I'm with John... nice looking planking.  I think once you sand out the clinkering on the first layer, you'll be ok.  Nigel has probably the best solution for the second layer.
Ahoy Mates :D
Thx for the likes and comments
Neptune: Welcome aboard; I see that you have build this kit. Your company and comments are most appreciated
Nigel: Thank you. I do agree that spiling would actually be much easier here but I have this whole OOB thing going on for this build. I am contemplating gluing two of the kit supplied pieces of planking together and then spiling that. On a side note I have just found the kit supplied wheel. That is going to be a big problem.
Mark: I am hell bent on correcting the kinkering and not sanding it out.
Sjors: Always a pleasure. I am a persistent "bass turd". That is my real strength. I am still working on the "skill" thing.
Back to the build  :pirate41:
I am posting this for anyone who might be using my log as some sort of reference for their build.
There seems to be a point where the planks need to transition around what I would call the hip of the stern. (We could talk jeans here).  I am getting a lot of kinkering: More then what would be safe to sand out even if I were to sand ..
What I have found is that after forming and installing these planks individually that I can come back to them and reform them again but now as a group.
First I clamp a wet paper towel to the area and let that sit for 15 to 20 minutes. I re-wet the towel, then nuke the area with my heat gun. When I start to smell glue I start making adjustments. By only wetting and heating certain areas and leaving others bonded I have found that I can now form sections instead of just planks to create a smoother surface.  I did not take any "before" images but if you look at my last post, the image of the stern shows the start of the klinkering (its out of focus) which got really bad on the final plank for this belt.  .
The image shows how I used a piece of kit wood to "persuade" these planks as a group. This set up was nuked with the heat gun. The wood traverses four planks which all had some klinkering to a degree. It took multiple sessions applying pressure and heat in different areas to get this wood to lie as it does in the final image
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
Ahoy Mates :D
Mike: Thx, I am hoping this will all be gone soon except the experience I gain from it
Dragzz: Please delete some messages, your mailbox is full
Just posting this so I don't forget it. I use my log as a notebook of sorts
While waiting for a plank to soak I decided to address a small gap in the bow planking. It really was not necessary but more of an experiment.  I really should have been doing treenails. Originally my plan for these was to use the sawdust and PVA trick when I did my final sanding
They are just little 1/32 by 3/32 scraps sanded into a wedge. Flat tree nails. If I have another opportunity to try this I think I might use a wider piece and put it so the grain follows the planks. The edge grain looks a little dark to do this on any final planking. I have not sanded it yet and it is still wet too. I just snipped them off with my plastic sprue cutters
Edited by JPett
  J.Pett
hello jpett   my mail is all clear now  keep up the great work that u are doing
Ahoy Mates :D
Brian: I did a grain matched wedge. They might work too good. The seam between the planks has almost completely disappeared. It looks a little off, the lack of any seam kind of highlights it. I should be able to cut a new one with the Xacto but it does work.
Lawrence: Thx: did you change your signature
Dragzz: Thx
I am just posting this link as it is very helpful.
http://www.shipmodels.com.ua/eng/models/elite/victori/index.htm
The images of the stern are very good. There are not many of them on the web. I also really like the color scheme. I might like it too much
Thx to Pronto for directing me to this site
http://modelshipworld.com/index.php/topic/5399-mordaunt-1681-by-nmbrook-euromodels-160-beyond-bashed/?p=252941
I also found Danny Vadas's Vic
http://www.shipsofscale.com/gallery/danny/victory/index.html
Edited by JPett
  J.Pett
Ahoy Mates :D
This should be my last post as a Commander :D
Dragzz: That build is amazing
Scott: It's the edge bending
Lawrence: It just looked odd but its yours to do as you please. The wedges are coming in quite handy on this first planking. Not sure if they will be good on the second
Well planking this beast is sure turning out to be a learning experience. I still can not seem to get my head around belts; that and the edge bending is really getting a little out of hand.
I have completed the port belt and decided to do the Garboard belt next. My hope is that once complete I will be able to better plan the next two belts. I am winging the plank widths. I am going with "they need to taper just before the stern and then flare" as my last model did. So far it looks like I am close and any errors should only cause minor problems. Fingers crossed.
The edge bending has me concerned on all three belts. I am hoping the thinner walnut will be a little more receptive to the curves. The drop plank on the port side had to be done three times. I now have some "franken planks" as a result of my changes. I normally would have just replaced the complete plank but do not know how much extra wood Corel has included. Currently my waste is less then one strip. Possible only a half.
In the stern my planks do not line up on both sides and I will have to pay better attention to this with the walnut. I am debating whether to make a correction on this or not. On the bow I had to pull back my drop plank due to all my mistakes and there were quite a few. I was happy with the way it turned out until I saw this picture. I see I have one more issue to address. I am hoping all this experience will only help me on the final planking. Trust me when i say the thought of just slapping all these  on and then throwing a sanding party; then inviting some filler is entertained quite frequently in the shipyard.
The bow end of the garboard plank was much easier then I thought. I just terminated it at bulkhead 2. Any further and it was curving up which I was told is something this plank should never do. I have some doubts as to how much and how I tapered the following planks as this led to considerable edge bending to get compliance. I went slightly wider on the last plank  to hopefully reduce it for the ones that follow. If I were to do this again I would put a filler here.
