Nice work Ron. Did you do the X stitching on the spritsail? I can't remember seeing it on the sails I got with mine, I must go look.
I remember when I made my first endeavour i used some old I white sheets to make the sails then after a few years of us smoking in the house (back in those days!) they were dingy brown from nicotine stain.
Cheers Steve
Current Build: HMB Endeavour 1:51 (Eaglemoss part work)
Previous Builds: USS Constitution (Revell plastic) HMS Victory 1:96 (Corel) HMB Endeavour 1:60 (AL)
I've put some tie down ropes on the sails but I can't get them to hang down straight.I've tried ironing and different glues but nothing holds.Any ideas would be good.I might haveto just can the idea and leave them off.
Current builds: HMS Victory - Caldercraft 1:72
Completed builds: HMB Endeavour - OcCre 1:54   HMS Supply - Caldercraft 1:64. Fishing boats, Bremen,  Palamos.
Ron, try a fabric stiffener (more robust than starch) which is usually available at an arts and crafts, or sewing supplies (Spotlight if in NZ?) - an alternative might be "stop-fray" .  You will need to position the ropes initially, spray and reset where necessary.  Just a suggestion not sure how permanent these will be though?
cheers
Pat
Maybe a 50-50 mix of white glue and water???   Did you wax the line first?
Hi Ron
Try thoroughly wetting each of the reef ropes with water let it soak in for w while then tease them into position with a paint brush. I'm assuming that the ropes are natural fibre, they should stay in place once dry. If not use diluted PVA glue applied with a paint brush.
Cheers
Steve
Hi Ron
To get them to lay down, you should have waxed them like Mark said.
After waxing them, tie a knot at the back of the sail put a spot of glue on.
Turn it over to the front of the sail and do another knot, then another spot of glue but at the same time hold the tail of the rope down wards let it dry.
The glue will hold it straight down.
You will have to pass the rope through some wax about 3-4 times on each side.
Hope this helps you.
Denis
Edited by Denis R
The sails are looking real good Ron... try doing what the guys said to do to get your ropes to lay flat.... should solve your problem ( I hope!!) :P
Frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Thanks a lot for all of your advice.The thread is Caldercraft I presume it's natural.I tried wetting and glue but that didn't work so i'll do it again as you've suggested with wax etc.
I've given up on the reef ropes for now I tried nearly every idea but nothing worked for me,maybe try different thread later on.Onto attaching a few sails,just need to make sure they aren't back to front like the first couple I did.Trial dry fit on the ship as well.
Hi Ron
Don't understand why you cannot get your ropes to hang down.
What sort of wax are you using, and what glue for the knots.
Send me a PM and I will take you through it if you wish.
Your build is looking fantastic.
Denis
I will send you some wax that I use, but you may have the same one please let me know.
Edited by Denis R
Hi Ron yours sails are looking very good, she is going
to look like the real thing when done.
I found this pdf the other day, a bit late for your sails but there is other info in it.
I don't know if you have seen it.
http://juwarki.org.au/wp-content/uploads/2012/03/VC-Man-final.pdf
Cheers Chris
nice work on the sails Ron.   I did reef lines on my America build.   can't remember exactly how I did it........take a peek there and I'm sure I showed how I did it  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
that's some sweet looking rigging.......the sail definitely doesn't hide it at all  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
More sails on,i didn't think there was so much rigging on the ship,i did have 150 metres of it,not much left now.No idea the purpose of boom pendants a bit of a strange mounting position on the plans.
