usedtosail
Everything posted by usedtosail
  1. Just sent you a paypal payment for swan plans and masting plans. I tried to send a PM but it didn't go through. Thank you for your great support towards this hobby and good luck in your future plans.
  2. Could you drill those holes while the assembly is still on the lathe, before you part off the wheels? This was one of the most rewarding parts to make for me. Have fun with it.
  3. What Pat said Dave. That is some beautiful work.
  4. Thanks Ed. Yes, I guess a clove hitch is really two half hitches. I just never thought of it like that because when I use them for ratlines it seems more complicated for some reason. I used to do seizings with half hitches but now I use more of a wrapping with a loop at the top that I take the end through. I like this type because it will slide before being fixed, which in some cases is not always a good thing, but in others is very useful. Keep up the great work and especially the books, which are some of my favorite reads.
  5. Great work as usual Ed. One question - you mention you are using clove hitches for the seizings. By what you show, it looks like those are half hitches, unless you are making each successive loop in opposite directions?
  6. Thanks popeye, and you folks who hit the like button. I finished up the flying jibboom rigging that was started in the last pictures - the outer traveling and fixed guys, and the outer martingale stays and back ropes. In order to tension these, I added a temporary line to the flying jib boom traveler to hold it from sliding back. This will be removed later when the flying jib boom stay is added, which will pull the traveler forward. I added the top gallant masts to all of the topmasts. These are a little harder to keep in line, and I have to keep checking them every time I add a new line. I added the topG trestle and crosstrees, which I had made earlier. I left the rear crosstrees off these when I made them because of the shoulder on the topG masts where the royal masts start (they are all one piece). There would be no way to slide the trestle trees over that shoulder, so I slipped the trestle trees on the mast at the topG shoulder and glued the rear crosstrees in place afterwards. This worked really well. I have not glued these to the masts, as I think the rigging will hold them in place. We will see. If I need to I think I can get some glue up under them. Once the topG masts were added, I glued the cheek blocks to the topmasts. I had also added blocks on loops for some of the stays, and I cut small chokes to hold the loops in place, which I glued on and painted black in place. I started the top gallant (topG) rigging with the fore topG shrouds. It was interesting having to thread these through the tiny bullseyes on the topmast shroud staves. I had to stand on a step stool to get high enough to look down on the bullseyes to thread them, but it turned out easier than I thought it would. From the bullseyes, they go down to the eyebolts on the fore top. I threaded each one through an eyebolt, then kept it loose while I added a seizing, slid the seizing down to the eyebolt while putting tension on the loose end of the shroud, then fixing the seizing at the eyebolt. This technique worked pretty well, although getting the tension right between shrouds proved more difficult than the lower shrouds. After the shrouds, I added the topG backstays, but did not tension them yet. I then added the jib stay, which required another mouse. I made this one the same way as the others, although it is smaller. I used very thin fly tying line to serve the stay and over the mouse. The jib stay goes through the traveller on the jib boom, then through the sheave in the end of the jib boom, and ends in a double block. There is a single block that is hooked to the bow sprit cap, and the tackle line runs to the bow pin rail. I hooked all that up this morning but did not get a picture. I also added the outer jib stay, which goes through the dolphin striker to an eye bolt at the bow, and flying jib stay, which goes through the traveler on the flying jib boom, but have not finished the outhaul for it yet. I have also been playing around with different techniques for making rope coils to go onto the belaying pins. In the past I have always bent the whole coil around a 90 degree edge and hung the whole thing on the pin. Since then, I have seen examples of ropes with one loop that goes over the pin and the rest hangs straight down from the loop. This is what I am trying to get to. I will show the jig I use and how I am doing it in a future post. Thanks for your interest.
  7. I think your plan sounds good. Having all real guns on the gun deck is a great goal and will really add to the details. I agree those fake barrels are lousy, which is why I closed the gun lids on them. By tunnels, I think you mean trunnels or treenails. Yes, I think you can simulate them by drilling holes in the planks and using wood filler to fill them, which is how I did mine anyway. The difference for your plan would be to line up the cut planks off the model, mark, drill and fill your treenails, then install the planks. Rigging the guns between the bulkheads might prove to be a bit challenging, but you could probably fake some of the rigging for the guns that will only show through the gun ports.
  8. Well, here is my journey into the world of rope walks. I started with the basic Model Expo ropewalk, which actually worked pretty well. It was tough getting the wooden gears to mesh nicely so after a while the end with all the gears became unusable. I then bought a Domenoff vertical rope walk. This worked OK, but I had problems not having enough height getting a length of rope as long as I needed, and I wanted more control over the tension of the finished rope, which was very dependent on the amount of weight used. So, I mounted the Domenoff horizontally, essentially replacing the end of the ME rope walk that broke. I still use the other end of the ME rope walk, which I modified so I can turn it with a power drill. I can vary the tension by holding the moving end with one hand and the drill in the other, keeping the tension as tight as I like while the threads are pre-tensioning and while the threads are wrapping into the rope. I also added a foot switch to control the Domenoff end, so I can stand at the other end to keep tension on the threads. I am very happy with most of the rope I can make this set up, except for very large ropes which I have not yet perfected. I buy from Chuck for those large sizes (.035" and up). I have also recently purchased a used Byrnes rope walk, which I have been experimenting with. So far, I have not been able to reproduce the rope with the same quality as I can with the Domanoff/Model Expo hybrid. If anyone is interested in the Byrnes rope walk, make me an offer. I really don't need it.
  9. Run a few battens along the outsides of the bulkheads. If they are fairly lined up you should be OK. I had some that need quite a bit of shimming on the outside to fair to their neighbors. I don't know if ME fixed anything, but they might have. As Captain Steve says, I cut off the spar deck supports where I place the gun deck and filed down the new bulkhead tops 1/8" so I had room for 1/16" solid underlayment and 1/16" planking for the gun deck.
