thank you very much B.E.,
its nice to have such an appreciation from a master builder like you are,
Nils
Current builds
-Lightship Elbe 1
Completed
Updeate
made the mushroom anchor with chain today
Nils
the size of a pin needle in the background
and against the pod
Current builds
-Lightship Elbe 1
Completed
thank you John,
I have to install the anchors and their chain-tubes before I close the forecastle deck planking
Nils
Current builds
-Lightship Elbe 1
Completed
Update
installed the anchor port fairlead into the forward side wall and fitted the operational Hall-anchor. also the bulwarks, the deck and fitting the deck in on the deck beams and between the bulwarks not permanently glued in yet, and the upper bulwark tops still have to be trimmed. I left an outcut in the deck for later access to the interior. The insides of the bulwarks and the vertical transverse frame (fore and aft)  have to be painted before glueing in the deck
Nils
mushroom anchor brought out
stb. bulwark mounted
all deck beams checked for smooth deck fit
the planked deck
bulwark flush with upper side
operational Wall-anchor fitted
port side bulwark
deck neatly fitted in (dry fit) .
Current builds
-Lightship Elbe 1
Completed
Many thanks for your comment input here Joachim,
and welcome to the build.
I looked up the version of the anchor chains when I got started. The mushroom anchor chain does not have these studs, but the stationary at the bow side Hall anchor indeed has a stud-chain.
Fortunately the autor (model builder Helmut Thomas) shot some photos of these details, in real in the dry dock,  to be seen on the enlosed pics
Regards from Glinde to Westerwald
Nils
the lft side chain is the one for the mushroom anchor
this is the chain for the sideHall-anchor
Current builds
-Lightship Elbe 1
Completed
many thanks Roel and John,
Roel,
I think you are right asuming that the mushroom anchor is not regularily hoisted.
John,
that was my thought also, but I remembered the dry dock pic proving me mistake ....
perhaps the constructors were not expecting "knots" in that chain causing possible chain break in stress situations
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Update
Preliminary check :
I made a black dummy for the white lettering on the later bright red hull. On the plan there are shown 20mm high letters. I will purchase  them from very thin white selfadhesive foil.
There are three criteria to fulfill:
1) a halfround bumper rail on hight of the main deck will  be horizontaly fitted to the hull, whereby the rail needs to run exactly on mid hight of the letters (letters E + B ), or slghtly below it.
    Hopefully the foil of the letters will follow and remain sticking tight to the area around the rail without partially lifting off.
2) the horizontal line for the portholes, in adequate distance beneath the deckline, has to lay horizontaly exactly in the lower blanc spaces of letters E + B
3) the drill holes for the portholes have to be clear of the hulls frames in those areas (This also mirrored for the other side of the hull)
Nils
Dummy with 20mm high letters
The outside diameter of the silicone glassed brass portholes will be 6mm, these have to be fitted into the hull without cutting away the broadness of the  lettering too much
Current builds
-Lightship Elbe 1
Completed
Great progress Nils. I am feeling a bit dumb because it was only in your last few posts that I realised she has a means of propulsion. The Trinity House light ships I am more familiar don't have propulsion and are towed on and off station.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thank you Keith,
the Elbe 1 is equiped with an old U-boot diesel motor of 650 PS for propulsion. I fitted a 4-blade prop (like shown in the Plan, although I see a 3-Blade one in one of the dry dock pics. The 4-blade in 20 diam. brass with M3 hub looks better to my eyes.
Here a few details I made yesterday ......
Nils
the stb. side anchorshaft
inside of the shaft blackened
fitting of the anchor fairlead
anchor dryfit, (40 mm long anchor with with slip in shaft )
this is the deck- level support and guide for the 13mm tube of the lighttower. The lower 13mm socket is fixed to the squarebar obove the keel
this takes up the lower socket for the foremast, the deck will also be equipped with a reinforcement at the point of going through. Here the stong "backbone" , (directly over the keel) which also takes uo the spindle press-in nuts can be seen
Current builds
-Lightship Elbe 1
Completed
Many thanks for looking in Vaddoc,
you`re always very welcome, and I hope you`ll stay tuned. The mushroom anchor is quite common for holding lightships to their position, having the nose in the wind, it prevents the ship from rolling too much for better convenience to the crew.
