Karen, you do construction and carving work at an exceptional level, I would be happy if you could explain in detail the working methods in creating the ship parts as well as the amazing carving you create, so that we can learn from you and there is a lot to learn😀
Frames, bars on the windows I draw in autocad or in corel. Then I cut it out on a CNC machine from wooden dies of different thicknesses. I draw the decor in 3dmax, then cut it out on a CNC machine and bring it to the final with a drill. For guns I make a master model from wood, then I cast it from tin. Then all the copper is electrolyzed and then blackened with a chemical solution. It's so hard to describe everything in detail. If you have specific questions, write, I will answer.
I twist the ropes for rigging on a special machine, which was made for me according to my drawings. For tying blocks, always caged ropes. I also check the first shrouds and all the loops that touch the spars.
This build is not unfolding in real time, correct?  This is a progression of photos of a model you have already completed, yes?
I’m already uber impressed, but if you are actually building at this pace, I will be at a complete loss for words.
Karen, thank you for sharing your build photos with us.  Your artistry is stunning.  I hope you will consider posting more of your work.  Beautiful!!
Wawona59
John Newcome
Wawona59
John
Current Project:
Wawona Lumber Schooner
