:omg: I fear I've hit a wasps nest!!!
Thank you very much, firstly, to all of you guys, druxey and mtaylor and JimLad, I really appreciate :)
I always thougth there was only one general rule, spread all over the world... :o of course it was a sin of ingenuity! Even in the British world the rule was not always observed, as the Edwin Fox seems to show.
But probably in the French shipyards there was only the rule of the shipwright, changing from a shipyard to another. I mean: there is no rationale, I think, in starting coppering from the waterline downward or from the keel upward, neither for new ship building nor for ships hull maintenance.
I've access to very few historic sources, but those that you guys checked are not showing a clear rule: maybe there is a 'Shipyard Rule', who knows?
Should this be the method I've to follow... I'm not documented at all on it: I only know the opposite one unfortunatly.
Do I have to lay the waterline strake first? Or do I have to start with the line of plates just below the waterline and then finish laying the waterline plates? And of course I've to start from stern and lay the plates going forward, but at a certain point they will start to taper: how do I calculate the correct tapering?
In other words: is there any step-by-step example here in MSW to read and learn?
Thank you very much for your support
Bye
Fam
Joint building:
   Brick de 24, 1/48, jointly with Jack Aubrey (POB from Ancre plans)
Works in progress:
   USS Constitution Cross Section, 1:93 (POF bashed from Mamoli kit)
Completed models:
   Santìsima Trinidad, 1/90 (POB heavily modified DeAgostini kit)
   Genoan Pinco, 1/50 (POB bashed from Euromodel plans - my current avatar)
   Viking Knarr, 1/72 (POF from Dusek kit)
I know that in British practice, the merchant ships were plated from above to the the keel, but it was from keel to wale in Navy yards! This explains Edwin Fox, a merchant ship. Then there are the French....
It now appears to me that the illustration posted (Planche VII) that the overlap is such that one starts at the wale and works down. (I clicked the illustration to enlarge it this time.) Sorry if I created confusion in your mind, Mark!
Hi Fam
In July 1778, French did  the first coppering on the frigate l' Iphigénie, imitating the English. Copper was coming from Hambourg, Germany.
There are 2 ways to copper the hull, the easy way and the hard way.
The easy way is back to front and bottom to top.
The hard way, the real method is described in Tome 3, last pages  of the 74 guns by Jean Boudriot.
This subject comes back often, you probably also can use the search button.
Hi guys
I really appreciate all your contributions, now I have some less doubts about how to continue. Thanks to all the above information, I think we can recap that:
  • coppering from stern to stem is confirmed to be applicable also to French ships (all contributors)
  • coppering from waterway downward to keel is not wrong for a French ship of about 1810 (Gaetan), but also for a British merchant ships (Druxey, Jim Lad)
  • coppering method varies from ship tp ship within the same navy and seem to depend by period (mtaylor)
  • coppering downward from waterline is more difficult than the opposite (Gaetan)
Unfortunately I don’t have access to the monography by Jean Boudriot to read about the method, and was unable to find anything in MSW explaining, or showing, the up-to-down process. I’ve only found these pictures (sorry, I’ve not asked permission to the owners, no problem to remove them immediatly):
Vaiseau de 74 guns (posted by Gaetan Bordeleau)
Other detail shots of this ship (see in Gaetan’s buildlog of ‘Le Fleuron’) show that it was coppered the standard way.
La Crèole corvette 1827 (posted by Johann-Archjofo)
Thise are clearly showing the up-to-down method, with 4 copper lines parallel to the waterline, but the coppering phase pictures was not posted by Johann.
I think that what Gaetan is meaning is about the transition between the parallel lines of plates (I’ve just one in the Brick) and the upward bending following lines: at a certain point away from midship they start to bend up, so that the plates have to be cut where they overlap the parallel lines.
The upward bend is very shallow at midship and becomes much more evident at poop and bow: whereas the latter is easier to see (and to do!), the former is more difficult ... and of course I don’t have any single picture of this area!!!! :angry:
In the meanwhile, these are my first attempts to make the copper plates. I’m using the method by Dirk (Dubz):
It’s working quite well, and it’s also fast... after the stamp is produced!
The wooden stamp is Yellowheart (boxwood) which is quite hard and dense; the pins are made of steel, come from a dressmaker supply and are glued with CA into slightly smaller holes.
My only concern is about the pins sinking deeper and deeper into the wooden support as a consequence of so many hammer hittings...will see!
Stay tuned
Fam
Joint building:
Works in progress:
Completed models:
I think you have it, Fam.    Now that I think about it, I had a link on plating French ships and can't find it.. I'll keep looking.
Nice work with the stamp.
