Yes Keith, that's really a monster.
But not quite as big as the next giant.
My Yamato in 1:200.
And yes, I get a little claustrophobic when I think about all the 1:200 ships that I still have in the pipeline here. Yamato, Rodney , Mikasa....
But I still found a decent place for the darling.
Edited by madtatt
Typo
Greetings from Germany, Joelle.
Follow me on
Instagram
Absolutley Beautiful  -  sutch a gifted  talent you have.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Thank you for the praise.
When I tackle the Yamato there will of course be a construction report, Yves. But I fear that it will take a while before that happens.
I'm currently pursuing a slightly different model building project that involves a completely different type of ship.
I will then show it in the Non-ship/categorised builds section.
So all that's left for me to do now is to present you the pictures of the finished model and wish you a lot of fun looking at them.
I would like to thank you again for all the nice comments and I am happy that you have accompanied me.
So raise the curtain...
Follow me on
Instagram
Amazing detail   this is well done Congratulations      :cheers:
                   WASA
                   USRC Harriet Lane
Thank you for  choosing  us  to  showcase  your amazing skills   -  cant wait to  see  your  other builds.
OC.
Current builds
Completed works.
Beautifully done.  Adding the crew on the decks really brings this ship to life.
  • 4 months later...
Hey....Just wanted to say this is by fare the Best 1/200 scale Bismarck I have seen!! The amount of detail is as close to the real ship as have seen!
Like on Turrets A&D you have the hand rails mounted Midway on the turret and turrets B&C you have the hand rails mounted on the bottom and you naild it....and not many ppl notice that kind of detail and you have that kind of detail all over the ship.
I'm in the process of building 1/200 Bismarck myself....I think mine is close and I hade the same type of detail as you in mind as you...but just dont have the time with other hobbies and life....to get to ur level..Like I said yours is the BEST iv'e seen...Monumental Job!!
Here is a few pics of mine.....Mark
  • 2 months later...
On 10/6/2023 at 1:07 PM, madtatt said:
Thanks for the compliment, Chris.😊
In order to do this, of course I need reliable information about this ship.
I used photos of which there are really more than enough and the book "The Battleship Bismarck (Anatomy of The Ship)" by Stefan Draminski as my source.
Absolutely recommended if you want to build a historically accurate Bismarck.
Additional to that i had very good background information from my model building friends from Germany who are working very intensively on this ship.
Years ago we founded a small and very special forum that mainly deals with the German Navy. But all other navies were also treated.
Graue-Flotte
And it goes on. It's the weekend and I have time...
 One segment still goes on the tower in the front structure.
After that it's time to stop, otherwise I could have problems if I want to raise the foremast.
But first check the angle of the camouflage scheme again.📐
Everything fits together.
And so the tower slowly grows taller.
Then let's move on to the chimney.
Here I had to proceed differently when painting than with the superstructure. Since it is extremely detailed, I painted the camouflage stripes in front of all the attachments. Otherwise it would not have been possible to mask him properly.
I then laid a variety of pipes using lead wire.
And so the funnel gradually fills up.
The pipe also received a small upgrade.
Crane installed.
And the railing.
Ready to put the crown on the whole thing.
First get rid of the rough plastic tubes.
And sorted what felt like 1000 brass tubes from Pontos.
One of the things I particularly like about Pontos is their drilling templates.
No matter whether it's for the tubes or for the crampons on the hull or the superstructure.
It couldn't be more accurate.
That's why I prefer Pontos to KA Models.
Absolutely 100 percent hole spacing. That's the way it has to be.
Then the holes are drilled out and the pipes are put into place.
Still insert the inner workings.
That's why the coronation now follows. Note that unlike the Tirpitz, the Bismarck has an aluminum cap.
And take a seat for the sake of rehearsal.
Absolutely brilliant work, love this to bits.
Greets, Jölle.
  • 5 months later...
  • 3 months later...
On 10/5/2023 at 3:56 AM, madtatt said:
Thank you Mike. I've had a quick look at one of your ship models and I'm afraid with the quality you are  building, they'll need that time.
Unless you can do magic. 😄
II have a little time before I have to go to work, so I'll continue a little.
Then the crane booms. Again, a very delicate work. Here I soldered the parts to get more stability.
And then he can go to the gallery.
The platform for the rangefinder is also being prepared.
