3 hours ago, Glen McGuire said:
Had I know more what about I was doing
 Glen, I'm pretty sure that's the motto for the majority of us. You're doing excellent work, keep the faith.
Current Builds: Sternwheeler from the Susquehanna River's Hard Coal Navy
8 hours ago, Glen McGuire said:
It was a bit tricky tying the lanyards inside the tight confines of the fife rails, backstays, shrouds, etc.  Had I know more what about I was doing, I might have done some things in a different order.
It's easier to rig such lines "in reverse" i.e tie them off at deck level at the start of rigging, then coil them neatly while doing other lines, then pass them up and tie off aloft.
I think that's good advice, Ian.  The even trickier thing, which I did not mention above, was drilling tiny holes in the deck for the eye pins inside the fife rails at the base of the masts.  Even my small pin vise was really difficult to position and work inside those tight confines.  I guess what I should have done is read the instructions backwards at the start.  Then I would've known where all those tie off points for the rigging are and could have put the eye pins and lanyards in place first.  Too late now!
Edited by Glen McGuire
Yes; if you ever build a Heller Victory there is much extra prep work before starting the rigging. For example, Heller's instructions have no means of holding the yards to the masts; in the case of the lower yards you need to add blocks at the feet of the masts for truss pendants. As you say this is much easier before the masts are even stepped.
The Heller Victory instructions are diabolically bad.
Well, I got to the end of my rope on this project.  Literally.  I ran out of cord for the stays, so I had to order more from BlueJacket.  While waiting for the new line to arrive, I circled back to the yards and installed all the foot ropes.  I've seen some people use thread for the stirrups and others use small eye pins.  I particularly like the way the foot ropes look on @Keith Black's Tennessee so I decided on eye pins.
Well, I took another look at the mast and spar diagram and realized the lower 3 yards on each mast have these little mini-foot ropes on the ends.  I did a quick search and found that they are called Flemish Horses.  Hmmm.  Had not heard of them before.  So I did a quick add.
Glen she looking beautiful. More horses?, those are fun to do. I noticiced no crowsfeet lines, or did I miss that part.
 Man it's going to be hard to let this one go, Just a fabulous fix . :cheers:
Bob M.
Edited by Knocklouder
Guessing typos lol
On the build table :
Pegasus  -Amati-1:64
On hold:
Astrolabe 1812 - Manuta-1:50
Those are some peachy yards, Glen. The foot ropes turned out really well.
I think they should be called Flemish Longhorns rather than horses.  But what do I know!
As far as the crow's feet, the BlueJacket plans don't call for those so I didn't install them.
Thanks, Keith.  My goal was to make them look as good as yours on your Tennessee.
I think you succeeded, Glen. The look better than mine.
I have reached a major milestone on this project - all of the standing rigging is complete!  WOOHOO!!!  :cheers:
The stays are taut (all 52 of them) and the masts are straight and aligned.  That calls for another round!  :cheers:
20250221_204946.thumb.jpg.1cc394e4970a1129159915b608186942.jpg20250221_204932.thumb.jpg.655b29e7f743d2a6e98460f9bdbe0a63.jpg
Next up is attaching the stuns'l booms to the yards, which means it's time to cozy up to the soldering iron.
You are a champion, sir. What a wonderful thing to do for that family. Like you said in your first posts here, the model does look to be in good shape overall. I too look forward to following this build, she is a beautiful vessel. I like your "do no harm" approach very much!
Great milestone Glen, one which I thinks not only deserves that drink BUT also an extra Rum Issue (break out the Bundy).  All looks great, nice job!
cheers
Pat
Everything looks amazing. Quite simply, amazing. Thank you for your hard work, Glen. Love the updates.
Well Pat, in the absence of Bundy here in central Texas, I settled for a few tots of Ol' Sailor Jerry's fine spirits!
On 2/26/2025 at 9:34 PM, Robert in Austin said:
Love the updates.
Glad you are checking in, Carson!  Slowly but surely the team here is gettin' it done!!
And now on to the studding sail booms (I always thought they were called yardarms but I seem to have been mistaken about that).  There are 8 yards that have studding sail booms - The lower 3 on the fore and main masts, and then the 2nd and 3rd lowest yards on the mizzen.  The crojack yard is not so equipped.
The booms are offset forward at a 45 degree angle to the vertical plane of the yard as it hangs from the mast.  Each boom is held in place by passing through 2 rings called studding sail irons.  The inner iron looks like a figure 8 with a portion of the bottom cut off forming a saddle that rests on the yard.  The outer iron is a simple ring attached to a rod bent at a 90 degree angle that feeds into a hole in the end of the yard.  I used brass tubes and wire for my irons.  I started with brass tubes of various inside diameters.  Of course none of them quite matched the diameter of my booms, so I had to drill out each of them to fit.   The rings below are for the fore mast yards.
