... To transfer the correct positions from the plan to the model I used masking tape. The tape first was aligned on the plan parallel to the gratings and the positions were noted on the tape (the black contours on the plan nicely shine through the masking tape, see image 1). In a second step the tape with the marks was aligned parallel to the gratings on the Syren deck, the position marks fine adjusted, the holes drilled through the tape, and finally the tape removed (image 2). Images 3 – 6 show the current status of the model.
Thomas
What a brilliant idea !!!
Edited by CaptainSteve
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
Thank you Glakie and CaptainSteve, and thank you for all the likes!
I found specifically Tamiya masking tape a very useful tool, and not only for covering up areas when painting a part of the model. It sticks well to pretty much any surface, you can nicely write on it with a pen, it is pretty transparent, and it peels off easily. So it is perfect for marking things on the model without leaving any permanent traces.
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Thank you,Mike! I still have a lot of 'repetition' ahead of me  :)
Thomas
I finished the remaining 11 carronade barrels. I used Cladercraft’s 18 pdr barrels (image 1) which - as already mentioned several times in this forum - fit Chuck’s Syren carronade drawings very nicely. I modified them a little by reducing the elevation screw holder in size (image 2a, lower barrel original size, upper barrel reduced size), milled 2 slots for breech ring and gun sight pieces (images 2b and 2c), milled a flat area over the predrilled hole to mount a little brass cube with a pin as basis for the barrel hinge (image 1 and image 3a), and after silver soldering, drilling the hinge hole, and a “little clean-up” with a rotary tool and diamond burr ended up with the finished barrel (image 3b). Image 4 shows the 11 finished carronade barrels after blackening and coating them with Model Master’s Flat Lacquer overcoat.
Thomas
Image 1
Image 2
Image 3
Image 4
That must have pained you greatly having to paint those beautiful brass carronades Thomas.  :)  I know what you mean about measuring the drawings and making the other barrels work.  That also works in reverse as the 1:76 scale  24 lb. cannon on my kit are the same size as Chuck's 12 pounders in 1:64 scale. So those will work for the long guns. Still looking to source some brass carronades though.
GEORGE
beautiful work Thomas,
Nils
Current builds
-Lightship Elbe 1
Completed
 Every aspect of this build is very, very well done!!!........a joy to observe and another level to strive for..........
jp
Built & De-Commissioned: HMS Endeavour (Corel), HMS Unicorn (Corel),
Abandoned: HMS Bounty (AL)
Completed : Wappen Von Hamburg (Corel), Le Renommee (Euromodel)... on hold
Current WIP: Berlin by Corel
On Shelf:  HMS Bounty (Billings),
George, Brian, Greg, Bob, Sal, Nils, JP, thank you so much for your kind comments! And thanks for all the likes! Feed back in general, and this kind of positive feed back in particular, is always very welcome and highly appreciated!  :)
Thomas
Dirk, if you continue to build another couple of ship models before you turn back to your Syren I may perhaps be able to catch up with you  :)
Thomas
Thomas, this is a very beautifully crafted model, congratulations on your skills, for muppets like me struggling with my first build it is an awesome example !
Love it to bits, Thanks for allowing us to follow and learn from your build.
regards Frank
Frank, thank you so much for your kind words! I learned a lot of new techniques and good ideas from build logs of other members in this forum. For me this really is part of the fun besides building the model - the exchange of ideas and solutions to modeling problems  :)
Thomas
Thomas,
I haven't been on MSW for a long time and have yet to catch up with all the nice builds here. I have seen what can be done with a lot of skill and creative thinking to bring these kit builds to a higher level. Along with yourself, Dirk and Augie, to name a few, it's a pleasure to see the results of your hard work.
Mike
Edited by Stuntflyer
Current build - Sloop Speedwell 1752 (POF)
Completed builds - 18 Century Longboat (POB) , HM Cutter Cheerful  1806 (POB), HMS Winchelsea 1764 (POB)
Looking great with all her teeth Thomas. Nice work!  :)
GEORGE
George, Mike, and Bob, thank you so much for your kind comments! And thanks for all the 'likes'. I am quite happy not to touch a carronade for a while! But then there are still the long guns . . .   :)
Thomas
congrats for building this Beauty Thomas,
all nice and clean, a delight to see.... (as per your to date Status)
Nils
Current builds
-Lightship Elbe 1
Completed
Nils, Dirk, and Sal, thank you for your compliments! It is always very motivating to get this type of feedback!
Dirk, I knew that you could not help yourself but point out the next wonderful task on hand, the carronade rigging!  :D
Thomas
As always a REAL treat to follow!
Wonderfully done, Daniel
After getting distracted by a lot of other (mostly business related) projects I finally found some time to resume work on my Syren. Now the long gun prototypes, which I have shown on my model during the last 2 years, need to be replaced with the final versions. As there are only 2 guns I decided to make the gun barrels myself based on Chuck’s Syren plans. Images 1a – 1d show the different steps of turning one of the gun barrels. In image 2e the trunnion holes are drilled. After a “sanity check” with one of the gun carriages from the Syren kit the barrel is separated from the raw metal piece and the gun muzzle finished (img 2g). Img 3a shows the barrel with trunnions in place, the locations for the breech ring and touch-hole parts milled out, and the parts lying beside the barrel. The assembled gun barrel and Chuck’s plans are depicted in images 3b and 3c. The final result after blackening can be seen in image 4.
Thomas
Image 1
Image 2
Image 3
Image 4
Edited by Gahm
That's a mighty good looking cannon Thomas!  :)
GEORGE
