Jack12477
Everything posted by Jack12477
  1. Ditto what everyone has said above. Fantastic job. Thanks for taking us along, I learned a lot from your restoration.
  2. What Browser are you using OC ? I'm using Firefox and having no problems with the photos.
  3. I can get Tamiya, Testors and Vallejo here for reasonable prices. Have not seen rattle can Tamiya primer yet but I do have a few rattle cans of Testors primer, does Testors work okay on PE. I think I have a bottle of Tamiya brush-on primer in my stash. Have to look. I've only just started to use Vallejo - mostly on wood tho, not plastic. Have a fair amount of Testors ModelMaster brand paints.
  4. When that happens, press and hold the power on/ off button until it powers down, wait a minute or two amd power back on.
  5. First I would like to thank everyone for your expressions of sympathy on my brother's passing. It was much appreciated. Back to the ice yacht build. After many failed attempts to make a bridle saddle for the gaff I decided to give up and use the split rings instead. Not having the machining or metal working skills and the extremely small size of the piece it was just too frustrating to continue. The gaff is now rigged. Next up is making the sails. The Rocket as it exists today is rigged with modern sails with grommets instead of a bolt rope. I've got some very very tiny grommets I picked up in Michaels some time ago but there is no "anvil" for flaring the back side of it. So I'm undecided as to whether I should replicate the modern sail or go with one that was probably used in 1888. More research is needed on that item. Photos below show the completed gaff as rigged. The pulley blocks are Chuck's SYREN internally stropped 1/4 inch single and double blocks as are the cleats. The jig holding the gaff is copied from a jig Ed Tosti (@EdT) uses. (Thanks Ed for the inspiration. It's easy to build and easy to use.) The silver clips on the tip of the gaff is there just to provide some tension for the lines, the sail will provide the tension when completed.
  6. When I tried to put my 18th Century Longboat thru sea trials, the glue dissolved and almost all of the planks popped off the frames ! Nice looking frigate, OC, glad she passed the first phase of her sea trials unscathed.
  7. Beautiful models Javier. Interesting you work in scale 1:160 as that is the same scale for N-scale model railroader as started by Arnold Rapido in Germany in the mid 1960s. Those models would really enhance an N-scale model railroad layout. I had such a layout but it is packed away now. Welcome to MSW.
  8. Denis, She was built in Baltimore MD and is named after a labor leader - see http://www.liberty-ship.com/#home She's now berthed in Baltimore Inner Harbor - just a "short jaunt" for you up there in New Hampshire
