Hi Gianpiero,
What for impressive work! Very good done! I will follow with interest.
Alex
Current build: HMS Sphynx, 20 gun ship launched in 1775 at Portsmouth, Hampshire.
On the drawing board: HMS Anson, 64 gun third rate ship of the line, launched in 1781 at Plymouth
Hi Giampiero
thanks for sharing your fabulous Model, very neat and accurate work, from the state it is already presenting, it shall certainly grow to a spectacular Piece of model art
Nils
Current builds
-Lightship Elbe 1
Completed
Giampiero,
Beautiful joinery on the bow, stern, and frames.  I'm going to follow along on your build and try to learn.
Thank you!!!.......
In order to block the stern oar in a more stable manner, on the excesses of the oarlocks I have tentatively set a provisional "crowning glory"  that I will take away when I have completed the transom
Edited by giampieroricci
Hello.
I have just read your build log.
And I am very impressed with you skill and the model.
That is a very nice looking forum/shape of the hull.
Well done on such a fine ship.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
beautifull build Giampiero
the impessive line of that ship can clearly be seen, wonderfull
Nils
Current builds
-Lightship Elbe 1
Completed
Is that ebony or dyed wood, Giampiero.   Very impressive work.
I thought maybe it would be appropriate to bolt the course of filling at least now that there is still no upper boundary for more space and avoid any awkward shot could damage the belts themselves.
This is the job I started.
I used the brass tacks of a diameter of 0.7 mm which I cut his head off and filed flush with the stem of the course.
Hi Giam.
Can you tell me how you managed to bend the ebony without it splitting/breaking please?
Do you soak it, heat it?
I have tried in the past and just ended up with a lot of scrap wood, a bad temper and then ending up staining some wood to simulate ebony!
Not the result I wanted.
Kind regards,
Ron.
thank you friends!
I managed to bend the ebony with the flame of a candle, and then I put in a suitable form.
however, they are strips of 2mm that I bent just enough to paste them on the model. The curvature of this model is not excessive.
My ship is about a meter long......
Ah, I see what you mean and thank you for the quick reply Giam.
(Or at least I think I understand: Do you "oscilate"" the wood over the flame of the candle while holding between thumbs and fingers and gently bending said wood over the heat)?
And can I call you Giam??
Ron.
Edited by ronkh
