Hello everyone, completion of the stern timbers.eZyWatermark_21-03-2024_08-36-40-6570PM.thumb.jpeg.de905f05ca980461510e9ce606e119cc.jpeg
eZyWatermark_29-03-2024_09-14-04-0420PM.thumb.jpeg.452c402c0c0889b523c7f432d1764977.jpeg
eZyWatermark_31-03-2024_10-03-15-5820PM.thumb.jpeg.a6785e17755332aa44b0a467e0cb21ab.jpeg
eZyWatermark_31-03-2024_10-04-22-0540PM.thumb.jpeg.4bff93eeabebcfafee743c8349890b43.jpeg
eZyWatermark_31-03-2024_10-05-24-1970PM.thumb.jpeg.27bf6e803ec5f3122dd13a2fc3af2828.jpeg
Greetings Tobias
Member of the:  http://www.arbeitskreis-historischer-schiffbau.de/
On the workbench:
Corvette La Palme (L'Amarante) from 1744 POF based on plans by G.Delacroix
https://modelshipworld.com/topic/32046-la-palme-by-tobias-136-pof/
LE ROCHEFORT - Harbor yacht from 1787 1:36 by Tobias (monograph by G.Delacroix)
https://modelshipworld.com/topic/34810-le-rochefort-1787-by-tobias-136-harbor-yacht-from-ancre-monograph/
Le Coureur - Kit from CAF with the plans from Ancre
https://modelshipworld.com/topic/29843-le-coureur-1776-by-tobias-caf-148/
9 hours ago, No Idea said:
Nice Job Tobias they are tricky parts to make.
Good morning Mark @No Idea, thank you. Yes, the side pieces are awful. The first time I tried Adrian's method, but I failed. Then I remembered your report and tried this, it was much better, but still not satisfactory. Somehow I can't draw well enough to get the same effect. So I went back to the method I tried with the small side pieces on La Palm. First cut out the curved shape and then the side profile. It worked very well.
Greetings Tobias
On the workbench:
Tobias in hindsight I should have used your method as it's far more accurate than the way I made these parts.  When it came for me to apply the planking to the dogs legs I had to thin them out to get the correct hull shape.  This pretty much showed my errors in the way that I made them.  I can see by the way that you have made yours you will not have the same experience as me.  I shall be using your method on my next build and thanks for sharing how you did these difficult parts.  Cheers Mark 😃
Hello Chuck @Chuck, thank you for your comment, much appreciated. I am following your construction of the Speedwell with great interest, as I plan to start it after Le Rochefort and La Palme. I bought the books almost two years ago and have already enlarged the plans to 1:36.
@giampieroricciRicci, thank you too for your comment, it is always a pleasure when you stop by my blog, see you in October in Evina.
Greetings Tobias
On the workbench:
Thank you for your comments and the likes received, always much appreciated.
The waterway has been made and the first planks have found their place on the deck. As Mark already mentioned in his build log, this is a bit tricky because they are twisted and have changing angles. Make decorative strips, measure the height and mark them with the help of tape.
eZyWatermark_09-04-2024_07-28-39-6590PM.thumb.jpeg.86f6ed851c66167eb15f245618dcf3a9.jpeg
eZyWatermark_03-04-2024_09-19-23-5800PM.thumb.jpeg.a5e02efb83e94406f218908332920841.jpeg
eZyWatermark_14-04-2024_12-56-35-8940PM.thumb.jpeg.393a02a9bd2c7b8493ba37e7914a6ee6.jpeg
eZyWatermark_14-04-2024_12-55-45-7260PM.thumb.jpeg.a1b8bf27ca3556edfb3c41a58232b65d.jpeg
eZyWatermark_03-04-2024_04-41-33-4740PM.thumb.jpeg.6c22bfef872cf4679acae0a4e4aa8847.jpeg
eZyWatermark_03-04-2024_04-42-29-2500PM.thumb.jpeg.5fe55739a035031892f69b0e6efdfdbd.jpeg
eZyWatermark_03-04-2024_04-45-58-8540PM.thumb.jpeg.059dff9f96bf2d7be53affb92046269d.jpeg
Thank you for your visit and see you soon.
