Posts posted by ChrisLBren
Probably the most difficult part to produce so far - Wing Transom. I used every tool in my shop (mill, all the sanders and chisels). I left off the dove tails in the rear of the part as it may make aligning the legs of the stern trickier later. They really aren't necessary for the structure and the risk of screwing up my third attempt at this part isn't worth it !
Thanks Greg ! Yes I am - my schedule is grab some coffee and work 430am-630am while everyone else in the family is asleep (my workshop is in the basement which helps with the noise) I really treasure this time doing a little everyday and just enjoying the process to begin my day.
Hi Mark,
Or you could go with 1/36th and build the Amarante if you're not scared of some carving. Personally I love the larger scales and this is one of Gerard's best. It about 34 inches unmasted.
- druxey, FriedClams, tkay11 and 4 others
- 7
Good Morning !
The construction site is now completed. It is composed of a Melamine board 48 by 16 by 3/4 thick I liquid nailed to 1/1/4 Red Oak Stair Balusters. It is dead level. The rest of the structure is 3/4 MDF and 1/4 MDF for the upper platform with the usual 1/4 threaded rods. I abandoned both the 3/4 inch birch plywood board screwed into the same oak balusters - it was not as level - and a 3/4 thick MDF board glued to 3/4 square battens. I will use the 3/4 MDF as a moveable platform for the plans.
My Taig milled arrived this week as well. I chose the Taig as I was able to purchase a refurbished unit with the same warranty as new for a discount to list. It comes stock to run at 10000rpm to cut wood with the upgraded motor. I love its weight as 80lbs and the x travels a full 12 inches. Its an amazing tool built with the same craftsmanship as my Byrnes machines. Most of the Sherline accessories will fit it. While not necessary to build this ship (I do love collecting tools though!) - it will certainly make the complicated and large structures of the bow and stern at this scale hopefully easier to realize. Its first task will be to cut the rabbets into the keel parts.
Hey Group,
I am currently building a 48 inch long by 16 inch wide build board for LGV. Both the 3/4 inch birch ply and 3/4 inch MDF are not dead flat. I am hoping that by screwing either board into 3 inch by 1 inch battens on the underside it will remain flat. Does one board over the other have an advantage as far as no future warpage ? Also it is my understanding that sinking screws into MDF may not be the best idea - I could be wrong here.
Thanks
I have seen a few logs that have a tilting mount adapted for the MF70 and its vise. From my search on the web most tilting vises sold commercially are too high (3 and 1/2 inches is the lowest I have found) to work well with the MF70's range. So I am assuming most of these mounts are home made.
I would want to purchase one and would be happy to pay for materials and labor for anyone who could build one of these of me. I am sure this item would be in demand by many other modelers on this site who own the MF70.
Please feel free to PM or post. I do have a design already drawn up with specs.
Thanks,
Chris
Thanks for the replies everyone - I believe I can make due with my existing mill to complete the keel parts on my LGV. I would like to have own one for the more complex assemblies of the bow and stern parts. A tilting table, vice, DRO and a mill that reaches 10000 rpm is necessary from the posts I have read so far. Any additional thoughts are appreciated.
No problem about "highjacking" this thread re wood supply. I bought a flitch of Pear wood a few years back and had a local cabinet shop reduce it to useable boards in 3/8, 1/4 and 3/16. I then dimension to spec with both the Proxxon planer and Byrnes Thickness Sander. I have a nice supply, however, I did burn thru a lot of wood for the frames. I cant imagine how much waste would have resulted using the "Hahn" method.
After 2 months of consistent work - 63 frames are cut and assembled and ready for sanding/bevels. One partial stern frame remains to be assembled later. I need to tweak both the stern keel parts to make sure everything fits snug and re do bow parts part h and i. Then to cut the rabbet. Thanks for stopping by.
Hi Group,
I am considering making an investment here soon. Currently I use a Proxxon MF70 which is a great little machine - however I am now building in 1/36th plank on frame for the foreseeable future. I picked up an Emco Unimat 3 a couple years ago from a member of this site which I will set up as my lathe and want a bigger dedicated mill.
It seems the models that are most mentioned here are Sherline series or the Proxxon FF230. I need the ability of a tilting table and or vise for either choice. Most swear by Sherline - would love thoughts as to model and accessories needed for my specific needs of larger scale/complicated assemblies. Sorry if my question here is redundant or been addressed.
Black Friday is approaching - so I am curious if either would potentially go on sale based on past history.
Thanks
Incredible work at this scale - amazing !!!
- mtaylor and MICHELE PADOAN
- 2
Thanks for the tips everyone. As a matter of fact just finished reducing some pear 1mm for more frames (32 completed and counting). I used a combination of the Proxxon Planer and Brynes thickness sander for the final .5mm. Cutting the boards in half to 12 inch lengths helped as well as being conscious of the feed rate and applying constant pressure to the board on the feed table. It worked great - my sander has course paper on one side which I used to get the billet to almost final dimension and finished with the other fine side.
- Canute, mtaylor, Ryland Craze and 1 other
- 4
I have been folllowing your buiild logs on the ANCRE site for years. Welcome to MSW - your art is truly maginificient and inspiring.
Hi Group,
I would appreciate some operational tips here. I am sure this is my fault not the tools - sometimes I am experiencing dips inthe 2 inch wide by 24 inch long plank I am dimensioning (probably from the drum of the sander). Usually they only about a 1/8 of an inch wide or so accross the plank so I cut around my parts around it which wastes wood.
Is this a feed issue or am I trying to take off too much wood in one swipe ?
I am reducing boards approx 6.75 mm thick to 5.6 mm final dimension.
Thanks much,
Chris
Le Gros Ventre by Richard Dunn - 1:24 - POF - from Ancre plans
Wow this will be fun to watch - I am building this ship in 1/36th and love the larger dimensions. At 1/24th will be incredible. There is currently a build log on the Ancre site for a build in 1/24. If you havent seen it - its worth checking out.
