Blue Ensign
  1. You’ve got it Ron, 👍 and 0.1mm line is about spot on for Crowsfeet, equates to 3/4” circ. line. B.E.
  2. It's been a few weeks, but wow what progress you have made Glenn, your planking is a joy to behold, and the whole model so pristine. Beautiful work.👏 ps I'm feeling inadequate. B.E.
  3. Beautiful work Thomas, an excellent demonstration of how to do it. B.E.
  4. I didn't use the lamination method myself as I managed to wing it with the solid, but I suspect the Cathead supporter on Diana is a little more beefy that that of Sphinx. Is the angle of Cathead on Diana based on a kit part? it doesn't look that steep on the AotS artwork and drawings., but you can always trial it with a piece of square stuff. The steeper the angle the further back along the Cathead the sheave slots will exit on the underside, in order to keep the run of the Catfalls vertical. Thank you David for your kind compliment, much appreciated. Regards, B.E.
  5. Your Crowsfeet look nice and taut Ron, but can you clarify if the method of reeving is one of your simplifications? I don't think I recognise the double looping of the line through the rim top holes, effective, but not necessarily authentic as far as I know. Regards, B.E.
  6. Cheers Guys, thank you very much. @ Glenn – I’ve picked up tips from many on MSW and the beauty of acrylics is that you can experiment a lot within a very short time. @ Chuck - your Winnie build is my constant reference for detail. I can’t replicate the top-notch standard of your work, but because of it Sphinx is much enhanced. @ Ron - I too will be adding the Billboard, bolster and lining, they appear on the Marshall painting. I intend to add stump lower masts and Bowsprit, but they won’t be glued into place. The gammoning will probably be the only rigging on the model. I am toying with the idea of leaving the masts as tall as the case cover will allow and maybe add the cheeks, front fish, and wooldings. I may also make up a full mast to include in the case as an example, but this all a long way ahead. @ Mark – I don’t know about gold standard, but I do hope my efforts are of some use to other builders. Regards, B.E.
  7. Post One hundred and Thirteen Adding the Figure. The provided resin Figure is nicely detailed, but not one of the most attractive figures evident on ships of the 18th c. For those interested in such minutiae it is likely that the figurehead was carved by Cuthbert Mattingly, Figurehead carver at Portsmouth Royal Dockyard 1760 – 1778 at which point he brought his son William into the business. Historical evidence may suggest that Figures were painted in colours, the unrestored model of Tartar of 1734 shows evidence of having been painted in colours, and there are other examples into the early 19thc. and beyond. I intend to leave the figure natural using only highlights and shadows to bring out the definition, it seems to suit the Navy Board style. This also accords with my natural inclination to avoid the garish. A base coat of Ochre Brown is applied, followed by a wash of Burnt Umber. Further highlighting (Yellow Ochre /Ivory mix) and shadowing(Dark Vermillion/ Burnt Umber mix) with a little darker wash for the crevices. 5957 I will be using Vallejo acrylics throughout. 6651 While I was trial fitting the Figure I noticed that the forward part of the Lower cheek seemed a little short. This looked unfinished to my eye. 6655 Generally where a full figure was involved the feet rested on or against the termination of the cheek moulding, as shown in the Marshall painting. 6646 I may be able to add a small piece of moulding to the rail. 6654 6652 6647 I quite like the look of the colour which varies given the light conditions but that is not to say that the urge to meddle won’t overcome me at some point. 6660(2) 6658 Still work left to do on the Headworks. B.E. 25/04/22
  8. Thank you David, It's worth a go but I would suggest you try laminating the supporter from three separate strips which will be easier to create the quite sharp curve required. I see there are some good drawings of the Diana Headworks in the AotS book. One advantage of lamination is that if three strips are used a profile can be created along the face of the supporter. The top of the supporter should be square with the underside of the Cathead which I didn't quite achieve, but given the size I just about got away with it. I await with interest to see the results of your endeavours. Regards, B.E.
  9. Thanks Ron, I just hope my blue colour mix lasts the distance. It should do there's not a lot of painting left to do. I felt I had to put the extra effort into the Rails as there will be nothing to distract the eye, no Catfalls with large hook, anchors, or rigging. Regards, B.E.