Greetings Tobias
On the workbench:
Hello everyone, thank you for the likes. The deck is finished with the planks, I don't want to add anything else to give a good view of the interior. Testing the various structures, anchor winch holder, etc. everything is in place and fits perfectly. Next up is the nails, two rows are already done.
eZyWatermark_25-04-2024_08-48-08-9790PM.thumb.jpeg.53b0faf203d5b506d11154286bc97b47.jpeg
eZyWatermark_25-04-2024_08-50-05-9990PM.thumb.jpeg.542dd16cece7e95d1d03c6319d22e5d2.jpeg
eZyWatermark_25-04-2024_08-49-02-4520PM.thumb.jpeg.acb24f6ead34a391bf6d51ff95b5f267.jpeg
eZyWatermark_25-04-2024_10-13-02-0140PM.thumb.jpeg.0091d61c91d14ca7f4177f1003e46121.jpeg
Greetings Tobias
On the workbench:
Hello everyone,
the deck is finished and has all the iron nails in place, now it's time for the bulwark planks.
eZyWatermark_01-05-2024_02-02-11-9880PM.thumb.jpeg.18d6bd36adffc54cb841b3a06192857e.jpeg
eZyWatermark_09-05-2024_06-27-27-0330PM.thumb.jpeg.f4cf301ea12858c2db2c0aafe3e7ce23.jpeg
eZyWatermark_05-05-2024_10-02-29-9990PM.thumb.jpeg.a491a3525a0eed035cfcb118fa03e8a4.jpeg
Greetings Tobias
On the workbench:
Hello everyone, a few small updates from my harbor yacht.
eZyWatermark_16-06-2024_03-58-25-6060PM.thumb.jpeg.7bd4e18c9d3f56f5a44769187b0092cd.jpeg
eZyWatermark_16-06-2024_03-59-38-5030PM.thumb.jpeg.5243f1517c38779a922eafa61d605c34.jpeg
eZyWatermark_16-06-2024_09-10-48-6080PM.thumb.jpeg.98295ee47661e15f892f20d8e9fb15ea.jpeg
eZyWatermark_16-06-2024_09-21-54-2590PM.thumb.jpeg.2871bfcd1fc7c2d3607e8d0787291ac5.jpeg
eZyWatermark_16-06-2024_09-22-35-2290PM.thumb.jpeg.fb95b067e90af8f0d3ad94d5e82fdaaa.jpeg
Greetings Tobias
On the workbench:
Hello Albert, thank you and thank you for all the likes you have received.
A little update from the little harbor yacht.
eZyWatermark_10-07-2024_08-58-00-7440PM.thumb.jpeg.c7e7604845c04b51a55b7b3b92b34365.jpeg
eZyWatermark_07-07-2024_04-01-49-5410PM.thumb.jpeg.5b0e3991d46efb49139f40edff8a5dc6.jpeg
eZyWatermark_07-07-2024_08-18-26-7120PM.thumb.jpeg.ef3bb677a746fc5fe734c18129647047.jpeg
eZyWatermark_07-07-2024_08-28-11-7430PM.thumb.jpeg.91e09186a69ca747262619007c162018.jpeg
eZyWatermark_10-07-2024_08-54-59-2110PM.thumb.jpeg.9bec967f95bfcfedda1f7f219af560ac.jpeg
Greetings Tobias
On the workbench:
We continue with a small update, expansion of the rear area with the small beds and cupboards.
