usedtosail
Everything posted by usedtosail
  1. I continue to work on the yards. As I mentioned before, I continue to refine the process as I have been going along. One big improvement I found was these V Blocks that I had in my father's stuff. They are a much better way to hold round or octagon stock on the tilting table, as shown here. I clamp one block down tot he table, then slide the other block along the yard as I drilled the holes for the jackstays, so I could support them under where I was drilling. This worked really well. After each yard is turned and drilled on the lathe/mill, I then added the other wooden features so they would be in place when I put the finish on the yards. Once that is done, then I will add the other items like blocks, stirrups, etc. I added battens on the lower and topsail yards, as shown in the last post, and the sling cleats, which I made from strip stock using a file to remove material. The mizzen or crossjack yard also had stop cleats, which I added. These are small pieces so I cut them larger, glued them on, then finished them on the yard with files. The topsail yards have coxcombs on the yard arms, and I have no idea what they were used for. If anybody knows, please let me know. I made them from very thin strip stock using a razor blade to cut the "spikes". The topsail, topG, and royal yards have parrel saddles, which are all a different size, but the plan that came with the kit only show one yard and then give the dimensions of the others. so to make the saddles I first copied the plans for the one yard and then re-copied it at the scale for each of the other yards. I cut these out and glued them to some folder material, then cut them out as templates that I traced to a piece of wood, cut them out roughly and then did the finish shaping with files. Here are the lower and topsail yards ready for finishing, and the topG yards that just need the parrel saddles added. I still need to turn the royal yards, stunning sail booms, driver boom, and gaff. Getting there, though.
  2. Thanks Dave. No problem at all. I have trouble keeping track of what I have done on my own model, let alone what others I have seen. Now its your turn to take up the challenge, no?
  3. You want carronades with screw posts, see my build here: https://modelshipworld.com/index.php?/topic/5003-uss-constitution-by-usedtosail-model-shipways-scale-176/&do=findComment&comment=384050. Have fun with those.
  4. Nice job on the frames. I like your struts. Those filler pieces took me a lot of time and I ended up doing the same as you - making the top part as a separate piece.
  5. She looks great Anthony. Don't know when I'll get to this kit, but I hope it comes out half as good as yours.
  6. Thanks Shane. It is always a crap shoot ordering stuff like this. Picking out the wood locally and making it myself is the way I should do it, and probably will in the future when I have more time. Work on the yards continues. I have the three lower yards shaped and am adding the battens to the octagon section, two at a time opposite each other so I can clamp them at the same time. For the mizzen/crossjack yard, the 1/16" wide battens I used for the other two were too wide, they needed to be closer to 3/64". To reduce the width of the 1/16" strips that I have, I made a jig from some plywood and two strips of 1/4" x 1/16" wood, which I glued to the plywood with a 1/32" gap between, and another strip over the top of the other two to act as a stop. I then ran this through the thickness sander a few times to reduce the height of the guide strips to 3/64". I can now put a batten strip in on edge and hand sand it down to 3/64" I made up the battens for the mizzen yard with it, and will also use it for the topsail yard battens. I have the three square pieces of stock for the topsail yards measured out and ready to turn in the lathe. I drilled holes in these while they are square for the two sets of sieves in each end, which I will shape into sieves after the yard arms are turned, either by hand or on the mill. You can see these above the other yards in this image. I keep modifying the procedure I am using for the yards, but overall it seems to be working well.
  7. Whoops my math was a little wrong on the number of yards to do. There are 12 yards plus the gaff and driver boom, so 14 total. So, 2 down and 12 more to go (original post edited).
  8. Thanks for the questions, Jon. I don't mind answering them here. The stock does indeed pass through the lathe head, which allowed me to make the yard in one piece. When working the yard arm, there was a lot sticking out the other end, so it did whip a bit as it rotated. I wouldn't do this with a metal bar, but with wood it was fine. I bought the lathe with what they call the "B" accessory package. This included the 3 jaw chuck, drill chuck, steady rest, live center, cutoff tool, and three additional cutting tools (the base lathe comes with a face plate, one cutting tool and a tool holder). I went with the larger lathe bed as it was not much more than the short bed. Of these accessories, I use them a lot except for the live center and steady rest. Then I bought a bunch of accessories at the same time. The mill column was one, and in the future I can buy a base for it. I use it a lot. Changing from the lathe to the mill is very quick. I bought a 4 jaw self centering chuck, which is what I used to hold the square stock. I find that very useful. I also bought a used independent 4 jaw chuck for holding odd shape things, which I have also had occasion to use. The sensitive drilling attachment I use a lot and really like it for drilling small holes. I also bought a mill vise, that I use a lot, and a rotating base for it, which I haven't used much. I already had the tilting table that I bought to use with my old Proxxon mill. I find it useful. I bought some mill bits and a mill bit holder, but my nephew is a machinist so he gave me a bunch of bits. One thing I bought that I don't use much is the rotary table. I think it will be useful in the future, but I would hold off buying it again right away. Sherline sells a cross slide accessory plate, which really comes in handy because the travel on the lathe cross slide is limited when milling. You can offset it to give you more room to mill long lengths, like when drilling the holes for the jack stays. There were two reasons I bought everything at once. One, I had received a bonus at work, so I had the funds, and two I got a 15% "senior" discount from Sherline, even though I am only 62. I have since ordered other accessories and they continued to provide the 15% discount. Call them and ask for Kat and see what she can do for you when you are ready to buy. I have to admit that I was not sure how much use I would get out of the tool, but since I bought it I have used it for various other projects around the house, not just modeling. It is almost as much fun as modeling itself.
