Thank you very much John,
Nils
Current builds
-Lightship Elbe 1
Completed
thank you very much Javelin,
I love old steam ships, and of course the riviting detail, knowing that it may be slightly oversized for that scale, but the rivited hull would loose its characteristic look, which I I like to see on the model. It shows up quite well, even through the painting. The riviting must be made out, also when the model is viewed in it`s casing from a meter away or so...
Nils
Current builds
-Lightship Elbe 1
Completed
 Nils, I came across this eBay listing I found interesting. The plate attachment is nicely done but sadly the hull shape is a bit whack. I've included the listing where all the photos can be viewed. They're pretty crummy and it's almost impossible to see the inside of the hull.
https://www.ebay.com/itm/145312092622?hash=item21d54691ce:g:k-QAAOSwH4ZlCid7&amdata=enc%3AAQAIAAAA8L8iKR6lE2Uf59SNQgTXtLrvv5KV8QrnXgchXEtJoOe%2FI4o9cVa6cv1vDgPi0PPJ6ERWXpo%2BVRnvdTwbtm41Y8P5fTryRrY1rbMptsS7dnvVhJ9QMWCsDy5O2mJgwNNiHUkTtlhUgEmqfPBKvRKykAd0R%2BLpozgKLYjUX5UKvMmhMSltddaq%2Fx24JzDMEH60dzLd9AL0HON69aSdKY9ALaSnSdipQUGPZm39fv9%2FlrjoX7lmTSHbrjkNDOPk%2FKPknmY0MW18821sEtrCa3%2B03NO76KFgHYkEoK6ViRwQS5m5Jne1W%2FdKAW2adSe0ugNE7Q%3D%3D|tkp%3ABFBM5sL5yoFj
Edited by Keith Black
Thanks for your input here Keith,
it looks like this has been an interesting sort of study for metal-plate riviting on a not further known or named dummy hull, in order to try out the process. The copper-plates seem to be real rivited and additionally soldered afterwards
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you very much Richard,
for looking in intensively...., and for your kind comment
yes, I use brass quite often as this is a nice material to solder
Nils
Current builds
-Lightship Elbe 1
Completed
Update
Made the rigging for the boats and for the cargo derricks. There are also hand-winches for the boats. The fastening points for the stays are set, I`m waiting for some ordered workable bottleneck-screws to arrive. The bridge still needs to be done.
Nils
all holds have supporting brackets
The cargo derricks are rigged
the boats have their own hand-winches (two per boat)
the derrick winches are rigged
Current builds
-Lightship Elbe 1
Completed
50 minutes ago, Rick310 said:
Great job!!
Rick
Thank you very much Rick
Nils
Current builds
-Lightship Elbe 1
Completed
10 hours ago, Jim Lad said:
She's looks great, Nils. Just to be pedantic, all the cargo gear rigging would have been wire rope.
John
Thanks John,
your words made me smile this morning, but who knows, perhaps someone one day will show me how it goes with wire ropes for these small winches.
The stays will be of tin galvanized steel rope.
Nils
Current builds
-Lightship Elbe 1
Completed
Craft stores carry stainless steel multi-strand beading and jewelry wire. I have some 3 strand and 7 strand 0.012 inch (0.30 mm) and 7 strand 0.015 inch (0.38 mm) and 0.018 inch (0.45 mm) wire.
At 1:87 scale these would be:
1:87 diameter            1:1 diameter
0.012 "/0.30 mm       1.0"/26.1 mm
0.015 "/0.38 mm       1.3"/33.1 mm
0.018 "/0.46 mm       1.6"/40.0 mm
Pros: It looks real and is very durable.
Cons: It is OK for straight runs, but it is VERY springy and I wouldn't want to try it with blocks or winch drums.
Edited by Dr PR
Phil
Current build: USS Cape MSI-2
Hi Nils,
I've been collecting various telephone and electronics wires. Some of them have tiny copper wires, but with a stainless steel look, inside. They go to less than 0.1mm diameter and can be turned into a single wire with a 0.2 -0.3mm diameter. I used a drill with something of a sliding weight on the other end to turn them. They are not springy as the ones Phil mentioned.
On the other side, I think the rope you used has a certain "wire" look to them and look very realistic. I doubt many people would notice the difference. We only notice because of the close-up pictures, so I'd leave it as it is. Wires are generally also greased and/or dirty on ships, so they don't really look like steel in many cases. From a distance they appear black rather than shiny.
Roel
Thank you very much, Javelin, John and Phil,
for your good advice with the making of fake wire. I`ll keep that in mind...., but meantime can also live with the greyish 0,7mm polyester rope, also used for the davits rigging.
