc6a4df.jpegIMG_4377.thumb.jpeg.70740a2baed7626fa232392f5b91f2db.jpegIMG_4380.thumb.jpeg.599bf1a98e88c2ddcbf05d1675e8948e.jpegIMG_4381.thumb.jpeg.048ce5ebf37ac516df32e19190d97149.jpegIMG_4391.thumb.jpeg.3ef7c31618e89de201ed013111bb1ac6.jpegIMG_4392.thumb.jpeg.ff723370f346f220f12ac0e522213314.jpegIMG_4393.thumb.jpeg.18490b884d3b0ce1cc1d7ea85fecb0cc.jpegIMG_4394.thumb.jpeg.ec9e926597a4cf064f34709ff83a6b54.jpegIMG_4396.thumb.jpeg.1d61075490c3f875e02a44a552f282a4.jpegIMG_4397.thumb.jpeg.33337b4ce949519f98cc69828228276f.jpegIMG_4398.thumb.jpeg.f1fc03e2b4f21445d999945989a8eaf1.jpegIMG_4399.thumb.jpeg.69d91c7e92fe015478e8f97dac5538ba.jpegIMG_4400.thumb.jpeg.81877b9403d1b86aabcd84e5a5fa936c.jpegIMG_4401.thumb.jpeg.ee0038ab26a209bb2d140d61dcfda71d.jpegIMG_4403.thumb.jpeg.163522696b5bdd85d92ded2f25ee194d.jpeg
Quarter Lift, Peak and Throat Halyard Tackles installed and belayed. image.thumb.jpg.27dcb3a164f237d1c600998a4b4f7e12.jpg
Onwards to the last Sail, the Main Top Sail. Steady as she goes. 🍻
Edited by John Ruy
Sails are looking really good, John!  Soooooo close to being done! 🏆
Not sure I saw it in any of your recent pictures, John.  When you get to actually rigging, for instance, your main gaff and main boom (with sail) to the mast, what are you using to hold them up in place while you connect to the mast?
Again, great work, sir!
Gregg
Thanks Gregg,
As for holding the Gaff in place while tying the Hoops, I simply use some rigging from the Gaff to the top mast to temporarily hold it up then I rig the peak halyards after the hoops are connected.
John
Main Topsail…
IMG_4411.thumb.jpeg.009bb814ddcf9ed5bdefbdc0214b6492.jpegIMG_4412.thumb.jpeg.85f5112c93ed84c424fc130aa662f42d.jpegIMG_4413.thumb.jpeg.c1c5cd5f6a0642d2457383167be0b575.jpeg
Bolt Rope, Halyard, Tack and Sheet lines attached.
IMG_4414.thumb.jpeg.89d918e806cab7b5f19bfd93ecd54032.jpegIMG_4415.thumb.jpeg.fc3c6caf547d7d67fb498e2977b87481.jpegIMG_4419.thumb.jpeg.214259660f7ae425a0f4e13e211d65a1.jpegIMG_4420.thumb.jpeg.0c0d2e932db794a193866aac16a2c722.jpeg
Clew Line attached with fair leads and blocks.
IMG_4421.thumb.jpeg.b8468c1e6735bcd491f3475436b5dee2.jpegIMG_4423.thumb.jpeg.025b161fe26ed1eed28b5c39530a510c.jpegIMG_4424.thumb.jpeg.91ffe6297d82a0a81e5eb962d404cb88.jpegIMG_4425.thumb.jpeg.e01b705fb566572bc40e22bb48b068a4.jpeg
Mast Hoops attached…
Laid her on her side to spray Fabric Stiffener on the Main Topsail.
Clew belayed to pin# 33 Port..
IMG_4434.thumb.jpeg.9a99754eadacac9c66f1d71101486fb4.jpegIMG_4435.thumb.jpeg.d2565a8aac07dd8520d20443d9533f53.jpeg
Main Topsail Halyard belayed to Pin# 37 Port.
IMG_4437.thumb.jpeg.50714f4cc8fae509e731436cbe99f884.jpegIMG_4438.thumb.jpeg.b58f896af720019874cb2cc759725437.jpeg
Main Topsail Tack belayed to Pin# 24 Starboard.
IMG_4440.thumb.jpeg.e29e53b1e7b8d561a585e1446211966a.jpegIMG_4442.thumb.jpeg.8800d9e437cc60c5712f33d8dcbc7dbb.jpeg
Main Topsail Sheet belayed to Pin# 32 Port.
One more application of Fabric Stiffener using a hair dryer to stiffen the wind into place. 😎
IMG_4446.thumb.jpeg.138fad85a91ac5f9a89adf2d2289f56b.jpegIMG_4447.thumb.jpeg.31a6b6c7de85019179e1b72f84f7a993.jpeg
Almost done… Here’s my final punch list.
1. Baggy Wrinkles
2. 1921 Canadian Flag w/halyard on Main Gaff
3. 1921 Nova Scotia Flag w/halyard on Main Top Mast
The drawings show a Flag Halyard on the Fore Top Mast. I’m not sure what goes there. Any ideas?
Is there anything I have missed?
Cheers 🍻
That is an awesome model!! Congratulations       :cheers:
Bob M.
                   WASA
                   USRC Harriet Lane
  Stunning and inspiring ... and very instructive for those who would follow with either Bluenose or Bluenose II !
Thank you… @Snug Harbor Johnny @Knocklouder @Dr PR @Glen McGuire
You guys and MSW are all my inspiration, every day.
Cheers 🍻