Edit... the site I had in mind is dead... <sigh>
Edited by mtaylor
November 24th, 2015
Hi all
while playing with the copper, at the same time I’m proceeding with the preparatory steps that I’ve described above.
Hawse holes and water scuppers lining
Both these jobs are now completed with the method I’ve described in the previous posts: in the end I didn’t try with the brass tubes because the result I’ve got with simple paper is fully satisfactory for me. Here are a couple of shots (still not painted):
Bowsprit housing
Every preparatory job has...a preparatory job to be completed before!
So before building and installing the gunwales, I had to clear the housing for the bowsprit mast in the bow portion of the bulwark... but before being ready to do this task, I had to build the large bitt housing the foot of the bowsprit (btw, what’s its name?).
I used Cherry wood for it, and just followed the drawings in the Ancre monography. I left the two legs longer than needed, then cut two square holes in the deck planks to house the legs. The holes are as deep as the deck planks thickness, so the bowsprit bitt is fixed directly to the false deck plywood.
The final height of the legs is then adjusted so to have the correct distance between the deck and the horizontal beams of the bitt. Then, after adding a couple of brass pins to the center of the bitt legs, the bitt was positioned into its location. No glue for now, but the fit is so tight that it is not really needed while I’m checking the bowsprit position. The next pic shows the bitt before shortening the legs.
To carve the bowsprit housing I firstly prepared a dummy of the mast, using a 10mm diameter dowel.
First step was to measure the slope of the mast from the plans, with respect to the deck surface, which is about 19.5 degrees. Then I cut three faces into the foot of the dummy: first was a sloped surface (1) to match the deck: the easier way to do this is to use the disk sander with the tilting table set to 19.5deg.
Then I had to sand the foot of the dowel at 19.5deg from the dowel section (2), so that it remains vertical w.r.t. the deck. Again, with the disk sander help...
Third I cut two flat and parallel surfaces on the sides of the bowsprit foot (3), so that its width is exactly the same as the distance between the bitt legs.
After these steps were done, I started cutting the bulwark above the bow timbers: initially with 10mm width, the same as the bowsprit diameter, then progressively narrower until obtaining a ‘U’ shape sloping inward. In the end, the external and internal pieces of the bow timbers were joined in a continuous saddle for the mast. While slowly removing material from the bulwark, the bitt provided a stable stop to the mast foot and at the same time a reference for its slope. A third check point was the distance between the dummy mast and the top of the bow timber, where the figurehead will be attached (sorry, don't know the correct name of this part):
9pdr guns
Continuing with the 9pdr guns, I verified that the carriage cheeks were about 1mm too narrow for the gun barrel ... actually, it is the opposite, because the carriage is perfectly matching the plans.
So, some deconstruction time also for me: I disassembled the cheeks from the axles and forward piece, built a new forward piece 1mm wider and reassembled the 5 pieces. The following picture shows the new wider carriage (left) compared to the original. The next shows how the second barrel (still bare) sits comfortably between the cheeks and is able to be trained upward without interference.
The following picture shows both the carriages rebuilt, with all the bolts and ringbolts required and with the wheels completed by their iron bands. Next is a shot showing the two barrels painted: the first still with matt finish, the farther also polished with a nylon rotative brush and with some graphite powder from a 2B lead pencil.
Final steps were to build the brass strips fixing the barrel trunnions to the carriage. They are cut from brass 0.5mm thick sheet, bent to match the trunnion, drilled with two holes and fixed by a 0.5mm brass hook (to the rear) and a 0.8mm pin (to the front).
Finally, several shots showing the completed guns on the deck, occupying their position at the first gunports. The barrel is now correctly aiming upward, even though the elevation quoin is still not in its final position.
The above closer picture shows the elevation quoin, with the pin handle lathed from a Birch toothpick, and the brass pins through the wheels axles. All the metal parts have been chemically blackened.
Finally, I also tried to position the guns at the stern chase gunports ... again satisfactory :D !!
To be continued...
Fam
Edited by Fam
Joint building:
Works in progress:
Completed models:
Many thanks Druxey, I appreciate! :)
Edited by Fam
Joint building:
Works in progress:
Completed models:
Thank you Dirk!
Joint building:
Works in progress:
Completed models:
November 30th, 2015
… Continuation …
Gunwales
Next scheduled step was building the gunwales, as they complete the upper edge of the bulwarks, protect them and give also more strength, that is not bad considering the hull will be inverted for some time.
The method is the same already described by my good friend JA, but I will show some more details about the procedure.
First step is to draw the profile of the gunwales: I used a piece of scrap cardboard (Corn Flakes boxes :P ), laid it flat above the bulwarks and transferred the bulwarks profile to the underneath of the cardboard with a sharp pencil.
