I wouldn’t describe your pace as “Little by little”.  You are making incredible progress.   I wish my build was moving as quick as yours.  Thanks for sharing your build log.
A note. I have found several part misnumberings. On page 29 Step 174 Part # 72 in the text should be Part # 73 as it is labeled on the MDF sheet.  On page 32 step 210 Parts # 246 and 250 in the text should be parts 252 and 253 as labeled on the 1mm wood sheet.
To make sure the stern panel had the 2mm clearance I used a 2x4 mm plank to keep things in line. The outer stern windows do align nicely outer pillars as described in the instructions.
IMG_6842.thumb.jpeg.d05c4244f9543199f910c3ad9cfe7191.jpegIMG_6841.thumb.jpeg.0acf7aadd0ea8f8b5b0fed1f59609e30.jpeg
Again clamps and more clamps. I measured out the points for the first plank/strake under the gunports then ran a line of tape to make sure looked correct then drew a line under the bottom of the tape to mark the course of the first second planking that also serves as the line for the first plank of the strake.
IMG_6851.thumb.jpeg.f2d022137bb15330cb5f85c2a81754e2.jpegIMG_6853.thumb.jpeg.f69cdcdd7bc71607e33e19cb924d7e23.jpegIMG_6852.thumb.jpeg.d378bf95db3fc4b15d329850bd9ce0cd.jpegIMG_6854.thumb.jpeg.e0d02dc09bf1b39041905d2a3786d554.jpegIMG_6850.thumb.jpeg.7fa94f173d50d205e7ee13d423961759.jpeg
That is it for today as I have to wait overnight for the bow pieces to dry out from being soaked and bent in to shape. Back to work tomorrow so things will be slower this week and I am on call next weekend.
Thanks for all the kind comments. Here is the work of the day.My dilemma is previous models usually use cyano glue at this stage which I did for the few upper planks., I glued and nailed the strake line (as in the manual photo) as it will be covered and makes it easy to identify. The manual states they used wood glue but not IMG_6857.thumb.jpeg.c0608b4b3b6ecea8c3533dc3e7e87fbb.jpegIMG_6858.thumb.jpeg.897c93588d1b76d2bdc88765041ec0c1.jpegIMG_6859.thumb.jpeg.a41dedb1a5da09453bf08daa8ede51c5.jpegIMG_6860.thumb.jpeg.14f620c921bdc9e141e30639d0798992.jpegIMG_6855.thumb.jpeg.21767554d0ef642c468d41fb6c8e91f6.jpegIMG_6856.thumb.jpeg.627ead67b472ab8b90d5fe14b4f5d5cc.jpegsure it will hold without nailing and clamping is impossible for most of this stage. Any thoughts out there?
I used almost entirely wood glue for hull planking as the CA smell gets to me.   But use what you're comfortable with.
i used a combination of pva and c/a
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Despite working the weekend, fortunately not to bust, I completed 4 more rows. Needed to put 2 stealers on both side to continue the curve but not easily seen. Sanding as I go first with 60 grit then 240. Once done planking will sand lightly with 120 to 240 to 320. Use some cyano and sand lightly to fill the holes/ gaps  for now.
IMG_6902.thumb.jpeg.741234a09afc2b1c77f3d2e597e04411.jpegIMG_6903.thumb.jpeg.a8b65939f98c157fe120fe2aae6bd22f.jpeg
IMG_6904.thumb.jpeg.79e5e6bd9a34707dc1265ffb47c5e993.jpegIMG_6905.thumb.jpeg.6b2efbe3b6bd36e3f7f789e9e162d4a2.jpegIMG_6906.thumb.jpeg.089906a9a21dc9fe09d62549022f58ed.jpegIMG_6907.thumb.jpeg.11d52bb75213176dfadceba5c2ca4565.jpegIMG_6908.thumb.jpeg.14979389a2106776e34a08997b18b3e1.jpegIMG_6909.thumb.jpeg.409d5301ebf3b5f72fcec5f77e75ada7.jpeg
Just catching up with your build - great progress (and I can't believe how fast you are, at least compared to me!). I was particularly impressed with your fairing - I've not tried palm sanders, but they certainly seem like a useful tool.
I look forward to following your log from now on.
Derek
Cheers, Derek
Current build:   Duchess of Kingston
On hold:              HMS Winchelsea
Previous builds:  HMS SpeedyEnglish Pinnace, Royal Yacht Caroline (gallery),
                            Victory Cross-section (gallery), US Clipper Albatros, Red Dragon (years ago!)
On the stocks:    18th Century Longboat
Foudroyant was wrecked about 30 miles from where I live. She was tethered to a pier when she broke loose in a storm and wrecked her.
Ongoing:
Well, the hull is done and sanded. I will rub a layer of filler later to get any small imperfections and resand but this is the first time a have planked a hull and got most of it done continuously bow to stern. Helpful hints from the community helped.
IMG_6924.thumb.jpeg.c91304d95a095a1b7bca180d63b5ba19.jpegIMG_6925.thumb.jpeg.5775e33d2a8a567ebbddb0bb123f896a.jpegIMG_6926.thumb.jpeg.6caf85b327d74e2f255b77cfd26ff711.jpegIMG_6927.thumb.jpeg.0caad25f15ebba5f89bff21af11d4f67.jpegIMG_6928.thumb.jpeg.6ee8f8da7511b23e6abfb9c437a4b6c7.jpegIMG_6929.thumb.jpeg.f363402ec404ae6e6fd3aa08dff86e22.jpegIMG_6930.thumb.jpeg.14a1c56be50aa9f8ee1dd9a9b7af4066.jpegIMG_6931.thumb.jpeg.35e346848a60b6053459b3b563d816c5.jpegIMG_6932.thumb.jpeg.fdda59b6b0f39beb903ea2b42ed3b49c.jpegIMG_6933.thumb.jpeg.e0c5620df1b1d1bacfdb7ab4c25b6d29.jpegIMG_6934.thumb.jpeg.bcc753c2b5acf256eee6e203256f13fc.jpegIMG_6935.thumb.jpeg.6cdfc2ea0845c10afb1a79a0ff08071f.jpeg
