Fabulous work Michael!!! I wouldn't feel bad about the small discrepancies in gun ports,the clearance between the cannon and port is TIGHT to say the least.If you haven't glued everything together yet,a solution for the axle pins would be to cut a small section out of the middle of the axles.This would enable them to sit tight against the wheels.As you have proper axle cutouts in the carriages,gluing the two halves together in situ won't be a problem.This adjustment will be invisible once the cannons are fitted to the deck.
Kind Regards
Nigel
Currently working on Royal Caroline
Hi Michael,
Beautiful work on your cannon! In perusing your log, I am repeatedly amazed at your continued attention to detail!
Good luck on finishing them.
Frank
Hi Michael,
just read through the whole posts concerning guns and carriages. They really look fantastic!
During the last few weeks, unfortunately, I had to solve some problems at home ... but now I am back again to follow your great work on the Wasa.
I like your choosen canons, they suit very well to the whole model. Even more I like your own carriages, and I wish you a lot of endurance for producing and adjusting all of them individually.
Concerning the four low gun-ports, I think your proposal is the best possible compromise and I am sure, nobody will notice this small difference to the real ship unless you tell it. The only other way would be to leave them away.
Looking forward to your next update.
Regards, Joachim
Joachim,
Hello again. Very happy that you visited. I have missed your own build updates and now understand. Welcome back. I hope that everything at home is again ship-shape for you. I appreciate your comments as well
Michael
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Nice cannons and carriages! Great detail work Michael.
/Matti
Matti,
thanks for your nice thoughts. I'm happy that you visited, I had not heard from you in such a long time. Very nice.
Michael
Under the table:
Completed:
Vasa-Corel -
Hi Michael, I admire the evolution, the progression in details...
I deleted my previous post. Sorry about my deleted question, I had missed your explanation, don't take this as negligence but to be impressed by photos and details... :)
Ferit,
OK (:-) may have missed it, but thanks for stopping by.
Michael
Under the table:
Completed:
Vasa-Corel -
Kind Regards
Nigel
Nigel,
Thank you for your advice. I have installed all of the axles so too late. Your, so simple but too "out of the box" for me, suggestion will stay in the memory bank for next time. And as always so much appreciate your posts and very kind thoughts.
Michael
Under the table:
Completed:
Vasa-Corel -
Just a thought Michael if you haven't had reached the 'gluing' stage.I dare say though,unless you had posted something,none of us would be any wiser.They cannons really do look fabulous.
Kind Regards
Nigel
Hi Michael,
Frank
Frank,
Thanks so much. I have seen some of your other beautiful ships, so coming from you this is a very nice compliment. These postings keep me trying to improve my skills (:-)
Michael
Under the table:
Completed:
Vasa-Corel -
Michael....... those cannons are awesome !!!!
Frank
Frank,
Thanks always appreciate your kind visits.
Michael
Under the table:
Completed:
Vasa-Corel -
Hi Michael
Great job on your cannons and carriages they sure do look super, you have out done your self on these,                                           ENJOY.
Regards   Lawrence
Lawrence,
Thank you. Its always nice when you visit. Appreciate your very nice thoughts.
Michael.
Under the table:
Completed:
Vasa-Corel -
Nice display Michael, I like Nigel's idea for drilling  the axles
Frank
It's one of those "Why didn't I think of that" sort of things.
Excellent work as usual.... :)
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
Hello Michael,
Your work is awesome and I follow it in silence.
Every day I look to your claims.
I don't know if this question was already asked but can you also tell me what is the size of the heads of the small nails (I mean the big ones).
Sincerely, Jadzo
Edited by Jadzo
Hello Michael,
Sincerely, Jadzo
Jadzo,
Thanks for your kind comment, and thank you for following my build. Very nice of you. Here are all of the nails that I have used on this build. I sourced these through Model Expo and Micromark. The third nail from the left is brass that I chemically turned to black. I hope that this is helpful.
Regards,
Michael
Under the table:
Completed:
Vasa-Corel -
Hi Mates,
Still working on those carriages.
Here is a minor update.  First pic. is of the upper and leading edge carriage metal frames after I chemically darkened the brass pieces. As I mentioned earlier each four piece set is specific a particular one of the 14 carriage.
I then glued all of the pieces. Subsequently realized that the black chemical process did not allow the glue to adhere to the carriages. I had not washed off each small piece for fear of having them go down the drain, so glued them directly. Instructions do say "wash off" Hmmmm
I then needed to scape off the glue sides to re-adhere the small parts. It would have been probably easier to paint them. Though I feared that over time the paint would peel off.
Next was painting the cannon barrels. I initially chose a water-based paint made specifically for airbrushing. BIG mistake. Paint would not adhere after drying. I knew of this potential but was rushing myself.
So after scrubbing off the first attempt at painting, I then used an enamel paint that needed to be thinned and was a bit messy at cleanup, but looks excellent.
Next was scraping the emblems to bring out their details.
Next steps will be to attach the cannons and add the upper restraining hinges, then on to the ropes/blocks. Again, thanks so much for visiting it is so appreciated.
Regards,
Michael
Under the table:
Completed:
Vasa-Corel -
Beautiful canons !! They look so realistic, well done!
regards, Joachim
My new Book in ENGLISH and GERMAN available:
"The colour blue in historic shipbuilding"
http://www.modellbau-muellerschoen.de/buch-en.htm
Current build   Amerigo Vespucci    http://modelshipworld.com/index.php?/topic/836-amerigo-vespucci-by-schiffebastler-mantua-model-scale-184-italien-sail-training-ship-build-1931/
See also our german forum for Sailing Ship Modeling and History:
http://www.segelschiffsmodellbau.com/
Fantastic job on those cannons !!
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
Nice cannons.I probably should have spent more time on my carriages - I always seem to get in a hurry on some things.
current build - HMS Vanguard - Model Shipways
Absolutely stunning Michael!!!!!!!!They are a model in there own right!Excellent work.
Kind Regards
Nigel
P.S.you can just put the small parts in a bowl of water and stir to rinse them off ;)
Joachim, Capt. Steve, Matti, Mark, Dave, Nigel, Frank, Lawrence, B.E. Thanks for all of your very nice remarks.
And a big thanks to all of you who clicked Like This, so nice of you to also let me know of your appreciation. I have been away for a few days and plan on getting back to the shipyard this week. Again thanks.
Regards,
Michael
Under the table:
Completed:
Vasa-Corel -
