Outstanding work Michael! You have inspired me to do more research and see what I can do when it comes time for the masts on my Couronne. Once I have seen those and how great they look I don't think I could be happy with a plain mast anymore.
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
Thank for your kind posts.
Frank, from a previous post: Also for the metal straps Ferrari parts have come to the rescue. Vinyl self-adhesive strips that are leftover from an F40 that my son and I built from a 1/12th kit. We had fun. I will use that as well as those small cleats at the wrap ends. - Never throw anything away right (:-)
-E.J: Thanks so much. We do indeed all learn from each other. I'm still "stretching" as a learner, but it's so nice when something that I may have done is inspirational for someone else as well. Your work is so excellent that your compliment is even more special.
woodo: Again thanks - nice to have you on board.
George: You're always so kind with your comments and your Clicks" (:-)
Regards,
Michael
Edited by md1400cs
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Ferit: Thanks for always dropping by and posting encouraging words. I have to assume, as also with most builders,  the last bits will be the flags.
Edwin : appreciate your visits and thoughts - Thanks
Working on rebuilding the mainmast lower platform. The one that I had started pre-building (same size as the foremast one) turns out is a bit too small. This one is easier, having struggled through the first two; now have a better grasp on how to make the small bits at a faster clip
MIchael
Edited by md1400cs
Under the table:
Completed:
Vasa-Corel -
BTW
I had thought why Hamilton who pays so attention to detail, had installed the radiant pieces on the crow nest so asymmetric. Can it be his indifference?! :-(
And then I just realized today that in the plans also, these radiant pieces are asymmetric... Great replica!...
I am afraid of that you will almost simulate the grains of the wood of the original Wasa :-)))
Really exceptional...
Edited by AlphaUrsaeMinoris
Best Regards…
Ferit KUTLU
Under construction: Frigate Berlin (Brandenburg Navy)
Hope: Frigate Wappen Von Hamburg (Brandenburg Navy)
Ferit, BV,
Thanks for your comments. Certainly appreciated. blush (;-)  --- Also thanks mates for the "likes" always a pleasure.
PS: Had I walked into this kit today after all that I have learned following other build logs, I would have done things differently with the hull planking as well as with the cannon framings.
Well the two under my table should benefit, i guess..
Regards,
Michael
Under the table:
Completed:
Vasa-Corel -
Hi Mates,
Have not posted in a while, Admiral has had, it seems like a book of honey do lists. So, in between, have been doing various detail bits before attaching the lower main shrouds.
Put together the rope knighthead that sits below in the upper gun-deck, along with its ropes, and block (thinking of re-doing that particular triple violin block to look more like that from the 1/10th) in the photo. Hmmmm??
Then worked on a kit block that needed some plastic surgery before being wrapped around the lower mainmast
Finished the main lower platform. I’m very happy with how the lower main mast came out - bit-by-bit moving forward.
To be continued…
Thanks as always for all of the nice thoughts, likes and just looking…
Michael
post-735-0-69627900-1463699168.jpegpost-735-0-59846700-1463699184_thumb.jpgpost-735-0-40477300-1463699197.jpgpost-735-0-61560300-1463699210_thumb.jpgpost-735-0-52124100-1463699226.jpgpost-735-0-37830700-1463699241_thumb.jpgpost-735-0-76226400-1463699254_thumb.jpgpost-735-0-10807800-1463699267_thumb.jpg
Under the table:
Completed:
Vasa-Corel -
Beautiful work, Michael !!
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
Hi Mates,
Thanks for the likes and the comments
Ferit, yes this bit is somewhat "not clear". The 1/10th and the museum's differ. I think that the museum just did a plain single wrap just for the visitor visuals. I then also think that the 1/10th builders decided to execute a more accurate representation of the actual block wrap. ??
In any case, I will use the 1/10th as my guide. I will, as I did for the mast rope wraps, use cleats to anchor the two ends of the ropes.
Though I also noticed in the 1/10th photo, (just below) - that there seems to be two versions of how the block was attached to the mast. 1) the photo you highlighted. and 2) the other having a loop, then a second rope used for the wrap. Though bothe photos seem to be taken at diff. build stages.
I think that I will use two simple cleats and just move on (:-) but, then I'm always changing my mind about things ha ha
MIchael
post-735-0-49843400-1463841370_thumb.jpegpost-735-0-12588400-1463841390.jpgpost-735-0-30028800-1463841404_thumb.jpg
Edited by md1400cs
Under the table:
Completed:
Vasa-Corel -
There is a shot from port side (highlighted by me)
and
a shot from starboard side at the photo in the last post.
Now it's clear for me after seeing starboard side.