In the stern getting the planks to conform and contact the plywood keel was not so easy. I found that nuking small pieces of paper towel in a shallow dish of  water and then clamping them to the wood very helpful. Getting the wood to make full contact with the plywood keel took no less then five sessions.. Because I believe I will be sanding most of this all the way back down in some areas I felt full contact necessary. Its just which area???, that is why it all needs to be put down. Sanding here, fitting the walnut and the keel post are one of my biggest concerns with this project. I also pulled up the garboard strake where it met the keel post. The plans do not show the planks sweeping up as mine do but I felt that if I matched the plans with this layer I would not be able to with the final one. I did this plank two times before I realized this and then did it another two more times to get this. . I am be big believer in water solvable PVA.  it really is a newbies best friend.
Edited by JPett
  J.Pett
And here I thought I was the only shipwright to face this phenomenon.  Ah, the joys of planking.
Coming along nicely JP.  No filler for you!!!!!
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
hello jpett   looking good buddy keep up the good work
Hi there, JPett -- This is a fantastic build, and your narrative of the travails along the way is as interesting and clear as always.
Here's the planking mantra:  "hmm, that looks right . . . it's gotta be right . . . . oh, @#$%&* now I have to pull it off"  Say that 3 times and you just might get the plank to sit right.
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
JPett,
Nice!! you are certainly an established master at planking super nice work. I will enjoy following along..
Yea you might be slightly "off" those electron microscope pics. show all errors.
Michael
Edited by md1400cs
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Ahoy Robert :D
I have not installed the upper deck. I saw that Dragzz had this same problem.
What I am doing is leaving the upper deck (part 18) off until after I plank most of the hull. Realize you also have to remove the upper section of a few bulkheads for gunports on the lower deck, then install those cannons but only after cutting out the gunports which will require the hull to be planked.  This would be insanely difficult if you follow the instructions by severely reducing your access here with part 18.  ATM I do not see this deck as being anywhere near necessary before planking at least up to the lower gunports either. Not to mention the curve in the bow which may or may not need an adjustment.  I plan to leave the last few rows of my first layer of planks off as i come up to this deck and then decide how to proceed.
I have not even planked the lowered deck yet either.I will most likely only start the lower deck once I reach it with the hull planks and finish it only after I planked the hull enough to cut those bulkhead sections out for the gunports. Cutting them out after planking the deck is going to leave a something undesirable. Not to mention what an oops might do to the deck cutting out gunports.
My plan is to have most of the planking done, bulkhead sections removed, lower deck planked, gunports cut, and maybe even all the cannons mounted on the lower deck before I mount part 18. Read some of the Caldercraft  Vic logs. That's what I used to developed this plan.
What I did so far was to plot the line which separates the wales from the hull and am currently planking the first layer of the lower hull. I will then use this line in conjunction with more measurements with the hull in a building jig and the plans to get the sweep of this deck. easy peasy lemon squeezy
Your build looks great so far BTW  :)
I have not seen this plan done in any other logs or completed it myself so please keep this in mind. Oh and i don't know what i am doing either.
Edited by JPett
  J.Pett
yes jpett mine is installed there nothing that i can do now some of thos ribs might be to tall but iam not to sure on that if post a pic of that would help to see what is going on so we can help
Ahoy Robert :D
"LOL" That my friend is the 69 cent question. As you can see in my earlier post I have them at 8mm in from the bulkhead edge on the cannon center for the 2 lower decks and for reasons unknown, slightly less on the upper gun deck. See plate 5
http://modelshipworld.com/index.php/topic/3709-hms-victory-by-jpett-corel-198/?p=250111
My plan is to be close. Close enough that I can space them out with a washer or counter sink them to match. Do not make the mistake I made in mounting them on the same plane as the waterline. This was wrong and I may have to remove or make an adjustment on some.
I used my pencil jig to transfer the height of the gunport center from the plans to each bulkhead. Then measured in 8mm on each bulkhead and use a square off my building board to get that line. Here is that post.
http://modelshipworld.com/index.php/topic/3709-hms-victory-by-jpett-corel-198/?p=249707
My next attempt involves plotting a line across the bulkheads on the plans using the gunport center and then transferring those measurements to the bulkheads on my kit
Edited by JPett
  J.Pett
Ahoy Mates :D
Augie:  "they need to taper just before the stern and then flare"   Seems we both had it wrong.
Scott: My professor said that science covers it all. Go figure
Lawrence: I agree. Even the admiral liked a good planking. :P
Dragzz: Thanks D
Martin: Got to go with the  @#$%& on this one
Michael: Looks whose talking. If you have some kind of quark based microscope over in your shipyard you need to share it
Robert: I already got you
Back to the build:  :pirate41:
Well not really. We have been a little preoccupied and work in the shipyard has been a little slow.  Stagnate might be a better word.
I have been studying and while helping another member I found this which is a real game changer. It was in the back of the Corel catalog included with the kit
I also solved the riddle of the upper stern post. The entire keel is covered with planking (thx Mark). I believe this would also include the rear of the keel where the ply is exposed. This will add 2mm here and should be just fine for me.
The little bulb is glowing. Time to get to work :cheers:
Edited by JPett
  J.Pett
  • 4 years later...
  • 4 years later...
