Thanks Tom, but it's only because I had forty som years of experience.
Bob
Current build:  SS_ Mariefred
First off I need to say thank you to all those who look in and click on the like button.  It’s so nice to log on to MSW and see that red signal that says someone likes what you said or did. Again thank you.
Now to get on with the boat.  The planking is almost done.  A little more clean-up in the stern and mount the transom and keel.  Also the planksheer so I can mount the stanchions and the bulwarks and then paint.  Wow, I shouldn’t list things like that it makes it sound like a lot of work.  Anyway here’s the pictures.
Bob
Edited by Cap'n'Bob
well.......it was a lot of work!  but,  you made short work of it  :)   the planking looks great! it will look even better with the keel and other bits of trim on there!   great job!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
John, Alfons, tarbrush, Popeye, thank you all for the encouraging words.  And now for one of the joys of the Darkside.  How to make that round stern on this boat.  I know, I must not think about it. I must trust the Force and just do it.
Bob
Bedford, I don’t know why I ever doubt the force?  It always comes through.
The planking is finished, the keel and the stern post are in place and the rail around the stern is on.  There’s a lot of cleanup to do but the parts are there.  Next its finish the rail and paint the hull and bulkheads, then the deck goes on.
Bob
looking really sweet Bob.....the stern has a nice shape to it  :)   like the concept with the stern rails as well.........nice!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Bob,
That transom, the main and monkey rails, and the aft ends of the waist at the fashion pieces look sweet. Well done sir. Did you put a little camber into the transom (port to starboard)? It appears so.
Cheers,
Elia
Elia
Rose Valley, PA
Arethusa: 1907 Gloucester Knockabout
John, Popeye, Alfons, and “likes” Thanks for the encouragement.
Elia, yes the drawings show a slight camber but doesn’t say how much.  It looks like about four inches from side to center in the profile.
Lawrence, glad you enjoy the show.  I did a web search for the Annie M Parker and saw the picture you posted.   That would make a fine model.  I might even add it to my list if you don’t mind.
Bob
Bob
I like this Little schoner of yours Bob
neat planking, fine lines, Looks like it is going to be a Beauty
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks Nils,
My hope is to come close to your fine work.
Bob
Bob,
'Standard camber' is 1/4" per foot of beam, but how many ships were built with 'standard camber' is another question!
John
John I didn't measure mine either.  Oh well.
Hi Bob
I thank you very much four your very kind words. I would be honored if you do add the Annie M. Parker to your list. In the mean time I will continue to search some build plans , for when I complete the HMS Victory,    Enjoy.
Regards   Lawrence
Lawrence,  I am not that famiilar with the Annie M. Parker but In a quick look around on the web the schooner American Eagle at 97 feet and its plumb bow seems very similar.
Bob
Lawrence, let me know about buying the plans.  The picture is fine I can see the similarity.
More and more I am loving the old schooners.
Right on.
Bob
Bob, I am glad I found your log. The schooner looks really nice so far. I am looking forward to following along.
Just catching up Bob, The hull is looking very sharp, I am looking forward to the rest of her.
Michael
Tom, Michael, thanks for looking in.  I'm with both of you, I am also looking forward to what is next.  The Lettie seems to have a mind of her own, but I do like where she's going.
Bob
Thanks Peetee for the kind words.  I'm glad it looks easy.  What you don't see is the number of times I take a part off to do it again, and again, and again . . .
Hi all,
The hull is finished.  When they rebuilt Lettie, which is what the drawings were taken from, the fore deck was raised to match the poop deck.  That’s why the deck measurement is longer.  They also extended the monkey rail all the way to the bow.  In trying to restore Lettie to original condition I installed the monkey rail around the stern, only up to the step in the deck.
I’m going to do something different this time.  I’m going to paint the hull and then install the deck.  On the one hand I won’t have to mask the deck; on the other it will be harder to sand the deck.  Well that’s how we learn.
Bob
Bob that is a sweet looking hull, An interesting trade off regarding the painting, be interesting to see how it goes.
Michael
Might be a good time to try using a scraper on the deck instead of sandpaper, because of the pre-painting. Like what you are doing and the thoughtful skill that is revealed by your work.
jud