The gunwales total width can be measured on the plans, which also show how they protrude about 1.5mm inside and outside the bulwarks. So I had to add another “parallel” line externally to the one already drawn, spaced 1.5mm away, and a second one internally to the existing line, at the correct distance to obtain the total width.
The above is the final result, with several red lines also traced: the midship line (to check symmetry) and the lines showing how to split the gunwales in several pieces.
I wanted to simulate the use of wood boards about 7-8m long, joined with scarph joints. So added these lines, drew the joints and cut the resulting pieces:
Then glued these pieces to a 2mm thick Pearwood board and cut them out with a scroll-saw.
Starting from the transom, I positioned the gunwale pieces on top of the bulwarks, alternating port and starboard sides to increase the visibility of any asymmetry. The pieces were held in position by pins inserted in the toptimbers and gunport side-lining pieces:
Piece after piece after piece...I got to the bow optimizing the flow of boards and every joint.
The gunwale boards have a composite profile on their internal and external edges, so I used the experienced technique of scrapers by cutting the required profile in a steel blade. Then locked every gunwale piece in a vise and scraped the two sides…
...with this result:
To avoid any painting problem after the installation, I pre-stained the boards underside with black stain. Here are all the gunwales pieces:
And finally the installation started. Here the problem was to firmly hold each piece pressed against the top of bulwarks, so to obtain a strong glued joint. The pin holes provided the needed reference for the alignment.
Above is the final results completed and below the gunwales finished with black acrylic paint: two light coats, a light sanding, a third light coat as final finishing:
The preparation for coppering was then concluded by painting a black area just few millimeters wide upward of the waterline: I wanted to avoid having the need to paint the hull down to the copper, and also wanted to avoid the need to protect the copper from overpainting, so prepared the base well in advance.
The waterline is still visible below this painted area because it will be the reference for laying the first row of plates.
And finally… coppering!!
I protected the gunwales and inverted the hull. After a long exchange of PMs with Archjofo/Johannes (thank you very much, you were very kind!) I obtained several pictures of the hull of his Le Crèole corvette, which is coppered exactly the same way described in the monography of Le Cygnus brig (ref. above posts).
The only difference is a single line of narrow copper plates at the waterline instead of four lines.
So I started producing the plates for the waterline: they are as long as the main plates, 33mm corresponding to 1.60m in the real world, but only 5.5mm wide instead of 10mm (0.50m). The simulated nails heads are 0.6mm diameter, corresponding to about 30mm. They obviously have a different (mirrored) layout from port to starboard.
Laying of the plates starts at the rudder post timber and proceeds forward, with an overlay of the plates by about 1mm (41mm in the real world).
And I immediately had to face a problem… how to approximate a curved line with straight segments! The solution was probably to use curved plates, prepared ad-hoc by the master blacksmith of the shipyard.
I simply used the prepared plates and cut the upper profile round, following the waterline. The lower profile of the plates waterline row results in a split-line, but it will be covered by the following rows of copper.
The flow of the row at the bow is much easier:
And these are the first two rows of standard plates completed yesterday night, with the few plates I had already prepared... unfortunately I had to temporarily close the blacksmith workshop because my relatives loudly protested for the hammering noise :(
To find its correct shape (natura lcurvature line) I used a 10mm wide plank, placed on the hull and bent to naturally follow the curvature of the hull. The next rows are just following the upper profile of this first:
Next days will be busy with the coppering. I will have also to prepare a third stamp for the plates covering the thickness of the keel-sternpost-stem timbers.
Cheers
Fam
Joint building:
Works in progress:
Completed models:
Thank you all for the appreciation and the likes!
Joint building:
Works in progress:
Completed models:
December 7th, 2015
Hi guys,
just a quick update from the coppering workshop…
In general I’m quite pleased with the “reverse” method, it’s quite easy and the result is pleasant. I only hat to introduce 1 drop "plank" at stern and to taper the plates a little bit at stem, as shown in the pictures below.
I only have a minor area of disappointment, that is the waterline close to poop: it should have got a nicely curved shape and instead it is a broken line, due to the length of the plates that does not permit following perfectly the waterline. I tried to cut the plates upper edge, but it was not enough.
Unfortunately the waterline row of plates was the first installed, so now fixing this area by removing the affected plates and replacing with others (curved) is at risk of definitely damaging the surrounding plates, in an area that will be very visible in the model.
Judge by yourself:
Another issue is related to coppering the “shoe” board attached below the keel: this item was already discussed in Dirk’s buildlog of USS Syren, with pros and cons.
