After finishing my 2+ year HMS Victory project, I had planned to take some time off from modeling and pick up again when I returned from a vacation trip in mid-September.  But I find myself getting antsy for a project, so here goes . . .
I picked this model because I wanted something simpler after the complexity of Victory -- and something without ratlines!
This is a Dumas model, and based on a couple of other Dumas kits I've built, it will require something of a mental shift from the construction of European kits:
  • First and foremost, everything is in inches!
  • The hull is expanded PVC over a wood frame
  • Dumas uses styrene strips for some finish items where other kits would use wood
I've included some "what's in the box" pictures.  You can see one of the PVC sheets.  Also some pictures of the manual and accompanying drawings.  Dumas has really excellent detailed instructions with step-by-step drawings.
Finally, looking at this kit and also looking forward in the instructions for the Amati Bismarck, which will be my next model after this, I've realized that I'm going to have to do some spray painting.  I have developed an aversion to spraying because it's too cold here in the winter to do it someplace like the garage, and the "backspray" mist gets all over everything in my workshop.  So I built the "spray booth" shown here (it's on its side in the pictures), with a small fan installed in the rear.  I've tested it, and if you put a piece of tissue over the fan, it acts as a filter and the fan draws out the spray mist.  We'll see how it works in practice.
Now  on to the kit.  For anyone who follows, hope you enjoy this one.
Regards,
David
David Robinson
Boston, MA area
Completed:  Constructo J.S. Elcano, Artesinia Latina Sanson, Dumas Mt. Washington, Bluejacket Nantucket, Amati Revenge, Artesania Latina  King of the Mississippi,
Amati Grand Banks Heritage 46, Amati HMS Fly, Amati Titanic, Dumas Chris Craft Commuter, Mantua Cutty Sark, Mantua Bruma, Kolderstok Batavia, Vanguard Models HM Cutter Alert, Caldercraft HMS Victory, Dumas USCG Fast Response Cutter
Currently Building:  Amati Bismarck
I'm a Coast Guard veteran so I'm always excited to see CG model being built. Unfortunately, there aren't many CG models in production. I have a copy of the out-of-production model for a CG 40 foot Utility Boat by Dumas that I hope to build someday since I was the coxswain on one them many years ago at the Captain-of-the-Port Los Angeles/Long Beach Station.
Will you be making this as a static model or an RC model, David? I'm looking forward to following along. Good luck!
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Bob:
I'm glad you'll be following this -- and I hope I build her in a way that honors your USCG memories.
I'm going to build it as a static model.
Regards,
David
David Robinson
Boston, MA area
The hull construction on this model is really different from the typical keel and bulkhead structure of plank-on-bulkhead ships, and I thought it might be interesting to describe it.
You have to come up with a "building board" that's at least 40" long.  I used two spare melamine shelves that I attached end-to-end.  I'll repurpose the smaller one as the base once I'm done with the board.  You mark the building board with measured lines.
Then you build the frames from mirror image pieces buttressed with wood strips.  One pictured here.
What are called "sheers" are assembled (4 pieces to a side) and laid out on the measured lines, gluing them once everything lines up.  Then I used tape to keep them in place while I marked the positions of the frames.
You can see the lines for the frames across the building board.  Then you glue the frames to the board -- the rear three are shown below.  Yes, glue them (!), and after the hull is built and the PVC sides are on, you knock them loose with a putty knife.  Took a lot of care to make sure the frames were dead perpendicular to the board as I glued them on.  Used a lot of CA accelerator.
Once all the frames are glued on, you slide in the 39" long sheers, and assuming they fit, you glue them.  I took a lot of care on the measurements, and so I only had to enlarge two sheer slots on one side to get it all to fit.  I was pleasantly surprised at how well everything lined up and came together.
Then the keel goes on, and the hull has taken shape.
Next step is to add stiffener strips to the hull, and I'll post another picture when that's done.
A nice fun change from the more familiar hull building process.