Following the style of the 1/10th seems accurate... Don't change your mind :-) :-) :-)
Best Regards…
Ferit KUTLU
Thanks Ferit,
Will follow the 1/10th
Looked at, and tried to make a couple of blocks from scratch to better match the longer and thinner ones as seen on the 1/10th photo just below.
Too much work, so took the kit block; minor reshape, better articulated the “pulley” areas, and added some black bands. Along with a second hole drilled to simulate the top lateral pulley.
Those black bands I had mentioned in a previous post – they were from a car model. They were self- adhesive vinyl trim from an F40.
Cut the strips to size, and then coated the block with clear flat gloss to “lock” the strips into place.
Michael
post-735-0-10462500-1464051775.jpegpost-735-0-15116700-1464051798_thumb.jpgpost-735-0-92956400-1464051809_thumb.jpgpost-735-0-02776000-1464051822.jpgpost-735-0-19903400-1464051837.jpgpost-735-0-35678800-1464051848.jpg
Under the table:
Completed:
Vasa-Corel -
Dave, thanks for your nice posts always nice to hear from you.
Buck, touched by your thoughts as well. You've also been such a kind visitor to this log - (PS you have also inspired me with your amazing amount of precise details in your log) as always cheers
Mates thanks for the likes, always encouraging indeed.
Michael
Under the table:
Completed:
Vasa-Corel -
Every time you update I am again just amazed with what you have done. Fantastic work Michael. I should keep a log of how many hours I spend looking at your photos for inspiration and guidance for my own build.
-E.J.
EJ_L
Your post is so touching - thanks so much, I'm so appreciative, and very happy that you find areas of help to you here in my log. Our hobby is certainly reciprocal in nature isn't it. My skill set, and I still have much to learn, has certainly also been helped by following and browsing other build logs here as well.
PS: Your hull planking, for example, I would love to eventually be able to emulate  (:-)
PS: 2 Noted your colorful signature and copied your's the other day ha ha.....
PS: 3 Yes - I did join the NRG the other day (:-)
Respectfully,
Michael
Edited by md1400cs
Under the table:
Completed:
Vasa-Corel -
Hi Mates,
Frank, thank for your comments.
Thanks for likes, and dropping by (:-)
A few added small time consuming details, as I want to make sure that all needed items are in place before I attach the mainmast shrouds to their deadeyes.
Turns out that the pin rails that I had located at the quarterdeck were in error (first early photo). Fred Hocker said, “we got that wrong, those pin rails were added by mistake, it should have been kevels”
So pulled them out-did leave some scaring, and then put together a kevel for each side.
post-735-0-35573900-1464628778_thumb.jpgpost-735-0-36584800-1464628816_thumb.jpgpost-735-0-66602700-1464628835_thumb.jpgpost-735-0-36292900-1464628851_thumb.jpgpost-735-0-05262000-1464628871_thumb.jpg
Used black nylon fishing line so simulate the four mounting cleats.
Attached the served rope around the mainmast along with the triple pulley. Added a rope trim at the mast base.
post-735-0-04925500-1464629008_thumb.jpgpost-735-0-79598100-1464629106_thumb.jpgpost-735-0-64364000-1464629127_thumb.jpgpost-735-0-78557200-1464629160_thumb.jpg
Made up some single blocks for drilling into deck.
Changed the attaching rope to the box for the capstan winding bars. (Though I think their shapes and lengths are amiss)
Next need to;
Tidy up carriage ropes
Drill vertical holes for upper railing braces
Drill more holes for newly needed belaying pin locations
Make six fiddle blocks and shrouds for main mast stay.
Then I can proceed with the 18 shroud attachments.
Cheers,
Michael
Under the table:
Completed:
Vasa-Corel -
Are you sure you are building the same scale model from Corel or is this in 1:35 instead of the original 1:75.
I see details on your model I cannot dream of, so perfect looking to the same on my Corel in 1:75.
Jan V.
current build: Vasa-1628 Corel / Battle Station Mantua/Panart,
previous: Statenjacht / Cross section HMS Victory / diorama shipyard
Joe, thanks very nice of you - as always : cheers to you
Frank, Yes the Vasa is always coming up with changes as they "discover" more errors at the museum. Including the 1/10th photos below.
The knigntshead rails (just behind the mainmast has two versions); one with pins, and one without. I built mine without, so the railing is too thick to NOW drill holes for pins. It appears in one of those photos that the ropes are just wrapped around the railing. Its hard to really see details however.
Though the Corel sheets do indicate pin holes for both fore and main mast railings. Hmmm ??
JanV, So nice- thanks so much you are way too nice. So appreciated indeed.
Also thanks mates for dropping and taking a look - always appreciated.
Edited by md1400cs
Under the table:
Completed:
Vasa-Corel -
just spent a very enjoyable lunch break catching up on you log, thank you
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
