I just finished a "stick and tissue" model of an F4-D Phantom jet in Vietnam camouflage. The kit is made by Dumas Products. They make a nice range of boat kits, rubber-powered aircraft kits, and also a couple of static scale aircraft kits like this one. The kit comes with a nice selection of light-weight balsa, vacuum-formed accessories, and four colors of tissue for covering. Since it will never fly I decided to cover it instead with iron-on Oracote, and since Oracote shrinks very tight I replaced all the stringers with much heavier balsa. Here's the frame before covering:
I air brushed the model with Vallejo acrylics, and used Silly putty to mask the camouflage. There are LOTS of YouTube videos that recommend Silly Putty, but I had a lot of trouble with it. Remember when you were a kid and used Silly Putty to lift images out of comic books? Well if you leave it on acrylic paint overnight it lifts some paint and leaves a darker streak. I had to repaint most of my camo. If you remove it immediately it works OK. Here's the paint job in progress:
The model is 1/25 scale and 28 inches long, basically "drive-by scale." It looks pretty good if you drive by slowly.
F4-Dfront.thumb.jpg.5030b7a39e408e5470d8475ec24df0f6.jpgF4-Dleft.thumb.jpg.67637b22e7a7eeee7e1b412f93a917ca.jpgF4-Dtop.thumb.jpg.67f75d2903ff823c1230b02d0740f4a1.jpgF4-Dbottom.thumb.jpg.9773d44519d23806636eaf9f0d9fdbaa.jpg
Nice, VERY Nice..... Difficult plane to build in Balsa & Tissue.....
Quote:
Thanks everyone. I built my first model airplane with my Dad when I was 8 so I've made a lot of them. I made a couple of model ships in my teens, but no more until I retired. The ships are usually a lot more challenging but it's all fun.
On 6/13/2023 at 9:22 PM, ccoyle said:
(I had to delete your tags, though. We don't use tags other than 'done' in this area.)
Thanks for keeping an eye on everything Chris! The site asked for tags so I put some in.
  • The title was changed to F4-D Phantom by rvchima - FINISHED - Dumas - 1/25 Scale