Regards,
David
David Robinson
Boston, MA area
Looks like a very distinct project; I'll be interested to follow along. I strongly considered joining the Coast Guard as a youngster but life took me a different direction.
Now all of the hull frame stiffeners are installed.
Regards,
David
David Robinson
Boston, MA area
Great explanation of this unique building format, David. It seems that you'll need to have a gentle touch when cutting the frames loose from the building board to prevent damaging them. That superglue is strong stuff!
Bob Garcia
Current Builds:
Some sequence issues relative to the instruction book sequence.
First, to Bob G's point about knocking the feet loose:  I used a palm sander to smooth out the hull, and the vibrations popped the hull right off the building board with no damage.  The instructions have it staying stuck to the board for the hull sheeting steps.
But having it free is good news for a couple of reasons:
  • If you look at the picture below, I'm holding one of the side pieces in place by hand, and as you see, it extends up past the sheer to form a bulkhead at the bow.  When the frame was on the building board, the point of the bow was right down on the board, so adding that side piece with the boat stuck to the board would not have worked.
  • Second, as the picture shows, with the side piece extending up past the "feet", if those go on ahead of removing the feet, which is what the instructions say, then sawing off the feet on the forward part of the ship would be really difficult with that bulkhead in the way.
So I have taken the feet off now, before installing those mid-boat to bow side sheets.  They came off pretty easily.  You can also see the rear side sheets already installed.
I don't find having the boat off the board to be a problem -- in fact it's a blessing.  I have a foam cradle which helps me to hold the boat steady, and because I can now turn the side I'm working on to the most convenient angle, it's much easier than it would be if the hull frame was still attached to the board.
Regards,
David
David Robinson
Boston, MA area
I'm surprised, Don, that the frames came unglued simply from the vibrations from the palm sander. Generally, at least in my experience, just a tiny drop of CA creates an extremely strong bond that is difficult to break free. Do you think that the CA didn't bond well with the melamine boards? Regardless, it sounds like it worked out for the better!
Given the issues you pointed out regarding the side bulkhead pieces, would you recommend not gluing the frames to the building board if you were to do it again?
Bob Garcia
Current Builds:
Bob:
I think the frames popped loose perhaps because of the melamine, but also because they are very thin, so any lateral force on the foot is going to twist it a bit and loosen the bond.
Yes, I would absolutely glue the frames.  It's the best way I can think of to get the frame measurements right, and to get the frames absolutely vertical.  And all of that is pretty critical when you start working with the hull sheeting.
But I'd pop the frame off before starting the sheeting.
Regards,
David
David Robinson
Boston, MA area
Rough sheeting of the hull is done.  I say rough, because as you can see, the sheets don't fit perfectly and there are a lot of gaps.  Fortunately, Dumas uses Bondo putty to deal with their styrene, so I'll be doing some sanding and puttying to clean up the hull.
One note:  sawdust falls to the floor; some gets on you even if you are wearing a work apron, and a vacuum cleaner takes it right off.
Styrene seems to be attracted to clothing, and it's hard to get it all off.  So I have taken to wearing the painting clothes that I keep near my workbench when I work on the styrene.
Regards,
David
David Robinson
Boston, MA area
I've now applied Bondo to all of the hull gaps and imperfections -- pictures shown.  There are probably some areas needing touch up, but they will become visible when I put the first coat of paint on.
The bow curve, made of 4 pieces that come together, was pretty uneven, and I had to sculpt a smooth bow curve out of Bondo.  I'm pleased with how that came out.
Regards,
David
David Robinson
Boston, MA area
Bow deck and bow bulwarks installed.  The bulwarks need Bondo to finish the seams, but . . .
Bondo really gives off strong vapors.  The air handlers for our den and bedroom are in the same area as my workroom.  So the Bondo session earlier this week caused some recriminations.:o
I need to set up a temporary workspace in the garage for future Bondo operations.
Regards,
David
David Robinson
Boston, MA area
Boat well installed and deck edging applied.