Now in the latter picture I’ve shown the first two plates of the last row just cut at the lower edge line of the keel, thus leaving the “shoe” free from copper… I show you more in detail:
What do you guys think about it? Should I leave it this way or should I replace the two plates with two complete plates, also covering the “shoe”?
Opinions, comments and suggestions are more than welcome, as usual
Regards
Fam
Joint building:
Works in progress:
Completed models:
Thx Dirk
You mean about the waterline or the keel shoe ?
Edited by Fam
Joint building:
Works in progress:
Completed models:
Yes, I agree with Dirk: Leave it this way and do not try to correct it. It is very unlikely that copper plates
would be cut in curves on the real ship.
For the shoe: I would leave it "unplated" as well. I do not know if the real ships had plates to cover the shoe, but
I know that occasionally, these shoes were replaced or fixed in some places. Having the shoe plated would definitely make
the job more difficult and would prevent monitoring the condition of the shoe when the ship is hauled in dry docks.
Besides, it makes a visual contrast between the wood and the copper, which is very pleasing.
Yves
Thank you both, my friends
I really appreciate your comments ;-)
Joint building:
Works in progress:
Completed models:
Fam,
The false keel or "shoe" as you call it, was designed such that if the ship grounded, it would protect the keel from damage.  It was designed to break apart if need be.  I wouldn't copper it.   As for the waterline, I agree with the others.
I liked the planking you did and now it will be coppered over and hidden.  :(
Thank you all for the likes and comments
Fam,
mtaylor
I remember having read this somewhere here, maybe in Dirk's buildlog. The problem was, a part from what is asked by avsjerome2003 (which I believe is true), that probably the copper protection continued between the keel and the false keel. Or some other mean was used with the same scope.
I initially applyed the two entire copper plates, then reminded having read this discussion and cut the two plates along the keel-shoe separation line. But the look was not enough, it was just like "cut-along" and not like "plate-wrapping-the-keel", don't know if it is clear enough...
Also tried to press the copper plate into the joint line, but the joint is so tight that the result is...no difference.
So now I'm thinking this: I'll remove these two plates, then will carve the joint line deeper and then will re-install the two plates trying to get a better look. Will show you the final result :)
And... yes, I concur with you that hiding the planking is a pity... I thought about it and decided that should the result of my 2nd planking be close enough to the level of perfection Chuck is so easily getting, I would give up with coppering... well, it was quite far from that, so the final decision was easy :P:D :D
Waterline: I'll do as you guys suggested and will live with it... another lesson learned, but the idea of trying removing the overlapped plates is really a nightmare to me!!
Thank you all for your support
Fam
Joint building:
Works in progress:
Completed models:
Very nice build Fam,
the coppering is beautiful and neatly done, also you second planking with the pencilline Patterns for the sheating Looks very accurate
Nils
Current builds
-Lightship Elbe 1
Completed
Mark, if the false keel were not coppered, wouldn't be subject to decay by ship worms and barnicals ?
Inquiring minds want to know.
Montani semper liberi  Happy modeling
     Crackers    :huh::o:(
Crackers,
The false keel was meant to be sacrificial and coppering would have impeded it breaking loose on a grounding.  I suspect they didn't worry about and also (IIRC) it was elm which was worm resistant.   The false keel wasn't treenailed or spiked but used staples at the side and were angled to allow this wood to be shed.
mtaylor
Fam
Fam,
Yes, it would have covered the bottom of the keel and then the false keel laid over it.  There's been some discussion of the coppering using the Vic and Constitution as photographic examples.
@Fam
Hello,
the coppering looks fantastic!
A great achievement.
Thank you Johann, apreciated!
I've now completed the starboard side and proceeding with the port side.
I'm planning to complete the coppering before Christmas holidays, I will post several pictures soon :)
I have a question for whoever has an answer:
my keel, rudder-post and head timbers are 7mm thick but my copper tape is just 9.6mm wide. If I use it to cover the keel thickness, that gives just a poor 1.2mm of copper overlap to the sides of the timbers :o
I fear this is a bit short, because probably I need some more width to have a row of nails on both sides of the copper plates... any idea, suggestion, comment? I would really appreciate!
Thank you in advance
My best regards
*** EDIT ***
I think I've found the solution: I managed to find a wider version, same brand, of the adhesive copper tape I'm already using .... 12.7mm width (or 1/2 inch) should be enough to solve my problem B)
Cheers
Fam
Edited by Fam
Joint building:
Works in progress:
Completed models:
December 24th, 2015
Hi all
as I promised, I’m able to show the completely coppered hull.
Firstly a couple of pictures at an earlier stage, when the plates covering the keel thickness are still missing.
