Posts posted by Mark Pearse
Thank you,
I should be able to cut next week, below are the cutting plans. There's something I need to check on the weekend.
Black lines are cuts & red are scored lines. The perimeter boxes are the bed size of the cutter. The glued up moulds should be quite rigid, but I think there's still going to be good reasons to build it on a frame, so I put legs on the moulds & more setout lines.
- druxey, KeithAug, Scottish Guy and 2 others
- 5
On 8/16/2023 at 3:07 PM, Louie da fly said:
But even though this looks somewhat weird
There looks to be an optical illusion, I think it's the tapering of the hull against the squareness, & the rectangle appears wider towards the stern. If there is no evidence the structures were not tapered, would it be wrong to try a version that has a very slight taper towards the stern?
- Glen McGuire and mtaylor
- 2
Hi everyone
It's been a while, but it's been quite difficult to pin down some of the details & shapes. The builders never recorded the keel profile or the shape of the stem. But she was on the hard last week & I took some measurements & I'm now close to the next step.
Just to recap, I'm going to cut an egg-cate style frame in plywood. My brother has a laser cutter so I can do them from 3mm plywood.
The shape is the boat is done, or nearly done:
I'll sort out spars etc later, for now it's just the hull. The pale blue shape in the drawing below is the lengthwise ply piece, which will also help support the stem. The drawing is assuming the stem is 10mm. You can see that mould #4 slides in from the top, the others slide in from the bottom. The ochre coloured lines are really reminders on how I will fabricate the cockpit area, using 2mm ply for that. The cockpit well is surprisingly steeply sloped, but the duckboard is packed up more at the stern end.
There will be some lateral strips inserted in the forwards sections, narrower at the bow & then a wider one.
Moulds half & 1 below. The red lines are not cut lines, they are burn lines to help an accurate setup:
Moulds 1.5, 2, 2.5, 3:
3.5, 4, 4.5, 5, 5.5 & transom:
There is a 28' version of the design, modified for ocean sailing, that just completed the Fastnet race. Below is the difficult conditions of the first day; the happy team approaching the rock. You can see the deeper keel & fuller shape in the first shot.
2 hours ago, Louie da fly said:
To allow somewhere to belay the vertical lines, I added a stringer inside the hull in line with the gunwale. But I'm not really happy with it, and I think I might replace it with cleats or something of the sort, to perform the same function. What do you all think?
Hi Steven, bearing in mind I know very little about these particular craft....I think your idea is good but somehow it doesn't look quite right, it's a lot of structure above the deck line.
- 2
4 hours ago, allanyed said:
Perhaps they do depict strings of pearls or gems.
or ceramic beads to weight the pieces of rope, or so the ropes can spin (like parrel beads).....
I was taken by the suggestion they were for putting the oars through & rowing. That would explain the apparent randomness, as loops for this purpose would not need to be fixed to the hull & might b moved around. The white dots as weights might then make sense, they would tend to not fall off.
- mtaylor, Glen McGuire and Ferrus Manus
- 3
23 hours ago, Louie da fly said:
Do the members agree with my interpretation, or are there any other possibilities that come to mind?
Hi Steven
Yes, I agree - but not because I have any insight into what they could be. I wish I could help on that. I agree that they just don't look like rope. And there's a randomness...two loops here, none there, etc. I favour something along the lines of rosaries, or charms, decorations..... A mosaic depiction of a ship can't go into too much detail, so it is probably be something either visually obvious or else something meaningful, & relatively minor loop of rigging rope doesn't fit well into either. I'm putting my money on meaningful.
Hi Steven
The model is showing a boat with a very pleasing shape.
- mtaylor and Glen McGuire
- 2
9 hours ago, Bedford said:
And the other slightly bigger project.......
a sailing boat?
47 minutes ago, mtaylor said:
It may have also been done to keep the keel from hogging.
Yes, even a slight curve in the keel would make the hull much more resistant to hogging, or just generally changing its shape. The curved hull planking meeting a curved keel is a 3D curved surface rather than an 'extruded' curved shape.
12 hours ago, woodrat said:
Its not much of a curve but it will make a difference to the end result.
it's interesting with boats how a straight line can look curved (the wrong way), & a curved line...just looks right.
- BANYAN, GrandpaPhil, Louie da fly and 3 others
- 6
I found the missing lines on one of the drawings, & will attach below the scans of my full size tracings, so 6x A1 sized sheets. Then my first go at the lines off them. I will next have a go at putting these lines with keel profiles, stem details, gunwale line, etc.
The double lines on the lower drawing is because the original drawings I had to work off were to the inside of planking. The double lines therefore are the inside & outside of the planking.
