5 minutes ago, realworkingsailor said:
Seems as likely as not, they would have simply extended the hatch coamings up through, unless they had no intention of using the after hold (which seems weird to me).
Andy
there is notning at all in that area to suggest the hataches are there, here is a tour guide of the after well deck
https://www.facebook.com/messenger_media/?thread_id=100002107592434&attachment_id=799897851150443&message_id=mid.%24cAAAAAHArC6CJRTLo72DE-0-c14sj
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
Sorry, I don’t have Facebook.
Looking at photos available online, there are four cargo cranes surrounding the decked over well deck, so the hatches must still be there:
Andy
Edited by realworkingsailor
Quando Omni Flunkus, Moritati
USF Confederacy
good afternoon everyone
curtosy of the rattle can we have the Britannic in colour
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
the hatches on the above deck
May be an image of indoor
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
this is quite a kit you have here KEVIN........and a real neat subject to boot :)  very nice progress so far.......don't envy you with the PE though :blink:
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Kevin,  Not sure that I understand the “hatch question” but possibly this helps-
In cases where cargo holds were located below other spaces, access was provided by “cargo trunks.”  These were shafts passing from the hatch through the upper space into the hold.  Cargo would be lowered down the shaft and then manhandled into position in the hold.  I can understand why these might be necessary in passenger vessels where owners did not want to waste upper level spaces by filling them with cargo.
Roger
Roger good evening
in the link  it shows the covered over well deck, as part of the walkthrough experience of the Britannic, it however does not show any hatches or trunks,
the photo here however does show the hatches on the deck above
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Sorted it was a trunkway, i will attampt to put two in
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
out in the sunshine, im still messing about with the scratch built after deck, the size is about right now
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
thank you for comments and likes
day 14
lots of little projects going on
Portholes, i dont want to spend several hundred pounds sorting out the rivets and portholes, but i can make a couple of changes so some of the kit widows are being filled in to make her look a bit like the Britannic
internal decks are haing PE windows fitted
lighting is ongoing
filling windows
IMG_4739.thumb.JPG.be200cba2cd913168b2d73f2b744a060.JPGIMG_4740.thumb.JPG.99115d55fb8427b81e4ebe1317304631.JPGIMG_4741.thumb.JPG.cb5271d75d8b52ff41e43fca12cff9a4.JPGIMG_4746.JPG
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Good afternoon everyone
day 16
i not going to go on about airbrushing, other than i remember why i dont do it
preshading, well thats enouth of that
deck work continues, yet again KA dont put in where everything goes, and hence i missed some of trhe stain glass window detals, to late now
lighting conrinues, i will most likely be running three feeds
IMG_4761.thumb.JPG.3b93b3887e9357c25a4e1ae7aad986c2.JPGIMG_4762.thumb.JPG.c1425aa0d66536e3ac2f7323abd44cbd.JPGIMG_4763.thumb.JPG.10473c2942cd8b0973dd6f3dccec40cc.JPGIMG_4764.thumb.JPG.ab50e35f9f6a14aa6d658d444651e1a2.JPGIMG_4765.thumb.JPG.e07d448a1f7ba941d347060b4ab75ec8.JPGIMG_4767.thumb.JPG.7c5187e63246c483bf38aab1ed030154.JPGIMG_4768.thumb.JPG.9eb094e0b4ac245a5b35732ac60f6df6.JPGIMG_4769.thumb.JPG.cddde3fbdf08d8f2159930df179cc813.JPGIMG_4770.thumb.JPG.a2f6f9e5ac5513ef9a95e31e182c7664.JPGIMG_4771.thumb.JPG.87466b9a8bf0e9b7098892521dd338c3.JPGIMG_4772.thumb.JPG.c42cb6793f74a30afdcf6aae6c8949ab.JPGIMG_4773.thumb.JPG.b0fe76c36b93d8767a2e2548d6deec95.JPGIMG_4774.thumb.JPG.ceb52cccdac9875e02e3e6f1b4a9c26e.JPGIMG_4775.thumb.JPG.032c10cd4a6a6f7a551fdfeed73c2452.JPGIMG_4776.thumb.JPG.0fcacefc55937f9f103f90cf32dfa70a.JPGIMG_4777.thumb.JPG.9cdb5160362d9f2d73de895a7e62cbe0.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Britannic is just a few miles away from my second house in Kea. The depth is 125 meters. There is also another wreck in 70 meters a French liner converted to military transport the SS Burdigala.
Every year Britannic was inspected by a group of Belgian divers. One of them died cause of wrong gas mixture used during dive.