  9. Before we get to the yards, I found this picture on the camera, which shows how I made the man ropes that are on the royal masts. I tied knots in some line, then hung them and coated them with diluted white glue to straighten them. When they dried, I seized one end to the topG top crosstree and the other end around the royal mast. For the yards, I am making heavy use of the Sherline lathe and mill combo that bought over the summer. I am learning a lot using them for these and the results are soooo much more precise than I have ever done by hand. I started out by using a steady rest with chisels to turn the yard arms, but I am using basswood for these and had a few tries where the chisel would dig into the wood and break off the ends. It took me a few tries to realize that I shouldn't cut the wood to length until after one end is done, and that hand chisels were not the best approach. So, I ended up using a right hand cutting tool to cut the round sections. I first drilled a hole into one end of a square piece of wood, using the tail stock, for the stunning sail boom bracket. This is a lot easier to do when the wood is still square. The size of the square stock is equal to the size across the octagon section of the finished yard. After the hole was drilled, I cut the circular section of the yard arm, then the smaller section at the end. I used a file to give it a very slight taper and round the end. I then cut the wood to length and did the same on the other end. One of the nice features of the Sherline lathe is that you can take the key out from under the head stock and rotate it to cut tapers. I did this to turn the round section between the octagon in the middle to the yard arms. The head was turned about 0.5 degrees - the width of the index line from 0 - and the taper cut. I left it a bit full, then did the final shaping using a file and sandpaper, to get the curved taper needed. I finished up with medium and fine sandpaper, then turned the yard around in the chuck and tapered the other side. This is what the yard looked like at this stage. It was now time to cut the octagon section in the middle. I could have used the mill for this, but I had such good results planing this on the masts, I decided to stick with that approach. I marked the 7-10-7 lines on the square part of the yard, using a compass and a 7-10-7 fan, then put the yard in a V-groove jig I made for the masts. I planed down to the lines, using the small plane shown in the second image. This plane works really well for this task. After planing, I put the yard back into the lathe and cleaned up the transition area from octagon to round with some light sanding. The next task was to drill the holes for the jack stays. These are on the top face of the yard, but offset from the center. For this I put the mill attachment on the lathe, and put the yard in the tilting table with the top facing up. The tilt was set at 15 degrees, so the holes would go in toward the center of the yard. I used a #77 drill bit with the sensitive drilling attachment, which is another absolute dream tool to use for this kind of work. I then drilled a series of holes 3/32" apart, or as I have stuck in my head, three full turns (.150"), three increments of 10 (.030"), and one increment of 5 - 0.385". I already know that I will be buying the DRO kit in the future. I also used the mill to make the sieves in the ends of the yards, but that was done after I took these pictures. That completes the fore yard (for now), and I am drilling the jack stay holes in the main yard today, so that one is almost done. Two down and 12 more to go.
  10. Wow, thank you all for the very nice comments and the likes. Shane, I have been holding the ship in an ugly but effective working cradle as I outfit it, and it is back in the cradle now. I made that stand a couple of years ago and this is the first time I used it since it was built. The base is indeed walnut. I bought it from Model Expo many years ago for a different model, then went with a different approach for it. I made the supports from walnut sheet, and it is finished with hand applied wipe on polyurethane. Popeye, I was uncertain about the closed gun ports too, thinking that if the ship is going into a fight why would they limit the guns that could be brought to bear. But, I really didn't like the looks of the dummy gun barrels with the port lids open, so made the decision to keep them closed. Maybe those gun crews were just a little slower to get ready then the others, and they are about to open. Yeah, that's it. I'll go with that. Now, as Ken says, there's yard work to do...(the best kind in my opinion)...