  10. Post One Hundred and Twelve. The Headworks. This, together with the stern have a deal of visual impact and need to look good. Some of this work has already been completed, the Head timbers, Upper and Lower Cheeks, and their associated Eking Rail and Hair Brackets. I had not yet fitted the grating pattern in place as indicated much earlier in the build, but this is now the next step. The Main Rail There is no denying, Main Rails are tricky, but Chris has produced a version that replicates the elegant curve up to the head and is the first model I have made where I haven’t had to replace this element. It is a three-section assembly which gives a combined thickness of 3mm at the head tapering to 1.8mm at the bow. 6617(2) As a simplification the False rail has been made part of the overall laser cut part, but ideally it should be a little thinner than the Main rail to which it would have been bolted. There is an outer section that beefs up the timberhead and stands proud of the rail. This creates the Stepdown which is a feature of the Main Rail. This benefits from a little light paring down to meet the lower level. Fitting the Rails The blurb gives a two-line instruction The rails can now be fitted to the bow as seen here and on plan. If only it were that simple! Yes, it can be, but the fit will be less than desirable. The forward tip of the rail fits nicely over the inner side of the Hair Bracket, but it seems to me that for the upper part of the Rail to sit correctly the back edge needs to be notched to fit over the Capping rails overhang and the Upper Hull rails. I start by holding the forward end in place and mark on the inner end where the upright crosses the hull rails. An angled notch is cut in the upright from aft. 6621 None of this will be seen with the Main rail in place. I also found it necessary to shape the grating pattern a little at the Fore end for a tension free fit. Ideally it would be useful to pin the Fore end to the Hair bracket but it so fine that the smallest pin I have tended to split it. I used pva to glue the rails in place knowing that should I need to remove them I could do it without damage. The following are the macro shots taken purely to give myself pain, otherwise known as highlighting areas for improvement.🙄 6628 6626 I decided to add a second pair of easement seats fitted between the False Rail and the bow. I suspect that these seats were far more popular than the exposed pair, but maybe that's just an assumption by a 21st c. man. 6625 6624 6622 6635 I have added the Saddle where the two rails meet at the bow between the Hair brackets. 6634 6632(2) Still work to do on the bow but overall, I’m satisfied the way the Main rails turned out. B.E. On this St George’s Day.
  11. Progressing well Glenn, One suggestion I would make is to paint diluted pva onto the footropes (Horses) and roll a paintbrush handle over them until they hang smoothly. Where stirrups are involved I also hang small weights off the end before trimming to keep them straight without curl. (I tend not to use brass etch stirrups) B.E.
  12. I’m sorry Chuck I don’t know the answer to your question, but it’s certainly available to those members of the Tffm club. B.E.
  13. Thank you Mike, The etched frieze designs on Sphinx are a tad finer than that used on Pegasus, but I followed the same procedure with Pegasus, and was very happy with that result as well. I followed the method described in 7.26 of Vo 11 of Tffm. On Sphinx I used Vallejo acrylics, but I think I used oils on Pegasus. You could always try hand painting on a frieze wide strip of suitable paper and see which you like best. It's always nice to do hand painted stuff but painting the brass to make it look like paintwork satisfied my artistic needs. Regards, B.E.