DAY 18
revisited the enclosed after deck and sorted the hatch truckways and the new 2nd class gymnasium
IMG_4797.thumb.JPG.cd83718882b1973d7039677ea8174211.JPGIMG_4798.thumb.JPG.f820171a83ef38e86bb7ad47add0cba2.JPGIMG_4799.thumb.JPG.bbd4f4c53cfc7a0d78a1d85578333937.JPGIMG_4800.thumb.JPG.94b91bbe171eb3b17e53438f0ad4acfb.JPGIMG_4801.thumb.JPG.477ba18f4b667318da5406d1cf9872c4.JPG
also on the top deck is a childrens play room this still needs work, im not happy with it at all
IMG_4783.thumb.JPG.fac5bb271bffee36f132ae0c520e5487.JPGIMG_4784.thumb.JPG.c144239c0dfc3a662d3f6d8a92bc0ce9.JPGIMG_4785.thumb.JPG.4e26212e71a75adad6865f5b43ece304.JPGIMG_4786.thumb.JPG.4cc1f8b17b170f861b3ac4f52971474a.JPGIMG_4786.JPGIMG_4788.thumb.JPG.529831cdf70c1b7695fc1d6af4adddd1.JPGIMG_4789.thumb.JPG.22d223b5025bf6ce932f396d8fe8b448.JPGIMG_4790.thumb.JPG.e731344dfdfaba51415bfe0768159ed2.JPG
i think some primer is required
IMG_4792.thumb.JPG.5268db6d3ed067ff0d7788482e1213a4.JPGIMG_4793.thumb.JPG.59e7f99791aae49ad67b4d7d55f3e933.JPGIMG_4794.thumb.JPG.5a2889134982e5d05e5fa98179320691.JPGIMG_4795.thumb.JPG.e1d5eb31062de20d2dd64c7251481413.JPGIMG_4796.thumb.JPG.17971970b29097412260a503a7da65ad.JPG
the primer has stopped the lightbleed
both sides of the hull are now with topcoats, been deliberatly left looking pants to ease the weathering (which is the same as i hate airbrushing)
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
2 hours ago, Blue Ensign said:
An interesting project and conversion Kevin, she's going to look magnificent when completed, the lighting will make her very special.
B.E.
loads more lighting to go in,  the kit comes with a 5vt lighting set, which on recommendation is discarded, however the power supply is a 12vt sytem with dimmer, i may obtain anr one which will give me the option to fully light her up like a christmas tree, but tone it down so it looks like the tree was still up in March
today i found out that she also had as well as the green hull line but green lighting along the upper deck
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
good evening everyone
day 22
over the weekend i did some photo etch and made up some of the winches and pumps
IMG_4829.thumb.JPG.13cae2eef2e89bceadf8fa9c66216ad7.JPGIMG_4830.thumb.JPG.3022587553c00bbae65bd5809c3c206d.JPGIMG_4831.thumb.JPG.d2ae42ab6b128b6ac9c395f998a2b1e6.JPG
then i revisited the preverbial pain, that being the after welll deck. i was getting lots of light bleed so it was all ripped out and resorted
IMG_4806.thumb.JPG.e499fb7b1cc142047ffd89077a5a886d.JPGIMG_4837.thumb.JPG.93bbe52c681fb7b5f5d9c81fa190a826.JPGIMG_4840.thumb.JPG.4ad2bc4aada6d3ddbddabf3ce8c4e2aa.JPGIMG_4843.thumb.JPG.4890830084c4f8f923326d219578af76.JPGIMG_4845.thumb.JPG.d55d87bcbfa53d0ef3c287845bfb422b.JPG
its better now, and the bulkheads dont glow anymore
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
lol i wonder what im doing on this site sometimes, i am full of ideas, just dont have what it takes to bring them to life
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thank you for comments and likes
day 23 forward well deck cargo hatches
the Britannic had a very different fwd well deck to the Titanic with raised cargo hatches up to the height of the focastle,
between these hatches are doors, so i am at present still trying to work out whats was in there, possibly access to ladders to the holds
titanic kit,
IMG_4847.thumb.JPG.cd0086c8f1f2f36641dd0334a56620dc.JPGIMG_4848.thumb.JPG.f9fff787aa0f12cac102c23fe7a27048.JPG
the hatch covers, and vents and winches are from the KAMK1 kit the rest is scratched
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
day 24 putting airbrush demons to bed
at long last i have sucessfully used the airbrush twice, and got decent results, i like Tamiya paints, i hate vajello primer
Hospital ships of the era were painted white and Military hospital ships were also identitified with green bands , i may have used too dark a green but it will be staying like this (for now anyway (not tempting fate)
Hospital ship - Wikipedia
a small amount of touching up to do
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
I am with you: TAMIYA paints are fabulous and very easy to spray. Just use 50-60% paint and 50-40% thinner and you are good to go.
Vallejo? I just cannot do anything good with them. Their primer is okay on plastic but a disaster on brass parts (Photo Etched).
I wish TAMIYA would have more colors.... especially for ships.
Yves
Excellent work with the sprayer  Kevin,   really came out  nice,     Vallejo  Surface Primer  is  ok  on  figures  as  it shrinks  down  onto the plastic, but its also quite  fragile  and soft  -  it scrapes  away too  easily,   and it leaves  a  slight  shiny  surface  that makes  colours  a bit difficult to adhere  to.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
good morning everyone
Day 24.5 (well its only lunch time)
we have red crosses x 6 and they all turned out ok
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
I agree  with Ken   - they have come out  really nice.
OC.
Current builds
Completed works.
7 hours ago, Canute said:
Nicely done. They look great. 👍
OC.
thanks guys much appreachiated, i did mess the other side up when masking, so sorting that out, basicly i masked it up but put the tape the wrong side of the mark, so the green line was to long and I never had a gap between the green and red
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
