Thank you all for the kind words of encouragement Things are moving along a little better now. Made the holes in the sails for the mast rings. Rolled the tip of a steel pick in gel CA. When you punch the hole the glue seals the edge of the hole similar to how heat would seal nylon. Makes clean neat holes. Started attaching sails to spars anywhere I could because it is more difficult for me to add them after the spars are added to the masts. Adapted some parrel sets I found from 3 line to 2 line parrels. Began adding gaffs with sails to the masts, attaching mast rings & working on the rigging in these areas.
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Wow, Jesse, those sails look amazing on the spars. Thanks for sharing the tip about how to get nice clean holes in sailcloth.
Steve
completed models:
Shenandoah (Corel)
waiting on the shelf:
La Sirene (Corel)
Half Moon (Corel)
Puritan (Mamoli)
Patsy (derisively): "It's only a model."
Arthur: "Sshhh."
Looking very realistic, great job you have done Jesse.  And also my thanks for a good tip about the CA gel to seal the holes and My guess is other things as well.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
You have to be careful. Most of the time CA glue is disaster for cloth. It makes it too hard & brittle & cracks apart but if you use it carefully like with the holes it is very helpful. The reason for using gel is so it wont soak up into the cloth any farther than the rim of the hole. Then you don't have any of the normal problems with it.
Worked on the gaff halyards & the yard braces. I usually like to tie onto the pin & form the rope coil with the same line like is in reality but I'm having a very hard time reaching it- too much stuff in the way. So I'm tying off & forming rope coils separately & laying the coil over the pin.
Looks good- i use a piece of metal rod "jammed" beneath the pin to wind the rope around if using the same rope as the rigging method and use needle nose pliers and a piece of brass wire with a hook and flat bent in it to work it.
Keith
Trying to get started on the clew lines but have run into a problem. The kit instructions told me to rig the block on the yard & not on the sail corner like the first photo shows. Now that I'm on the rigging page it shows the block on the sail corner which changes how the clew lines go a little bit. I'm confused. Do I change my blocks or do I just try to make it work like it is?
I think I figured out the blocks are supposed to be on both. These instructions are so vague & there are gaps in them. Anyway I'm going with that & moving on with it.
Thanks Rev!
Rigging has come to a stop- my lyme infection has flared up with a vengeance leaving me feeling deathly sick. Right when things were moving along a lot quicker too! Oh well, this will pass- soon I hope. I really want to finish this ship.
Oh !!!
:huh:  :huh:
Well, no like for THAT post, I can assure you !!!
Hope you are feeling better and back to your ship-yard as soon as possible, Jesse.
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
Likewise Jesse, hope you're feeling better soon and able to move on with this - the finish line looms ever closer!
Hang in there Jesse, we are all rooting for you.
Cheers,
                       VOC Ship Surabaya
Ditto on the well-wishes, Jesse.  Sail look great. Nice job.
Jack
Current buildUS Constellation
Doing a little at a time. Rigging sheet & clew lines. Added the stay & flying jib sails.
Very near finishing the Scottish Maid. Wishing Keith was around to see me complete it. Since I'm so near to the end I'm taking another look at the details around the ship. I noticed the reef points on the port side of the Main Mast Boom Sail. I have the sail catching wind from the starboard side, billowing out on the port side. The way this makes the sail shaped the reef points should not be laying sloppily against the sail on that side. I painted each one with watered PVA & clipped them to dry so they would hang down.
Yup, those reefing lines at these scales are always a problem but you are doing okay with the thinned PVA !  It's looking really very nice!
Cheers,
                       VOC Ship Surabaya
Some of my sails looked whiter than others after some water/PVA washes for shaping. I wanted to show weathering so I did some more washes with tea. This time I added baking soda to the tea. It fizzed a little at first so I added more until it stopped fizzing. Hope this works- never did it this way before. Also borrowed an idea from CaptainSteve. I dry brushed some paint & smeared it with my finger to look like water staining running down from the grommets. I like the way they turned out.
Yes I think I will Dave
One last sail, a few lines & the flag is about all that is left.
