This will be my second Vanguard kit. I have wanted to build this ship model ever since it was released. I will be building it for our new first grandson, Thomas Joseph. His nursery is a nautical theme so the completed model will go in there when he is older. I have to include a picture of the little guy. The sailer suit was actually his father's, our son, from when he was a baby.
Ok enough of that. I have unboxed the kit and started cutting out the bulkheads and keel. Pictures of the actual model coming soon.
Your grandson is very cute! I love that the sailor outfit his father wore was saved to be worn again by a new generation!
I've been reading through your build of the Bounty Launch as I start mine. It been very helpful and I'll be following this build as well.
Thanks EvanKeel. I will follow along with your Bounty Launch build. I really liked that kit too.
Just your typical shot of gluing the bulkheads to the keel. Of course everything fit together like they were made for each other.
I glued two of the lower deck sections to the bulkhead. Because there is a curvature to the deck, I used these modified clamps to hold them while gluing which worked great.
Looks like fun, and a great prototype. Neat legacy to start your grandson off with, too!
Thanks Eric and the likes.
I continue putting the frame together and this was the trickiest part - adding the base for the upper deck. It has to be bent just enough to get between the frames and those very fragile transom supports. I managed to get it in place and glued to the bulwarks and used some clamps to hold the middle of the deck sown while it dries.
The next step is to add those transom pieces, to protect those transom supports.
After adding the transom pieces, it was time to fair the bulkheads, add the stem piece, then add the gun port pieces. The gun port pieces had to be soaked then bent to the bulkheads. As per the instructions, I pinned the bottoms and clamped the tops to the bulkheads, let them dry overnight, then glued and pinned them back into place. I did the port side pieces first, and I now have the starboard pieces soaked and drying.
I am worried about where the aft gun port pieces are glued to the transom pieces, as this is a very thin gluing area and I don't see anything coming up that will help hold these joints. I did use medium CA to hold these joints which should help.
The gun port pieces came out pretty well but there were two issues. At the transom the gun port pieces were pinched in between the last bulkhead and the transom. I determined that I had not sanded the transom piece enough so it was causing the ends of the gun port pieces to be out too far. I carefully released the glue joints between them and the transom pieces, then used a Dremel sanding disk to reduce the width of the upper transom piece. When I re-glued the gun port pieces to the transom piece, I also put a spacer between them to push them outward a bit. When the glue dried the gunk port pieces came out much straighter. I am also not worried about that joint, as medium CA seems to hold it very well.
The other problem I had was that at the bow the bottoms of the gun port pieces were a little too far away from the first 5 or so bulkheads. The planking strips provided for the first planking are pretty thin so I was worried that I would sand through them getting them flush with the bottom of the gun port pieces. My solution was to use a thicker planking strip for the bow area of the first plank below the gun port pieces. This should give me enough meat to sand without getting too thin. I can also use wood filler in this area if I need to to fill in any gaps that might show up.
So the first planking has started. I measured each bulkhead using a tick strip to determine the number and width of the planks at each bulkhead. The planks need some tapering at the first 5 bulkheads at the bow and at the last bulkhead and transom at the stern. I tapered two thicker strips for the first plank at the bow and two regular width strips for the rest of the first plank, soaked them for just a few minutes, used a plank bender to bend in curve at the bow, then clamped them to the bulkheads to dry. Once they are dry I will glue and clamp them in place.
One plank down, many more to go.
I put about half the planks from the gun ports down, but then I decided to add the garboard strakes and plank up to what I had already done. Here are the garboard strakes being glued in place. I first glued the planks to the middle bulkheads using medium CA glue since I couldn't plank them to anything. I then glued the fore and aft ends to those bulkheads, which I was able to clamp.
Thanks Thukydides.
I planked part of the way up from the garboard strakes until I had a gap of about three planks left.
At this point I was again having to bend the planks a lot, so I decide I would add a drop plank in this gap. I added one more full length plank then the drop plank. You can see one on the bench in the next image. It still has a good bend through most of the length but fit pretty well.
And here it is being installed.
I have since cut the planks to fill the remaining gap on each side and am in the process of gluing them in place. I have also started filling in the low spots on all the planks with wood putty and will start sanding the hull when that is completed. Not the prettiest planking job but OK for the first layer. This will all be covered with the second layer, which will be pear. The pear strips are not as wide as these planks so I am not sure if they will be easier to bend and fit. I hope they will be but we shall find out soon enough.
I have completed the first planking. I filled the low spots with diluted wood putty then sanded everything smooth, then did that two more times to fill any remaining low spots. I used a Dremel to cut and sand down the ends of the planks at the transom. I also filed down the nail heads but left them in place. I think it came out OK for a first planking but the second planking has to be a lot better.
I then used the second planking strips, which are pear, to start planking the transom. These strips need to be cut and sanded flush with the first planks before I can start adding the second planks over the first.
I planked the whole counter and transom with the pear strips. I used vertical planks for the lowest section, but deviated from the instructions and used horizontal planks for the upper transom as well as the counter. Mostly this was an aesthetic issue for me but also it made this task a little easier. I used small files to clean up the excess plank lengths in the gun ports and rudder opening, and a Dremel with a sanding disk, files, and sanding block to sand the excess plank ends to be flush with the first planking. I also filed the back edge of the keel piece down to 1.5mm so the second planks with fit somewhat flush with the stern post.
