Posts posted by Justin P.
I suspect Ill join the cohort of those who've snapped one of those frames as well! If you don't mind Ill follow along!
- Ryland Craze and Canute
- 2
On 9/4/2020 at 4:15 PM, glbarlow said:
I gave it a lot of thought and did several tests myself. And concluded I didn't want to muck up my hull with tree nails. I'm happy with my decision.
Great work on a nice model!
Yep... that's basically what Ive decided as well.
Yes... Ive been plugging away. School has started up and with COVID the kids are homeschooling, meanwhile Im also still working from home so things have been pretty hectic. The last few stages of my build have gone well. Slowly, but well. Its amazing just how much time some of these steps can take, and Ive just been chipping away as and when I get a few hours in the shipyard. Also, I may be overdoing things a bit as my patience has grown and my ability to overlook flaws has diminished. Just getting the painted gunports finished took awhile, as I really wanted them to be just so, and thus open many hours filing, filling, painting, and then in some cases going over them all again. I really look forward to a time when I can get some of these things done right the first time. The result is that my gunports are really squared up and have nice clean edges-which was the goal..
I then started in on planking in the sills and lintels. This was a pleasurable enough task, but did take a LOT of time as notching in the along the ports took a lot of trial and error until I figured out a system and tool combination that provided consistent results. I planked up both sides, sanded and then stained. I was quite pleased with how it turned out. The transom came out well, too. I opted to deviate a bit here where the upper transom calls for a single piece of laser-cut 1/16th thick sheet cut out for framing in the ports. I chose to simply plank it in as well. This may well have been a mistake, we'll see when I get there.
Then began the lower hull planking saga. I think overall Im getting closer to doing it right, and farther from doing it wrong - BUT there are still a lot of problems... I mean, its better than I was expecting it to be. Ultimately this area is painted over and then coppered so Im not overly upset, and Im glad Im only gonna need a tiny bit of filler at the stern. I used a combination of tapering, tick marks, and edge-bending, with the last plank on both sides needing to a be spiling job from a piece of sheet I had laying around.
I also had a bit of trouble at the transom where the planks bend upward to meet the transom and stern post. I needed a bit more support to get things to lay down properly and so had to improvise some filler and an additional plank.
Of course that was not the only improvising that was required - meet the rubber-band/post clamping jig.
Some other planking shots and my edge-bending jig:
And here is where I am today:
Yes, I stained it. Why? I have no idea. I just felt compelled, and yes I am still going to paint it black per the instructions. Next I need to add the second layer of wales just under the ports, and move onto the transom. Anyway... its coming along. As for the trunnels I agonized over in an earlier post, I decided to forgo them completely. I think at this scale they'll be a detail that will detract rather than provide to the overall piece. Thanks for watching!
- NovaStorm, Retired guy, JpR62 and 6 others
- 9
On 10/17/2020 at 5:28 PM, BobG said:
Any progress to report, Justin?
Hey Bob! Funny you should mention it....
Model Machines currently sells a selection of blades that correspond (perhaps not exactly) to the above document. I buy direct from him.
- Canute, thibaultron, mtaylor and 1 other
- 4
Seems too large to be a button to me, I agree its more likely a knob or handle of some sort.
- Keith Black, mtaylor and Canute
- 3
I think people can sometimes get bogged down in equipment and machine tools if led to believe they are "needed" to achieve a satisfactory result. I think if your are an efficient and knowledgeable user of mills and lathes then by all means, we all do things our own way. Not knowing someones experience or skill set with mills and lathes, they wouldn't be my recommendation for something like masts and spars. I think its important to remember that perfect results from machines require a certain level of understanding and knowledge with those machines. Hand tools, in my opinion, can be a bit more forgiving even if result as not as exact.
I know my scrap pile consists of far more machine mistakes than it does mistakes made by hand tools.
- Ryland Craze, druxey, mtaylor and 4 others
- 7
3 hours ago, druxey said:
Seems like using a sledgehammer to crack a nut. None of my masts and spars have seen a lathe. It is not difficult to start with square stock marked out (don't need a four jaw chuck!), cut it eight-square except fo the square sections, then round off the parts that need it, using strips of sandpaper back and forth until the 'flats' just disappear. You don't need a lathe with a long bed ($$$), 4 jaw chuck ($$), steady ($$), filing rest ($$) or other paraphernalia. Just pencil and rule, sharp chisel and sandpaper. There; I just saved you a ton of money!
