8 hours ago, AON said:
I thought they weren't.
Also, I believe the fore and aft trucks (wheels) should not be inclined. The fore trucks are inboard.
I am not sure I understand what you are saying. Can you elaborate a bit?
Darn auto correct on my phone.
Not incline .... in line.
Apparently age has tripped me up again. I am wrong. They are inline.
Apologies
Edited by AON
Alan O'Neill
hopefully these help
Alan O'Neill
1 hour ago, Gregory said:
To follow along, I could use some labels.
”steps, brackets”?
Check out the below plan from RMG (typical of my question). No date is given but based on the design I am pretty confident this is a mid to late 18th century carriage.
I have labeled the elevation to indicate the parts I am talking about. The brackets are the big pieces that make up the sides of the carriage. Now if you look at the plan just to the right of this you can see that both the steps and the ends are drawn with straight vertical lines (perpendicular to the center line of the carriage). I have seen many plans that do this so this is by no means an oddity of just this drawing.
I would have thought that the ends and the steps would have been at right angles to the brackets themselves as opposed to how they are shown on this drawing. My question is was this just a drawing convention or were the carriages actually constructed this way.
1 hour ago, Glen McGuire said:
This is from the USS Constitution Museum's website
This is partly where my confusion comes from. Modern redrawing of these plans (as exemplified by your example and also Caruana's redrawn plans in his book on English Sea Ordnance) seem to depict them at right angles to the brackets. I am trying to understand why contemporary examples seem to in almost all cases use one convention, but modern examples another. Hence why I am wondering if this was just a drafting shorthand that was done.
Edited by Thukydides
I offer the two images below showing the end face of the steps were square to the bracket and not to the centerline of the carriage assembly.
On the Victory photo, the end face of the step would not be seen if it was square to the centerline, so it must be square to the bracket face.
the carriage construction photo... square to the bracket face.
I suspect the carriage drawings were simply easier to complete square to the centerline with a tee square... but easier to cut square to the bracket face.
They would have enough of a necessary challenge cutting the cannon pivot trunnion and the axle pockets square to the centerline so why make things more difficult then they need be.
Alan O'Neill
I'd say they're square with the bracket rather than the centerline.
At first I thought not, since the use would be for mounting those blocks and you'd want a flat face to touch the flat block face. Then I thought it wouldn't have been necessary when using a quoin? (wedge), but this picture seems to suggest both a block and quoin. (this one is in Rotterdam Maritime Museum).
But then I also had these guns:
This one is in Maastricht, here you can see the block, but if you look closely at the step below the block and the angles, they aren't straight compared to each other. Looking at the direction of the angle, I'd say the step is square to the bracket, while the block would be square to the centerline.
The contact surface on the forward face of the block would also indicate a similar angle, but less visible.
And then I have this one, close to my home:
It also seems to indicate square to the bracket.
I do admit the last ones are not from that age and shore guns rather than maritime ones, but I hope it gives you an indication.
Roel
I'm not sure whether any of the carriages in the photos are original, so are suspect sources. As to whether the vertical parts of the step were square to the centerline or the brackets does not affect their use. The horizontal steps were the essential part of the carriage for using to lever handspikes while adjusting the quoin and hence elevation of the piece.
This is a contemporary(1775) drawing that has showed up in several discussions.
An artefact from Thorsminde.
This is a 3D reconstruction of the artifact carriage.
― Jimmy Buffett
On Hold:    Rattlesnake
Given the detail of the plan from the Constitution Museum's website, I would be surprised if the draftsman took a shortcut with the steps.  Just my opinion though.
22130-GunCarriages.pdf
I also have seen that one. It is from Robertson's Mathematical Instruments. The carriage in question likely dates from somewhere between 1755-1766, but as carriages didn't change much from 1732 to 1787 (with the introduction of the Bloomfield gun) the dating is not super relevant. The funny thing with that one is that the top bracket (in the plan view) clearly has the steps perpendicular to the centerline, but the bottom it is less certain (though this may be due to distortion from the scanning).
The Thorsminde example does seem to show the steps as perpendicular though it is pretty worn...
I suspect your are correct, I would just like to be a bit more definitive than "suspect" :). The drawings in question I believe were all drawn in the early 1900s documenting the ship as she existed at the time right before they started a major restoration. One would imagine that the gun carriages would have changed little, but it is not definitive enough to make me comfortable.
Most model examples I have found from the period seem to be perpendicular to the brackets (though it is hard to be sure from the pictures). That being said this is a pretty minor detail so it is not out of the question that they were just simplified when making the model.
Thanks everyone for all the suggestions. I think I will have to do some more digging. Every now and again I find definitive answers, but so much of this research is sorting through numerous historical examples, evaluating them and then justifying the conclusions on the basis of preponderance of the evidence.
