Never said it was easy :-)
But these are just the questions to investigate, see if brings further our understanding.
XXXDAn
@Kevin
Looked at Longridge and I believe that that was more a temporary fix with the two lines running upwards that loosely.
XXXDAn
Well it all seem's feasible , but remember dropping anchor was done mostly if not always for bigger ships in port.
So all hands to the ropes.
Frank  :piratebo5:
Edited by foxy
Feasible yes - that says it quite right :-)
Even though letting go the anchor was possibly more spectacular - if seen from the lower deck with the flakes running out - getting the anchor up and about was more laborious.
Lets do the count: 260 on the spill, 30 handling the messenger, another 50 stowing the cable in the hold. Then another large crew on the forecastle getting the davit out, catting and fishing the anchor, the spill midships manned for the catting and fishing - is 800 men enough one wonders ...
XXXDAn
800 is probably more than enough, Daniel.  I would imagine that the davit would be set up while the messenger, etc. were being set up.  We have to remember that the gun crews, for example, didn't work anything but the guns or do maintenance (like holystoning) so they would have been the labor for the capstan, stowing, etc.  I'm guessing that some things overlapped such as fishing and securing the anchor but every man had his duty.
Mark, do not forget, some left specimen are still needed for the handling of Yards and sails :-)
I think, it is getting tight, by the means of manpower.
Henry, it would be funny to break this down into the single steps just to see how this works.
XXXDan
I think we can assume that working the capstan to haul the ship up till the anchor cable is 'up and down' (the actual term we used to use in the Navy) and then weighing and hoisting the anchor out of the water would take the longest.  The stowage of the cable in the cable tier would run concurrent with this.
The set up, i.e.: Laying out the messenger, breaking down stanchions, and rigging the fish davits would not take that long.  I could see catting, fishing , and stowing the anchor taking , timewise, something in between the two.
I bet I could find more info if I spent more time researching.
Henry
Laissez le bon temps rouler !
Of course, you still need men aloft shaking out the sails.  As soon as the anchor is aweigh the vessel is adrift, so you need to set sails for her to be hove to while you finish raising the anchor.
Henry
Right then - my turn to throw the cat amongst the pigeons
you are at sea,
When is the anchor rope removed from the hawse, how difficult a job was it and have you modelled the bungs to replace the rope
I am asking the question after seeing this print by Geoff Hunt
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
Hi Dafi
In the following link you will find the full process of hauling up the anchor, albeit in the late XIX century, and getting under way.
The capstans are still manual and there is the sequence of operations, the stations for the crew, etc.
http://www.hnsa.org/resources/manuals-documents/age-of-sail/textbook-of-seamanship/getting-under-way-under-sail/
hope this helps
Zeh
Great work as usual Daniel. I don't get as much time here as I like as between life and family I wish there was more hours within the day. However, I have learned and continue to learn new things from your work and Dave's 1/96 Constellation build on this forum. If I can do half as good with my ships...I'll be fully satisfy ;)
Mike
Thank you Popeye, I will pick up fishing the anchor as soon as I have more time again, so every help wi ll be welcome :-)
Ken, the anchor rope was removed as far as I know as soon as they were leaving the shore. Retrieving it was easier in my opinion, replacing it much more a task using a messenger rope to pull it in place and keep it in place while the lashing was done. The plug still will come of course.
Thank you Zeh, will study this :-)
Dave, ships were always a wet case in those days ;-)
Thank you Mike and Lawrence, always a pleasure to entertain you :-) :-) :-)
XXXDAn
As I do not find much time to do bigger things, I was looking for bits that could be done in smaller steps :-)
And know something very hurtful for all lovers of the classic look, not only the "proposed pink-punk" is new to get used to, much more hurtful and more provable things are on the way ;-)
By the "rediscovered" Turner drawings from after the return from Trafalgar one can see clearly the build bulwarks instead of the timber heads. Also 3 ports are to be seen. Compared to the Jotica version I used the smaller holes to give access to the timber heads as seen in the Boyne/Union classes and aft of the waist on todays ship.
Took me some thought to get the smooth curve into all 3 dimensions, so I started with bolting on a base.
Then determined the position of the ports with some ledger shrouds ...
... glued on the inner planking, opened the base at the gunport ...
... temporarily placed the timber heads, fixed in the internal structure ...
... glued on the outer planking and opened the openings.
The handrail are two evergreen strips glued together to obtain a nice curve.
Cheers, Daniel
Very interesting results based on the research, Daniel.   And with your build, that research is realized in physical form.  As for "hurtful"....  to who?
To the traditionalists :-)
XXXDAn
neat way of building up the bulwarks.....I like the way you did it.   very nice work  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you Jan, Poppy and Frank!
@Jan: Worse!
XXXDAn
Worse???  Pink stripes then with maybe green wales and purple curtains on the gunports?   Oh.. and paintings on velvet in the great cabins....    :)  ;)
No, I am even NOT taking the flower power sails as reference ;-)
XXXDAn
Edited by dafi
The admiralty would kill me if I brought such a monster bottle home ...
XXXDAn
OK - Deal!
...ähm...
... anybody an idea what is in there? Nelson-brandy?
XXXDAn