Hi Steve
Good to hear from you. Do you mean Marcus Cranney's Ranger build? Tweed River, I think is where he lives...
Below are the traced lines. The A1 sized tracings were scanned & loaded them into a draughting programme, then scaled & assembled. There doesn't seem to be enough lines though. The photo looks to show 11 frames plus tuck (transom - but it's called tuck on the drawings, so I'm following that, I believe it's what the older shipwrights in Sydney used), & the drawings shows 9 frames plus transom. I'll start by checking the lines drawings again, see if I missed anything.
- Mirabell61, Scottish Guy, KeithAug and 3 others
- 6
Hi Jim, Keith
This photo is a good one, a displacement hull trying to exceed her hull speed. I was out on the day, motoring our boat with my heavily pregnant wife & watching the start of a race. It was 5-10 knots 5 minutes before this photo was taken. Best reminder ever to always check the weather forecast. This is the boat I'm doing a model of, & the benefits of her higher ballast ratio are showing - the hull is lighter because in strip planking the hull is lighter as timber never soaks up any water, so the boat needs more lead to pull her down to the waterline.
I have been asked to make a model of a specific yacht, the yacht is a recent build of a 1930s Sydney design. My previous build logs are both of designs by Cliff Gale, & somewhat inevitably, this is a Cliff Gale design also. Actually, I'm thrilled, & it is a version of his most famous design, or at least his best known design.
The yacht herself was built around 2000, & built strip-planked. The original yacht built to this design was called Ranger, & Cliff had her built for himself & his family. They are 24' (7.3m) long & 9'6" (2.9m) beam, so very beamy for a short boat. But they are excellent for their purpose: day sailing in Sydney Harbour, overnighting & near coastal sailing. This one has sailed as far as Tasmania, but with good preparation & picking the suitable weather windows.
Since 1933, when the original was launched, around 9 or 10 have been built, some not especially close to the original design. But there's one completed a couple of years ago & another nearing completion, being built by retired shipwright & general legend Ian Smith.
I'll let the photos do the talking, & if I think of more things to say I'll add them in following posts. I'll also try to find a couple more good photos of the yacht herself.
Launch day, or close to it, I think around 2002.
They are great day boats, & sail well with all that sail area. Quite a lot of usable room, for a small boat.
Happily, I have the original lines drawings from the build. That's something you don't see very often in this forum....1:1 lines drawings from the actual build. These yachts vary a bit, the original one - Ranger - was adjusted during her build, to increase her load carrying capacity. This yacht, built 65 odd years later, is actually closer to the original designed lines than the first yacht built to the design.
There's 3 main lines drawings, here's the first, taped to the dining room floor:
The second, sitting on that:
And the third:
The lines are to the outside of the ribs / inside of planking. Fortunately, there is this doodle on one corner, in the top left side of the 2nd lines drawing:
I have traced over these in a series of A1 tracing paper sheets, & they are getting scanned & I will assemble a digital compilation of the lines.
Thanks,
- michael mott, FlyingFish, KeithAug and 9 others
- 11
- 1
Wow, thank you everyone for the assistance. This is a huge help.
John, good to hear from you as well. Thanks that's great idea & turns out I have a mate who's an upholsterer.
Keith, thank you, & yes I tried Ropes of Scale (after searching this forum, the name came up quickly). They don't seem to have white of the same weave. Their 'cable laid rope' is exquisite, but more complex in the weave. This is actually 3 strand, so visually quite simple. The hull might have been ballasted inside the hull or perhaps screwed onto the underside of the keel. The hull is screwed to the stand & I haven't removed it to look. The shape of the hull is 19C in yachting design, a real 'lead mine', or that's what I've heard them called: narrow beam with very deep hulls. It's quite hard to photograph her without distortion but I'll attach a bow shot lower down. Another option is that she was only sailed in light conditions, the 'lead mine' boats are known to heel quite a bit as the hull shape doesn't have much volume to support a lot of ballast nor much buoyancy righting moment from hull shape.
Hi Mark, good to meet you. Thanks for the link to Ropes Galore, that's also a very close match, & I can't resist the cheesy business name. Yes I've read a lot on the Balmain Bugs, which raced in the harbour for prize money, but I think (going from memory here, Steve Crewe's book on them is the one to read) that they started in that type from maybe the 30s. This model is (my estimate) 1900-1914. I believe that she would not be capable of sailing in the harbour without risking losing her. And I thin she was sailed for pleasure rather than races - why? There is no evidence that she could be tacked quickly. The Balmain Bugs were tacked in split second as they were self tacking, they just rowed up behind & pushed the boom across. This one has 2 jibs & a staysail - & only the one traveller bar for the headsails. I think that they had only one sheet, & the boat was set up for one tack across a pond (like Centennial Park, which was a popular place for it). The 2 foot Bugs also had a mast 8 or 10' tall, much larger than this.
