This site is the coolest. I keep learning new things and find inspiration in builds and techniques others have done. Lately I have been working on the water barrel and have adopted ideas from my friends Ferit and JPett. Ferit's barrels in his Berlin build are things of beauty  (well actually his whole build is!) and JPett showed the coolest technique for running toothpicks chucked in a Dremel through a drawplate.
http://modelshipworld.com/index.php?/topic/1799-frigate-berlin-by-ferit-kutlu-corel-scale-140-year-1674/page-3#entry41545
http://modelshipworld.com/index.php?/topic/45-rattlesnake-by-jpett-model-shipways-ms2028-scale-164th/page-8#entry34842
The water barrel on the whaleboat had to hold enough water for 5 people and I'm guessing it was somewhere about a pony keg size, maybe 7-1/2 to 10 gallons. The oak barrel itself probably weighed 15 to 20 lbs and filled with water that would be from 77.6 lbs to 103.5 lbs depending on capacity and barrel weight. It wouldn't seem likely that the crew would pull a cork from the barrel, hoist it up and chug a lug from it like a canteen. As heavy as it was it would also need to be well secured since a barrel rolling around loose in even small swells could easily break an ankle or leg or damage the boat. The plans show the barrel stowed in the rear compartment. It seems like it would be very awkward to unlash the barrel and drag it out whenever you wanted a drink. Ferit's build gave me the idea of mounting the barrel on a cradle and sticking a tap in it. Seemed like a practical solution so I decided that's how this whaleboat's water barel would be set up. I found pictures of wooden barrel taps online and did my best to copy one.
A real tap
My scratch made tap
Scale check!
The pieces for the tap were fashioned from a white birch toothpick. Small holes were drilled for the handle and the cross spigot. I was surprised how small you can turn the toothpicks down. The base of the handle has a very small round tenon that was glued into an equally tiny hole in the cross spigot!
The cradle in progress. The stretchers have little dovetailed lap joints just because I'm a geek! :)
The assembled cradle
The barrel lashed to the cradle with its tap installed
Of course the crew needs something to drink the water with!
My wife got me an Optivisor with a Quasar led light kit on my last birthday and it was a real help while making this stuff. I had an Acuvisor before, but it has plastic lenses while the Optivisor uses optical glass lenses and are much nicer. The lights are always shining where you look. Highly reccomended!
Edited to add missing pictures back - thanks for the heads up Keith!
Edited by Salty Sea Dog
-Buck
Current build: AL Morgan's Whaleboat (1st build)
Kits in the ships locker: I cannot confirm nor deny that there may be a few kits in there...
Very, VERY impressive.  I can see you doing ship-in-a-bottle next !   DSiemens can tell you how to 'make' water.
Thanks for the comments on the Optivisor.
Edited by Augie
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Am I seeing your cradle right, is the rails dovetailed into the face plate?  If so... wow...and beyond that, wow everything is...wow.  Your details are beyond amazing, (does "wow" trump "amazing"?). Seriously, wow.
Brian
Hi Buck,
Could you tell me; this Optivisor, how many diopters has it?
And could you build a new Morgan's Whaleboat (2nd build) of which the lenght will be as equal as the lenght of your scratch tap?! m0974.gif
Hi Ferit,
The Optivisor can be ordered equipped with different lens choices. I have the 2x lens. I wear eyeglasses, and as I've gotten older, I now use bifocals. Looking through my bifocals and the Optivisor, the focus is best at about 10". Without my glasses, it focuses at 4" and objects appear larger and are easier to work with. Here's a link showing the lenses:
http://www.doneganoptical.com/products/optivisor
They also have an optional loop that I may get to try really small stuff!
http://www.doneganoptical.com/products/optiloupe
I don't think I could make a whaleboat that small, but this guy could!
http://artisticthings.com/the-miniature-world-of-nikolai-aldunin/
Brian
Hi Brian!
Yes those are lapped dovetail joints. You can click on the pics to enlarge them and see them better. I think "wow" does trump "amazing" but I am trying to improve my skills even further to become "Buckrageous" ! lol8.gif
Is your move to your new house still on track?
Best wishes,
-Buck
Hi Keith!
I had really thought about mortising the center post but didn't. I decided that it would be too easy to mess up trying to make dinky square holes and that would ruin the pieces. Darn it...nothing Buckragious about that. :( I might put trenails in it though! :)
-Buck
Wow, this is nice. I'm not so sure I'll go to that much detail on my 7 boats, or I might never finish. This are very nice.
