Everything posted by thibaultron
I would start with a general Google search, then go to Ebay. Ebay has a Saved Search feature (a highlighted option under the search bar), that once selected, they will send you an email, the morning after the item is listed. I generally also save that type of search to my bookmarks, and check a couple of times a day. Kits from 2004 should not be hard to get, though you may have to search for a while for one to come up.
I would suggest adding some wood blocks at the bow.
- 111 replies
- Nonsuch 30
- Model Shipways
I'll be following along, also. I have this kit, the Bismark, and Missouri main turrets, and the Bismark and Missouri secondary kits as well.
I'd like to get a good bench top drill press for the smaller drill bits. I know the cheap harbor freight, home depot, etc. ones are nowhere near the quality I need, but don't need the $400 to $1000 ones either, just a good one for modeling. Is the Proxxon or a similar one really "Precision"? Any recommendations? I already have a full sized floor mounted drill press, so just a bench top for light work.
I updated/expanded my spreadsheet on calculating the best angle to place your print at for the smoothest surface finish. The new spreadsheet now includes a calculation for what exposure time to use when printing thinner layers. As you decrease layer height, less exposure time is needed to cure the thinner “strip” of resin, as the light has less material to shine though. I’ve also added a new calculation to show the correct angle to place the print on, should you desire a specific layer height, rather than the other one that showed the correct layer height for a specific angle (still included on the sheet). I’m not sure how useful the new calculation will be, but I figured it was good to include it. General Angle Values For Printing Aflat Surface on a Resin Printer_017.xlsx
The other day I printed out the case of a resin printer heater designed to fit inside the printing area of the printer. I wanted to insure that it would fit, before buying the two most expensive parts (the heater/fan, and the power supply. It does indeed fit inside my Anycubic Mono 4K, so I'll order the rest of the parts. Once it is built I can Use some of the resins that require 25C/77F, or more, for best results. In the winter I can't get the shop that warm with my space heater, and in the summer the temp will drop at night, and 77F is a little warm for doing any type of physically active work. Here is the video I found on the heater, files are listed in the description block:
Sharing
thibaultron replied to Patrick Matthews's topic in CAD and 3D Modelling/Drafting Plans with Software
Thanks!!! -
Screwed up
thibaultron replied to gregkthompson's topic in Building, Framing, Planking and plating a ships hull and deck
First, throw away the Gorilla Glue, or at least save it for other non-hobby uses. I don't know of anyway to soften that type of glue. You may have to carefully cut the two sides of the bulkhead free separately, and either remake it, or glue each side back on separately. -
A ship's stove too small to print? (For La Jacinthe)
thibaultron replied to tkay11's topic in 3D-Printing and Laser-Cutting.
If you decide to get the Mono 4K, there is a Facebook group for this printer. We also have a 3D printer thread in this forum.- 17 replies
- ancre
- CAD print resolution
No, I've been finishing the renovations in my shop, and building the shelves/legs for my HO layout. I'm also having enough problems with one hip, that it will shortly have to be replaced. It now takes me a few days to do stuff that would formerly take me a few hours. I hope to get back to her soon.
Santa Fe Superintendent’s Car In Ho Scale Part 002 Painted the car side and a print of the oil bunker today. The paint I used is a bit darker than what the final model will be, but it does what I wanted, make the details Pop! Here is the picture of the test piece now All that scale detail does show. It is even visible at normal viewing distances. What a relief! You can even see the beveling of half round window sill ends. One bad thing is how visible the layer lines are, even at the ideal angle, once painted. I’ll have to think on this as there will be lots more rivets, which will make sanding these difficult, and a filler type primer may make the details disappear, and still require sanding. I may try printing this vertically, and see how that works. To do this I’ll have to print a side as two pieces, but that can work. Here is a picture of the rivet detail on the bunker. The overall print failed, but I’ll talk about that later. It does show that the rivets print crisply. The rivets are a scale 1 1/2 inches in diameter, spaced 1 5/8 inches on center. So detail wise the printer is doing great. The layer lines are also present on this , but they were also present on the ShapeWays print I had done quite a while back. The ShapeWays rivets could be seen, but they were connected by shallow valleys.
Here are some pictures of the locomotive skirts I printed out a few days ago, as applied temporally to the model. First the model without the skirts Now with the skirt parts just set in place. The chunk missing from the bottom left of the right skirt, happened when I was removing a reinforcing band used during printing. Shows why I will have to use a les brittle resin on the final parts. The skirt parts are just set in place. The square tab at the top would be trimmed when finally installed. I have to thin the skirts a little, they stick past the inside of the shell and would prevent removing the shell from the frame, for servicing. I also have to remove some of the detail from behind that area, as the details stick out a little past the shell. I may also add tabs behind the skirts, and mount them to the frame rather than the shell.
Storage and transportation
thibaultron replied to Mark m's topic in Modeling tools and Workshop Equipment
Not quite recommended, but funny anyway. Several years ago when I was doing the RC Warship Combat, one of the members that came to that year's Nationals, had an unusual solution to bringing his ship. He had one of the large battleships, which at 1/144th was quite long, but he had a small car. So he put a clamshell carrier on top, and cut form fitting slots in each end. He placed the ship in with about a foot and a half sticking out each end, and traveled several hundred miles like that! He said he got lots of strange looks along the way!