At this point I am ready to start the second planking of the hull. I started marking off the hull for these planks which are 1 mm thinner than the first planking. I'll figure out the tapers at the bow and maybe the stern before I start. I also marked three bulkheads to use for a 3 butt shift as I will not be using full length planks for the second planking.
I started planking the port side of the hull. I am using a full length plank for the wale so I bent one to fit and used the laser cut marks on the bulwark to align it. I used medium CA to glue it on, a small section at a time.
Happy Father's Day to all you Dads out there.
Edited by usedtosail
Here are the first four planks on the port side. I have started tapering them at the bow and stern. I measured down 10 planks in the middle section, then used a batten to extend the line to the bow and stern. I only had to taper about the first inch and a half at the bow and inch at the stern. These pear planks take to @Chuck's edge bending technique really well, using only a small iron.
I finished adding the first 10 planks on the port side. These are not scraped/sanded yet.
I am now doing the same to the starboard side.
I guess I should call this build the classic Speedy kit, as Vanguard is about to release an updated version which is quite a bit different in construction.
I have been planking away on both sides of the hull. I added 10 planks to the starboard side, then added the garboard planks. I used a wider plank for the planks next to the keel as this will allow me to use an even number of full width planks down the middle of the hull. I then added five more planks down from the top of the hull on the port side, which is where I am as of today.
These planks cover all the area on the port side that won't be covered with copper tape. I will now add the remaining five planks starting at the keel and working up, so if the last plank is funky shaped it will be covered in copper foil.
On 5/11/2023 at 2:26 PM, Thukydides said:
Good job on the garboard.
I agree!   Too many times we see models with the garboard running much too far forward and up onto the stem area.
Allan
Edited by allanyed
Thank you Allan. The trick for me was being able to edge bend that second plank up enough to fit tight to the first one at the bow end. It was a fairly sharp bend.
I have completed the second planking on the port side down from the wales. I am really pleased with how this came out. I have some sanding to do but much less than I usually do.
Now to complete the second planking on the starboard side.
Thanks Sjors. The Conny took me five years to build. This one should be about a year, so yes a big difference.
I have completed the second planking on both sides. The starboard side came out much better than the port side. In fact, I think it is the best planking I have ever done. I am very happy with the result and will use the starboard side as the "show" side.
I now need to trim up the excess planking so I can fit the stern post, then scrape and sand these planks to smooth them all up.
Thanks Theodosius.
After my families' vacations here at the lake, I finally have some time for Speedy. I gave the second planking a final rough sanding. I thought I had done a good job planking but I still I had a lot of sanding to do and some filling of the seams with fine saw dust. I am ready to move on to the next step though.
Thanks mugje. It took a while to get there but I am happy with the result.
Moving on now, I removed the bulwark extensions above the false deck and sanded the excess down flush with the deck. I also sanded the excess glue off the insides of the bulwarks where I had glued the gun port pieces to the extensions. I then painted the inside bow and transom using a few coats of diluted MS Bulwarks Red paint. I cut the insets from the planked deck piece and lightly sanded it to remove the char but not the details, and gave it a coat of wipe on poly before I fit it and install it.
While waiting for things to dry I have been blackening the small PE parts, like the eyebolts and hooks. When I built the Duchess of Kingston I painted these parts with black paint, but I found that process very tedious. I can blacken each kind of part all at once with much less effort and the result looks nicer to me than the painted parts.
What kind of metal?  My personal favorite for brass is no longer made so I have gone to Birchwood Casey brass black and better still is copper instead of brass and liver of sulfur.  The latter can be applied with a small brush after the part is secured in place.  Dilute the LoS, apply, then rinse with clean water, and it does not discolor surrounding wood.
No matter the metal, it needs to be thoroughly clean.   An acid bath using Sparex or similar product followed by a good acetone and then water rinse works Handle with gloves, tweezers, or pliers to keep body oils off the parts before blackening.
Allan
I also use Birchwood Casey for blackening brass. I do use Sparex if I have solder joints to blacken, but for these I have been just soaking in Acetone for 10 minutes, rinsing in water, then 3-4 minutes in diluted blackening solution, then another rinse in water.
I fit the planked deck to the false deck. I only had to widen the slots at the transom to fit around the braces. I then used a stiff paint brush to brush wood glue onto the false deck, making sure to go all the way to the edges. I used clamps on the bulwarks to hold down the outside edges of the deck and weights to hold down the inner part of the deck. The slots at the transom were tight enough to hold that section down. I'll see tomorrow how this worked out.
Sorry to keep you all in suspense for a few weeks but I forgot to post his before we went on a 10 day vacation to Seattle and Alaska. The deck did glue down well to the false deck using the above method so now I can focus on planking the inside bulwarks. I started by running 10 of the pear planks through the thickness sander to even them out and remove the saw marks from the planks. I should have done this with the outside planks too. I also continue to blacken the PE parts.
