hi sonic
           nice start, ill be watching your build with interest, im thinking of starting this ship soon :rolleyes:
current builds.
kit H.M.S.Unicorn, scratchbuild H.M.S. Albert. X section Triton, Bluenose.
Good Luck with this as it looks interesting.
Later 42rocker
Current Build -- Finishing a 1:1 House that I've been building for a while
Current Build -- Triton Cross Section
Thank you Clonmelboy and 42rocker for your kind comments! And yes Clonmelboy you should start the Triton build is one of the best for first build. 42rocker  I will need more then luck because is my first build and I'm learning as I go :rolleyes:
Greetings, Sinan :pirate41:
Build log:TRITON POB 1:72
Ahoy, Sinan :D
Very impressive first build
Looking forward to your next post
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
Hi Sinan!
Looks like you're off to a good start there.
1:72 vs 1:48, you don't make it too easy on yourself with that scale ;) on the other hand, some details can be left off. At 1:48 I guess one wants to put in as much details as possible but at 1:72, some things can be "forgotten".
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
Thank You Pete, J.Pett, Dida and Hakan.
Dida the wood that I use for the stem and keel is pear, for the other parts I will use some sherry, poplar and walnut.
Hakan Yes is harder to this scale and I will try my best not to lose to much details.
For now I'm struggling with the bulk head tapper at  the stern and stem, hoping I will manage it somehow. Pictures of my error soon :P
Welcome back Sinan. It's nice to see yo model also at MSW 2.0
Regards Christian
Sinan,
Post a picture and ask.  With the collective minds around here, you'll probably get at least one good, solid answer.
I didn't think that preparing for planking e.g. fairing the hull, and then inner framing will take that time to do. And on the other hand my modeling time is gone pretty small. I hope I will start planking soon :huh:
I'm still fairing the hull (struggling really :blush:) and I'm not sure about the most complex bulkhead No 27 or the stern one. Below You can see on the picture I'm not sure about the fairing direction. Please help about it is it like on the picture (top view in relationship with stern - stem direction) or is opposite direction. Thank You !
Hi Sonic
my interpretation (from engineering experience of drawing interpretation):
- brown line is the profile of the bulkhead's side facing the stern
- black line is the profile of the bulkhead's side facing the stem
At top, bulkhead rear profile is larger (port to starboard) than forward profile (an a bit higher, too)
At mid height, bulkhead rear profile is narrower than forward profile
At low height, bulkhead rear profile is again larger than forward profile. This looks strange to me, as Frame27 is close to stern and hull lines should become even more narrow.
So: you should obviously cut the frame following the enveloping line (= the most external, whichever it is, brown or black), then draw the brown lines on the back side (facing the stern) of the bulkhead and the black lines on the front side (facing the stem), then sand the bulkhead profile so to join the front black line to the rear brown line.
Also note that you have to carve two notches on the front side of the bulkhead, for gunport lintel and gunport sill.
Curious to read other answers, to see if I'm correct (I've very few experience with this type of interpretation).
Following your job with much interest, this could be my next project...
Ciao
Fam
Edited by Fam
Joint building:
   Brick de 24, 1/48, jointly with Jack Aubrey (POB from Ancre plans)
Works in progress:
   USS Constitution Cross Section, 1:93 (POF bashed from Mamoli kit)
Completed models:
   Santìsima Trinidad, 1/90 (POB heavily modified DeAgostini kit)
   Genoan Pinco, 1/50 (POB bashed from Euromodel plans - my current avatar)
   Viking Knarr, 1/72 (POF from Dusek kit)
Thank you Fam for your reply. I was thinking the same about it because for all of the bulkheads is the same case but this one was really strange. I made this two templates one with the black and one with red line. I hope this will work.
Thank you Guy for your estimation :) I hope l start with planking soon. For now I'm working on preparing the hull for it. I'm on a fairing and soon I will start on framing the stern and gun ports. I post some pictures soon I hope because I didn't know that this is the most time consuming job.
Leeetle update.... I almost finish with the outside and inside fairing (You can see the hull on some parts it looks like the creature from Frankenstein because I sand to deep and then I glued some thin strips of wood :) I think is a boo boo). For rough sanding I use a small disc sander attach on the rotary tool. The small disc is made out a bottle  cap  cut to a disc with oversize sandpaper glued on. I "steal"  this idea from The Matthew project  and is work really good not only for fairing but almost for any sanding. Here are some pictures :)
Nice sanding tool and great tip.  You've done a great job on the Triton and I'm looking forward to seeing more.
Looking very good,I will be looking forward to the planking.    Larry
With Age Comes Wisdom,I'm Still Waiting!
Current Builds:Syren.Triton Cross section.
Completed Builds: Virginia by AL
                           King of the Mississippi by AL
                           Constellation by AL
  • 4 months later...
Sinan, very nice start...
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
Sinan, this is real thing. No Tehnodidakta
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
  • 2 months later...