And that's the gem from Veteran that belongs there.
Her the first weapons from Veteran Models. An incredible amount of depth.
They look fantastic when painted.
And with that the admirals bridge can be put together.
But the 2cm C/30 gun from Pontos is also impressive.
A little bit of rigging is already attached as I won't be able to get to these places afterwards.
The tower slowly grows taller.
Finally, another test to see if everything fits together.
Well, that's it for today.
Greetings, Jölle
Love all the quality workmanship and the painting is amazing, very well done Jolle 🤛
Graue-Flotte
Crane installed.
And the railing.
Brilliant workmanship. 🤛
Greets, Jölle.
On 10/9/2023 at 4:27 PM, madtatt said:
Thank you very much, I am so happy to read this.
I have actually already won one or two prizes with my ships.
Unfortunately that won't happen with this ship. I'm just too afraid to travel with this huge monster.
But on this page, I don't know if you know her, I won first prize with her.
From the comfort of my model making room. 😄
ModelWarships.com
No surprises here 😂 🤛
On 11/15/2024 at 6:49 AM, madtatt said:
Thank you Jeff.
I'm excited to see how you'll implement your Bismarck. Knowing your Mikasa, it's going to be a blast again. 👍
Still working on the hull Jolle 😂 After looking at your magnificent model l am really looking forward to this model, just don’t hold your breath, l can see this taking a while. Have decided to do Bismarck in my second favourite scheme, yours being my favourite, shall have her being towed up the river Elb on her maiden voyage, at least l won’t have to tackle all that superb weathering that you are an expert at. 🤛😂  Your model belongs in a museum where it can be admired everyday. Absolutely superb and thanks for sharing, shall be looking at this for ages, hey and your boats on Mikasa with canvas being pulled back. Brilliant. 🤛
That'll definitely be wonderful.
Do you want to create a diorama of the Virgin being dragged up the Elbe? That would be extremely cool. 😎
Follow me on
Instagram
Yes, decided that making a model of her that’s possible not very common will raise some eyebrows on a very popular battleship, shall do it in the same way as my Mikasa except with water all around ship, but raised high enough on plinths to make all the efforts on the underside visible, at least someone might notice it’s been changed a little bit 😂 This is where l’m looking for a bit help from you, l need to source drawings and photos of the Tugs and small pilot boats accompanying her so l can try and scratch build these, obviously with your contacts with your Bismarck build and speaking the language could greatly help me here. Am sure all the boats were from B&V maybe Hamburg Museum could help with info. 🤛 Here’s hoping.
Hello Jeff.
My friends and I are already researching which tugs and pilot boats might be involved. The problem with the whole thing is that there are many pictures of the Bismarck with tugs in them. But it's usually not clear which specific contract the whole thing is for. Here, for example, is a very good picture of the Bismarck with two tugs.
The picture is so good that you can read the name of the ship. The tug on the right is the "Brunshausen".
But in this picture it should be clear that it cannot be the maiden voyage, since that is only the hull.
It's more about this situation, but even here it's often unclear which trip was involved. This is a picture on the way back to Hamburg.
For me and my friends, the tugboat "Seefalke" is currently a possibility. That must have been at the back.
It is now restored and in the German Maritime Museum. Here is a picture of the restored ship.
Hochseebergungsschlepper_Seefalke_-_Bremerhaven_02.thumb.jpg.8ce1c8108b8b11c875d2ce5b67bf041d.jpg
Then the tugboat Wotan would have been at the head.
And last but not least, there's the tugboat Arngast. That could also be considered.
In the following picture in interesting camouflage paint.
And then there are countless boats that simply have the B&V from Blohm and Voss and a Roman numeral on their side, and that you can also use.
That's the current status. I'll continue to inquire and get back to you.
Edited by madtatt
Follow me on
Instagram
@ccoyle
That's great, Chris. Just scale it down and you have an excellent template for scratching.
@Jeff59
I need the exact time period you want to depict, Jeff.
Do you mean the technical maiden voyage? The Bismarck was towed across the Elbe several times. Now an entry has surfaced from the war diary that the Bismarck collided with the lead tug Atlantik on September 15, 1940.
So new tugboats keep popping up, and we need to narrow them down. I've also contacted an old friend who used to be a curator at the Hamburg Maritime Museum. We'll see what he can contribute.
Follow me on
Instagram
