GuntherMT
Everything posted by GuntherMT
  1. Agree with Dave. Don't worry about fairing R until you've got all the other blocks installed so that you can fair it all together.
  2. As the above folks have said, really difficult to tell from the photo's. Break out another piece of planking and make sure it gives you a smooth run along the bulkheads. You should be able to start it at the keel and then slide it slowly up the bulkheads and have it make a nice clean run from stem to stern at any single spot while moving it along from bottom to top like that, on both sides. If you can't do that, then identify the areas that need work (pencil works good for marking spots that need help) and focus on making very small adjustments until they are right.
  3. I saw Mike Lonnecker's FA at the NRG conference (actually, helped carry it to the display room from the parking garage), and it's a fantastic model when fully rigged. I think you'll love it when you are done and not regret making this decision, Lou.
  4. Multiply everything by 1.3333 or 133.33% to convert from 1/64 to 1/48. 1/16" x 3/16 = .0625 x .1875 so multiply these values by 1.3333 to get .08333 x .24999 or about 1/12" x 1/4" (I think).
  5. Hello Michael, and hey, another AVS is born, cool. On the stern, I found that the only way to really 'see' what it would look like was to put it together enough to temporarily set the window frames in, and then I could step back and take a look (and/or photograph it) and get a feel for how it would look. You can correct the angles somewhat by shimming and sanding as needed rather than tearing it apart, but as you probably know if you went through my log, I ended up completely tearing all the stern framing out and re-doing it after the first attempt. It seems that the stern is a tricky part on a large number of models, and sometimes you just have to be willing to take a do-over on it until you are happy with the result. Happy building, and hope to find the time to follow along with you on this journey.
  6. Hi Joe, I'm behind in my build log following, so I completely missed that another AVS build had started. It's looking good so far, and agree with what the others have said about taking your time doing the fairing, it's really important. One of the things that I used that helped me a lot on those bulkheads where the plank will lay across then in a curve, was to use a sanding block that had a rubber cushion under the sandpaper, allowing the sandpaper to bend around the bulkhead and naturally create a curve. Just use a light touch so that you aren't forcing a severe curve, and just work each bulkhead as needed. As far as running out of planking, even if you do, you can get more from Model Shipways by just asking, or buy some from a hobby store, basswood is cheap. Alternatively, if you are crazy like me, you won't use any basswood on exposed planking anyway, and you'll end up with lots extra on the bench even after using a bunch of it for things that they aren't supposed to be used for. Happy building, and I'll try to follow along as I have time!
  7. I was pretty happy with how the walnut looked on my hull, and of course the keel & bow post are all walnut as well. Another good wood I believe would be cherry, although I only used it for contrast on some deck furniture. There are a couple of logs here done by DocBlake (Dave) in the kit section, here: http://modelshipworld.com/index.php/topic/10979-armed-virginia-sloop-patrick-henry-by-docblake-finished-lauck-street-shipyard-scale-132-pof-admiralty-style/ and here: http://modelshipworld.com/index.php/topic/6998-armed-virginia-sloop-by-docblake/?hl=%2Barmed+%2Bvirginia+%2Bsloop Where he uses no paint, and only the wood for coloring, and his choices of woods were quite nice looking if you want to take a look at them.
  8. Was great meeting you at the conference and seeing the Naiad in person Gary. Your other ship was fantastic as well, and your build board/work station is pretty cool.
  9. You are a lot more ambitious with your first build than I was. Good luck and I'll be following along, even if I won't have much (or any) advice since I'm still learning in the world of kits for now.
  10. Looking forward to this one Pamela. I expect great things. Have you decided what kind of woods you are going to be using?
  11. If you are replacing it with wood, you can just cut the mast step into the wood. This is how most mast steps in wooden models are done, you have to hand shape the mast step to fit at the correct angle. This is what the base of the mast on my AVS looked like:
  12. Karl, Another thing that would help to bring people to your log is if you put a link to the log in your signature. Currently you have links to your finished ships in the Gallery, and to the Vasa log, but the "Pride of Baltimore II" at the bottom of your signature is not a link, so there is no way for people who see it in your signature if you post elsewhere on the forums to follow it to your build log. Of course, if you aren't posting anywhere else, then that won't help at all.
  13. I had a couple of those connections. I just stropped the block to have a small eye at the end where it would connect to the larger line, and then seized them together with thread. I don't seem to have a very good picture of it, but maybe you can figure it out from this. I do not remember where I read about doing it this way, so no idea if it's even remotely accurate.
  14. You only started the log 4 days ago. Be patient, it takes time for build logs to develop a following. Not everyone checks the forum every day, and many people don't look for new logs on a regular basis as there are just so many going on. I clicked on this one because I actually love this ship and plan to build it myself some day, and I know there are a few other logs going on, so I don't think it is an unpopular ship at all. In any case, looks like you have a good start, and I'll try to check in once in a while to watch the progress, but my time has been quite limited recently, so no guarantees! Have fun building her, she's got fantastic lines. I use the PoB II as my desktop background on my PC.
  15. Was quite a few pages behind on your log Greg, but noticed it was now "Finished", so I had to catch up. Fantastic work, and great detail as usual. Looking forward to seeing what you can do with the Yamato!
  16. It seems to change with versions Frank. I used to use Firefox on Windows and then it stopped working so I switched to Chrome. It worked fine, but for at least one update of Chrome, it stopped working. I think it has to do with a browser update breaking Flash (or vs. versa) and until whichever one got broken by the other's update gets around to fixing it, you just have to switch browsers for a while. Luckily Chrome has been working well for over a year now without any problems *knocks on wood*.
  17. My testing shows that it's just '1600x' on the long side. I've posted a few almost full square 1600x1600 images (off by a few pixels). File size maximum of 2mb.
  18. Beautiful work Frank. Looking forward to seeing it again in person next week, well, and you too I suppose
  19. Very nicely done on the rails so far. Looking forward to seeing how you handle those complex chain plates.
  20. Another variation on those clamps is to simply glue a short piece of wood into them rather than using the steel clamp handle, that gives you a softer surface pushing against your planks. You'll find a bunch of pictures of this in my build log, I made a couple dozen of them with wood instead of the other clamp handle. Functionally they are the same thing though, and they are used in a fairly high number of build logs on MSW.
  21. I'd say that is pretty good for an 18" long keel piece. If you want to you could place it on a perfectly flat surface and put some heavy weight on it for a day or so and see if it gets 'perfect', but I personally wouldn't bother, as you'll have more variation than that in putting the bulkheads together on it I would guess.
  22. Acetone will dissolve the CA, so you could just cut them at the top, use acetone to remove the glued bits, and re-seize them at the appropriate location. If that fails, there is always the old fall-back of just re-doing them.
  23. Did not realize that the museum had a downloadable kit of the San Salvador. Good to see this! I got to see her sailing in the Parade of Sail over the Labor Day weekend, pretty cool to see her under sail finally.
  24. Congratulations on crossing the finish line Dave. She's a beautiful model, and something you should be proud to display. What's next on the bench besides completion of the Independence?
  25. The San Salvador in San Diego is now fully rigged, and I just happened to get a photo at the Festival of Sail a couple of weeks ago that I believe answers your question: Behold, the inside the shrouds lateen yard!