Glen
Unless my eyes decieve me, your 22130 gun carriage plan pdf is odd.
The top sheet, top left corner, top view of the carriage.
The top bracket has steps square to the centerline and the bottom bracket has steps square to the bracket.
I wonder why they depicted them both ways.
Alan
Alan O'Neill
Well Alan, you made me go back and take a closer look!  I drew some vertical lines on the plan and the steps for both brackets do appear to be off the centerline, but just barely.  However, they do not appear to be exactly perpendicular to the brackets either.  So I think Thukydides is right and further investigation is required to get a definitive answer.
Edited by Glen McGuire
Log #13: A Research Rabbit Trail
I have been casting my net a bit wider in an attempt to reconcile some of the issues we have been discussing here regarding gun carriages. As I mentioned one of the main goals with this log is to bring those of you following along on a journey through my research, I thought I would open the door a little on what this looks like for me on a practical level.
Having exhausted (at least as far as I can tell for the moment) all of my leads that deal directly with guns and carriages, I decided to start looking for sources that might incidentally mention / show them. I started by searching for paintings from the period which depicted deck scenes. In doing so I came across the following very interesting painting (I have cropped it to the parts I am interested in and increased the exposure a little):
The painting is of Lord Howe at the Battle of the Glorious First of June 1794. Now I have to do some more research to confirm this fact, but the RMG description says that the painter:
Quote
Mather Brown travelled to Portsmouth to sketch the 'Queen Charlotte' and the officers. He made careful drawings and measurements, and studied the captured French ships.
This implies a degree of care and accuracy about the scene which makes it very interesting for research despite the fact it is about 15 years after the time period I am concerned with. In particular you can see the following interesting details about the gun:
  1. It appears to be a Bloomfield 12pdr based on the breeching loop and the label on the stool bed. The Queen Charlotte carried 12pdrs on her quarterdeck confirming this detail.
  2. The name of the ship is written on the quoin, this may be an extra embellishment added by the painter, but given the care he took to get everything just right it is possible this writing did exist on the gun.
  3. The carriage is painted a brown/yellow color similar to how the current carriages on the Victory are painted. This is in contrast to the bulwarks which can just be made out in the background as being a brownish red.
  4. The breeching rope appears to be hawser laid.
  5. The tackle at the rear of the gun is a double block. This matches what I have found in my research (12pdrs and up had single double combos), but runs counter to what Caruana says. It is a similar colour to the carriage.
  6. The strop for the block appears to be served.
  7. The stool bed has a slot which the quoin fits into allowing it to slide along. This makes a lot of sense to me from a practical perspective, but I have never seen this in any of the plans or other drawings.
  8. Edit: I also just noticed how the eyebolts are countersunk like the example Gregory posted.
The next step is then to carefully go back through all the other primary documents/pictures/plans I have acquired to see if any of these details are mentioned or implied. Often I find when I go back I notice things that were just mentioned in passing that I missed the importance of. These other sources in combination with more research into the artist will allow me to judge how reliable I treat these details as being. Then comes the question of if there are accurate, do they also apply to the 1780s?
Log #14: Practice Makes Perfect
It has been a while since I posted an update mostly because I don’t have much concrete to show.
On the research side I have been continuing my work on identifying contemporary paintings / drawings showing the details of pre-bloomfield guns. I have also been working hard at updating and correcting the document and I hope to release a second version with a number of new sections and transcribed primary sources in the coming months.
On the modelling side I received a scroll saw for Christmas and have been practicing with it on some cheap 1/4 in basswood I got at my local hardware store. Like anything it is much harder to use than it looks and I want to make sure that I really know what I am doing before I try cutting anything important. Getting the tension right seems to be one of the tricky parts. If anyone has any helpful tips on getting precise cuts I am all ears.
Speaking of wood Canada Post finally came through the other day and I received my wood order from @Joe V. This is only the wood for the keel / stem / sternpost / stern framing which will be made of pear. I haven't yet fully nailed down how much and what sizes I will need for the planking etc… I also got some yellow cedar strips as I am considering using it on certain parts of the model. I will need to do some tests to decide exactly how I am going to proceed. You can also see in this photo the beginnings of the build board with the top view of the model glued to it.
Finally, I have been doing a number of tests using scrap wood left over from my alert build on painting options. I have been experimenting with the effects I can get with relatively translucent inks. You can see some of my early test below.
A lot more tests will need to be done before I am willing to commit to a path, but I think at this point I have an idea of the aesthetic I want to go for. Part of the uncertainty relates to one of the current focuses of my research, did the coppering on Perseus come up to the wales or only the waterline. No clear answers yet, but if anyone has any contemporary sources which talk about the very early coppering that was done by the RN (1775-1780ish) I would love to hear about it.
Edit: I made a first attempt at the knee of the head and it doesn't look that great but practice makes perfect. I think next time I am going to try cutting further from the lines and sanding / filing / using my mini chisels to get a better fit.