eZyWatermark_11-07-2024_09-30-59-1390PM.thumb.jpeg.18085abe4c34aac25e358f90ba73ddd8.jpeg
eZyWatermark_14-07-2024_08-40-27-3670PM.thumb.jpeg.a3adc53f4957b71400f72e6f81ad3641.jpeg
eZyWatermark_17-07-2024_12-32-06-8470PM.thumb.jpeg.827070360d1f8d9d5da2e35c5364540d.jpeg
eZyWatermark_17-07-2024_09-29-15-3600PM.thumb.jpeg.f729d75df1897c8638e70af21112e918.jpeg
eZyWatermark_17-07-2024_12-31-11-4800PM.thumb.jpeg.3679409b571694721e352060a1787b8b.jpeg
eZyWatermark_23-07-2024_07-33-44-0500PM.thumb.jpeg.b22b62f470e7a92bfa028c192c9296be.jpeg
eZyWatermark_23-07-2024_09-02-00-2670PM.thumb.jpeg.efee72eeef1469692a2d0afecc8859d2.jpeg
eZyWatermark_23-07-2024_10-05-15-6480PM.thumb.jpeg.8eb4f6a0522bed0b52a51cf97b09ebed.jpeg
eZyWatermark_28-07-2024_07-38-01-7970PM.thumb.jpeg.7c54a2122d0986c14c96a1e1e2f0e540.jpeg
eZyWatermark_28-07-2024_06-19-43-7370PM.thumb.jpeg.e4f37c469246b8846ef1cf56ae7bb017.jpeg
eZyWatermark_28-07-2024_07-33-35-5510PM.thumb.jpeg.7cc6b40b59dae4f1d82c1966f2bbf4a9.jpeg
Greetings Tobias
On the workbench:
Hello Mike, thank you for your nice comment, your work is also wonderful and precise.
Now a few smaller details that are very time-consuming.
eZyWatermark_05-08-2024_09-33-03-6540PM.thumb.jpeg.987816380c3ad4c51e4395458104c422.jpeg
eZyWatermark_05-08-2024_11-28-54-5050PM.thumb.jpeg.caec0a9d9f74bcd686f922c3650e6a7a.jpeg
eZyWatermark_09-08-2024_10-39-00-5480PM.thumb.jpeg.3daf347d4eaa9751a54492674b2ec28d.jpeg
eZyWatermark_11-08-2024_07-51-48-5450AM.thumb.jpeg.a1099ae858f2fdf99633a35533036607.jpeg
eZyWatermark_14-08-2024_07-24-12-4600PM.thumb.jpeg.9b5982e9dc271417f4dfd60467da2639.jpeg
eZyWatermark_11-08-2024_07-47-27-6830AM.thumb.jpeg.012a1598fd36ed852a23f94290136aad.jpeg
eZyWatermark_11-08-2024_07-49-04-7580AM.thumb.jpeg.e486be176d818f680dd1c7a816f774aa.jpeg
eZyWatermark_14-08-2024_08-58-19-1360PM.thumb.jpeg.7acc4fa9fde35c214b8c54acaea64c39.jpeg
eZyWatermark_14-08-2024_08-59-13-9550PM.thumb.jpeg.bb6957317492288a3e0d795e8e3ddf95.jpeg
Greetings Tobias
On the workbench:
Good morning everyone,
the work on the Le Rochefort is coming to an end. A few small things will be done in the next few days, but nothing earth-shattering before the summer break begins. The Admiralty and yours truly are heading south and we will spend two lovely weeks on the coast of Croatia. Now a few final pictures, this time in original size with all the parts made so far and shown dry on the ship. This will also be the construction stage with which I will attend the international meeting in Evian in October. What still needs to be done after the holiday is the construction of the transport and exhibition showcases. I would like to thank you again for all the comments and likes, but also for the odd tip and the odd criticism, which is just as important as praise.
eZyWatermark_18-08-2024_10-10-47-3180AM.thumb.jpeg.ce3b6b9b92587862300000f8f7284a72.jpeg
eZyWatermark_18-08-2024_10-12-02-9110AM.thumb.jpeg.2bbcfad87b6c90fb8128f4b5586062f4.jpeg
eZyWatermark_18-08-2024_10-15-07-2330AM.thumb.jpeg.4d29babf43e5bd197819b835a96c3c0d.jpeg
eZyWatermark_18-08-2024_10-16-15-8170AM.thumb.jpeg.349616d01971262aa72339112c439ebe.jpeg
eZyWatermark_18-08-2024_10-16-48-9360AM.thumb.jpeg.1ab80d8a0ab6a06599f50564fccdc967.jpeg
eZyWatermark_18-08-2024_10-18-02-1570AM.thumb.jpeg.2dc3f0830725d48e2c7d6696db80797c.jpeg
eZyWatermark_18-08-2024_10-21-03-6140AM.thumb.jpeg.364d81d7093ae10c6df8d0334fc67435.jpeg
Greetings Tobias
On the workbench:
On 8/18/2024 at 1:01 PM, druxey said:
Enjoy your holiday! Both models look very nice indeed.