I`ve just made the infeeds of the coal chutes for the bunkers, and acc. to Andy`s post (#137) and my post (138) they are situated (dryfit) on the boats deck near the funnel. Stb. side is a closed chute cover, and port side the cover is open with view into the chute. They may be shifted a bit, when the tube connections to the watertank are made
Nils
cover for the coal chute closed
and open on port side
Current builds
-Lightship Elbe 1
Completed
Nice find Cotrecerf,
thanks for sharing this
Nils
Current builds
-Lightship Elbe 1
Completed
12 hours ago, Retired guy said:
Deck is looking very good Nils lots of details 👍
Regards
Richard
Many thanks Richard, I`m pleased you like it
Nils
Current builds
-Lightship Elbe 1
Completed
I have simulated wire rope by twisting together strands of copper wire and then painting them in some dull silver colour. One can also get at a reasonable price silver wire down to 0.007 mm(!) diameter (which is used to bridge broken printed circuit connections in repairs, I believe).
It is difficult, however, to twist more than two wire together evenly. For simulating rigging wire, it should not be twisted too tightly, as in real wire rope the angle of the strands is less than for fibre ropes.
There is also some (expensive!) japanese fishing line in steel grey, which seems to be braided with four strands. I have not seen it in real life, but it may be worthwhile exploring: https://www.ebay.de/itm/284004752603?var=585466534836
Eberhard,
many thanks for your idea input here. I`ll have that in mind. Also the possible use of fishing-line (Japanese) material sounds interesting
Nils
Current builds
-Lightship Elbe 1
Completed
44 minutes ago, Veszett Roka said:
Nils,
Search for Litz, or Litze wire in electronics shops:
https://audioverse.de/produkt/21-awg-up-occ-wire-litz-wire
Usually they made from very thin, sub-0.05 mm wires, sometimes thinner than human hair.
Good point Vezett,
many thanks for your comment. The "Litze" is silver-coated, which is good for applying, but the seller recommends special caution when soldering, is nothing for beginners...
Nils
Current builds
-Lightship Elbe 1
Completed
This is to pass on my special thanks to all fellow builders with their kind recommendations for  scaled wire ropes for rigging purposes.
I have own good experience with using steel rope like the (meantime not any more common) remote wire control for model power planes.
This steel "Diamantlitze" is either  total 0,5 mm OD, 19 strand x 0,1 wire .....or total OD 0,25 mm 7, strand  x 0,1 mm. Both are galvanic tin coated.
I applied this very suitable material (50 Meters on the spool) for soldering for the stays and shrouds of my tallship-models Pamir and Gorch Fock, as those would be spanned and confrontrated with considerable pull-forces caused by the working bottleneck screws
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Update
before rigging the aft mast, I connected the tubes to the fresh-water tank.....
Nils
the stb. side tubing :
discharge to mach.room, winter anti-icing with bypass heater-spool from the funnel inside, and swanneck vent on top of the tank for tank ventilation
port side tubing :  filling tube from lower freshwater supply, discharge, local for boats deck with tap. Maybe I`ll also hang a small bucket near the tap
the two heavy front bollards with mooring rope for going through the bow front bulwark openings
Current builds
-Lightship Elbe 1
Completed
Nicely done Nils
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
thank you very much Keith,
I hope I`m achieving a good mix of the old 1918 Corsicana and the 1955 movie-ship Ergenstrasse.
I`m wondering wich nationality flag they were flying, as the  capt. had order to "break through the British controlled lines" and head back to Germany. in that case it would not have been wise to set the German flag anyhow.
In the movie the capt. set the German marine war-flag ( it was a civel ship though ! ) at the time the Ergenstrasse  was intercepted in  the Norway waters by the Royal Navy.
As a civel ship she must have been flying the official (between 1935 and end of WW2) german merchant ship flag, which is the general red backgrond with the white Hakenkreuz on it. In the movie the capt. held this in hands for setting but then decided to set the war-flag instead, like German battle ships were flying. I would like to set a flag to my model, but unfortunately do`nt know wich one, Any recomendations ?
Nils
Current builds
-Lightship Elbe 1
Completed
48 minutes ago, Jim Lad said:
Depends whether you want to go movie or more realistic, Nils. I' think I'd go for the merchant flag (being ex Merchant Navy).
John
Many thanks John,
I`ll take your opinion for more realistic as well. (official Merchant flag of those years)
The novel "The Sea Chase" by Andrew Geer of 1948 begins in your hometown in Sydney Harbour appr. two days before WW2 broke out. I saw this movie so many years ago , but still remember, that the captain ordered even to break down the wooden Lifeboats and everything made of wood on the steamer for feeding the boilers in lack of coal on his escape...
Nils
Current builds
-Lightship Elbe 1
Completed
