yea....I have a couple of my  'plastic pals'  using it.....they've been using another paint as well.......Jo Santos  {hope I spelt it right}.  believe it or not,  they've also been using windshield washer in mixing it as well.   I haven't tried it...I'm too much of an enamel fan  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Small update this time from the paintshop. I painted the hull red with (I hope) the right red colour. Tomorrow I will mark the waterline and will paint the upper part of the hull.
looking good Kees!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
That is a very nice looking hull.  Well done.
Bob
Current build:  SS_ Mariefred
I bought a nice looking prop but its much to shiny. I like to paint the ship like its in use so it needs a little weathering. And so does the propellor. In the past I tried to do this with paint but that didnt work out well. I remembered a proces from scienceclasses called electrolyse with an katode and an anode. How that works you can find on the internet but the pictures below show how I (mis) use it.
Here's what whe start with. A nice and shiny propellor.
First an conductive fluid wich means you dump some salt in warm water and give it a goed stir.
Then the power supply. I use one with 9V DC and little amps
Then separate the minus and the plus and connect them with the prop and a piece of metal with zinc on it. Try in wich order. If you have it right the prop will produce lots of small bubbles later.
Then place them in the water. Make sure the two pieces of metal do not touch eachother. I use some clips to clamp them to the pot.
When you do it wrong the zinc piece will produce bubbles
And when you do it right the prop will produce lots of bubbles
Then leave it for some 15  minutes but try to inspect the prop during the process. It will go fast and if you are satisfied with the result stop on time. Its good to rub the prop with a rag so you can see the endresult.
Looks nice allready
And the final result. Iam very satisfied with it. I admit its a little bit ghettostyle but it works to me.
Edited by kees de mol
Kees,
The weathering with paint is done with salt as well. Quite a few instruction movies on YouTube for model cars, railway wagons, etc. Maybe for a next time, though I like this solution better. Rersult is marvelous
Carl
Yes I know the salt-methode. Look at my log of the FR927 to see what I did with it. But its not comparable with 'my' technique. They are both very different.
a friend of mine told me about this method.......I really haven't had the reason to try it yet.  it works well.   Bill Nye would be proud of you.......very well done!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Some photo's of the paintshop. Painting is progressing very well but its a lot of work. Also some forgotten jobs to do. It was very hard to find out wich colours to use and where. I have only one hazy colourphoto made from a distance. But I think I have things clear now.
Kind Regards, Kees
looking nice Kees............look'in nice!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Car spray paint ...? You're moving fast my friend. Your paint job is looking good!
Carl
 The Motip is the plastic primer I use and the other spraycans I use for several jobs. For the ship I onlu use my Airbrush and Revel Aqua colours.
Kind regards, Kees
That's a surrise, I would have thought that all superstructure and railing was always painted White.
don'tknow where I got that idea, but now it's proven wrong :)
Great looking ship she is.
Jan
. I would have thought that all superstructure and railing was always painted White.
When the ship was delivered the superstructure was white indeed but later she was painted green in the collours of the shipping company 'Kennemerland'
Here on this colourpicture (the only one I have found) you can see the wheelhouse was green.
The frontdeck was green also as I was told but the railings were white.
Kind regards, Kees de Mool
Today I finished the wooden deck. It was not easy and I made some mistakes but I am glad with my choice to make a real wooden deck. Later there will be stuff on the deck so it looks even better.
that must have been an absolute pain to do!   I don't envy you on the clean up...but when you do,  it's gonna look great!   I use a black archive pen for the calking.....India Ink doesn't seep into the wood as much.  I used to use crayon.....works well,  but scraping needs to be done due to the crumbs and cast off rubbings.   looking at all those nooks and crannies......you did an absolutely spectacular job.   are you going to use a clear poly?   I use semi gloss lacquer, but I've never use it on plastic......I think it would be OK,  if you chose to use it  :)     super job!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
You've got your work cut out for you, as Popeye already pointed out. Must look awesome when you're finished though ...
Carl
Progress in the paintshop. It's a real pain in the **s to find out wich collours where to use because I have only black/white pictures but with the help of some old sailors it will be a succes. Al collours will be softened later with washes and dry brush.
except for the yellow mast it starts looking like its straight from a Tintin movie, I am sure there will be plenty of debate among these old salts about the colours, by the way, I think that green looks really authentic, blends well with the other colours
Edited by Jan B.
OMG!!   I remember TinTin  :D    so cool!    super paint work Kees.........really starting to come together.   very interesting how you got the information for the build.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I had planned not to update anymore before I finished the Antje in total but I could not resist to post some progress pictures. Before you look at the pictures please keep in mind that the work is not finished yet. Lots of finising paintwork has to be done and offcourse a matt finish to give a nice uniform shine on the work. First 3 pictures to show the work on the frontdeck and the last pictures one with a Dutch Florin again to show the dimensions. (A florin is less than an inch)
Portside from the bow
Portside from the rear
Starboardside (Iam not satisfied with the wooden deck yet)
And the last one with a Florin
Kees,
Just stumbled upon this log - and I'm really bummed I only just caught the tail end! You've made a really impressive ship - it captures the essence of a workboat wonderfully!
~Ben
~ Ben
___________________________________________________________________________________________________
Current Builds:
'Doll-Boat' - 1:12 scale 40' Cruising Sailboat
S.S. Edmund Fitzgerald - 1:350 plastic kit w/ Photo Etch Parts (On Hold)
fore deck looks awesome Kees....really like the colors and layout.   flats always work well in making aspects stand out.   no worries about not being finished,  this is progress!  :)
did you try to add filler to the deck?  it might be a pain to do,  since the deck is populated somewhat,  but perhaps a medium stain or wash will darken it up.
     for some plastic kits,  aftermarket wooden decks is done as a sheet,  that can be laid down.   it may have benefited you better,  if a template was made and assembled it that way   {lot of extra work though}.    then it could have been sanded and sealed at that time.   for this reason {besides others},  is why I opted to do wooden deck for my United States,  rather than try planking over the plastic ones.   I like what you did here,  but it might take some effort,  if your still unhappy with it.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Some last progress on the model before completion. I made some decklights out of plastic. Painted and weathered them to make them look like brass. Also made a sail on the reardeck and I finished the deck with some boxes and other things. Last thing to do is to add the (later added) trawlportal and some rigging.
decklights
Decklights fitted. Also the nameplate is added
Reardeck
This is how she is now. Its the set-up of the ship like she was build in 1959. Later in 1969 a frontportal was added (as seen earlier in the thread)
wonderful use of color Kees.......she's come together in a big way!  ;)  spot lights look way too cool!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