On 8/18/2024 at 1:15 PM, No Idea said:
Have a great holiday Tobias
Hello Durxey and Mark, thank you.
Greetings Tobias
On the workbench:
Good morning colleagues, the holiday was too short as always but that's life. Now to Le Rochefort, the whales have been installed, the port side has also been planked and the captain's cabin has got its doors. I would also like to thank you for your visit, the comments and your likes.
eZyWatermark_19-09-2024_09-34-10-5850PM.thumb.jpeg.727562a0b9ed9a15bcd2fc01c5a844d0.jpeg
eZyWatermark_29-09-2024_04-43-45-8880PM.thumb.jpeg.1690b77d8d21635243740955ea9ea925.jpeg
eZyWatermark_29-09-2024_04-46-29-3160PM.thumb.jpeg.5223dac95c424a61faf8334a4d92cf84.jpeg
eZyWatermark_04-10-2024_02-23-43-3490PM.thumb.jpeg.653353967918c579c238b84865e93d8c.jpeg
eZyWatermark_04-10-2024_02-22-21-0170PM.thumb.jpeg.7cfeb3448121341606c15c2be5bb9b42.jpegeZyWatermark_04-10-2024_02-21-35-4890PM.thumb.jpeg.459b93d3412d209cba82a2f1ead7792e.jpeg
Greetings Tobias
On the workbench:
Albert and Mustafa, thank you for the encouraging comment and everyone else for your likes. This weekend I was visiting France with the German delegation and was able to take part in a great meeting with my French colleagues. Here are a few impressions.8b29fae3-c96d-4fc8-b9b9-d36d25b27881.thumb.jpeg.5f406d6b3ba1af44d20c89f6942312f5.jpeg
Greetings Tobias
On the workbench:
  • 3 months later...
Hello everyone,
I have very little time at the moment as I am renovating the lower floor of my house. But every now and then I do find myself drawn to the workshop. Here are a few progress pictures.
eZyWatermark_09-02-2025_03-13-25-3630PM.thumb.jpeg.6d3b6da307ad5dfcb69bf1745f131273.jpeg
eZyWatermark_09-02-2025_04-45-26-1050PM.thumb.jpeg.7b513d31063cd17bf1cbfef56e2fa362.jpeg
eZyWatermark_09-02-2025_09-41-20-1560PM.thumb.jpeg.a14d42079161409e1f96a8ed80e79a8b.jpeg
eZyWatermark_09-02-2025_09-43-21-2680PM.thumb.jpeg.dbab1dda8f3c74a7ae522344fafbf43a.jpeg
I looked at the plans again and noticed that the planks seemed to be overhanging. @G. Delacroix was able to help me and confirmed it. So I dismantled the first two planks and replaced them.
eZyWatermark_10-02-2025_07-48-13-2940PM.thumb.jpeg.0f19a1855804fdb225a5f9ad8c0e6b1b.jpeg
eZyWatermark_13-02-2025_09-49-14-6690PM.thumb.jpeg.d599fa1edca3b3fa55ce40a81b80d7dc.jpeg
Edited by Tobias
Greetings Tobias
On the workbench:
Thank you for your interest. Also to everyone else who left a like.
Just a small update with an attempt to implement what is shown in the plans.
eZyWatermark_14-02-2025_08-24-54-7020PM.thumb.jpeg.36c8999a4c91cc6b90a38f3da8438b70.jpeg
eZyWatermark_19-02-2025_09-59-22-0460PM.thumb.jpeg.30fafe6e1c0f24d3ba2b2a6380d85309.jpeg
eZyWatermark_14-02-2025_08-22-38-3220PM.thumb.jpeg.2b41a5a26a94fcd1cad5d3f75eaf819c.jpeg
eZyWatermark_19-02-2025_09-57-36-6460PM.thumb.jpeg.c5d70c7e8471d8aa5a62dac14a34ca37.jpeg
eZyWatermark_14-02-2025_08-23-19-5590PM.thumb.jpeg.3a4bbe085288139049331b7c52f3b4f8.jpeg
eZyWatermark_19-02-2025_10-00-08-8790PM.thumb.jpeg.3a66fdf43d6a04a7d6bae79229437688.jpeg
Edited by Tobias
Greetings Tobias
On the workbench:
