Lovely appearance! I love those Veritas chisels.
JD
Current build: Schooner Mary Day (scratch)
Previous builds:  Model Shipways Pride of Baltimore 2, Amati HMS Endeavour, Midwest Muscongus Bay Lobster Smack, Bluejacket America, Midwest Sharpie Schooner
  • 3 months later...
I obviously missed some posts here due to my habit of sailing in the summer.
What a nice looking platform Mike!
And since it's new years eve I take the opportunity to wish you a prosperous 2025 with lots of hours at your workbench!
Keep it up!
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
Thanks Håkan, truly appreciated :)
Yes, spending more time on the hobby is my new year resolution, even sneaked a couple of hours recently!
Best wishes to you and a lot of joyful days in your workshop!
Mike,
Yikes --- just catching up - 🙂 your work is so good!
Cheers,
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Time for some side projects :)
Fist I was concerned about the side-to-side alignment inside the hull.
The height measurement gauge is asymmetrical, and flipping it around may introduce some measurement errors. So I wanted to make a pointy thing that can be moved side-by-side on the top gantry.
There was a question in another log - "what is the mill for" - here is a classic example of a simple part that should be square with a precise and square-profiled recess. Mill is much more consistent and requires less skill than a "well tuned table saw", for example.
For the "pointy bit" I needed something very soft to avoid scratching the part. Basswood from the Model Shipways kit was ideal - I use it a lot as a soft lining for clamps and jigs.
I wanted to practice milling it in a rotary table instead of using lathe or a rotary tool. Not the best idea, the finish was not smooth at all (though such a soft wood is not making the task easier)
The resulting gadget. When in action - only one clamp is holding the arm in the correct position, while the assembly slides side to side. Should work even with curved beams, by probing the ends of the beam.
In action:
Next up was the problem of wood stock preparation.
Majority of the interior construction is made out of relatively small lumber, 2-4mm in 1:48 scale.  I could never cut those perfectly on a table saw, they always need a lot of finessing later on, resulting in an uneven strip. The wood sheets I have are 1 or 2 or 3mm thick, so more sanding is needed if you need something in between. The strip preparation was taking too much efforts.
A thickness sander would be ideal, but the only one in a small scale is Byrnes, which is rather a collector item nowadays.
DYI options are not appealing either, and they are still noisy and dusty.
Another alternative is a thickness planing jig. Most of them are too complicated for my task - with knobs and adjustments leading to inaccuracies, so I decided to use spacers. The range of required thicknesses is rather narrow - on of the largest parts (gun deck beam) is just around 4mm thick.
Decided to build the jig out of scrap piece of walnut. Did not want to risk using plywood, the grooves might end up on a wrong layer, resulting in an uneven surface. They are tiny, but need to be smooth.
Cutting precise grooves on a table saw is not so easy, but slow and steady does the job :)
Router plane helps to clean up the bottom of the groove:
Resulting jig, custom made for the miniature Veritas bench plane:
Spacers are made out of styrene, very good material for that. Easy to get in a variety of thicknesses, affordable, does not warp with moisture, fairly hard (to avoid compressing too much when planing). I have cut a bunch of spacers with a smallest increment of 0.25mm, should be enough for the range of thicknesses I need.
Jig in action:
Quite happy with it! Simple jig, but very effective. And perfectly quiet :)
The finish is incredibly smooth out of the box, so I can use the part right away with no further surface cleanup or sanding. If necessary - should not be hard to add a sanding block for the same jig.
I could easily get down to 1mm thickness, anything lower - and it is better to hold the "tail" of the strip rather than push it into the stop, otherwise it might get wavy.
Do you stack the spacers to get the variety of thickness in 0.25mm increments?
Alan O'Neill
Yes, I need to stack different thicknesses, of course trying to reduce the number of spacers (using one 2mm instead of two 1mm, etc). It's a bit similar to the dado stack on a table saw :)
Since the depth of the groove is around 4.5mm - you do not need that many spacers to tune to the proper thickness
Lovely, opposite ends of the spectrum. On one side, the mill with lathe setup and on the other a "simple" shooting board. Excellent!
Can't wait to see more progress 😉
Keep it up!
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
Very impressive! I may have to duplicate your jig.
JD
Thank you for the comments, as always! They do help to keep the momentum :)
To proceed with the pillars - I should first dry fit deck beams into their positions.
