Posts posted by JSGerson
Pinnace Stern Bench Seat
Once more I deviated from the practicum. In this case, the practicum constructed the bench seat from three pieces of boxwood: two side seats and the transom seat. I elected to use one piece of 1/32” plywood because I wanted to use a template I made from the US Navy plans. Interestingly, those plans show the bench as one piece. If the bench in real life was made in multiple pieces, it doesn’t indicate where the seams are. Like the practicum, I did not install any of the underlying support knees or braces. They would have been a lot of work and in the end wouldn’t be seen.
Before I made the template, the 3/64” x 1/64” rising was installed about an 1/8” from the top of the rail. It will support the bench seat and the thwarts.
- Tigersteve, DocBlake and Nirvana
3
Naw, they are like appetizers to the meal of the big model. I enjoy the detail.
The sole then given two coats of diluted white paint; I didn’t want a thick coat of paint. The idea here was that I was hoping the individual planks would be visible after the paint dried. In the end, I still need to enhance the edges around the portable panel with an X-acto blade. Finally, it was fitted into the stern. Another eyebolt with a painted simulate plate was also installed.
BTY, I wasn’t concerned that the edges of the sole were not fitted into the sides of the boat model as these will be hidden by the stern bench seat.
Pinnace Stern Sole
Being a landlubber, I’m was not familiar with boats when I started building these models. So once again, I’m modeling something I have no knowledge about. I’m referring to the aft end on the pinnace, something called the “sole.” This appears to be a floor section of the boat and in this case, one with a portable panel. I’m not certain as to sole’s purpose, but I assume the portable panel is there to gain access to the area below it.
The practicum simulates the sole with a piece of styrene etched with lines imitating pieces of wood. I’ve seen others use 1/64” plywood and do the same. I thought I would try something different. Using individual pieces of 1/32” basswood, I reconstructed each piece of the sole as best I could. First a pattern was made based on the plans, but adapted to conform the actual model. This was used to size the pieces and orientate and locate their final position. The problem was that the sole required that the piece be glued edge to edge. This is not structurally strong. To compensate for this lack of mechanical strength, the pieces were PVC glued directly onto paper in five separate groups.
- DocBlake and CaptainSteve
2
- CaptainSteve, DocBlake, MEDDO and 2 others
5
Pinnace Bow Footboards
These are the short footboards at the bow. According to the Navy plans and the kit’s plans (although you’d be hard pressed to see the detail in their scale size plans), there are four 4 support members that pass over the keelson and supported along the inside walls. From those builders that have posted this detail, including the practicum, nobody has included them in their build. I did, even though you can’t see them when the model finished.
- Blue Pilot, Geoff Matson, DocBlake and 2 others
5
The pre-painted beam structures were glued in first using PVC glue so I could make small adjustments. At his point, I decided I didn’t like the copper wire for the bolt. I decided to sacrifice the #80 bit I used to drill the bolt hole as the bolt itself. It was stiff and had the right thickness and color.
An eyebolt was required just forward of the step. The eyebolt was not shown a dimension on the Navy plans so I made some measurements off the plans and reduced it scale. It came out to be approximately 1/16”. Because the eyebolt was shown on a metal plate, I painted the bolt and a square area around the bolt black to simulate the metal plate.
Finally, the cross structures were added, the two outer “wings”, then a filler piece in the center. A bit of touch up paint, and it was complete. The whole mast step is just ¾” in length.
- Duanelaker, coxswain, Tigersteve and 5 others
8
Two of the pieces fit at right angles to the beam pieces and appear to sit on the floor boards. This is where I was confused. The plans state that the two beam pieces fit against the keelson. From the plan view, the cross pieces appear to fir over the beam pieces. The elevation view implies that they butt up against the beam pieces. My best guess is that this structure is constructed somewhat like a grating. Because this was going to be painted and was in a limited view area, I “cheated” and tried to make it look right, not necessarily built right. That license sure comes in handy.
- Nirvana, coxswain, Geoff Matson and 3 others
6
Pinnace Mast Step
Now that the Pinnace’s interior shell has been completed, the interior structures can now be made. First is the mast step. As usual, my first order of business is to find pictures of the real thing and research how others made theirs. Try as I might, I could not find a single pictures on the internet nor in any of the books on the Constitution I have, nor in any of the books on small boats I have. I did have the Navy plans, but even those were a bit confusing. The practicum skipped this part all together.
Of the 34 build logs I have collected, less than five devoted any detail or images as to how they did what they did for the ship’s boats. And of those, nobody followed the kit’s plans which mirrored the Navy plans, meticulously. As usual, just about everyone used artistic license to either skip a lot of details or alter the design for one reason or another. That was their choice and I have no problem with that. My choice is to try and follow the Navy plans as best I can.
