I started the TRITON cross section build as a first step toward scratch building.  Or as they call it here the "Dark Side".  The plans are very easy to follow, crisp and clean.  It has been a pretty steep learning curve for me.  Going from having most of the parts laser cut to having to cut and shape each piece myself.  Had some set backs but for the most part, progress has been in the forward direction.  I have postd a few pics with descriptions to cover my progress to date.
"I've told you a million times, don't exaggerate   ;) "
 Current builds:
  H.M.S. TRITON Cross Section by Bbrockel - Scratch Build - Scale 1:48
  US Brig Syren by Bbrockel - Model Shipways -Scale 1:64
Hello Bob,
A first step into scratch building. I envy you
As far as I can see you've made a good start. I will follow your progress.
I wish you good luck with this build.
Thanks for sharing and take care,
Anja
Those we loved but lost are no longer where they were, but are always where we are.
In the gallery: Albatros 1840 - Constructo
Hi Bob,
Sorry for not dropping by sooner.  Nice to see your log back here.
I miss your start up pics from the original log.  As usual, you're doing a first rate job.  I'll be following!
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
I like your framing jig setup. Nice.
Later 42rocker
Current Build -- Finishing a 1:1 House that I've been building for a while
Current Build -- Triton Cross Section
Glad to see this log back up and running.  You are doing a very nice job on the Cross Section and I hope to see the other Triton build logs back online.
Ryland
               - Nautical Research Guild
Hi Bob: So this is where you'er at, the DARK SIDE, very impressive work there Bob, have you given up on your other builds? Did you make the jig for your frames? it's a very good looking project you'er working on. I'll try to keep up with your progress, thanks for stopping by . talk at you later1
Frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Bob:
You are doing some really nice work. I like your right angle jig. That will be good to use on a fully framed model as well. Good job.
Russ
Hi Bob, Glad you've re-posted. As usual your work is top notch.
I'm happy to be able to follow along!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Thank you all for the very kind comments.
Sjors, I copied the gantry-style build board from Mike41 over at Model Ship Builder web site.  I've added the link to Mike's thread on building the build board.  Take a peek, it's pretty easy to construct.    http://www.modelshipbuilder.com/e107_plugins/forum/forum_viewtopic.php?5571.0
Edited by bbrockel
 Current builds:
I am happy that I can  see your pictures on MSW 2.0. She's coming out really nice.
Regards Christian
Hi Bob
Nice work. I like your idea of the extended False Keel to hold everything in place. I'll be watching your progress.
Ron
Ron
Current Build: H.M.S. Triton Cross Section 1:48
Why is it that I always find out the best way to do something is after I have already done it the wrong way? - Me
I like how you kept the false keel long so the you could screw it down. Great way to hold it. If I change scales and redo my first step then I'll make sure that I do the same. This is something that should be adding to the start of the plans for everyone to see. Looking forward to seeing more. Thanks for sharing.
Later 42rocker
Christian, Ron, Rocker and Grant.  Thank you all for looking in on my build and your kind words.  The idea for the extended keel to screw it down to the build board came from another member here on the forum prior to the "Great Crash".  I just borrowed it.  :rolleyes:
 Current builds:
Bob
Can't help it, your
"If at first you don't succeed, you need a bigger hammer"
Makes me think of the old chestnut of
"if at first you don't succeed, then don't take up skydiving"
Looking forward to more on your build.
Later 42rocker
A little more progress on the TRITON. Adding the floor planks, some of the hull planks and shaping and dry fitting the lower gun deck beams.  Little bit at a time.   :)
 Current builds:
Very Nice Bob. I really like the look of your wood. :)
Rusty
Bob,
it's looking good. You're right, a little bit at a time. All my screwups occurred whilst rushing things. There is a jig for doing deck beam rounding (from TFFM), if you're interested I can dig out some pictures. It does make life a little easier,
Regards,
Grant.
Thank you Rusty.  It's repurposed douglas fir (approx 50 years old, very nice to work with) from a remodel project in the house.
You bet Grant.  I'm always interested in new ways to do a task.  And pictures are a great help.  Thanks.
 Current builds:
Looking good Bob.very neat and clean.  Larry
With Age Comes Wisdom,I'm Still Waiting!
Current Builds:Syren.Triton Cross section.
Completed Builds: Virginia by AL
                           King of the Mississippi by AL
                           Constellation by AL
Bob
It's looking great. I like your clamps you are using. I will have to make some. Your planking looks great too.
Maybe it my eyes, but on the lower gun deck beam on the right hand side, it looks like the beam has a split in it. Does it? I zoomed in on the beam but it's still hard to tell. Just thought I would bring it to your attention.  :)
Ron
Ron, If you are referring to the second lower deck beam, its the paper template coming unglued from the wood, but no split.  Thanks for keeping an eye out.
Thank you Russ.  Just trying to keep up with your quality level of work.  I'm really enjoying your Biloxi Schooner build.
Edited by bbrockel
 Current builds:
Bout time you get this build log up!  Jk.  Great work.  It's really coming along.  Sounds as though you've made great use of research and used all the best techniques.  The quality of the build shows that it's paying off.
