You're right David B. & Mike,
I cleaned up most of Constructo's cleats ( some were so bad they can't be cleaned up) and painted them. I'll let the paint dry while I'm snorkeling in Cancun.
Thanks
They look okay to me. Plus once you start putting lines on them they will look even better.
David B
I look at model kits this way, they supply the parts, you supply the labor and between the two, I hope to come out with an exceptable model. I have seen some high end models that turned out poorly as well as I have seen some less expensive kits turn out msome beautiful models. It depends on how well the model is constructed by the builder and finished off. I have discarded some kit materials and opted to either replace them with higher end fittings or make my own. A kit is only the starting point, it's up to YOU to make a beautiful model out of it.
I'm starting deck gun production. I had to make most parts from scratch with a very poor drawing and photo to guide me. I'm still making the barrel mount rod from coiled wire. Thanks to you all, I now know how to straighten it out. After I get this proto type together, I'll work on wheel design. I'm studying many different photos and drawings of deck guns to come up with a design that I think will look good.
Question?:
Does anyone glue their deck guns permanently in position?
I had to pin the two deck guns on my Virginia Pilot Boat since they slid all around the deck whenever I touched the ship. I can only imagine with 22 deck guns, my deck will look a total mess.
Rich,
I answered in your other post about this, but I think it's the de facto standard.  We definitely don't want those babies moving around.
Since the cannon carriages on the Mamoli Connie were metal I used a spot of epoxy under each cannon. I could not possibly have done any of the rigging on the cannon without first gluing the cannon firmly in place.
Edited by robnbill
Bill
Chantilly, VA
Its not the size of the ship, but the bore of the cannon!
Current Build: Scratch Build Brig Eagle
Completed Build Log: USS Constitution - Mamoli
Completed Build Gallery: USS Constitution - Mamoli
Here's my gun assembly line. First I have to straighten the coiled wire and cut it into 10mm pieces. Then I have to glue that pin into a the hole in the cannon. I made a measured marked "jig" on masking tape to place the two vertical gun supports then glue the cannons to it. When that is set, I glue the cannons on to a 10mm by 20mm piece for the platform. Then I glue the wheels that I fabricated out of "Q" tip shafts and painted plack. Then I glue the elevation wedge with a brass pin installed. Last I'll add brass rings for the rigging.
Here's a dress rehearsal for the first 11 guns. I'm doing it to check out the scope of the rigging and to do some touching up on spots I don't like. I want fairly good continuity down the line.
Full Dress Rehearsal!!      All guns in place.      Just looking at the fully armed model gives one pause at the lethal fire power of a close aboard broadside would have!  I wouldn't want to sail close aboard this ship with enemy colors flying.
Enough fiction....now to rigging the guns.
Rich, the carronades also had a ring at the top of the cascabel for the breech line to go through. The long guns had the breech line wrapped around the cascabel. I soldered rings onto each of the carronade barrels for this.
Bill
Chantilly, VA