  11. Thanks Popeye and Ken. And now after almost 4 years of work, I have come to a major milestone - the standing rigging is completed! In honor if this event, I set up the back drop and put the Connie on the stand I made for her, and took some glamour shots. It was nice being home for Thanksgiving so I had tome to do this. Enjoy.
  12. Thanks Al, and for those who hit the like button. The ladder is a bit out of scale, but I could not work with wood that was less than 1/32" square. I am pleased with the result.
  13. Hi Derek. I think you will be happy with the ME offering. I wanted to show you my set up, which is a combination of the Dormanoff vertical ropewalk and the ME horizontal rope walk. For the head end, I replaced the ME version with the Dormanoff. I was using clamps to hold it vertical, but this weekend I sandwiched it between to aluminum angle irons, which is much sturdier and easier to clamp to the bench. For the tail end, I was using a modified version of the ME tail end, as shown on the right in this picture. The handle broke off at some point, so I jammed a cut off bolt into the end hole and threaded on a couple of nuts, so I can drive it with a nut driver in an electric hand drill. Because I can turn it so fast with the drill, I wanted something a little better, so I built the next generation back end over the weekend, shown on the left, mostly from some sheet aluminum I had. I cut the disk and threaded in the eye bolts. I also pressed a ball bearing into a hole in the vertical sheet, and turned a shaft that is threaded on both ends. The disk is threaded onto the shaft with a nut to hold it in place, and two nuts are threaded on the other end for the nut driver. Have fun with your rope making. When assembling the ME rope walk, put the head end together carefully so it turns easily. That was the biggest problem I had with mine.
  14. Thanks again Al, Popeye, and GMO2. Welcome Hal. I made up the three ladders over the weekend using the jig shown here. Along with the post to hold the loop at the top of the ladder, there are two eye bolts that the ladder lines are threaded through and the lines clamped. I could have also tied the lines around the eye bolts, but the clamps made it easier to get the ladder off the jig. I was going to put plastic over the graph paper, so the glue would not stick the ladder to the jig, but the ladder was held just off the surface so no glue got to the graph paper. The jig worked really well to align the rungs and hold them while the glue dried. I stained the rungs with oak stain and hung the ladder on the fore topG mast. If you look closely at the above picture, you will see a block sticking through the rungs near the bottom of the ladder. The main topG stay was formerly in that block, so I had to remove it, put the ladder in place, then replace the stay. No big deal, but I should have known the order and held off on the stay. It is back in place now, but I took the picture before I added it back, and before I trimmed the loose ends of the ladder lines. I kept those lines really long, which helped when I had to seize them to the eyebolts at the back of the trestle trees. I threaded the line through the eye bolt, then left it very loose, which meant that I could put the seizings on well a way from the mast, then slide them into place while tightening the lines, and fix them when the ladder was at the proper tension. I have to stain the other two ladders and add them to the main and mizzen masts. I can also now start on the fore royal shrouds, back stays, and stay.
  15. No rush getting the Swan plans to me. It will be a long time before I can think about starting. Thanks also for the materials list. What length should the 3" sheets be - 24", 36", something else? Thanks.
  16. Thanks so much, Al, Popeye, Dave, GMO, and kmart, plus the likes. GMO2, I like your plan to model the 1927 restoration version. I agree that it is a great historical event for this great ship. I will look forward to following your build, as I am to other builds that are in progress or about to be started. I finished up the mizzen topG shrouds, back stays and stay. I found that if I tensioned the stay first, then the back stays, then the shrouds, they look better than tensioning the shrouds first. I did it in this order on the main topG mast, but not the fore topG mast. Not enough of a difference though to redo them, though. I promised to take pictures of the rope coil jig I use, but have not made any new rope coils yet. Here are some pictures of the latest ones I made, along side some older ones that I don't think are as good. The older ones are the two on the left in both pictures. The others are all the newer ones. I think the main difference is that the newer ones hang better. The other difference is that the newer ones are made from cotton rope while the older ones are nylon rope. I plan to use mostly cotton rope for the running rigging. I am now working on the three Jacob's ladders that hang on the topG masts to the topmast trestle trees. I was going to make these by gluing wood strips to the line, but decided to try drilling holes in the strips and threading them through the line, which to me seems more secure. I set up the mill with the sensitive drilling attachment and used some parallels with 1/32" wood strips between them to make a jig for holding the 1/32" square basswood for the rungs. There is a slot at the top of the vise that these strips fit into. I first tried drilling through multiple strips, but after the first two, the drill bit wandered enough that the holes were coming through the sides of the rungs. I then drilled each strip individually. I used a #77 drill bit, which left enough "meat" on the sides of the holes, but makes stringing the rungs onto the line a bit difficult. I have to keep dipping the end of the lines into thin CA to harden them after adding a few rungs, as the ends want to fray. Because the vise is not actually holding the strips down, I used tweezers to hold the strip as I drilled each hole, especially when removing the drill bit from the hole. After drilling the holes for 4 rungs, I removed the strip and cut the rungs off. With this process I was able to make about 20 rungs in 30 minutes. I need about 70 rungs for the three ladders. I also used a small drill bit holder so I could center the tiny drill bit in the sensitive drilling attachment more easily. Here is the mill set up: Here is the first batch of rungs and the start of assembling them. I did not trim the rungs to length until after they are strung on the lines, then I slide the rungs together and trim the ends with a scalpel. I am currently putting a jig together with a piece of graph paper that will secure the lines while I glue the rungs in place. Look for that in a future post.