John
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
Thanks John! I know what you mean. I've been about to finish this thing ever since I started this log! lol8.gif I can't imagine doing 7 of them. At the scale of your ship, how long will your boats be?
-Buck
Buck - astounding work! I got the house with the view - now just counting the days until we get there (34)
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Why? dont you have a dinky mortising chisel that goes with that dinky dovetail saw you used? :D
I must have misplaced the dinky chisel when I was hunting on the floor for the dinky sharpening stone!
Congratulations Wayne! That is so cool. Wishing you a trouble-free move and I'm so glad that you will finally have a larger drydock area!! Thanks for the nice comment.
-Buck
So no mortise and tenon, hum....
well if they are not Buckrageous maybe they could at least be considered Buckalicious. Which, if there was Cognac rather then Perrier it would definitely get my vote. One does need more then bubbly water when rowing in a whale post nantucket sleigh ride, might also help settle the nerves a bit also after all that high adrenaline activity.
Holy smack! What amazing work on some tee-tiny features. Dovetail joints?!?!? :o My hats off to you!
Perrier on a whale. Who would have thought they had it so good! :D
I have got to get me an Optivisor and LED light system. That is an awesome magnifier. I can see where it would come in very handy with the detail work.
Looking forward to seeing many more photos of your work.
Eddie
<p><span style="font-size:12px;"><strong>"Be yourself. Everyone else is taken." - Oscar Wilde</strong></span></p><br />
<p> </p><br />
<p><a data-ipb='nomediaparse' href='<a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/2720-elsie-by-4whelr-modelshipways/#entry73752'>http://modelshipworld.com/index.php?/topic/2720-elsie-by-4whelr-modelshipways/#entry73752</a>'><span style="font-size:12px;"><strong>Current Build - Elsie</strong></span></a>
ZyXus, Eddie and Robbyn- Thanks for the great comments- much appreciated. Eddie- the OptiVisor with lights is really handy with the little bits and when working with thin threads. Amazon seems to have good deals on them or you can get it with lights as a package deal from Stewart McDonald (a luthery supply house):
http://www.stewmac.com/shop/Tools/Special_tools_for_Inspection/OptiVISOR_Headband_Magnifier.html?actn=100101&xst=3&xsr=781
-Buck
Buck - Thank you for the link. Will definitely check them out.
Eddie
<p> </p><br />
Buck,
Just catching up on your project. Whoa your miniature detail work is spectacular. I remember loving the axe, well you've outdone yourself again. Supper cool. Your gorgeous super sweet little whale skiff will be so full of amazing supplies that it might not float (:-)
Lov it...cheers
PS: Thanks for the reviews on the Optivisor lights. On my list...to order from Amazon
Michael
Edited by md1400cs
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Hi everybody!
Things have been nuts this last week and are about to get nuttier. I just got back from Colorado and I accepted a new job out there. I will need to get my current house ready to sell, pack up everything and hopefully find a new place by Sept 1st. I hate to leave my current place since I have the perfect shop and man cave set up.
I don't know if I will have any build time with all that I need to get done for a while, but I'll try to keep up with your build logs.
Best wishes,
-Buck
Congratulations, Buck - I can most assuredly empathize with the pressing demands of a move!
Good luck with the change - and don't worry, we'll be here!
Wayne
Epictetus
Kansas' loss is Colorado's gain!  :)  :) :)
Don't worry about building ....... you're going to have much to do.  Hope it all goes well and that you've found yourself a good opportunity.
Take your time.  We aint going nowhere and your work is worth waiting for.
Keep us posted........and best of luck !!!!
Augie
Previous Builds :
Ahoy Buck
I understand the Colorado Shipyard is run by some guy whose always either fishing or flying
Good luck with that :D
'Lol"
All kidding aside, Colorado is a great place to call home. Best wishes for a quick sale on the house and a pleasant moving experience (if there is such a thing)
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
Buck,
I just gotta' ask... that tap doesn't turn or work, does it???   :o  :o
Good luck on the move.  Do keep an eye out for that fellow who runs the Colorado Shipyard.  He's either fishing for moose, or fishing for trout using an RC bi-plane.
Congratulations on the new job Buck, but I am sorry to hear another Kansan is moving away :( . But I get it, you gotta go where the work is, that is how I ended up here last year myself.
Hope everything goes smoothly in the the house selling, house hunting/buying, and the move itself.
Robbyn
If you risk nothing, you risk everything!
Current builds
Syren (Model Shipways) version 2.0
AL San Francisco II
Mordaunt (Euro Model)
Completed Builds
18th Century Longboat designed by Chuck Passaro
In the closet
Battle Station
Al Charles Morgan (1980s version)