  14. Post One Hundred and Eleven. Foc’sle Capping Boards and Timberheads The instruction is to have the inner edge of the rail flush with the inner bulwark. On my model at least there was a little lining-up mismatch in the curve around the bow area. This is most probably due to the way the round on the hull was faired all those months ago. 6564 The capping rails were on and off the model numerous times before eventually painting and gluing in place. The timberheads are individual and position specific. It took me some time to locate them on the parts sheet (sheet6) and the location plan (sheet14) and then find the actual timber sheet. 6608 The Timberheads are quite nicely shaped and only need cleaning up before painting. I was pleased that they slotted into the capping rail with a perfect fit. Note that the bottom edges are angled to suit the sheer line. The Fish davit supports and Snatch block at the Cathead are nicely detailed. Cathead supporters There should be a smooth curve to meet the Eking rail but at this scale it will be a tricky thing to carve the curve out of a solid block, so I tried the water/heat bend approach first. The kit item was used as a template to draw the shape with a much longer tail onto a piece of 2mm Pear wood. I use the spare fret from the kit as a donor piece. The shape is cut out on the scroll saw and left to soak for several hours. 6578(2) The bend is then induced to match the pattern of the eking rail. 6577(2) This took more than one soaking to get as close as I could without splitting the wood. An alternative approach would be to laminate three separate strips of thinner stuff which may be easier to curve. 6580 The top of the supporter where it meets the Cathead requires to be angled to sit right with the curve. This is a bit of a compromise but at least achieves a smooth curve. At the bottom end the Cathead needs to be fayed to meet the Eking rail. Part of the sheer rail pattern that sits beneath the Eking rail needs to be removed to allow the Cathead to sit flush with the hull. 6593 6595(2) 6598 6599 6609 Am I satisfied with the result, perhaps not 100%, but I will reserve further judgement until I come to fit the Main Rail of the Head works. B.E. 21/04/22
  15. Post One Hundred and Eleven Catheads Tricky things Catheads. The good news, the Catheads align with the previously installed Cattails. The less good news the Catheads are proving a pain to install. From the blurb pics it looks like the Cathead only fits inboard to the extent of the angled base. Even with the slot cut down to deck level on the inner side and to the bottom of the top rail on the outer side, the cathead stubbornly refuses to allow the Gunwale to sit flush. 6481 The Cathead stive is 30° which looks a little steep to my eye, Goodwin (The Construction and Fitting of the English Man of War) gives the angles at between 15° - 20° 6482 In this shot the Starboard side Cathead is set at 20°, the Port side as per the kit arrangement at 30° 6483 20° suits my eye much better. Adjusting to a revised angle will entail fiddling with the deck fit but will resolve the fit issue below the Gunwale. Fettlin’ the Cathead. The Cathead is a constructed part with three sheave holes pre-drilled. A star emblem is lasered into the decorative cap that fits to the outer end, a nice touch. Greater realism can be given to the sheave holes by using a scalpel blade and micro file to give more form to the sheaves, and by inserting a pin thro’ the sides of the Cathead to represent the sheave pins. There is a simplification with the sheave holes, which are drilled vertical to the beam. The sheave slots should really be vertical in relation to the stive. Not an issue for me on this occasion as I am not rigging the Catfalls. I have decided to leave the Catheads bright with the panels painted blue and the cap decoration also coloured. This accords with the Marshall painting. 6535(2) I have set the angle at 20°, a simple jig is used to match the pair. 6534(2) 6551(2) 6540 6541 5639(3) 6556(2) 6554(2) I am trying not to think about the Cathead support bracket at present which I know should follow the curved line of and fay into the Eking rail. The manufacture of the kit provided Laser cut item precludes this feature. I will have a go at making a replacement but forming the compound curve is no easy task, unless because of the small size a curve can be induced in a length of 2mm thick Pear strip. Still I have the covering boards / capping rails/ Gunwales to consider before I need worry about that. B.E. 18/04/22
  16. Thanks Bug, the major dust making aspects of the build have now been completed, but there is an ongoing need for sanding and re-painting here and there apart from the general dust that just appears. I have temporarily modified the Dyson hand cleaner (Mrs W hasn't noticed yet) by taping a length of flexible Evergreen Tubing over the nozzle. Crude but effective.😉 B.E.
  17. Post One Hundred and Ten Foc’sle Breast rail More tiny little pieces to assemble and fit. It’s these small fittings that soak up a lot of time, I have been fiddling with these for two days. 6518 Made more difficult by my deck modifications resulting in the need to tweak the support knees so that they sit on the carlings whilst retaining the above deck height. 6527 As with the Bitts the belay pin holes have been filled in. 6524(2) 6520 6528 The support knees for the Belfry are added. Constant soft brushing is now required to keep the dust down, must try and find a small nozzle cleaner to get between the beams. In the next post I return to the Cathead. B.E. 16/04/22
  18. Can't quite recall what I used but around 3mm square is close enough. It needs to be flexible, and once I had cut the notches, the strip was heat bent to follow the sheer. B.E.
  19. Nice Rudder Head cover Chris, 1 like the compass design on the top. 👍 These little details make all the difference, at least to me. B.E.