I like your 21`Fisherman`s Launch
Nils
Current builds
-Lightship Elbe 1
Completed
Update
Hull is all smoothened out and aft rounding rails (brass halfround) are mounted. The other rails will be from halfround nutwood strips.
All is ready for metal plating now. Am preparing for railings, starting with forecastle deck. First dry fit for foremast and lightmasttower
Nils
rounding rails fitted. These are bent to shape, so that there is hardly no stress for springback when glueing on, also to avoid messing with the glue (CA)
a bit of wood filler will do to smoothen curves
masts in dryfit
checking railing hight, the railing for the forecastle is a special bit ( 400mm length ) I found on the web, as the last available piece. It is of chemical etching and the brass has 0,6mm thickness, that appr. twice the thickness as I used on my Ergenstrasse rails. Unfortunately the source company does not exist any more, what a pitty. This railing type can be inserted into prior drilled holes of 0,8mm diam, and the hight of the top line therefore adjusted to the required hight, I will solder on mini washers as stopper  on to the fastening posts, so that the chosen hight can be permanently fixed for 1:87 H0 figurines after glueing in.
I wish I could get more of this railing type Here a dummy with the desired hight
here are the fist two templates for the aft round metal plating
Current builds
-Lightship Elbe 1
Completed
many thanks Richard and John,
Richard, the lightmast, still to be finished, was not so easy as I had thought .....
John, I`ll do my best for the further build ....
Yesterday I made a first dummy trial for painting, plating,  attaching of an obsolete 20 mm high letter. The bright light red color is RAL 2026 in silk-gloss, that is the one used on german fire-brigade and civil rescue vehicles.
Nils
I am a bit suspicious about the permanent sticking quality of the letters on a structured plating background. In the moment it seems to work ....
The black sub waterline color is a silicone based black thermo-coating paint used for oventubes, etc.
Current builds
-Lightship Elbe 1
Completed
Hi and thank you Gary,
many of the sequences have been performed with my previos models before, so I don`t have to spend too much time and headachs in thinking of how I shall do it.
Here for example, I started with the plating today.
New this time is the use of 10 mm wide Tamiya masking tape as a space holder, as I`m plating in "Belts" and need the better steady horizontal line for optical appeal
The plates are cut from a self adhesive aluminium foil roll with a table paper guilutine. Poncing is done with a suitable double tooth wheel ( clock cock wheels) to the back of the protection paper before removing it.
The foil thickness (without glue film) is 0,125 mm for best results
Nils
starting with the trick part
in Basic the plates are 15 x 50 mm, The rows, apart by 10mm, and then a cover plating "belt" over the 10 mm wide horizontal gap. The platings are stagered to the next line above.
a nice smooth hull surface provides a good ground for plating on
10 mm Tamiya distance holder, removed again before the covering, overlapping "belt is put on
Current builds
-Lightship Elbe 1
Completed
Thank you Lefebvre,
as I`m retired from my profession many years already, I have much time for my hobby. I guess its appr. 15-20 hours per week, but my admiral keeps me going also for house and garden.
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Levebvre,
the display capacity in my hobby office is exhausted for a longer time ago already. Because I favor a glas-casing for permanent  dust  protection, it takes even more space every time.
Three ships have now already moved to our attic room office for this reason. My wife does not like shipmodels in the living areas of our home, and I have accepted that wish., so the lightship is probably  the last one built in my shipyard. Perhaps there comes an oppertunity for selling the one or other some day for a fair price.
Nils
Current builds
-Lightship Elbe 1
Completed
Excellent progress Nils. I look forward to the next instalment.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thank you very much Keith,
I`m moving on with the plating, its almost completed ...
Nils
Current builds
-Lightship Elbe 1
Completed