At this point in the construction, things move along pretty fast.  We'll see if that continues.
Regards,
David
David Robinson
Boston, MA area
The main decks are painted and installed.  Lots of touch up needed.  You can see holes drilled for gooseneck vents -- also had to drill a hawse hole which is just barely visible in this pic.
Regards,
David
Edited by drobinson02199
David Robinson
Boston, MA area
Finished painting the upper part of the hull white and marked the waterline.  Now finishing the bottom fittings before painting the rest of the hull red-brown.
An oddity of this kit for someone like me who is building it as a static model (vs. R/C).
The rudders and fittings to install them are included in this kit.  BUT, the props and shafts are not, although the skegs are.
The props are in the "running hardware" accessory kit, which is a cool $134 on top of the $375 I already paid for the model.  No way.  There's a clear asymmetry in the way parts are supplied with the base kit for a static modeler, and I think I will write Dumas about it.  Props and enough to mount them as dummies should be in the base kit.
So I went onto Amazon and found some nice brass props for $10 for the pair, used some brass rod from my "spares" supply, and voila . . . what you see.  All of this will be painted red-brown so the brass and white skegs will all blend together.
Regards,
David
David Robinson
Boston, MA area
Stabilizers mounted.  Now it's time to paint the bottom of the hull.
Regards,
David
David Robinson
Boston, MA area
Finished painting the hull.  This is by far the best waterline I've ever done, and I attribute that to some vinyl masking tape I found on Amazon.  Instead of piecing Frog tape to follow the line curve, this stuff just flexes to do it.  I also used a tip I got from this site, which is to run a bead of varnish down the edge to seal it.
I can give anyone who is interested in the product the Amazon reference -- just send me a message.
Regards,
David
David Robinson
Boston, MA area
Here's the cabin framework.  This is upside down, so the cabin roof and deck are lying on the work table.  Next step is the cabin sides.
Regards,
David
David Robinson
Boston, MA area
Cabin sides on and something called cabin shields mounted.  Next step is to add some detail to the cabin sides.
Regards,
David
David Robinson
Boston, MA area
Looks to me that you are doing a fantastic job with a less then great model kit. I have a Dumas kit that I drag out occasionally and putter with - bought it in 1986 and it may never get done! Fully half of my model is replacement materials for that which didn't fit, wood that split or was missing from the sealed box.
This will be my last post for a few weeks as I'm headed out for a vacation.
I have added most of the details to the cabin.  Everything you see will be painted white, and then black fill inside the portholes.  I've placed the cabin where it will go on the boat.  The main hull is sitting loose on the stand, which will be painted black when construction is done.  The top cabin deck will be gray.
The long side rails need a support bracket about halfway down.
What's not mounted yet are:  large vents, painted gray with black fill, and life rings, painted red (the manual wants orange, but I don't have any orange paint and red will do fine).
I will tackle the painting when I get back in late September.
Regards,
David
David Robinson
Boston, MA area
Regards,
David
I would like to know what kind of tape you used , thanks so much .
For Legion 12:
Here's a screenshot of the Amazon page for the tape I mentioned:
David Robinson
Boston, MA area
As a note to drobinson and others, 3m make several widths of fine line masking tapes that can be found at most auto body and parts stores - and it might be fresher then what AMAZON might supply. My history is one time with AMAZON for automotive masking tapes - and it wasn't good.
Now back from vacation and back to the model.
Painted the cabin and mounted some accessories on the sides.  Cabin in pictures is dry-fitted to the main hull at this point.
Regards,
David
David Robinson
Boston, MA area
Here's the pilot house with the roof not done yet.  Dry-fitted at this point.
Regards,
David
David Robinson
Boston, MA area
Pilot house roof installed (and glued on).  Pilot house and cabin are still dry-fitted.
Regards,
David
David Robinson
Boston, MA area
Very sharp work.
One minor detail, the side light on Starboard is green, while port side light is red. I see you painted SB red...
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