Next, I cut pieces of brass tube in half to make the lower half of the inner iron that will rest saddle-like on the yard.
Next step - soldering the top and bottom half of the inner irons together.
Next, I soldered a small piece of brass wire to each ring for the outer irons.
Here's a closeup of 1 pair of irons dry-fit (before I bent the wire on the outer iron).
Here are the foremast yards with the booms and irons in place and the irons painted black.
And a final closeup.
The fat end of the boom will be lashed to the yard, which is next on my to-do list.
 Handsome studding sail booms, Glen.
I’m no where near ready for a build like this, but you are doing a wonderful job of preparing me. I would have never figured out what you were doing by the words you were writing. But your pictures teach me well:-) thank you Glen!
I like the look of that, Glen. Nice work on those soldered pieces, very clean and precise.
I call BS on that, Bryan!  I've seen your work and it is high quality with great attention to detail.  Don't underestimate yourself!  :cheers:
Thanks, Mark.  I could not solder a lick before I started ship modeling a few years ago.  I continue to be amazed at how many different skills you have to learn to be able to do this hobby!!
True statement right there!
Fantastic work, Glen!  Great soldering and well - everything else too.  Clean, crisp and as Keith said, handsome.
Gary
Completed Scratch Builds
Time to hang the first lower yard, which will be on the fore mast.  It's a somewhat complex trio of items that hold the yard in place (at least complex for me trying to figure it all out).  There's a sling that is composed of connected rings.  The bottom of the sling is wrapped around the middle of the yard.  The top of the sling wraps around the top of the mast top.  The way I understand it, the purpose of the sling is to be the primary weight bearer of the yard.  Although I'm not sure how it gets disconnected when the yard is lowered.
The second item of the trio is the jeer blocks which are used to raise and lower the yard.  There are 4 jeer blocks in total.  The lower ones (seen below on either side of the sling) are double blocks that are attached to the yard inside the parrel cleats.  The upper blocks will be added later and are attached to a sling wrapped around the mast top.
The third item in the trio are the truss pendants which hold the yard against the mast.  One end of the pendant is seized to a bullseye.  The line is wrapped around the yard, runs behind the mast, thru the bullseye on the other side and then is seized to a block where another line takes it to the deck.
And here is the yard in place.  Below I've highlighted the sling which holds up the yard.
Here's the full set of jeer blocks in place.  The upper jeer blocks are triples.
Here are the truss pendants in place.
And here's what the whole thing looks like without all the red circles.
This process will be repeated for the main and mizzen lower yards.
It must feel great to be able to finally add a yard! You're doing really great work, and its all the more impressive considering the tiny scale. Although I suppose 1:96 must seem huge after all those ships in bottles...
 Superb work, Glen. Could the two rings have simply been unlashed from one another and the yard then lowered to the deck?
Glen,
There are no rings used in the sling.  There are simple eye splices that are seized or lashed together, end to end.
Also, on Constitution the truss tackle pendants have a double block seized in and the tackle runs up to another double block seized to an eyebolt under the top before leading down to the deck.
Regards,
Henry
Henry
Laissez le bon temps rouler !
I would need a drawing with very large pictures to keep me on track with all this 😮 Very nicely done, Glen, it looks so precise.
Amen to that, JC!  The SIB work has definitely prepared me for drilling tiny holes in things and threading line in hard to reach places!
 You are probably right, Keith.  I don't see any other logical way to accomplish that.
Yes!  What I would give for some detailed photos with labels, etc!  I read the BlueJacket instructions about 100 times, then I study bunches of build logs with lots of great pics ( @xken and @KurtH have build logs that have been incredibly helpful), but I always seem to need a shot from a different angle to help me figure out exactly what to do.  😃  The truss pendants in particular!
Hey Henry!  Thanks for the explanations on the sling and the truss pendants.  That makes a lot of sense.  I've been trying to follow the BlueJacket instructions as close as I can and they seem to read a bit differently, unless I am interpreting them wrong (which is a distinct possibility!).  For the sling, the instructions say, "Set up over masthead, brought down through hole in foretop, and set up to sling thimble on yard with a lanyard."  Throughout the instructions, thimbles seems to be interchangeable with bullseyes.  I did not have any bullseyes large enough for this application so I decided to fashion brass rings as a substitute.  Unfortunately, there were no pictures of the sling in the instructions to help.
Regarding the truss tackle pendants.  I really had a hard time interpreting what the instructions were saying, and that's even with a picture!  As I mentioned above, I must have read it a hundred times trying to figure it out.  Here are the instructions and the accompanying picture.  "Seize a thimble into one end of a 8" rope which is wound around the yard at the parrel cleats.  Then pass the end of this rope through the thimble of its counterpart.  A block takes the rope down to the foot of the mast."
I'm not 100% sure, but I believe I matched what the instructions were telling me to do.  Perhaps there are multiple ways to rig the trusses depending on the timing of the construction or restoration?