I used Faber Castell archival India ink markers to do the black on LN. It worked well and was easy and left a film thickness that is much more scale than a coat of paint.
Getting tension right on the blade is bit a hit and miss type thing until you get a feel for it.  Have scrap wood handy and tighten the blade so it's not "wobbly".  Test.  Tighten more if needed.  If those are pin blades (pins at the top and bottom, you'll just have to test, test.  With the none pin blades, they'll usually come loose when too tight.   You'll eventually find the sweet spot.
The other idea is to go to a seller of these saws or even a wood working shop and talk them.  Sometimes they'll blow you off and other times, they'll help you out.
Alan O'Neill
1 hour ago, AON said:
like tensioning a stringed instrument
I second that it has to sound right, if I was musical I would give a note to aim for :-), it has to to be a 'ting' not a 'thunk'
Also make sure the blade square to the table in all directions.
Blade thickness can have an effect too, a thin blade will wander more that a thicker blade.
On mine with a very narrow jewellers piercing saw blade I can cut along a printed line and get an accurate shape.
with thicker blades cut as close as you feel comfortable with and sand back to the line.
You probably know this, don't force the material through let the blade do the work.
I have found that as the blade gets blunt it will wander more.
When cutting acrylic, put Sellotape along the cut line, it acts as a lubricant.
Tim
Current Builds :
Cutter "Speedy" 1828 from Plans by Bill Shoulders at 148
Bounty Launch - Scratch build - FINISHED
85 ft. Harbour Tug. scratch built  from plans by Francis Smith. ( FINISHED but no build log for this )
HMS Lightning. kit bashed from Deans Marine HMS Kelly kit ( FINISHED ) yes at last....
I tension to a high pitched 'ting', but haven't tried to figure out the pitch! The finer the blade, the more tension is needed to prevent deflection in curved cuts.
Have you tried  black dye on your scrap wood?
Thanks to everyone for all the suggestions. I have been watching lots of youtube videos and am going to keep practicing. I keep cranking up the tension a little higher and havn’t broken a blade yet. My biggest problem at the moment is going with the grain. I will be cutting along the line fine and then all of a sudden it starts to wander.
Yes I have read / heard this a bunch. Like many things practically what this means is harder to get down. I am also still struggling with sometimes when I turn the piece I end up deflecting the blade to the side and don’t realize till when I let go the blade snaps back into the correct position. I suspect like many things this will just require practice. It is less of a problem since I tightened the blade more so maybe even more tension is needed? Just what sort of ping is required is difficult to get down.
I use a combination of liquitex and daler rowney inks as that is what I have on hand. I may consider others, but as I am planning to start playing with shades and hues a bit and I already have all the colours I need. I may look into the markers, but in general I prefer the control I have with the liquid ink as I can thin it down (particularly important with the black).
I have not tried dye though I have considered it. The worry I have with it is one of control. I have seen you previously mention Frieberg’s leather dye, but as a bunch of my painting is probably going to have to be done. on model, I would be worried about making a mistake.
I am going to keep playing with the acrylic ink first to see if I can achieve the effect I want. If not I may consider other options, but at this point I am relatively optimistic that the ink will work. I have gotten some aspects of the finish I want and I think it is mostly just a matter of practice and getting the ratios right. Some inks (particularly the black) need to be thinned down quite a bit to keep them translucent enough to allow my underpainting to show through.
Dye stains are mostly surface and will sand away very easily except on end grain, and they can be painted or sprayed on as they're just dye powder mixed with ethanol. Speaking of which, I recommend dye stains from luthier manufacturers, you want stains designed for thousand dollar instruments. They're not expensive, if you're really interested in options you should get some to add to your experimental program. I really like dye stains for their translucency, you still get the wood grain and figure even with the stain.
2 hours ago, Thukydides said:
what sort of ping
using my iphone I get an A# not sure how accurate it is
see you tube https://www.youtube.com/watch?v=iNnseubrRMM
Tim
Current Builds :
Time for a minor update as it has been quite a while since I last posted on Perseus. Work has been busy so modelling time has been limited and I have been lately distracted by another project.
Despite this, work has continued in the background. However I have very little to show for it as the work has mostly focused on practicing future cuts on scrap wood. I have been using the more warped pieces of plywood I have (not suitable for the main build) as tests to practice cutting out the bulkheads on the scroll saw. I have also been cutting out test keel pieces from basswood I got at my local hardware store.
While this has been going on I have also been experimenting with trying to cut tight joints for knee of the head. My second test version is much better than my first, but I am still having trouble getting all the joints really tight. Any suggestions anyone has would be much appreciated.
I plan to keep practicing with the basswood until I am happy with my results and then I will shift over to attempting the final version with my pearwood.
