Thank you Karen,   I wonder if the style on the museum model is atypical rather than a  more common design.   I can understand how the drawings were done by McArdle if he based them on the contemporary model.
Again, your workmanship is outstanding.
Allan
Edited by allanyed
In the French navy of that time it was lead braces that held the panes. ( see L'ambitieux  of  Jean Boudriot ) Perhaps the same for the English navy?
Le meilleur apéritif n'est pas forcément le plus cher, c'est celui qu'on partage !
Generally the largest panes at the time were no more than about 9" by 12" - often smaller. A molten ball of glass was spun into a disc. After cooling it was cut up into panes, so-called 'crown glass'. The central portion attached to the pontil yielded the cheapest piece, sometimes seen in old windows as the 'bullseye'.
As far as I understood, McArdle drew drawings from the museum model, and not from the modern one.
As I understand it, at that time, large-sized glasses could not be made. Therefore, it will be correct to make small squares on the windows.
Edited by KarenM
Beautiful work!!!   Can you describe a little bit about your carving techniques and what type of tools and wood your are using?   Where duplicates exist such as on the beakhead bulkhead and the wreaths around the ports, each piece looks identical to the other which is remarkable.
Спасибо Карин
Allan
All decor is made and boxwood. I made the body out of pear. I modeled the decor in 3Dmax, then cut it on a cnc machine. With my hands, I modified a little after the cnc machine.
When the decor was ready, I covered it with tung oil. The oil hides small problems in the decor. After 2 weeks, I covered it with bituminous varnish. I diluted the bituminous varnish very strongly with a solvent, then applied it to the decor with a brush. Almost immediately rubbed the decor on top with another brush. The decor turned out to be dark in the recesses, and light on the protruding parts.