Laser cut beams provided by The Lumberyard in the "timber package" were surprisingly all wrong - too narrow, but way too high. Almost an inverse of the necessary dimensions. Also their arc radius is too small, compare it with the one recommended in TFFM:
Making them from scratch is an exciting little brain teaser. There are so many ways! :)
I opted for a template and a mill method.
Making the template is a matter of copying the curve from TFFM onto a piece of plywood and gently shaping it.
Rocking it side to side against the light helps to highlight the curve.
The shaping is done with a router-style jig, I added small tabs to limit the rotation of the part, just in case.
The beam is attached to the template using hot glue. Tried double sided carpet tape - it is too flexible, allowing the part to move on the jig.
But which cutter to choose from? Plenty of options!
After a set of experiments it is clear that you need two different approaches for each side of the beam.
Dremel cutters pictured here were quite bad, rubbing the wood rather than cutting it, creating a lot of force on the part.
The outside curve is best shaped with my go-to 3mm Proxxon cutter. No effort required to feed into it, it cuts like butter and leaves a super clean surface that needs just a gentle touch-up with a sandpaper. Here is the raw surface after milling (an unfinished blank is below, for comparison):
Foto2025-02-10112127.thumb.jpeg.58f3e1ab31fcd82f031ec03fe56b42ee.jpegFoto2025-02-10111132.thumb.jpeg.549a74e392ed3017014656cd22fed933.jpeg
However it does not work on the inner curve - it catches the wood easily and is way too dangerous to operate, since my fingers are quite close to the cutter when feeding from this direction. Using it was like trying to feed a tiger, would not recommend.
The best was to use the rotary tool sanding drums - a courser one to remove bulk of the material and a finer one for the last few passes.
It does not catch and provides just the right amount of resistance when feeding the part. And much safer - I brushed my finger on it a couple of times and it left no marks, as opposed to the sharp mill cutter that can eat you alive.
Of course it leaves sanding marks, but they are not too bad and are easily removed by hand sanding.
Also the geometrical consistency is not great, the drum is a bit barrel-shaped. But on that scale (and on the surface under the beam) that deviation is invisible and can be adjusted by scraping it.
Now I have first 5 beams, 10 more to go!
Foto2025-02-10135625.thumb.jpeg.b6068f34c2771410379ab68c920a3676.jpegFoto2025-02-10135120.thumb.jpeg.ba73722489bb0678307167c80e98f264.jpegFoto2025-02-10134930.thumb.jpeg.ff548d83e15bd0540aad512bdb79c3b9.jpeg
But now the difficult decision is the type of wood for the lower deck structure. These first 5 beams are made out of boxwood, should I continue the entire deck in box or should I try pear instead (same as on the aft platform)? It should darker over time and be similar to the inner planking.
So far I'm thinking to keep the lower deck in lighter colour, so it would be more visible deep in the hold when the upper deck is built. Both decks would get a very minimal planking, possibly no planking at all on the lower deck.
The upper deck would be in Pink Pear, I think.
But is the boxwood too bright for the lower deck?
Of course it is an artistic choice, but would really appreciate some comments and opinions! :)
I'm really bad at trying to find the colour match, but I understand how important that is in a long run 🤓
The lighter color of the boxwood on the lower deck would highlight the geometric construction.  Then the upper deck geometry would be highlighted the same?  Then using the pink pear for deck planking, furniture, etc.  The inverse would be nice also...darker geometric construction and lighter (scrubbed/washed/moped) decks.
Either way, your work is superb!
Thanks for the feedback and thoughts!
Brad, I will aim for some contrast indeed, do not like the bland look of monotone models where all elements are done in the same wood shade. At the same time not likely to paint anything, except some black wales and railings.
Giampieroricci's Pegasus is a great example of that - a couple of contrasting wood tones, black trim.
Potentially planking above the wales would be slightly darker (light pear?) than the one below (boxwood).
The trickiest part is that the visual taste would evolve over years of the build, so a style that I decide on now might get ugly by the time the model is completed.. :D
Edited by Mike Y
It is time to understand the internals of the ship's lower deck... And it is not easy, even after spending hours with the drawings (both Hahn and NMM archive plans) and my beloved TFFM books.
Would really appreciate help from the audience 🤓 Some conventions of the Admiralty drafts are elusive for me, hopefully make sense for colleagues with research experience.