I agree, I actually found using a lathe to be more work. I tried at first because I had one, and wanted to use it. Eventually I settled on square stock, an Ibex finger plane and sand paper. Much easier.
- flying_dutchman2, mtaylor, shipman and 2 others
- 5
1 hour ago, NovaStorm said:
Not sure i totally follow how you have achieved the .5mm pencil treenails. Are you drilling a tiny hole and inserting a small piece of lead, sorry if this is a dumb question. The results with the pencil look great the eye effect makes it look aged and weathered especially with the stain you are using. Nice going ~
Its just a mark. Place pencil onto the wood, and twist back and forth like you are just trying to make a dot. That mark will hold up against staining and light sanding. In this case I think I just used too much pressure.
- NovaStorm and Overworked724
- 2
Busy week. I managed to get all the gun and sweep ports constructed. This took me forever, but Im happy with the result. As mentioned above, I constructed everything all the way through this process against the recommended instructions, as I felt more comfortable with fewer passes with the fairing sticks. I wanted everything in place so I could just fair once. This may have meant two or three times the work, but for me, less room for error. Below is shown this process, with the starboard fairing near complete, with the inboard and port sides left to be completed. This work was done with a combination of knives and sand paper.
And now pictured with everything completed to the point that I could move on.
I then started work on the stern framing, which thanks to the excellent production quality of my particular sample everything went together nicely. I proceeded with building out the ports in the same manner as above.
Its at this point that the build proceeds into paint choices, upper wale planking and thoughts about finish and tree nailing. I really wanted to think this process out before proceeding, so as I do in my professional life I decided to mock it up first. I built a dummy section of upper wale with gun and sweep ports; painted and planked it and then added treenails. Finally a wash of stain as per the recommendations. Its at the treenails where I deviated. In other Syren builds, the treenail examples Ive seen haven't sat well with me. All other details might be wonderful, but it seems some of the proportions and material choices just put me off. Im a big fan of the filament and/or pencil type so thats the direction I went.
Paint: Model Shipways "Bright Red Trim." I had done the other in "Hull Red" but I rejected that immediately and did not move forward with that mock-up.
At the moment Im feeling rather ambivalent about the result. The full mock-up is done with a .5mm pencil while the partial mock-up below is done with .6mm monofilament. The monofilament is much cleaner, while the pencil crushes the grain a bit and results in the elongated "eye" shape around the nails. Not something I want all over my model. The filament at .6mm is still a bit too large for this scale (in my opinion). I may knock-out one more quick mock-up with a smaller filament size if I can find it, or I may try some blackened wood filler. I should sleep on it. Otherwise, Im happy with the Golden Oak Miniwax stain, the choice of graphite for the caulking and paint choice.
- Matt D, abelson, Overworked724 and 9 others
- 12
On 8/25/2020 at 8:44 AM, NovaStorm said:
Your Syren work looks really clean and precise Justin.
Are you are planning to taper the stem in order to fit the figurehead?
Thanks. Yes I do plan to taper it. I know it sounds crazy, but sometimes I deviate on steps, knowing how I work and in which order I might achieve greater success. For instance, Im now working on the gun ports and will not fair any of it until the entirety is constructed. The instructions say to fair as I go (i.e ports/lintels then the next step) but I know that just wont work for me. Im bound to take too much off if there are multiple steps.
19 hours ago, WalrusGuy said:
Still deciding on whether to order blocks or just use the kit supplied ones
Definitely get the blocks.
- VTHokiEE, Ryland Craze and WalrusGuy
- 3
2 hours ago, NovaStorm said:
Having tried the kit supplied nylon rope I made the decision to purchase rope from Chucks, Syren Ship Model Company Model Expo has a limited supply of rope for there kits so the supplied rope does not always fit to scale. I knew I had seen the info somewhere so after much searching with out luck through Dubz's Syren log, I was able to finally find the info which I had saved to my comp months earlier. Here is a reprint of what is required to fit the ship with the recommended rope sizes, posted by Chuck. I will reprint that info here for anyone looking for that information.