  17. Just sent you a paypal payment for swan plans and masting plans. I tried to send a PM but it didn't go through. Thank you for your great support towards this hobby and good luck in your future plans.
  18. Could you drill those holes while the assembly is still on the lathe, before you part off the wheels? This was one of the most rewarding parts to make for me. Have fun with it.
  19. What Pat said Dave. That is some beautiful work.
  20. Thanks Ed. Yes, I guess a clove hitch is really two half hitches. I just never thought of it like that because when I use them for ratlines it seems more complicated for some reason. I used to do seizings with half hitches but now I use more of a wrapping with a loop at the top that I take the end through. I like this type because it will slide before being fixed, which in some cases is not always a good thing, but in others is very useful. Keep up the great work and especially the books, which are some of my favorite reads.
  21. Great work as usual Ed. One question - you mention you are using clove hitches for the seizings. By what you show, it looks like those are half hitches, unless you are making each successive loop in opposite directions?
  22. Thanks popeye, and you folks who hit the like button. I finished up the flying jibboom rigging that was started in the last pictures - the outer traveling and fixed guys, and the outer martingale stays and back ropes. In order to tension these, I added a temporary line to the flying jib boom traveler to hold it from sliding back. This will be removed later when the flying jib boom stay is added, which will pull the traveler forward. I added the top gallant masts to all of the topmasts. These are a little harder to keep in line, and I have to keep checking them every time I add a new line. I added the topG trestle and crosstrees, which I had made earlier. I left the rear crosstrees off these when I made them because of the shoulder on the topG masts where the royal masts start (they are all one piece). There would be no way to slide the trestle trees over that shoulder, so I slipped the trestle trees on the mast at the topG shoulder and glued the rear crosstrees in place afterwards. This worked really well. I have not glued these to the masts, as I think the rigging will hold them in place. We will see. If I need to I think I can get some glue up under them. Once the topG masts were added, I glued the cheek blocks to the topmasts. I had also added blocks on loops for some of the stays, and I cut small chokes to hold the loops in place, which I glued on and painted black in place. I started the top gallant (topG) rigging with the fore topG shrouds. It was interesting having to thread these through the tiny bullseyes on the topmast shroud staves. I had to stand on a step stool to get high enough to look down on the bullseyes to thread them, but it turned out easier than I thought it would. From the bullseyes, they go down to the eyebolts on the fore top. I threaded each one through an eyebolt, then kept it loose while I added a seizing, slid the seizing down to the eyebolt while putting tension on the loose end of the shroud, then fixing the seizing at the eyebolt. This technique worked pretty well, although getting the tension right between shrouds proved more difficult than the lower shrouds. After the shrouds, I added the topG backstays, but did not tension them yet. I then added the jib stay, which required another mouse. I made this one the same way as the others, although it is smaller. I used very thin fly tying line to serve the stay and over the mouse. The jib stay goes through the traveller on the jib boom, then through the sheave in the end of the jib boom, and ends in a double block. There is a single block that is hooked to the bow sprit cap, and the tackle line runs to the bow pin rail. I hooked all that up this morning but did not get a picture. I also added the outer jib stay, which goes through the dolphin striker to an eye bolt at the bow, and flying jib stay, which goes through the traveler on the flying jib boom, but have not finished the outhaul for it yet. I have also been playing around with different techniques for making rope coils to go onto the belaying pins. In the past I have always bent the whole coil around a 90 degree edge and hung the whole thing on the pin. Since then, I have seen examples of ropes with one loop that goes over the pin and the rest hangs straight down from the loop. This is what I am trying to get to. I will show the jig I use and how I am doing it in a future post. Thanks for your interest.