  10. Thanks for the compliment, Kmart. I hope my log helps all of the next round of Connie builders. And you all will help the next round, etc. etc., as the previous builders helped me. It is a long journey for sure. I am getting close to 4 years on this build. But it is so rewarding. And you are off to a great start. And one more thing - if you haven't already, check out XKens build log of his Connie. A wealth of information is there.
  11. Kmart, well to the connie club. I look forward to following along with your build. Don't hesitate to ask questions, but it has been a few years since I was at these steps. Tom - go for it, and please start a build log when you do. i'll follow along with yours too.
  12. So the work on the topmast standing rigging is completed. All of the ratlines have been added to the topmast shrouds, and the breast stays have been redone to start at the topmast top. I apologize for the pictures, now and in the future, as the cluttered background makes it hard to see details. I do have a backdrop I can use but it in another room and I don't want to keep moving the model in and out. I was going to stop and take some good pictures after the topmast rigging was done. but I ended up just continuing on with the flying jibboom rigging. Here are pictures of the in progress and completed topmast standing rigging. And here you can see the start of the jibboom standing rigging, specifically the outer traveling and fixed guys, and outer martingale stays. I attached the flying jibboom to the bowsprit cap by drilling a hole through the boom into the cap, then gluing it in place with a piece of wire in the holes. This seems to have made a nice secure attachment, and I then placed a U shaped piece of wire over the flying jibboom as more of a decoration than an actual support. The metal bracket in the middle I glued to the end of the jibboom, so there is a good attachment at that end too. I wanted this to be well attached in case I bump it later.
  13. Yep, I made the same attachment, using another brass tube with a tight fit into the tube on the serving machine. The other mod I did was add a handle to the crank:
  14. I like the comb jig to hold your grating pieces. They look great (or should I say grate).
  15. Thanks Gary. I completely got those wrong. I have the breast backstays on, but have them coming from the lower mast heads, not the topmast heads. I will have to take them off and redo them, but that is not a problem as I have had to redo many things as I have gone along. I have the AOS book but haven't been using it as I don't think it is very accurate, but in this case it is. The MS plans don't show the breast backstays in relation to the other standing rigging, but the picture of the breast backstay on the plan shows the loop at the top and does say to go around the topmast head.
  16. Thanks for the likes, guys. Topmast rigging continues with the mizzen topmast. I added the topmast shrouds, stays and backstays, and next I need to add the sheer poles. I also have started adding the ratlines to the fore topmast shrouds. Easier than the lower shrouds but still will take some time.
  17. I added the main topmast stays which were a little tricky. They have a mouse on top like the other stays and go through bullseyes on the back of the fore mast, then down to bullseyes on the deck. I had placed the eyebolts for these bullseyes a while a go while outfitting the deck, but failed to add hook the bullseyes to them. These eyebolts are inside the fore pin rails so I found it impossible to get enough room to hook them. I then tried suspending the bullseye with the hook down from a loop of thread, which allowed me to get them hooked with tweezers from underneath the pin rail. The problem now was how to keep them hooked while I threaded the lashing between the bullseye on the end of the stay and the bullseye on the deck. That loop of thread turned out to be the trick, as I just looped it around some of the belaying pins in the pin rail and clamped it, which not only held the bullseye hook in the eyebolt, but also held the bullseye up so it was easier to get the lashing line through it. I was able to thread both stays without them coming unhooked. Here is the result. You can see how close to the pin rails these are. And here is an overall view with the stays in place. I finished up the main topmast shrouds last night and have two of the four mizzen shrouds in place. I had to remove the fore futtock staves because they were too low and the catherpins would have interfered with the fore topmast. I was able to carefully cut them away from the shrouds, but I did have to cut off all the small bullseyes and tie them to new wood pieces. I installed the fore and main topmast futtock staves last night, and am working on the catherpins for these shrouds.
  18. I think you did a great job on those canopy frames Dave. I didn't even attempt to make them, rationalizing top myself that they wouldn't have been on the 1812 version. We'll have to call you SolderDave for a while.
  19. First off, I want to extend my well wishes to you members in Houston and Florida. Hurricanes are a b****, don't mess with them, especially these monster storms. I was having problems with the topmast deadeyes wanting to rotate in the top, sometimes a full 90 degrees or more, because I had made the holes a little oversize to get the strops through them more easily. I should have made them with thinner slots. But, I saw this trick in xken's build log, and it worked so well I wanted to make sure future readers of this log find it. By inserting a strip of wood through the deadeye lashings before tying the sheer poles to the shrouds, the deadeyes are held in the right direction and the seizing on the sheer pole holds them that way when the wood is removed. Thanks Ken for the tip. The topmast futtock staves on the Constitution have 5 bullseyes lashed to them to guide the topG and royal shrouds to the mast top. I was going to use some bullseyes supplied with the kit, but as you see in this picture they are too big to fit on the 1/2 inch or so long staves. So, I made new bullseyes from brass tubing. I had always used a vice to hold tubing to cut it, but on a whim I bought a jewelers bench vise which provides a nice flat surface to cut on, and had much better results. In fact, I was able to cut all 30 bullseyes, with some spares, in less than an hour. And they did not crush or have rough edges like when cut in a vice. I blackened them and tied them to the staves with a single overhand knot that was fixed with glue. I also made the two collars with single blocks that will go over the shrouds on the fore topmast for rigging the topmast yard. The collars are one strand of served line wrapped back on itself and held under a single seizing. Here are the fore topmast futtock staves in place on the shrouds, with the catherpins on them too. Stay safe and have a good weekend