  20. Post One Hundred and nine Foc’sle fittings. Belfry. I have been looking forward to assembling this important feature on a ship model. 6496 This is a laser cut assembly of multiple delicate parts. In cleaning the char, I used very soft hands and a mini vice to prevent any flex during sanding. As I intend to leave the Belfry bright good cleaning is essential to show the Belfry at its best. The Belfry on my Pegasus build is a little fancier than that supplied with Sphinx, and I can’t really let a sixth-rate sloop outshine a ship rated for a Post Captain. On my build there will be little around the Belfry to distract the eye so there are enhancements that can be made and one that should be made. The basic main patterns and canopy look fine, but I feel the supplied lower support patterns let the structure down. To my eye they look ugly and very obviously stick-ons, lacking the elegance of the Classic design employed during the 18thc on this feature. The Headstock can be tweaked to a more stylish shape. A crank arm can be added. There is very little brightwork on my version of Sphinx, so I have indulged myself a little with the Belfry. As with Pegasus I intend to copper the Canopy roof, this will have the additional benefit of masking the layered assembly. I’m not sure what the purpose of the two cleats on the aft face of the columns are for. On Pegasus two cleats are shown on the sides of the columns, indicated for the Fore T’gallant braces belay. For Sphinx these are indicated belaying at the Foc’sle rail. 6497 I begin by replacing the lower support patterns, using 3mm x 0.8mm Pearwood strip to build up the base of the column fore and aft to reflect the chamfered pattern of the athwartships design. 6500 This instantly improves the look of the columns. A shaped Headstock is cut from some 2mm thick Pearwood fret. 6507 The pattern cross bar is cut away from the Main pattern (scary) and replaced with a more stylish version. The bell fits into the base of the new Headstock. The Bell is quite a nicely modelled Brass item. 6512 A Crank arm is formed using an old Hammock crane and fits into the top of the Headstock. 6516 Finally, the Canopy top is coppered using some copper foil tape also used for a representation of the metal strapping on the Headstock. Still some fettlin’ to do and the support knees to add but overall I’m pleased with the result. B.E. 14/04/22
  21. Have IPSFocus been playing around with the Theme display? Mine suddenly went into a strange linear display with oversized logos, virtually unusable on a desk top monitor. It seems that it is what they call the default mode, and to get anything recognisable the option is 'Uniform' which sort of looks like my old preference. My old display theme. Anyone else experiencing this, you need to scroll to the bottom of the page and change the selection in 'Themes' B.E.
  22. Post One hundred and eight Snaggins. Not for the first time I take a backward step and start ripping up the work I did the day before. Why I didn’t stop when I sort of knew the colour match wasn’t ultimately going to satisfy my eye I don’t know, a case of hope over experience perhaps. It is not that difficult to remove planking without disturbing the adjacent planks. Dampening the strake and easing using a thin blade they can often be removed intact. 6470 6472 6473 Another day to rectify what I should have done in the first place but I am now happy with the colour match. Movin’ on. B.E. 12/04/22
  23. Post One Hundred and seven Completing the Foc’sle planking. The inner bulwarks patterns were put into place following the kit blurb. The Cathead slot was then cut to match the outer bulwarks. The Margin planks proved stubborn with initial attempts thwarted when the planks broke at the cross grain of the sharp curve. This was addressed by the simple expediency of applying sticky backed labels to the underside of the strip before cutting. With the margin strips fixed the thin bulwark skins were glued into place. At this point the decks were covered to hopefully limit as far as possible sanding dust dropping to the lower decks. 6413 The bulwarks are sanded level, but I had the Foc’sle gunwales handy to check progress. There are only three strakes of planking along the bulwarks. This involved a couple of hooded planks, as nibbing was not a general feature of this period. 6419(2) Forming a hooded plank, cut out of 10mm strip and edge bent slightly to match the margin. Planking completed, but it will require scraping and sealing. 6457 6456 6451 6453 6450 Still a fair bit of fettlin’ to do and more stuff to add. I am thinking about removing the three paler hooded planks and try to find a better colour match. They keep catching my eye in an annoying sort of way. B.E. 11/04/22