Hi Roger, thank you as well. I looked up Cuttyhunk line & it is beautiful stuff. A bit thin, but a great idea. The one on the model is probably cotton, it is probably softer than linen. And I looked up the company you mentioned, they have one quite good, just a bit thin in diameter.
Jaager, thank you as well, & I agree with your comments on the model & the rigging. Make do, but she was well made.
I did find a couple of alternatives that are quite close, apart from the Ropes Galore option from Mark.
This one is close:
This is the bow view of the model. The side photo doesn't really show how dramatically slim she is.
Again, thank you everyone for your assistance, advice , comments.
- Jim Lad, mtaylor, BLACK VIKING and 3 others
- 6
Hi everyone
I am doing some repair work on an antique pond yacht. It's a full sized small yacht rather than a scale model, this is important because I'm trying to find thread similar to some that's on the model, as opposed to a scale version of something.
She's a great model, my estimate is 1900-1914, the hull is about 107cm, & the bowsprit adds about 50cm.
In fact she's difficult to take a reasonable photo with a phone, but there's one below to whet your appetite. Unfortunately the original finish was removed, it would have been almost black. I can see that it looks good like this, & I am not doing a restoration, just repairs.
One of the lines that is incomplete is the mainsheet. It's about 1.5-1.6mm diameter & quite white. It's like a classic 3-strand rope. It's soft & is probably cotton.
Another one is what has been used for standing rigging, definitely not the original, but perhaps 30-50 years old anyway. I'm not replacing it, just matching it for rigging. In its weave, it looks like vb cord (ie: Venetian blind cord).
I did some hunting on the forum in general & found some ok leads...but not quite the same thing. This is 3 strand, not a more complex weave, & it's quite white.
If anyone has seen something very close, & they recall where it was from, I would greatly appreciate any tips.
much appreciated,
- Keith Black and mtaylor
- 2
Bravo Keith, & thank you for explaining the process so carefully throughout.
What is a pig stick....?
- mtaylor, Keith Black and KeithAug
- 3
Hi Keith
Germania is looking just beautiful. Just a practical question: will you be adding glue to stabilise the rope coils?
- mtaylor, KeithAug, FriedClams and 2 others
- 5
Hi Steven
This looks very interesting.
Do you have an idea of how large the actual vessel would have been? It's difficult from the images, with the way they have multiple scales operating at once.
Hi Keith
The putt putt engine is beautiful.
- Keith Black, FriedClams, KeithAug and 1 other
- 4
Some interesting planks to come.
- FriedClams, mtaylor and Keith Black
- 3
Ranger type yacht by Mark Pearse - 1:12 - SMALL
Good progress, I've cut the moulds & have started assembling them. It's always exciting when the model starts to go from 2D to 3D...
But first I have to make some comments that may assist others who choose to cut their own moulds from laser cut drawings they do themselves: the assembly was more difficult because when I worked out the shapes to have cut, I didn't include the building frame in my thinking. Assembling them was more complex then it needed to be. Anyway, it worked out ok.
I originally planned to screw the moulds to timber strips to hold them, but it's now quite obvious that if the moulds interlock in the way that these do, then screwing them together wasn't possible. So they were all glued to the main building frame beams with PVA.
The photo below includes a detail of the bow extension - the laser cutting bed was only 600mm long, so there were some extra pieces at the bow. This gave an opportunity to make the bow thick enough for the inner stem to land on & sit against. you can see how the front moulds include a cutout for the 8 x 8mm inner stem. You can also see the lateral pieces to give rigidity in the planking stage.
The inner stem will be glue laminated by the jigs I cut, also by laser. 3 thicknesses of 3mm plywood. The pale lines will help to position the final piece.
The transom piece has just been temporarily tacked on with hot-melt glue. The plywood is still loose, although I pinned it with dogs of hot-melt glue to stabilise it. In the next few days I'll glue them with epoxy glue.....once I've had a good long look at the frames to see if I need to tweak anything.
The uneven spacing of the moulds has a reason - the lines drawings I got were the actual moulds from the boat's build. The moulds were used to shape a series of glue laminated frames that were not evenly spaced. The hull was strip-planked (timber/epoxy composite construction) & there are only 10 or 11 frames (or ribs) instead of the 60 or 70 needed for traditional construction. So, because they were the only lines drawings I had to use that same spacing, which was to locate the frames in relation to hatches, mast etc.
thanks,