Brief background: after the capture the ship was surveyed and slightly modified, and I am building the post-modified, Beaver's Prize version of the ship. The relevant bit: "Lower decks were altered to provide more space"
The aft section of the lower deck raises a lot of questions..
Here are Hahn's plans reflecting the original ship, note the strange step in the run of the lower deck. I guess it was done to improve the headroom in the officer cabins? Is that really common? Looks like a hack :)
But once I started looking in the Admiralty drawings from NMM (ZAZ4296 and ZAZ4297) the picture got even more complicated:
(the modifications are in dotted lines, that's what I am aiming for).
1) That strange step is still there, but the very next beam is raising the floor back, so it looks like a trap designed to make people trip? :) Why not just continue the deck in a straight and fair line?
2) Additional beams are added and the deck continues further aft, making the Breadroom significantly smaller. I guess the "additional space" was not for provisions, but for officers, makes sense
3) Btw, what are these highlighted sections on the deck draft? Are these gratings, or scuttles, or ladder ways?
Here are two plans aligned:
And the last one - what are these two rectangles?
Meanwhile I keep cutting some wood while trying to avoid a modelling block because of these puzzles :D  And surely there would be more of those going forward...
Possibly it is reversed?
The lower section is on centre for more clearance passing through and the raised levels are the officers cabins?
They'd step up into them.
I admit it is all unexpected.
I am just guessing.
Waiting for someone "in the know" to enlighten us both!
Alan O'Neill
At the top of the deck plan there is the comment "the ticked lines and those in green are proposed alterations, the others are as she is now".  Also, look where the magazine lantern is in location to the faint word "magazine".
Toni
Member IPMS
                           Utrecht-1742
Ladders are usually shown in the companionways. If you can look at draughts of similar vessels, usually the layout of these is similar.
The two rectangles are scuttles (proposed - see Toni Levine's observation). They would have had solid covers flush with the deck, with lifting ring bolts.
Thanks a lot for the ideas!
After looking into Swan's and others layouts the rectangles are now solved - these should be the Fish Room hatches.
The only mystery remaining is that step down between two adjacent beams (marked with a question mark in my previous post). It does not look like a sloppiness of a draftsman, he could have easily continued the dotted line to join the "proposed alternation" with the rest of the deck. But he kept those separate on purpose...
upon reflection it seems the headroom is needed on centre below this deck, in the hold.
the higher line seems like the wings (officer's quarters)
hopefully someone with more experience can confirm.
Alan O'Neill
Officer quarters are on the "second floor", right above the dotted line. So this modification actually makes their cabins smaller while increasing the headroom below, in the hold.
The "step" is around the area with ladders that get down to the hold.
Of course I can just remove that extra beam and continue the deck in straight and fair line, like so.
But it feels wrong to just "fix" any weird quirk you find on your ship. Strong feeling that I am just misreading the plans and it has a purpose, but I can't find any similarities with similar vessels of that period...
Seems correct as you can see the light below reach up to the upper beam.
Alan O'Neill
Two thoughts: One, sometimes the purpose of something on a plan only becomes apparent when you model the ship in 3D. I've had many "Aha! So that's why they did it that way" moments. Two: were those 'proposed alterations' actually carried out?
Thank you both.
Druxey, I tried imagining it in 3d (also using Swan and Pandora 3d drawings to help imagining it), and still can't imagine the dip being in place there. I'm likely reading too much into the plans.
According to Hahn's book (Ships of American Revolution) the proposed alterations were implemented in reality, and the ship went into British service with all of them in place. Would not doubt his research, definitely not the can of archived worms that I want to open :)
His book does not mention anything on the lower deck details, they were omitted entirely from his model.
Ok, the modelling block is over, decided to ignore that dip and make a normal straight lower deck like on all the other ships:
Remaining beams are cut out of boxwood. Cutting curved blanks really makes a big difference, I extracted 10 planks from the same width of a sheet instead of the previous 6.
They are rough from the bandsaw, but milling setup takes care of it, and the result are nice and smooth beams :)
Marking beam locations was a bit nerve-wracking. Pencil was not precise enough when working on such angle, but a marking knife is perfect for that job. Taking a lot of care to not scratch anything around...
Finally! I can go back to building instead of overthinking :)
Edited by Mike Y
Maybe it is one of those AI rendered pictures where people have 13 fingers and three arms?
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
