Everything posted by the learner
What ever push stick you make sure to keep your fingers away as far as possible! EDITED OUT GRAPHIC PHOTO, ADMIN
There are a lot of suppliers here so I am sure you will not have any problems find a supplier there.
- 503 replies
- washington
- galley
Wow fantastic job on the hinges, are they the correct thickness? looks a bit thick to me but might be the pictures. The build is really progressing nicely and I love the shop, wish mine looked that good!
- 503 replies
- washington
- galley
ancre La Belle 1684 by Oliver1973 - 1/36
the learner replied to Oliver1973's topic in - Build logs for subjects built 1501 - 1750
Great time lapse, are you using MS powerpoint? I see you are keeping your helper busy, train her well we need more expert wemon in this hobby. -
This guy's carving and model building skills are fantastic gota see mour of his work!
- 27 replies
- carrvring
- micro wood carvring
(and 3 more)
What is the difference between left and right capsquare? The angle of the frame? At 1/4 scale or less is there enough difference to be noticable if you only make a straight capsquare? On the jig to get left and right is it the angle of the pin thats inserted in the jig right? Well explained, thank you.
Doris so sorry to hear of your loss, I am sure that your husband was very proud of you and your work, it is fantastic!
- 1,035 replies
- royal katherine
- ship of the line
Fantastic job on the cabin detail! What is the process for making the cushions/mattresses? Perhaps a seperate log.
- 589 replies
- le gros ventre
- cargo
Bob Thanks for the link! https://uses.plantnet-project.org/en/Ficus_(PROSEA_Timbers) A prostrate or climbing shrub, reaching up to 10 m or more, creeping and clinging close to walls or tree trunks by means of numerous aerial rootlets, ultimate branches 30-80 cm long, erect. Leaves dimorphous, two-ranked, on sterile branches ovate, 1.5-3 cm long and shortly petioled, on fertile branches oblong, 5-10 cm long and with long petioles; figs solitary in the axils of leaves, pyriform, 40-60 mm long, yellow-brown pilose when young, ripening glabrous, red to dark blue. Male flowers in many rows, filling the distal half of the fig, stipitate with 2-3 stamens, female flowers sessile or shortly stipitate. F. pumila is an increasingly common feature in urban areas. I will definitely save as much of the larger pieces that I can when I do cut it down, this plant will take over and does grow fast!
I had trimmed some fig ivy in my back yard last year and had saved several crooked pieces and set off to the side. This week I cleaned them up and removed the bark. The wood is cream color, has no visible grain and the wood is hard as all get out. Has any one ever used this wood or know where I can find information about wood and has any one in the Community used this wood?
Be interesting to see what you will be able to do with the Mini CNC, will be following your use along with the rest of your build. I have been a little hesitant in purchasing one because of the cost and learning curve. The prices are comming down but I am getting older making the learning curve harder!
- 589 replies
- le gros ventre
- cargo
Thank you for the drawing, very much appriciated. Guy
- 20 replies
- st. gabriel
- master korabel
Thanks Andre, will look for it here.
Yes we all learn from what others do and how they do it and we become better in what we do, regardless what we do.. as long as we attempt to do it better. Your build inspires us all. -
Hmmm I recently acquired this kit that has been started from a gentleman who recently lost his wife and I would like to finish it up asap. I guess I need to post a build log here and will definately will be following your build Also I note that there is another Prince build on modelshipbuilder but is almost finished, a good build and a good reference.
Fantastic build, well documented with many references, thank you!