Fantastic re-post of great info. Thanks! Also, Ive been away for a bit, but your progress is wonderful. I love the details you are putting in.
Glad to be focusing back on this project. Along with work I took some time away from Syren to finally finish my Bounty Launch which had been sitting around for some time. Now that I have no more open projects, Im very happy to say my attention is squarely on this complex build.
Reorienting myself to where I left off took a bit of time, I needed to assure myself that I had completed outer fairing to the point where I thought I ought to stop. I couldn't quite recall where my mind was when I set this aside. Needless to say I sanded a bit and ran a few battens satisfying myself that I indeed came to good stopping point.
I then went ahead and installed the lower deck planks and stained according to Chucks good suggestion of Miniwax's Golden Oak. I very much enjoy the warm, weathered look this stain imparts on basswood. I'll need to experiment a bit to get the right whitened/silvered tone for the upper deck but suffice to say that on its own its a really nice color.
The next few steps proceeded well. I cut out the gunport templates, taped them together and strung them up to the bulkheads. Unfortunately they didn't quite fit very well, which must be a problem with printing because I really couldn't hunt down a problem on my build. Reading through the instructions a bit relieved my anxiety some, as it turns out the overlay of this template and the positioning of the bulkheads isn't terribly critical. More important that the port sills go in along a smooth line and that they go in square. Running another batten to check the line of the sills gave me the confidence to go ahead here.
After installing the port sills I went ahead and ran a second upper batten for the lintels.
Of course something didn't feel right as I was checking this out. This inner ear I credit to having read the instructions so many times, as Chuck clearly states that this isn't necessary, and that what I ought to do is simply measure the 15/32" from the top of the sills and mark the locations of the bottom of the lintels accordingly. Curiously, I went ahead and took a line off my batten and then went back and cut a couple 15/32" sticks and sure enough had I gone ahead with my batten I would have screwed up. Thankfully I caught this, and took the reminder to slow down and read the instructions yet again. Something I must remember.
The sticks proved very useful, leaving me with perfectly level equidistant port sills and lintels. Next Ill finish off the bow and the gunport frames. Then more sanding...
- JpR62, BobG, Overworked724 and 6 others
- 9
40 minutes ago, dvm27 said:
my cable bill with Xfinity is over $300/month
No offense Greg, but that is outrageous! I don't pay for cable, just internet. We have HBO, Netflix, Amazon Prime Video, Disney Plus, Peacock and Apple TV and we pay less than $200 for all of it (including the high speed internet to stream it). I havent see an ad or a commercial in 3 years. It all is connected seamlessly on our living room TV (and can be watched anywhere we happen to go. That said, I watched Greyhound on my phone, on a plane and still loved it. Cable TV is a rip-off.
- thibaultron and mtaylor
- 2
On 7/30/2020 at 10:14 PM, glbarlow said:
Not sure about all the harsh judgements and concerns about accuracy, seems silly. It’s a movie. They used the USS Bainbridge because it was available for filming. It’s a 98 minute streaming movie, of course there is CGI involved.
I read the book recently, it was not as good as the movie. The movie is an exceptionally well told tale about leadership under extreme pressure, if you missed that point I suggest you watch it again.
I feel similarly. I know next to nothing about WWII Naval warfare or ships, at least compared to the Age of Sail. I too felt the movie was really more about pressures of leadership, vigilance, and commitment to duty. The noise maker and radio hijacking bit was an interesting twist if only just a thematic element and not something that ever actually happened. It was exceptionally heavy on CGI, which I noticed early on but quickly forgot about as the characters and momentum of the story was exhilarating. I thoroughly enjoyed the movie. It is, after all, a movie - not a treatise or history lesson.
It will eventually be available to rent either on DVD or elsewhere, it was only released on Apple TV due to COVID. Expect to see it at your local Redbox.
- lmagna, glbarlow, thibaultron and 2 others
- 5
Looks really great. I might have lost my mind trying to work out those tiny sheaves - perhaps I will when I get there. Definitely understand how work gets in the way, I had a great productive few months and now Im all bogged down myself with "emergent issues." Though, your description is a bit more gracious that mine might be...
Shapr3D
in CAD and 3D Modelling/Drafting Plans with Software
Yes. I use it all the time. Got a question?