Using the Navy plans, the four main parts of the mast step were reduced to scale and used as a template. The plans call for a 1 inch bolt to pass through the two beam structures. This would also pass the curved bottom mast so that the mast could pivot along the length of the beam of the boat. A 1 inch bolt reduces to scale of 0.013” or the same as a #80 drill. Any of the images I’ve seen of other builder’s boats, their bolts appear to be thicker. My initial thought was to use some real thin copper wire for this.
How the Jacob's Ladder was anchored bugged me, so I did some more digging. I found the following statement in Commodore S. B. Luce, U.S. Navy's Text-book of Seamanship. The Equipping and Handling of Vessels Under Sail or Steam, 1891 pg. 61:
"...the lower end [of the Jacob's Ladder] setting up to the afterpart of the crosstrees...and hook into eyebolts placed for that purpose."
I realize that the date of the book is almost a 100 years later that the commission of the ship, but I think this would not have changed much. So you are right in using the eyebolts.
BTY, this same paragraph in the book also gives a verbal description as to how the ladder is fabricated should you want that.
- Canute, CaptainSteve, xken and 3 others
6
The rail cap was next. The practicum used styrene, I used boxwood. The plastic would have been easier, but is nicer. Also according to the plans, the cap is not painted white. Due to the severe curve of the side rail, this was accomplished with two pieces of 1/32” thick boxwood – one cut to the shape of the bow curve and the other was edge bent after soaking in water for a while. The transom was simply a straight piece of wood.
- DocBlake, Duanelaker, coxswain and 5 others
8
Getting pictures that high up of the masts with any detail is just about impossible for the general public. I did some digging in my book library and I found these drawings in Olof A. Eriken's book, Constitution, All Sails up and Flying. I hope they are what you are looking for. The rope ladders it shows are a little different than yours.
Jon
- CaptainSteve, xken, mtaylor and 1 other
4
Pinnace
Now I will concentrate on one boat at a time. The pinnace is the first. The plans call for 1/64” thick footlings but don’t specify their width. The US Navy plans show these are 5” x 1” or about 1/16” x 1/64” but the kit does not provide 1/64” wood stock. Using the Byrnes saw and some of the kit wood stock (I forget which size I used), that was easily remedied. I painted the cut pieces first and then glued them into place using 1/32” wide spacers.
- MEDDO, Geoff Matson, DocBlake and 4 others
7
The two whaleboats progressed in the same manner as the gig. At this point, Model Expo came through and my paint package arrive...supposedly again. This time it did not disappear. A coat of white primer was applied to all four boats. I hadn’t realized that I didn’t coat evenly until I saw this photo, but a second coat of primary color paint should take care of that.
- coxswain, Elijah, Tigersteve and 5 others
8
Are the furlough sails full size sails rolled up? Is that what you mean by "full size sails"? I thought most model builders "cheat" and use just enough material to make furlogh sails look realistic. The problem of course is the scale of the sail material; you just can't get something thin enough, with the right. texture, and translucency to match the scale.
Jon
You should be very proud. Now I've got to ask a few questions:
- I assumed you carved the stars. How did you hold them to do it?
The nameplate intrigued me:
- Did you carve the letters? If not, what did you use?
- How did you achieve the very thin white border around the nameplate?
Jon
- Canute, SawdustDave, Piet and 1 other
4
Do be careful when using the styrene. I've been told they yellow as they age so it's best to paint them.
- mtaylor, Canute, CaptainSteve and 3 others
6
I am curious about the tools you are using for the carving especially the spoon chisel (I think) in the X-acto type handle. Is that part of a set and where did you buy them?
Jon
- SawdustDave, Omega1234, mtaylor and 2 others
5
Gig
Like the pinnace, the gig kit plans are very accurate as compared to the US Navy’s plans. Hunt’s practicum shows you how to make an acceptable looking model though not necessarily complete or accurate. Some points:
- The practicum uses one strip of styrene over the ribs to form the gig apron, keelson, and knee. Like the pinnace, I plan to use separate pieces for each and notch the keelson to fit over the ribs as shown on the plans The average observer may not see this detail, but I will know.
- A lot of the hardware and detail (e.g., lifting rings) were left off due to scale size, visibility, or complexity.
- The gig backboard and all the gratings were eliminated
- The gig thwart support stanchions were eliminated
- The oarlocks were eliminated
- The “wing” on top of the rudder, and the pintle and gudgeon were eliminated
- The slats for the stern benches are too fine for this scale and were rightfully replaced by a single sheet of wood. I have ideas about those and the gratings.
My intent is to add as much of the detail shown on the plans to the model to the limits of my ability and patience. Here is the gig at the same point as the pinnace with the ribs and flooring supports waiting paint. The only difference is that I added the interior gunwale. So, onto the two whaleboats:
USS Constitution by JSGerson - Model Shipways Kit No. MS2040
The template was rubber cemented to the plywood and cut out with my 40 year old Dremel hobby scroll saw. To my delight and surprise, with just a few minor tweaks with a file, the bench seat fit perfectly.