I tried to adjust the color rendering so to match the real color of new copper, which is amazingly bright and shiny.
The following pictures show how I set the copper foil into the narrow and shallow groove that separates the keel from the false-keel... I don’t know if the picture manages to render the effect... well it is not exactly like if the copper continues between the two parts, but is looking almost as I wanted.
Next picture is how I prepared the stamp for the plates covering the keel width. The holes will house the steel needles used to stamp the simulated nails on the copper tape.
There is no detail about these plates in the Ancre monography, but I needed a greater width to have some margin for bending each plate to the sides of the keel timbers.  The keel is 7mm thick, as I wrote above, and I managed to find a copper tape 12.7mm wide.
The layout of the nails is the same as for the other plates, just extended to the larger width of these plates. But, differently from the hull plates, I added another row of nails to the side edge, so that both left and right edges look correctly.
I imagined that the curvature of the bow timbers profile would have caused the plates to wrinkle at the sides of keel. To minimize this, I decided to reduce the plates length to about a half of the length of the hull plates: I firstly tried with 20mm length, but the wrinkles were still present and quite difficult to avoid. At 15mm length (instead of the standard 33mm) I managed to avoid the buildup of these wrinkles. So the final size I chose is 12.7mm width and 15mm length.
As for the hull plates, I started producing a small batch of plates for testing how they looked. When I laid the new plates on the side of those I’ve used for the first test, my heart almost missed a beat... OMG, the color was very different!!! More pinkish, as you can see in the following picture:
Probably a different brand of copper, or a different surface finish,  or whatever... I didn’t know what to think!
I stopped working for a couple of days, thinking at what to do to fix this problem. Then just tried: degreased both copper types with acetone (nail polisher), then rubbed them with very fine steel wool ... and the miracle happened!
I don’t know what the reason was, I cannot believe the older plates had already oxidized ... well I didn’t care: now both plates types showed the same color.
Ok, let’s go forward: the amount of wide plates was not much, just about 20. So it was a job quickly done.
The next two pictures show the final plates installed on bow timber and stern post... you can see that the colors are still different, I fixed it later.
The last step of coppering was to try reducing the excessive shining of new copper by applying a weathering patina, so to simulate the natural ageing of copper.
I used the recipe suggested by Dirk (Dubz), a mixture of vinegar and salt, with as much salt as can be added to the solution before it starts to fall to the bottom of the pot. I also heated the vinegar to melt a bit more salt... a super-saturated solution I think it’s called.
Again, I used the tester plates to check the effect:
What above picture is showing is much more than the real effect, but I wanted to show it because three different areas are visible: to the left is the original copper, in the middle is the copper just covered with some mixture and to the right is the copper after the mixture has dried.
To be honest, I saw this result on the hull before, then I checked on the testers and noticed that a white patina had developed... in other words I was impatient to test the new technique and did not left enough time to the chemicals to complete their effects.
The effect of the mixture was treble: immediately the copper changed color, taking a more brownish tone. Then it lost great part of its shine. And finally the white patina appeared, probably a side effect of the excess of salt in the mixture...
Back to the hull: before applying the mixture I thoroughly degreased the entire hull with acetone, then passed all the plates with very fine steel wool... and the copper colors harmonized.
Then applied the mixture in several coats, using a ragged piece of fabric that I dipped into the solution: in this way I tried to avoid leaving any excessive amount of the stuff on the copper.
And this is the final effect:
I’m now thinking at how to face this patina, even though I admit that I’m not disliking the final look ...
A couple more shots of the coppered hull how as it is right now, before the shipyard was closed for Christmas holidays.
I used a different camera, with much lower performance, and this is the reason for such different color rendering...
You may see that I also added a third molding strip just below the water scuppers, an addition of the very last minutes. I’ve missed it during all my previous analysis of the plans, but discovered it when checking for the next job.
I’ve used Yellowheart wood strips that I had available in the scrap parts box: don’t be surprised for the strange color matching, because all this area will be painted black.
To set these strips I temporarily glued several 4.5mm wide spacers below the main molding (they are visible in the above picture), then used them as a guide for laying the new molding.
Next job, in the first days of the New Year 2016, will be the cheeks that laterally support the knee-of-the-head ... stay tuned!
I wish you Merry Christmas and a Happy and Prosperous New Year 2016
Fam
Joint building:
Works in progress:
Completed models:
The coppered hull looks fantastic. I like especially that you don't coppered the false keel, what was common for this time
Regards Christian
Nice and clean coppering Job Fam,
Looks very nice....
Nils
Current builds
-Lightship Elbe 1
Completed
